andrewmoir
Nothing But Rejections
Tue Jul 22, 2014 12:15 pm
I'm starting to get a bit frustrated with all the rejections I've been receiving recently. For example, the shot below was rejected for blurriness.
https://www.airliners.net/addphotos/r...20140722_z1405206412.2936fedex.jpg
I am having a real hard time comprehending all these rejections. This shot below was rejected for oversharpening, when I applied hardly any sharpening.
https://www.airliners.net/addphotos/r...g/20140722_c1405172963.5792ups.jpg
[Edited 2014-07-22 05:16:50]
MLP86
RE: Nothing But Rejections
Tue Jul 22, 2014 1:46 pm
The aircraft on first one seems a bit soft for me, while the power lines already getting a "stairs" effect. Maybe that was meant. For the second I also can hardly comprehend oversharpening.
Rotate
Tue Jul 22, 2014 2:05 pm
Both rejections are okay in my eyes.
The 2nd does have indeed oversharpned titles and reg. You said you hardly attached sharping on the 2nd pic. What do you mean by this? Could it be that you have your incamera sharping quite high? Thus resulting in: No need to resharp --> No chance to adopt selective areras sharping?
ABC
andrewmoir
Tue Jul 22, 2014 4:22 pm
Quoting MLP86 (Reply 1):
Can I fix this image by sharpening it more? I imagine I would need to sharpen the entire image because this site doesn't allow selective editing? I already used two rounds of the unsharpen tool, 70%, radius .2.
DL747
Tue Jul 22, 2014 5:32 pm
Quoting andrewmoir (Reply 3):
No, selective sharpening is perfectly fine, it is even mentioned in the editing guide as a suggestion.
John
Hey, thanks for stopping by! My photos can be found here: https://www.airliners.net/search?user=17 ... lay=detail
andrewmoir
Tue Jul 22, 2014 5:55 pm
Is selective noise reduction allowed too? (The sky)
dazbo5
Tue Jul 22, 2014 6:30 pm
Quoting andrewmoir (Reply 5):
Yes, and is often required with the sites silly insistence of zero tolerance of noise of any description. Apart from certain cases.
Darren
andrewmoir
Wed Jul 23, 2014 12:06 am
I have since purchased a new lens since taking those photos.
Can somebody comment on the photo below? Does it require more sharpening given it's current size?
https://www.airliners.net/addphotos/big/ready/y1406073692.1224wja.jpg
Thanks.
vikkyvik
Wed Jul 23, 2014 6:37 am
Quoting andrewmoir (Reply 7):
Looks not bad to me. Maybe a bit on the oversharpened and contrasty side.
cjmoeser
Wed Jul 23, 2014 6:48 pm
Quoting andrewmoir (Thread starter):
Sorry to bring this back up, but I had the same problem. You need to go into your camera internaly and tone down the sharpining off the camera. I have a Pentax K30 and in my Aviation mode I had sharping at 0, but I found it was sharping the photos to where I didn't need them to be, so I put it down two spots and it's not to sharp, and not to soft.
737guy
Thu Jul 24, 2014 1:20 am
I think calling the first one blurry is extremely picky. Most likely got a strict screener I suppose.
Second one looks maybe soft to me; certainly don't see oversharpening as a whole.
Mitchell Haughee
andrewmoir
Thu Jul 24, 2014 1:29 am
Usually the first things I check when I look for oversharpening is the windows, which I learned from this site. I took a look at my camera menu and couldn't find any sharpening settings.
So this one still looks over sharpened eh? I adjusted the curves so the contrast should be better.
https://www.airliners.net/addphotos/big/ready/m1406161397.6261wja.jpg
I sharpened it with the unsharpen tool in photoshop, amount 70% radius .2, threshold 2. Maybe the sharpens the photos? It's a Sigma 70-300 APO DG with marco mode off.
Thanks.
[Edited 2014-07-23 18:30:26]
DL747
Thu Jul 24, 2014 1:44 am
Hi,
Yes, this one is still oversharpened and now might be a bit bright.
John
andrewmoir
Thu Jul 24, 2014 2:27 am
I just realized the reason for my recent rejects is because I'm shooting JPEG AND sharpening in photoshop. I didn't realize the camera automatically sharpens JPEG pics.
I have had shots accepted here before shooting JPEG so I will just stop sharpening the shots. Does anyone else shoot JPEG or do you all shoot RAW? RAW confuses me.
andrew
[Edited 2014-07-23 19:28:27]
vikkyvik
Thu Jul 24, 2014 5:31 am
Quoting andrewmoir (Reply 13):
RAW. I think the last time I shot JPEG was the first week after I bought my first DSLR.
Yes, it does. But you can control how much it sharpens them, plus a bunch of other export settings.
Shooting RAW basically allows you to control all those export settings on your computer.
DL747
Thu Jul 24, 2014 5:35 am
Hi,
RAW confuses me.
RAW actually confuses me less! Instead of having the camera control a lot of variables, as Vik stated above, you control them, or at least more of them in post-processing.
John
dazbo5
Thu Jul 24, 2014 7:06 am
I wouldn't agree that's the reason. I shoot JPEG all the time and have 6,500 shots on the database! Just make sure your camera is applying minimal in-camera sharpening. My default is to have everything set to 0. I've had few problems.
Darren
andrewmoir
Thu Jul 24, 2014 12:59 pm
Good morning gentlemen,
Ok so I found the setting and reduced the sharpness to zero on the camera. I then edited the JPEG file in photoshop and produced the photo below.
https://www.airliners.net/addphotos/b.../ready/q1406207734.4196embraer.jpg
Do you think that's the correct amount of sharpness? I made sure by zooming in on the windows and there were none of those "spots" from oversharpening.
Andrew
[Edited 2014-07-24 06:16:34]
dazbo5
Thu Jul 24, 2014 2:54 pm
Quoting andrewmoir (Reply 17):
The front half of the fuselage looks fine on my screen. The aft is a little soft though. It's also noisy in the sky and it needs to be cropped a little on the right to centre is better.
Darren
andrewmoir
Sat Jul 26, 2014 3:12 am
Good evening
Can one of you guys have a look at the two photos below? I have sharpened them in Lightroom and PS so I'm looking for some feedback.
https://www.airliners.net/addphotos/big/ready/y1406329765.1252aca-2.jpg
https://www.airliners.net/addphotos/b...g/ready/z1406344245.1709airbus.jpg
vikkyvik
Sat Jul 26, 2014 4:13 am
Commenting on sharpness only, the first looks a bit soft, and the second a bit oversharpened.
powwwiii
Screener
Sat Jul 26, 2014 5:11 am
ERJ looks soft/blurry, 320 seems passable in term of sharpness. But both seems have a strong contrast, and a magenta/red tint.
len90
Sat Jul 26, 2014 5:50 am
Agree with Tao on everything except the contrast on the 320. I thought the contrast on that one would be acceptable. Magenta/red tint on the 320 is also not as bad as the tint on the 190.
Len90
andrewmoir
Mon Jul 28, 2014 4:48 pm
Can I please get a pre-screen on the shots below?
https://www.airliners.net/addphotos/big/ready/o1406565677.826fedex.jpg
^ That shot was rejected in my first post. I applied more sharpening, and reduced the noise in the sky.
Also, can I get an opinion on the shot below?
https://www.airliners.net/addphotos/b...g/ready/e1406516156.3793c-guws.jpg
DL747
Mon Jul 28, 2014 6:28 pm
Hi,
The first looks fine to me now. The second looks pretty good but appears to have too much noise reduction applied to it, as there are areas, mainly under the wing that are a bit blotchy and lacking detail.
John
FighterPilot
Mon Jul 28, 2014 6:41 pm
Also I would say the lettering on the WS 737 is slightly soft.
Cal
*Insert Sound Of GE90 Spooling Up Here*
vikkyvik
Mon Jul 28, 2014 7:44 pm
Quoting DL747 (Reply 24):
Agreed, which is probably contributing to:
Quoting FighterPilot (Reply 25):
I would also lower it in the frame some.
andrewmoir
Wed Aug 06, 2014 12:04 am
Hey guys,
I know this site likes cool artsy shots, I was wondering if the shot below had any chance. It's cool how the title is well lit.
http://i.imgur.com/6ncdDT3.jpg
DL747
Wed Aug 06, 2014 12:29 am
Hi,
Quoting andrewmoir (Reply 27):
cool artsy shots
I don't really think this falls into this category. The shot seems very toplit and the top of the fuselage is blown out while the bottom is dark. It is also oversharpened in spots and soft in others, harsh, and looks a bit yellow to me.
John
[Edited 2014-08-05 17:30:01]
vikkyvik
Wed Aug 06, 2014 3:29 am
Quoting DL747 (Reply 28):
Fully agree. Andrew, it's basically a photo taken in not-spectacular light. The upper half is borderline overexposed, and the whole thing is a bit over-contrasted. Overall quality doesn't look great.
As we've mentioned before, you'll help yourself immensely if you shoot in good light to start with.
andrewmoir
Wed Aug 06, 2014 4:26 pm
Ok what about this shot? It was rejected for wrong category. I selected the morning/dusk/night category. Shot was probably taken between 6-7 AM. Do you think an appeal is worth it?
https://www.airliners.net/addphotos/r...140805_b1406569161.4535embraer.jpg
vikkyvik
Wed Aug 06, 2014 6:06 pm
Quoting andrewmoir (Reply 30):
This isn't a subjective rejection. The sun is up, therefore the shot is not "dusk/night/dawn".
When you upload a shot, next to all the possible category selections, there are helpful little "Read Me" links; I suggest you read them prior to choosing a category. For the dusk/night/dawn category, it simply says:
A photo shot when the sun is below the horizon.
andrewmoir
Wed Aug 13, 2014 12:47 am
Hi guys,
Wondering if you can provide some feedback on these night shots.
https://www.airliners.net/addphotos/b...407888834.7997air_canada_final.jpg
and
https://www.airliners.net/addphotos/b...eady/b1407890235.3237departure.jpg
The first one I sharpened using the lens blur option and used some noise reduction.
Thanks.
mjgbtv
Wed Aug 13, 2014 1:13 am
I like both but I'm not sure that they have good chances here.
The Air Canada looks quite soft in spots. I think it is also in an awkward 'in between' spot light-wise. If that is how it really looked you could certainly argue that point, but I'd say you might be better off with more contrast and a pure silhouette.
On the second, both the aircraft and part of the runway are heavily heat hazed, which is probably going to get you a rejection. It also looks like it would need some CCW rotation.
vikkyvik
Wed Aug 13, 2014 1:46 am
Quoting andrewmoir (Reply 32):
Both photos would likely be rejected for dark at the least. The first one is kind of cool, but you could have exposed it significantly brighter and kept the same effect.
In the second, there's not enough detail in the runway and such to warrant it, really, and the runway lights don't really stand out at all. Again, if it had been exposed considerably brighter, it may have stood a chance.
