Soaring1972
Window-View-Soft-Rejection
Thu Oct 24, 2013 12:22 pm
In the last days I have recieved now a second vindow-view with soft-rejection. So that makes me wondering now!
Is this picture realy soft especialy if you compare it with other recent accepted window-views?
https://www.airliners.net/addphotos/r...31024_x1381779295.1333czj43453.jpg
Thanks to all ONE-Star voters just to push a photograph down!!!
mjgbtv
RE: Window-View-Soft-Rejection
Thu Oct 24, 2013 9:31 pm
The top left corner and the bottom of the struts look out of focus or at least very soft - maybe DOF?
Soaring1972
Fri Oct 25, 2013 8:12 am
Quoting mjgbtv (Reply 1):
Do you relay want me to do a photograph wich is sharp from 1m in front of the lens till 30km of the lens???
epten
Fri Oct 25, 2013 9:35 am
It certainly is doable, with a glass large enough (so even when fully stepped down, enough light still comes through) and good technique and editing.
http://cdn-www.airliners.net/aviation-photos/photos/6/5/6/2335656.jpg
Soaring1972
Fri Oct 25, 2013 12:04 pm
mjgbtv
Fri Oct 25, 2013 4:41 pm
Quoting Soaring1972 (Reply 4):
Anyway this could not be the reason for soft because you can find other pictures with parts near the glas not 100% sharp like these:
Interesting. Since the aircraft is the 'subject' according to the info I would have expected whatever portion of the aircraft is visible to be judged according to the usual quality criteria. I may have to use your Dornier shot as an example to question a rejection of my own
Quoting Soaring1972 (Reply 2):
You could always crop out the out-of-focus portions, but based on your examples maybe that is not what the screener had in mind.
Soaring1972
Sat Oct 26, 2013 10:08 am
