YQZ380
Pre-screening
Sat Oct 03, 2015 6:32 am
Hi all,
I was wondering if I could get any opinions on these shots?
https://www.airliners.net/addphotos/big/ready/d1443601487.5547dsc_2284-3.jpg
https://www.airliners.net/addphotos/big/ready/p1443481182.9413dsc_2207-3.jpg
http://i.imgur.com/hu8PpdO.jpg
Thanks.
Yang
Life is like an airliner; if you try to climb too much, you will stall.
cjmoeser
RE: Pre-screening
Tue Oct 06, 2015 6:45 pm
Hi,
The top one looks a overexposed on the whites. Also a bit flat
Second one looks soft on the body, and could use a little bit of a tighter crop.
Third one, I would get a second opnion for that one. I haven't really done any crops like that, but everything else looks ok.
Joshu
RE: Pre-screening
Tue Oct 06, 2015 8:51 pm
The third one is soft/dark/high in frame
The second one is grainy/soft/high in frame
The first is soft/flat/needs leveling (CCW), slightly overexposed
Washington-Baltimore Spotters Group
YQZ380
RE: Pre-screening
Wed Oct 14, 2015 1:01 pm
Thanks guys. The first one indeed got rejected for overexposed, though the second got accepted.
I tried my best at this 1/6 seconds handheld panning yesterday:
https://www.airliners.net/addphotos/big/ready/x1444784062.4837dsc_3129-3.jpg
How does it look?
Additionally, I want to see if this BA 777 is acceptable for anet.
https://www.airliners.net/addphotos/big/ready/f1444811281.2913dsc_3424-3.jpg
cjmoeser
RE: Pre-screening
Thu Oct 15, 2015 4:16 am
Top looks blurry and needs some CCW. also a little soft and dark
BA777 looks dark also, and needs CW rotation. maybe a little soft on the body.
vikkyvik
RE: Pre-screening
Fri Oct 16, 2015 4:22 am
Finnair is not bad for 1/6 panning! I'd bring the midtones down a good bit to help with the milky look of the photo. Then I'd probably edit to 1100 or smaller, as there is some blur visible.
BA doesn't look too great, quality-wise. Looks pretty soft toward the rear.
YQZ380
RE: Pre-screening
Fri Oct 16, 2015 9:02 am
Right, so I gave them both a re-edit.
https://www.airliners.net/addphotos/big/ready/m1444985433.1873dsc_3129-3.jpg
https://www.airliners.net/addphotos/big/ready/b1444986121.4031dsc_3424-3.jpg
Better?
