guth99
Pre Screen Tips
Thu Aug 07, 2014 11:24 pm
Hi Guys
Please could you guys take a look at the photos linked below and give some comments about them then i can rework them before uploading.
Special Thanks to John for helping me out(DL747)
https://www.airliners.net/addphotos/b...07453766.0007aerlingustestjpg2.jpg
Josh
[Edited 2014-08-07 16:37:33]
monsoon84
RE: Pre Screen Tips
Fri Aug 08, 2014 4:00 am
Hi,
All I can see is that there is some dead space left of the nose, but other than that I think it looks good.
Kenneth Armijo
vikkyvik
RE: Pre Screen Tips
Fri Aug 08, 2014 5:42 am
Quoting monsoon84 (Reply 1):
The dead space is fine, but it would likely be rejected for quality/oversharpened and probably editing (for what looks like excessive use of shadow/highlight to brighten the aircraft).
guth99
RE: Pre Screen Tips
Fri Aug 08, 2014 10:40 am
Hi Guys
Thanks for the comments I have re-worked it so please could you re comment thanks
Josh
https://www.airliners.net/addphotos/big/ready/u1407494842.9978aer1320shadowedit.jpg
[Edited 2014-08-08 03:48:42]
guth99
RE: Pre Screen Tips
Fri Aug 08, 2014 12:30 pm
I have another photo here for you guys to have a look at if you could please comment and give pointers i would be very grateful.
Thanks to John for the edit (DL747)
Josh
https://www.airliners.net/addphotos/b...1407500896.4035johnseditvirgin.jpg
DL747
RE: Pre Screen Tips
Sat Aug 09, 2014 9:52 pm
Hi,
The Aer Lingus 320 looks ok to me, but maybe a bit compressed for some reason.
John
Hey, thanks for stopping by! My photos can be found here: https://www.airliners.net/search?user=17 ... lay=detail
guth99
RE: Pre Screen Tips
Sat Aug 09, 2014 9:58 pm
Hi john
Don't know why there would be any compression as it was saved at the highest possible quality.
Josh
cjmoeser
RE: Pre Screen Tips
Sat Aug 09, 2014 10:29 pm
Quoting Guth99 (Reply 3):
Hi Guys
Josh
https://www.airliners.net/addphotos/b...07494842.9978aer1320shadowedit.jpg
The elevator is oversharp, you can see some jagies. otherwise it looks fine.
Your otherone looks a touch hot, and with the elevator cut off it may not work, in my opinion, but it may.
DL747
RE: Pre Screen Tips
Sat Aug 09, 2014 10:46 pm
Hi,
Quoting CJMoeser (Reply 7):
Good call on that one Colin.   I think what I was seeing is slight oversharpening making high contrast edges look weird and I thought it was compression. I agree with Colin on slight oversharpening.
John
cjmoeser
RE: Pre Screen Tips
Sun Aug 10, 2014 3:03 am
Quoting DL747 (Reply 8):
Thank you!
Looking at that photo some more, and the whole photo is oversharp. You can see it in the reg. and the black line near the wings. The crop is kinda off, you should move it it back a bit more and balance it out from the nose and tail.
combatshadow
RE: Pre Screen Tips
Sun Aug 10, 2014 2:32 pm
On the Virgin A320, similar things. The crop needs to be redone, I wouldn't cut the horiz. stab off. And it's a good image, just a little bit oversharpened in some spots. But if you knock the whole image back in sharpening, you will be soft in other areas, such as the titles
Bob
DL747
RE: Pre Screen Tips
Sun Aug 10, 2014 5:24 pm
Hi,
Quoting combatshadow (Reply 10):
I did this edit for Josh and I had to do that because the original had it cut off once the photo was rotated properly. Josh, unfortunattely, I think you'll just have to bin this one.
John
mjgbtv
RE: Pre Screen Tips
Mon Aug 11, 2014 1:09 am
Cutting off the horizontal stab seems to be somewhat frowned upon, but the way it was done here should not be a motive rejection. See example 15c ('Justified clipping of stabilizer') in the Motive section of the rejection guide.
Users browsing this forum: Crosswindphoto and 6 guests
