RCoulter
Pre-Screen - Another Longshot?
Fri Jun 21, 2013 1:12 am
Any chance for this shot or is does the light ruin it? Ignore the watermark obviously...
http://highsierraspotters.com/forum/.../files/1/162890krno06102013_wm.jpg
mjgbtv
RE: Pre-Screen - Another Longshot?
Fri Jun 21, 2013 1:47 am
The light is not great but I don't think it ruins it. I do think it could use a bit more brightness/contrast.
Might be a touch high in the frame also.
JakTrax
Fri Jun 21, 2013 10:42 am
The light doesn't do it for me but centring looks fine.
Karl
angad84
Fri Jun 21, 2013 12:24 pm
I've gotta be the only weirdo that thinks the light is solid. Goes nicely with the weather and the greys on the aircraft itself.
Agree that it could use a touch more contrast, or just a slight lift to the white levels.
RCoulter
Fri Jun 21, 2013 3:21 pm
Quoting mjgbtv (Reply 1):
Quoting jaktrax (Reply 2):
Karl
Quoting angad84 (Reply 3):
Thanks guys, maybe I will give it a go and see what happens since it looks like two out three think it may be OK.
RCoulter
Sat Jun 22, 2013 3:55 pm
Here is a new edit with the suggested changes: http://machimages.com/temp/A.net/pre-screen/162890KRNO06102013.jpg
I am not sure if I went too low, but knowing A.net it may be OK.
angad84
Sun Jun 23, 2013 11:30 am
Looks a bit dark.
dlowwa
Mon Jun 24, 2013 8:22 am
Quoting RCoulter (Reply 4):
This would be rejected for dark/harsh contrast.
RCoulter
Mon Jun 24, 2013 3:31 pm
Quoting dlowwa (Reply 7):
Thanks Dana, I will see if I can get somewhere with a new edit.
sovietjet
Tue Jun 25, 2013 2:27 pm
Quoting RCoulter (Reply 5):
Off topic, but when did you take that photo?
RCoulter
Tue Jun 25, 2013 3:01 pm
Quoting sovietjet (Reply 9):
June 10th of this year.
sovietjet
Tue Jun 25, 2013 3:52 pm
Quoting RCoulter (Reply 10):
Cool! I was at Fallon on June 12 and all of VFA-204 was there. Then at Reno-Tahoe on the 13th but didn't see much.
RCoulter
Tue Jun 25, 2013 5:21 pm
Quoting sovietjet (Reply 11):
Yep, that's where they were heading to when I photographed them. They had diverted to RNO the day before because NFL wasn't open from what one of my contacts that talked with them told me.
I hope you got some good shots at Fallon!
