EGTESkyGod
Pre-Screening - Confidence Dropping
Thu Jun 06, 2013 6:33 am
Hi all
It has been a while since I posted in here because my confidence in my ability to edit photographs up to the required standard has diminished somewhat. I think something has happened in my Photoshop and no matter what I do the quality is affected, even shooting in RAW.
The reason I am trying again is because this particular image of QF11 has my Best Man on board, and I'd like to have it in the database. I'm pessimistic.
https://www.airliners.net/addphotos/b...vh-oqf_yssy_qf11_5-6-13_clifty.jpg
Here are two recent rejections:
https://www.airliners.net/addphotos/r...3451roulettesillawarra2013_cwc.jpg
https://www.airliners.net/addphotos/r...127.9559p51_a68-118_cwc_5-5-13.jpg
Something must be happening in photoshop because they are so grainy.
Anyway, your help is appreciated as always.
Charlie.
dlowwa
RE: Pre-Screening - Confidence Dropping
Thu Jun 06, 2013 6:41 am
Quoting EGTESkyGod (Thread starter):
A little dark, but as you remarked, quite noisy. I'm assuming you either shot at a higher ISO, or had to boost the exposure in post, which would account for the noise.
First one is not that bad, other than the dust spot and being a bit soft, it should be fixable. Second one is dark, noisy, and soft/blurry, so don't think you'll be fixing that one.
EGTESkyGod
Thu Jun 06, 2013 7:59 am
Quoting dlowwa (Reply 1):
ISO was 200... I think my automatic settings in Photoshop must be banjaxed, because this appears to be a common occurrence. As for the exposure boost, not a lot at all really!
EGTESkyGod
Sat Jun 08, 2013 12:01 am
OK had another go at the QF A380.
A whole boost of Noise reduction, brightened up a bit and hopefully sharpened correctly.
https://www.airliners.net/addphotos/b...h-oqf_yssy_qf11_5-6-13_clifty2.jpg
Thoughts?
JakTrax
Sat Jun 08, 2013 12:34 am
First thing that hits me is the feeling of being unlevel, with several background references support this theory. Surprised no-one has commented but would benefit from a bit of CW rotation.
Karl
EGTESkyGod
Sat Jun 08, 2013 12:42 am
Quoting JakTrax (Reply 4):
Funnily enough, I spent ages on the levelling of this alone and I'd convinced myself that this was the best I could get using the buildings as a reference.
dlowwa
Quoting EGTESkyGod (Reply 3):
Looks much better. This one at least would have a decent chance, though I would give it a little more contrast to help those chances.
EGTESkyGod
Sat Jun 08, 2013 1:01 am
Quoting dlowwa (Reply 6):
OK this is my latest go... Contrast boosted, CW rotation, and hopefully sharpened correctly.
https://www.airliners.net/addphotos/b...h-oqf_yssy_qf11_5-6-13_clifty3.jpg
JakTrax
Sat Jun 08, 2013 1:24 am
Levelling looks much better.
EGTESkyGod
Sat Jun 08, 2013 3:15 am
Cool, thank you. I've actually given it one last re-edit because it appeared just as dark as the first attempt, so using the 3rd image I have lightened it up a bit.
https://www.airliners.net/addphotos/b...h-oqf_yssy_qf11_5-6-13_clifty4.jpg
EGTESkyGod
Mon Jun 10, 2013 3:11 am
Got a couple of older ones in the queue that I've had another go at since I've discovered how to reduce noise considerably.
1) British Airways 747 - Sydney - https://www.airliners.net/addphotos/b...47g-civj_yssy_cwc_23-10-2012x3.jpg
2) Air Caraibes A330 - Exeter - https://www.airliners.net/addphotos/b....911f-ofdf_egte_cwc_15-09-2011.jpg
As well as the final working of the Qantas A380, can I get your thoughts on these please?
Charlie.
dlowwa
Mon Jun 10, 2013 4:44 am
Quoting EGTESkyGod (Reply 10):
Pretty bad editing halos around it, would lead to a definite rejection.
A little soft, but might be fixable.
EGTESkyGod
Mon Jun 10, 2013 8:57 am
Quoting dlowwa (Reply 11):
Editing halos? What are they and where? I've reworked it from scratch anyway (See below)
https://www.airliners.net/addphotos/b...83g-civj_yssy_cwc_23-10-2012x5.jpg
How's this?
https://www.airliners.net/addphotos/b...4277f-ofdf_egte_cwc_15-09-2011.jpg
Also had a go at the Roulettes shot again.
https://www.airliners.net/addphotos/b...8653roulettesillawarra2013_cwc.jpg
Charlie.
[Edited 2013-06-10 01:59:49]
dlowwa
Mon Jun 10, 2013 3:36 pm
Quoting EGTESkyGod (Reply 12):
The area immediately adjacent to the fuselage has pretty bad color bleed. Almost certainly from poorly done noise reduction.
Still there, and pretty bad banding in the sky as well. Whatever you're doing for noise reduction, it's not working very well.
How's this?
Maybe a bit flat, but should have a decent chance as is.
They look a bit blurry and oversharpened to compensate.
EGTESkyGod
Tue Jun 11, 2013 7:24 am
Quoting dlowwa (Reply 13):
I'm thinking that it's a reflection of something because it's on every shot in the sequence before editing...
And that's the reason my confidence in my editing is shot.
dlowwa
Tue Jun 11, 2013 7:31 am
Quoting EGTESkyGod (Reply 14):
No, I guarantee it's from noise reduction in editing. It's actually a lot less strong in the second version, so it's something within your control. If you want to send me the RAW file, I can try an edit.
EGTESkyGod
Tue Jun 11, 2013 7:39 am
Quoting dlowwa (Reply 15):
Please do! I'm getting lost in my inability.
Also, I still have two versions of the QF A380 in the queue, which should I stick with?
dlowwa
Tue Jun 11, 2013 5:07 pm
I've done an edit, but I see you've removed the first two versions you did. If you could put one (or both) of them back up so we could compare, that would be good.
EGTESkyGod
Tue Jun 11, 2013 9:59 pm
Quoting dlowwa (Reply 17):
I've got 3 versions here.
1)
http://i268.photobucket.com/albums/jj8/EGTESkyGod/G-CIVJ_YSSY_CWC_23-10-2012x2.jpg
2)
http://i268.photobucket.com/albums/jj8/EGTESkyGod/G-CIVJ_YSSY_CWC_23-10-2012x3.jpg
3)
http://i268.photobucket.com/albums/jj8/EGTESkyGod/G-CIVJ_YSSY_CWC_23-10-2012x5.jpg
Thank you for your help and patience, Dana.
dlowwa
Tue Jun 11, 2013 11:24 pm
My edit:
http://imageshack.us/a/img14/6830/img459211024.jpg
You'll notice I toned down the color a bit, and there are no halos, which are really visible in your version #2
So, a couple of things - a) the original is quite soft, almost to the point of blurriness around the nose, and b) there is quite a lot of noise visible, far more than I would expect to see at only ISO100. The former is likely related to the lens and the slower shutter speed, but the latter I can't explain. It could simply be that the base ISO for your camera is much noisier than others (perhaps because of the pixel density), though I've seen cameras with higher density pixels with less noise. The saving grace is that a large crop wasn't required, so it wasn't too hard to hide those flaws at 1024 pixels. Compare a 100% crop of your image converted from RAW with no other editing done to a similar crop from one of my images, also with no other editing:
http://imageshack.us/a/img196/8050/bacomp.jpg
With this one you should easily be able to see yours is much softer (almost blurry, as I said), and there is a lot more noise visible, though both were at ISO100.
JakTrax
Wed Jun 12, 2013 1:12 am
Interesting comparison. The OP's left-hand image certainly looks a touch blurry, but I have to say Dana that your original looks way sharper (i.e. over-processed) than it should be at a default setting. Is that a RAW?
Karl
EGTESkyGod
Wed Jun 12, 2013 7:07 am
Quoting JakTrax (Reply 20):
Yeah, it looks great! What settings do you have in-camera?! Perhaps I can learn? Or maybe my hands aren't steady enough.
dlowwa
Wed Jun 12, 2013 8:08 pm
Quoting EGTESkyGod (Reply 21):
1/500
f/5.0
200mm
ISO100
I wouldn't really recommend f/5 unless you really trust your lens, but mine's pretty sharp even when relatively wide open, so I almost always have it around at f/5.0 or f/5.6.
For anything over 200mm, I typically use a monopod or tripod with swivel head. I can't remember if I did for this shot, but it's quite possible I had it on something. It doesn't make a huge difference, but the ratio of good shots to blurry ones does go up.
EGTESkyGod
Wed Jun 12, 2013 8:59 pm
I'm using the standard 75-300mm lens, I really want to upgrade to an 'L' lens when I can afford it. But I was more meaning the in camera settings relating to sharpness, etc. I have a feeling I have changed those and maybe that's affecting things before I edit. But I like the monopod/tripod idea.
Tonyholt777
Wed Jun 12, 2013 11:39 pm
Quoting dlowwa (Reply 22):
Hi Dana
Interesting post - Were you using a full frame or crop camera?
Good shot by the way.
tony
dlowwa
Thu Jun 13, 2013 2:29 am
Quoting EGTESkyGod (Reply 23):
With RAW files, in-camera settings are meaningless, as you control everything when converting the RAW to jpeg. Did you mean to ask what the conversion settings were?
Like I said, not totally necessary, but I find you tend to get more keepers when using one than not.
EGTESkyGod
Thu Jun 13, 2013 6:32 am
Quoting dlowwa (Reply 25):
Sure! Anything that may help.
Also, before I get a Double rejection for those QF A380 shots, which do you recommend I leave in there?
dlowwa
Thu Jun 13, 2013 7:26 am
My default sharpening/nr settings for ACR are 50/1.0/30/0 and 25/0/0/0. Both of the images in the comparison above were processed with those settings.
Quoting EGTESkyGod (Reply 26):
Probably the second.
EGTESkyGod
Wed Jul 03, 2013 8:01 am
Accepted!
Thank you Dana.
Photo © Charlie W Carter (EGTESkyGod)
