A388
Post-screening: Contrast/Soft
Mon Nov 23, 2015 8:18 pm
Hello,
This photo got rejected for needing more contrast:
https://www.airliners.net/addphotos/r...0.9956helveticf100rcmuc191015a.jpg
Why is this? It looks to me(?)
And this photo got rejected for being soft:
https://www.airliners.net/addphotos/r...46234746.8893ib320rcmuc191015a.jpg
The photo looks good me(?)
I'm looking forward to your feedback/tips.
A388
airkas1
RE: Post-screening: Contrast/Soft
Mon Nov 23, 2015 9:23 pm
Hi Roger,
Quoting A388 (Thread starter):
It looks a bit 'milky'. Try adding 10-15 more contrast in Photoshop and see the result (the figures aren't an exact science). Just be careful the grass doesn't get too dark.
Does look a bit soft on the cockpit, passenger windows and main titles. They should all be able to withstand a bit more sharpening.
A388
Wed Nov 25, 2015 2:20 pm
Okay thanks Kas, I will have another go at it. Thanks for your advice.
A388
alevik
Sun Nov 29, 2015 5:06 pm
Quoting airkas1 (Reply 1):
Rather than using the contrast adjustment, you can adjust the left side levels slider. Many images suffer from low contrast due to the levels not being adjusted properly.
Pete
Improvise, adapt, overcome.
A388
Mon Nov 30, 2015 1:40 pm
Quoting alevik (Reply 3):
Quoting airkas1 (Reply 1):Try adding 10-15 more contrast in Photoshop and see the result
Pete
Okay thanks alevik. I will have a go at it again. I have another photo of which I would like tips but will post this in another thread.
A388
clickhappy
Mon Nov 30, 2015 7:10 pm
The F100 shot also needs counterclockwise rotation
