cjmoeser
Post Screen Contrast & Soft
Sun Aug 30, 2015 8:10 pm
Hi all,
I've been getting a lot of Soft and Contrast rejections lately for Military aircraft, and I'm going to be doing some reedits on the majority of them. What can I do to help fix these? Here are some examples of my rejections. I've been using around 65-70% with sharpening in Photoshop elements and between 65-69 Contrast in Lightroom.
Contrast Flat and soft
https://www.airliners.net/addphotos/r...0092966.546162-3575-kc135-6aww.jpg
Soft and Low Contrast
https://www.airliners.net/addphotos/r...9945.663190-0239-391st-f15e-mo.jpg
Soft and more contrast
https://www.airliners.net/addphotos/r...9_l1439238653.664290-0242-f15e.jpg
Soft and needs contrast
https://www.airliners.net/addphotos/r..._e1439240928.43590-244-f15e-mo.jpg
[Edited 2015-08-30 13:13:41]
kulverstukas
RE: Post Screen Contrast & Soft
Sun Aug 30, 2015 8:49 pm
Are they out of camera JPGs or RAW developed? I see terrible chromatics on wheels...
cjmoeser
Sun Aug 30, 2015 9:08 pm
Quoting Kulverstukas (Reply 1):
I shoot RAW. Could that be becuase of selective Sharpening?
vikkyvik
Sun Aug 30, 2015 9:22 pm
Quoting CJMoeser (Thread starter):
It almost looks like you've lifted the shadows - especially on the first one. Contrast is quite noticeably low on all of them. The fighters could all probably use a slight brightness boost, too.
Quoting CJMoeser (Reply 2):
Sharpening will make fringing worse look worse, yes. But it's caused by the lens.
I wouldn't worry too much about it - the last shot is the only one that has fringing that I would call noticeable.
cjmoeser
Sun Aug 30, 2015 9:25 pm
Quoting vikkyvik (Reply 3):
I did lift the shadows on them, becuase they were very dark otherwise. Add contrast then and a little exposer?
kulverstukas
Sun Aug 30, 2015 9:48 pm
Use lens profile correction in LR, if it doesn't recognize your lens, try to choose it manually. It will remove fringes.
vikkyvik
Mon Aug 31, 2015 1:06 am
Quoting CJMoeser (Reply 4):
Gotcha. That will give them the very low-contrast look that they have. You can sometimes get away with a bit of shadow-brightening, but not nearly this much.
Doesn't matter to me the order you do it in. I do both at the same time by using the "Levels" histogram in Photoshop.
Basically, you need to darken the blacks, darken the mids, and brighten the whites, on the fighters, at least. The 135 looks bright enough.
cjmoeser
Mon Aug 31, 2015 1:31 am
Quoting Kulverstukas (Reply 5):
I don't believe it has a Sigma 50-500 on there... I'll double check thought.
Quoting vikkyvik (Reply 6):
Quoting CJMoeser (Reply 4):I did lift the shadows on them, becuase they were very dark otherwise.
Ok I'll give that a try and do a little bit work with the levels instead of the shadows and see how that Goes.
Appeal Maybe?
vikkyvik
Mon Aug 31, 2015 5:25 am
Quoting CJMoeser (Reply 7):
Appeal Maybe?
No. It's still soft and the contrast is low. "Dark" wasn't a rejection reason (at least you didn't mention it).
Users browsing this forum: Google [Bot] and 8 guests
