frankc
RE: Pre/Post-Screening (frankc)
Thu Aug 23, 2012 11:33 am
Hi,
Would this image be passable in terms of color/saturation and exposure?
https://www.airliners.net/addphotos/b...y/r1345721198.8348frankc_hbimj.jpg
Many thanks!
Frank Clautier
dlowwa
Thu Aug 23, 2012 3:24 pm
Quoting frankc (Reply 50):
Should be. I might crop it a bit wider though.
frankc
Mon Sep 03, 2012 11:00 pm
Hello again!
Looking at this image below,
https://www.airliners.net/addphotos/big/ready/j1346712918.9862vc-2.jpg
Would this be passable in terms of Contrast/Exposure/Dark?
There are other problems, but this is just a quick-and-dirty edit, mainly to pop up the issues above.
Many thanks in advance,
Frank Clautier
dlowwa
Mon Sep 03, 2012 11:17 pm
Quoting frankc (Reply 51):
I would brighten it a bit, and bring the contrast down.
frankc
Wed Sep 05, 2012 5:37 pm
Hi,
I'd like to request some info/feedback on the following rejection:
Rejection reasons
1) Soft
2) Color (blue tint)
https://www.airliners.net/addphotos/r..._m1346066690.5781frankc_dbekp2.jpg
I understand that the image may be a touch blue, but I don't see the softness... or would the latter be a consequence of the former?
Thanks a mil as always!
Frank Clautier
dlowwa
Wed Sep 05, 2012 5:39 pm
Quoting frankc (Reply 53):
Sharpness ok, but color is off.
frankc
Tue Sep 11, 2012 9:14 pm
Hello again
I've posted 2 images in the queue: same aircraft, same date.
Are these photos likely to be sufficient different in order to avoid a double rejection?
https://www.airliners.net/addphotos/b...y/s1346747117.2554frankc_cgdpf.jpg
and
https://www.airliners.net/addphotos/b.../r1346761028.5464frankc_cgdpf2.jpg
Thanks again,
Frank Clautier
dlowwa
Wed Sep 12, 2012 12:38 am
Quoting frankc (Reply 55):
No, they will be considered double, so please upload only one. First one has nicer light, I would go with that one.
frankc
Thu Sep 13, 2012 4:31 pm
I've made a quick-and dirty edit of an image:
https://www.airliners.net/addphotos/b...g/ready/h1347553328.3717eirja1.jpg
I'd like to check for 2 issues please:
1) The crop. Not only have the wings been cut, but also a bit of the horizontal stabilo.
2) The exposure (fuselage too bright?)
Are these 2 items likely to cause problems? (Please ignore the other issues in this edit)
Many thanks!
Frank Clautier
dlowwa
Thu Sep 13, 2012 7:14 pm
A little bright, but should be passable; crop on right ok, but better wider on left not to cut stab.
frankc
Sat Sep 15, 2012 7:42 pm
These images seem to have some issues - would it be possible to point to the areas involved please?
Rejected for softness
https://www.airliners.net/addphotos/r...5_c1346916505.4121frankc_dbekp.jpg
Rejected for oversharpened (I think it's the registration mark)
https://www.airliners.net/addphotos/r...5_t1346970863.0328frankc_cfbcr.jpg
Many thanks again!
Frank clautier
dlowwa
Sat Sep 15, 2012 8:13 pm
First is a little soft on the left side/tail area, second is borderline, the cheatlines are making it look oversharpened. Maybe just the horizontal stab. and winglets are a bit jagged, the rest should be fine.
frankc
Sat Sep 22, 2012 8:49 pm
Hi again,
I was just wondering if this one would suit in terms of vertical centering please?
https://www.airliners.net/addphotos/b...y/j1348323831.5255frankc_eirja.jpg
Thanks a mil!
Frank Clautier
dlowwa
Sun Sep 23, 2012 12:41 am
Quoting frankc (Reply 62):
A little high, but should be passable.
frankc
Mon Oct 15, 2012 4:45 pm
Hi,
The top of the roof of the hangar behind the aircraft in the image below looks a bit like a thick halo, and it's probably even more emphasized by the low sun. Does this necessarily kill the image?
https://www.airliners.net/addphotos/b...ady/v1350252536.8146frankc_vc2.jpg
Thank you for your advise,
Frank Clautier
dlowwa
Mon Oct 15, 2012 7:13 pm
Quoting frankc (Reply 63):
Not sure what you mean, but I don't see the hangar being an issue.
frankc
Mon Oct 15, 2012 8:36 pm
Thanks Dana - it's just the top of the hangar that looked smudged to me.
Frank
frankc
Sat Oct 20, 2012 10:39 pm
Hello,
This is a scanned photo - I've no significant experience with this type of image processing so I'd be grateful for your feedback!
https://www.airliners.net/addphotos/b...y/k1350772416.8868frankc_ooctw.jpg
Many thanks,
Frank Clautier
dlowwa
Sun Oct 21, 2012 12:55 am
That's not too bad for a scan. A touch soft & grainy, but should be acceptable. The only real problem is the poor light, but that has nothing to do with the scan, just looks like the weather that day wasn't too great.
frankc
Thu Nov 01, 2012 10:42 pm
If I would crop this image tighter, I'd be able to get rid of the lightpole on the left, but this would still leave a large bright area though. So I'm just wondering if the cropping is ok?
It's just a draft, so please ignore the other flaws.
https://www.airliners.net/addphotos/b...y/f1351809255.6847frankc_grjxp.jpg
Thank you for your help!
Frank Clautier
dlowwa
Thu Nov 01, 2012 11:45 pm
Quoting frankc (Reply 68):
Crop should be fine.
frankc
Thu Dec 20, 2012 3:12 pm
I received a rejection a while ago for color cast (green/cyan) and dark.
I did a few corrections and I think the color feels better now.
However I think that it's maybe a touch too bright in the new edit, so I was wondering how it looks like on your end?
Rejected:
https://www.airliners.net/addphotos/r..._f1354793176.9529frankc_n310gj.jpg
Corrected:
https://www.airliners.net/addphotos/b.../z1355735057.0776frankc_n310gj.jpg
Thank you!
Frank Clautier
dlowwa
Thu Dec 20, 2012 6:24 pm
Quoting frankc (Reply 70):
Corrected:
Should be ok.
frankc
Wed Apr 03, 2013 11:44 am
Hello
I inserted this image in the queue:
https://www.airliners.net/addphotos/b.../t1364988725.6364frankc_n317mj.jpg
However the large version of the image (in the queue) has a smaller size compared with the original edit (and consequently it looks softer too).
Am I uploading perhaps an invalid size (which is, in this particular case, 1024x678) ?
Thanks for looking at my issue
Frank
dlowwa
Wed Apr 03, 2013 4:18 pm
Quoting frankc (Reply 72):
That size is at the minimum, but is acceptable.
Can't really comment as I can only see the one you've uploaded, though it doesn't appear to be too soft.
frankc
Wed Apr 03, 2013 5:12 pm
Thanks Dana,
I checked at another PC, the image stretches to the original size hence it must be an issue on my local machine.
Frank
frankc
Fri Apr 11, 2014 9:04 pm
Hello
It has been quite a while since my last upload. Looking for feedback on this one:
https://www.airliners.net/addphotos/b...y/h1397249718.6639frankc_eclnq.jpg
More specifically, is this image passable in terms of contrast/brightness?
Frank Clautier
powwwiii
Screener
Sat Apr 12, 2014 5:07 am
looks maybe just a tad dark, but not too much.
