kulverstukas
RE: Is It Anet Worthy 2016?
Sun Jun 12, 2016 8:59 pm
Quoting angad84 (Reply 83):
If you don't try to get this up - at ANY size - I will be very sad.
OK, I tried...   5 of 5 get rejected today, 10 more to go. I don't think my photos are up to this site latest screeners demand - nothing changes since February.
kulverstukas
Re: Is It Anet Worthy 2016?
Wed Aug 03, 2016 2:08 pm
Rejected for two reasons. What "Left in frame" mean? Also "Soft" which doesn't feels soft for me (if we talking about copter which is the main object, other can be soft however). And I can't get whole idea of HQ 1 from firs screener - and rejection from second.
airkas1
Thu Aug 04, 2016 1:50 pm
It means exactly what it says.. Subject is too left in the frame (not centered).
It looks passable.
scbriml
Thu Aug 04, 2016 2:22 pm
So you think he should move it further to the right? ;) :o
I suspect the screener meant it needs to be moved "left in frame"? Personally, I'd crop most of the rotor out - it's adding nothing and makes the shot look unbalanced:
airkas1
Thu Aug 04, 2016 2:34 pm
Oh, I forgot to mention that I obviously don't agree with Left in Frame. Probably a miss-click by the screener. I agree with Steve's crop.
kulverstukas
Thu Aug 04, 2016 3:27 pm
Hm... I know that left is right and right is wrong but does it apply to aviation pictures? Seriously, Kas, you seems dismissed both rejection reasons, right? In case I still want to frame it the way it is (which technically comply with Anet rules)?
airkas1
Thu Aug 04, 2016 3:48 pm
Of course it applies to aviation images. You have to take horizontal centering in account too, not just vertical centering. And I didn't dismiss either rejection. I explained what "left of frame" means and I said the sharpening is passable. If you include the rotor, it would be borderline OK for me, although it does look unbalanced from that angle (which is why Steve's crop looks better).
vikkyvik
Thu Aug 04, 2016 6:20 pm
I thought images didn't get rejected for what looks like an unbalanced crop due to including full helicopter rotors.
airkas1
Thu Aug 04, 2016 6:27 pm
That's why I said that this crop would be OK for me. I'm pretty sure the left in frame rejection was a mistake.
kulverstukas
Thu Aug 04, 2016 7:41 pm
Appealed it, let's wait outcome. UPD: Accepted. Question: if I upload another shoot with same copter at the same place same day but hoods closed and engine started (first ground test of new modification) will it be rejected as double?
Blurry and OS?
airkas1
Thu Aug 04, 2016 8:18 pm
Yes.
kulverstukas wrote:
Blurry and OS?
Not really OS, but the tail/rotor looks OOF.
kulverstukas
Fri Aug 05, 2016 6:46 pm
Top #1 photo of A.net... With 360 views... Shame on this new site!
kulverstukas
Sun Aug 21, 2016 9:08 am
airkas1
Sun Aug 21, 2016 5:17 pm
Looks soft/bit heathazed.
kulverstukas
Mon Aug 22, 2016 8:52 am
Soft? I just exchanged all my editing gears and has three different screens attached - 17" 1920x1080, 24' 2560x1440 and old one 20" 1600x900 (which I put instead of sole 24" 1920x1200 I used to check how it looks like on non-retinas). All three makes me impression that its closer to OS.
kulverstukas
Re: RE: Is It Anet Worthy 2016?
Mon Aug 22, 2016 8:54 am
angad84 wrote:
Quoting kulverstukas (Reply 78): I think this one don't worth trying even at 1024?
A
Managed to get it through a couple of rejections and to PC after a bit hot worded appeal ;)
airkas1
Mon Aug 22, 2016 9:58 pm
Sure, but it still looks soft/heathazed for me.
Good to see it finally got in.
angad84
Tue Aug 23, 2016 7:11 am
A
I saw that -- good man!
A
JohnKrist
Head Support
Tue Aug 23, 2016 6:29 pm
Oh man I envy your spotting location!
kulverstukas
Wed Aug 24, 2016 3:52 pm
angad84 wrote:
A
A
So hope you will not be saad, man? ;)
angad84
Wed Aug 24, 2016 6:05 pm
Haha, absolutely not!
A
kulverstukas
Sat Aug 27, 2016 10:02 pm
angad84
Sat Aug 27, 2016 10:51 pm
The An-2 is a bit backlit, but the cool factor might make up for it ;)
The Il-14 is good.
kulverstukas
Sun Aug 28, 2016 2:51 pm
airkas1
Sun Aug 28, 2016 4:27 pm
Il-14: looks good to me.
An-2: dark due to backlit. Otherwise ok for me.
L-39: blurry nose and aft fuselage.
kulverstukas
Tue Aug 30, 2016 8:19 pm
airkas1
Tue Aug 30, 2016 8:37 pm
That's quite an angle of attack. Looks passable to me.
kulverstukas
Sat Sep 03, 2016 4:34 pm
As part of it is OOF I think it's no go for A.net?
airkas1
Mon Sep 05, 2016 8:31 pm
You are correct.
kulverstukas
Tue Sep 06, 2016 10:30 am
What level of tolerance then for DOF in such conditions for A.net?
airkas1
Tue Sep 06, 2016 10:45 am
Well, perhaps don't include the side of the entrance in the frame. One way to achieve that would be getting closer, although that would also involve using a wider zoom.
kulverstukas
Tue Sep 06, 2016 11:47 am
Ok, let's look into another cockpit:
or
still part of picture will be OOF because of DOF
and here we go with 12mm - still...
angad84
Tue Sep 06, 2016 6:59 pm
I've seen worse OOF issues in cockpit shots accepted here, but it's really subjective from one screener to another. What aperture were these shot at?
A
kulverstukas
Tue Sep 06, 2016 8:03 pm
An-22 @ F8
Il-76 @ F4,5
An-12 @ F8
Il-14 @ F6,3
kulverstukas
Sat Sep 10, 2016 4:38 pm
Heh, rejected for OS and empowered with blurry after appeal. And as HS see blurriness in it it's for trash can then because blurriness in contrary to softness can't be cured, right?
Rejected for dark and doesn't pass appeal too. So as i understand it's not A.net worthy as I think it can't be pushed "brighter" any more that I done already.
airkas1
Sat Sep 10, 2016 7:23 pm
Usually blurryness can't be fixed. But sometimes going to a smaller size will help 'hide' blurryness (as in it being less apparent).
kulverstukas
Sat Sep 10, 2016 8:03 pm
Problem is I can't see any blurriness in this and couple other rejected today. Soft parts - possibly. But not blurry.
airkas1
Sun Sep 11, 2016 9:41 am
I'm not on my screening computer at the moment, so I'll check back later this week to offer an opinion.
kulverstukas
Sun Sep 11, 2016 10:59 am
Thanks. BTW, what is your screening installation? I changed my old TN set of notebook + monitor (Samsung X360 13"TN 1280x800 + Samsung SyncMaster 2443NW 24"TN 1920x1200) for new IPS one (Ideapad Z710 17"IPS 1920x1080 + Dell P2416D 24"IPS 2560x1440 + Acer V203h 20"TN 1600x900) with much dense dpi/ppi. I connect Acer with it's loose ppi specially to recheck sharpness on "non-retina" screens. But judging from my constant decline of acceptance ratio, it doesn't helps :(
airkas1
Fri Sep 16, 2016 10:16 pm
My screening monitor is an iiyama Pro Lite XB2483SHU.
kulverstukas
Fri Sep 16, 2016 11:11 pm
It's exactly same dpi/ppi as my Acer V203h
