Candace
Post Screening (Candace)
Fri Apr 05, 2013 9:27 pm
Hi.
Have just had my first photo rejected for being soft, which I acknowledge now is certainly the case.
I have only had my DSLR for 6 months and this was my first attempt to submit a photo to A.net so I am very much a novice, but would appreciate any feedback in terms of whether this photo is redeemable, or any advice on how I can remedy this issue in the future for similar shots. Should I be increasing the sharpness level in my camera, or is this step best left for post-editing?
I am shooting with a Canon 60D with an EF 100-400mm f/4.5-5.6L
I did have a go sharpening the image in PS, and have re-uploaded for screening (currently in the queue), but I feel now I should remove it as it looks over-sharpened and harsh to my eyes!
Original reject:
https://www.airliners.net/addphotos/r...30331_c1364116479.1689img_3765.jpg
Edited version currently in the queue:
https://www.airliners.net/addphotos/b...ady/z1364887187.3721img_3765-b.jpg
DL747
RE: Post Screening (Candace)
Fri Apr 05, 2013 10:03 pm
Hello and welcome both to the forum and to a.net!
Not bad at all for your first photo. I would say that the re-edit looks a bit harsh (too much contrast) and a bit oversharpened. I would wait for a screener opinion before changing, though.
John
dlowwa
Fri Apr 05, 2013 10:04 pm
Quoting Candace (Thread starter):
Sharpening looks better on the newer one, but the contrast is a bit harsh.
Candace
Sun Apr 07, 2013 6:50 am
Thank you for your opinions. I will delete my edited version from the queue for now and try again sharpening and adjusting the contrast on the original.
Candace
Sat Apr 13, 2013 10:50 am
Hello
This is pre-screening but I don't know how I can change the thread title. Is this photo worth submitting? From the original I have applied sharpening and adjusted the colour and contrast slightly.
http://i1140.photobucket.com/albums/n563/CandaceAKL/zk-kfj.jpg
Any feedback appreciated. Thanks
angad84
Sat Apr 13, 2013 11:54 am
Quoting Candace (Reply 4):
It's not correctly centred (high and to the left). The aircraft is also very small in frame, so try cropping closer.
I'm a very poor judge of sharpness, but contrast, colour, exposure etc look ok.
PHX787
Sat Apr 13, 2013 3:09 pm
Fix the crop on the convair and you may wanna sharpen it a bit but I think it's in much better shape than the ANZ photo
dlowwa
Sat Apr 13, 2013 5:59 pm
If you fix the centering/distance issue, it looks like it should otherwise be ok.
Candace
Sat Apr 13, 2013 10:36 pm
Thanks all. Will fix up the cropping and centering and try my luck uploading to the screening queue.
