EZEIZA
Post Screening; Noise
Thu Jun 06, 2013 2:17 pm
Hi, this shot was rejected for noise/grain, wih a message saying "blotchy sky". What exactly does that mean, how to avoid it and how can I correct it? Yes, I know, a lot of questions lol. Thanks in advance!
https://www.airliners.net/addphotos/r...6_w1369489413.8792eclab_1edit2.jpg
dlowwa
RE: Post Screening; Noise
Thu Jun 06, 2013 3:28 pm
Quoting EZEIZA (Thread starter):
Yes, quite noticeable above the aircraft.
If you're not shooting hi-ISO, then you're likely doing something in post-processing that is causing it. Surprisingly, some kinds of noise reduction can cause that kind of blotchy sky. Without knowing the exact details of your image and how you processed it, can't say much more.
EZEIZA
Thu Jun 06, 2013 3:35 pm
Quoting dlowwa (Reply 1):
Thanks! it was a low ISO shot, 100, so that should not have caused it. I use neat image for noise reduction, could tha be it? if so, how come it can show up in some pictures and others not?
The rest of the processing is fairly standard for a normal sunny shot, slight level correction and some sharpening.
what does "blotchy" mean exactly?
rgds
kulverstukas
Thu Jun 06, 2013 4:10 pm
Spotty. Like dalmatine dog
EZEIZA
Thu Jun 06, 2013 4:20 pm
Quoting Kulverstukas (Reply 3):
great example lol
vikkyvik
Thu Jun 06, 2013 4:21 pm
Quoting EZEIZA (Reply 2):
Typically, larger adjoining areas of different brightness/color. Usually larger areas than typical luminance noise (grain).
Can also be caused by compression, or having strong brightness gradients (typically manifested as banding).
That's a tough question to answer. Every shot simply isn't exactly the same.
dlowwa
Thu Jun 06, 2013 4:39 pm
It could be. Try processing without Neat Image, and see how it turns out. I don't use any seperate noise-reduction plugins, but the only time I see banding/blotchiness in my own images is when I've set the noise reduction too high in ACR.
EZEIZA
Thu Jun 06, 2013 7:53 pm
Quoting vikkyvik (Reply 5):
thanks!
Quoting dlowwa (Reply 6):
the thing is I basically use NI for every single picture, and I very rarely get noise rejections. I'll try re editing without any noise reduction and see how it works out.
thanks all of you for all your help!
vikkyvik
Thu Jun 06, 2013 8:30 pm
Quoting EZEIZA (Reply 7):
If you're shooting at low ISO in decent light and not underexposing, you shouldn't need to use NR for every photo. I used to do that too, until I got better at exposing correctly, and realized I didn't really need to add much NR, if any.
EZEIZA
Sat Jun 08, 2013 8:09 pm
Quoting vikkyvik (Reply 8):
great, thanks for the tip! it will save some time too lol
