fmgirard
Rejection Reason Question
Fri May 02, 2014 12:28 am
I submitted the following photo and one of the rejection reasons was "void of color an unwelcome editing," as well as a few other reasons. Does anyone know what that specifically means?
https://farm8.staticflickr.com/7431/13815852964_fcccd94817_b.jpgAir China 747-400 @ SFO by thediamondguest, on Flickr
TIA
UA GS | DL Diamond | This post represents my personal opinion and not that of my employer, Airbus, a division of EADS
mjgbtv
RE: Rejection Reason Question
Fri May 02, 2014 1:04 am
'void of color' might mean that it looks a bit under-saturated.
The background seems unnaturally blurry. If that was done in post-processing it would be 'unwelcome'=not allowed.
fmgirard
Fri May 02, 2014 1:13 am
Ok, that makes more sense. As for the background, I didn't realize it was blurry until I opened the image in Photoshop, to which I kept it blurry.
Is that ok?
vikkyvik
Fri May 02, 2014 1:23 am
Quoting mjgbtv (Reply 1):
It does indeed.
Quoting fmgirard (Reply 2):
Theoretically, there's nothing wrong with a blurred background. But as Marty noted, it looks very strange in your image, as the foreground and aircraft are all sharp.
Although I will note that the aircraft tail is partially blurry as well, so the image would be rejected for that.
Very weird - any idea where that all came from?
fmgirard
Fri May 02, 2014 2:38 am
Quoting vikkyvik (Reply 3):
I'm not sure where the blurriness came from, but I suspect that it has to do with the depth-of-field on the camera. The image was taken from the United Club, in the International Terminal @ SFO as well, if that could have something to do with it as well.
vikkyvik
Fri May 02, 2014 4:05 am
Quoting fmgirard (Reply 4):
Doubtful it's DOF - the airplane is sufficiently distant that even wide open, I'd expect the background to be relatively sharp. And given the tail suffers from blur/softness too, I think it's more likely caused by the windows you were shooting through.
mjgbtv
Fri May 02, 2014 12:19 pm
It seems to be about the top 40% of the image. Do the windows have a shading material on them?
fmgirard
Fri May 02, 2014 3:52 pm
Quoting vikkyvik (Reply 5):
Quoting mjgbtv (Reply 6):
The windows do have a dimming tint to them, as well as anti-reflective coating on the outside.
Would this cause an automatic rejection?
fmgirard
Fri May 02, 2014 3:54 pm
This is another picture taken at nearly the same time as the other one:
https://farm4.staticflickr.com/3796/13815227773_f81204a6e3_b.jpgUnited Airlines 757-200 @ LAX by thediamondguest, on Flickr
vikkyvik
Fri May 02, 2014 4:59 pm
Quoting fmgirard (Reply 8):
What lens are you using? Almost looks like that tilt-shift toy-looking effect.
Quoting fmgirard (Reply 7):
Shooting through a window doesn't cause an automatic rejection, but the artifacts/effects produced by said window (dirt spots, streaks, reflections, bad contrast, bad colors, softness, etc.) can cause a rejection.
fmgirard
Fri May 02, 2014 10:27 pm
Quoting vikkyvik (Reply 9):
I was using an 18-55 Nikkor attached to a D3000.
epten
Sat May 03, 2014 6:15 pm
The blurriness is definitely NOT DOF. It certainly looks "artificial". Perhaps there's a feature somewhere which is unintentionally "on"??
