vishaljo
Pre-Screening EY A380
Mon May 02, 2016 12:51 pm
Hello!
We just received our Inaugural EY A380 @ BOM yesterday and i'd like to know if these photos are upto the mark
https://www.airliners.net/addphotos/b...1462137312.3291img_1415_edit-1.jpg
https://www.airliners.net/addphotos/b...1462172552.3959img_1417_edit-1.jpg
Cheers - Vishal
Joshu
RE: Pre-Screening EY A380
Mon May 02, 2016 3:14 pm
Sorry, it seems really dark (even for time of day) and has a touch of heat haze to it.
Washington-Baltimore Spotters Group
vishaljo
Mon May 02, 2016 3:31 pm
Thanks for the reply Joshua, are you referring to the second image or both?
Because if you see, its the jetwash which is creating the hh impression behind the engines as if you see the borders of the flap near the wing root - its clean.
[Edited 2016-05-02 08:34:40]
vikkyvik
Mon May 02, 2016 8:26 pm
Both images are too dark, I think. Both are also high in frame, and the tail at the bottom of the 2nd one is very unsightly.
The first is better with regard to HH/jetwash, but does seem soft.
airkas1
Mon May 02, 2016 10:20 pm
Quoting vikkyvik (Reply 3):
   + hazed on the wings.
yousaf465
Tue May 03, 2016 11:14 am
Tail need to be cropped.
Which camera + lens you used for this ?
yousaf465
vishaljo
Wed May 04, 2016 1:06 pm
Right, so i've removed the second one. And re-edited the first one with slightly more selective sharpening & curves.
https://www.airliners.net/addphotos/b...1462300136.2076img_1415_edit-1.jpg
Joshu
Wed May 04, 2016 1:17 pm
Not bad, seems a bit noisy to me but I am not on my screening comp right now.
vishaljo
Wed May 04, 2016 1:25 pm
Thanks Josh. I've looked at it thoroughly & given it a good NR besides the fact that its an ISO 100 image.
Do let me know when u see it on your screening pc.
Cheers - VJ
airkas1
Thu May 05, 2016 8:08 pm
Still some haze vibes on the wings, but otherwise ok.
Joshu
Thu May 05, 2016 11:05 pm
Grain is better on my screening comp, I'd give it a try.
vishaljo
Fri May 06, 2016 1:52 pm
Quoting airkas1 (Reply 9):
That's due to the jetwash of the engine as only that section has a slight effect. Thanks Kas & Joshua
Also, how is this: https://www.airliners.net/addphotos/b...1462197962.1033img_1523_edit-1.jpg ?
[Edited 2016-05-06 06:53:23]
airkas1
Fri May 06, 2016 2:05 pm
Quoting vishaljo (Reply 11):
Also, how is this:
I'm not on my screening PC at the moment, but;
- The centering is off (too much empty space on the right).
- The right wingtip is cropped off (motive).
- It looks incredibly red (I can't imagine that this monitor is the cause of that).
Even if you manage to fix all 3 issues, I'm not sure you'll end up with an acceptable (for A.net) photo.
[Edited 2016-05-06 07:06:13]
Joshu
Fri May 06, 2016 2:40 pm
Quoting airkas1 (Reply 12):
Like Kas says, the original is just not good enough to do anything with.
vishaljo
Fri May 06, 2016 3:14 pm
Alright, point taken.
How about this: https://www.airliners.net/addphotos/b...1462205100.2292img_1595-edit-1.jpg
Shot with tripod mercury level
airkas1
Fri May 06, 2016 3:24 pm
Quoting vishaljo (Reply 14):
How about this:
Not bad, but I'll have to judge later when I'm on my screening PC. Only thing I can think of now is that the hor.stab. is cropped quite closely (not sure if cut off or not).
vishaljo
Fri May 06, 2016 4:08 pm
i've cropped it right at its tip
airkas1
Fri May 06, 2016 9:30 pm
The crop on the right is too tight. Looks fine otherwise (but if you can somehow manage to make the background lights on the right less bright that would be better).
vikkyvik
Fri May 06, 2016 9:41 pm
Quoting airkas1 (Reply 17):
   Tough to tell if it's clipped or not, which basically means it's too tight.
I'd bring the brightness of the whole image down a bit. Can easily survive that, and I think it would look better.
It's also quite high in frame....
airkas1
Fri May 06, 2016 9:50 pm
Quoting vikkyvik (Reply 18):
Good point Vik, that will work as well
Centering is fine as is imho.
vikkyvik
Fri May 06, 2016 10:01 pm
Quoting airkas1 (Reply 19):
That brings us back to Len's centering thread.
To my eyes, centering the fuselage on a tall-tail airplane like a 73G or A380 looks way too high. There are certainly images with similar centering that would be rejected for hif.
vishaljo
Sun May 08, 2016 11:58 am
This was rejected for colour & centered. Screener remarks: Oversaturated
https://www.airliners.net/addphotos/r...90.431621-feb-2015_1038-edit-2.jpg
I can desaturate it if it looks unnatural coz i only did vibrance by like 5. But, its the centered rejection that puzzles me.
Its hif or lif ?
YQZ380
Sun May 08, 2016 12:16 pm
Quoting vishaljo (Reply 21):
I'd say high in frame. The C-17's tall and thin tail occupies quite a large amount of space in the upper portion of the frame, so moving the aircraft down would make it look better.
Saturation looks fine to me though.
Yang
Life is like an airliner; if you try to climb too much, you will stall.
len90
Sun May 08, 2016 4:00 pm
I think we discussed this topic pretty well last week. The centering on this picture is subjective but ultimately the tall and thin tail will make it look high in frame when to me it really isn't. Move it down a few pixels and resubmit.
Len90
airkas1
Sun May 08, 2016 7:10 pm
Its hif or lif ?
A message should be left with any centering rejection. But in this case it's safe to assume it's high in frame.
Saturation isn't too bad, but if you're going to re-edit anyway, then it could use a little less.
vikkyvik
Mon May 09, 2016 4:43 am
Its hif or lif ?
As noted, hif. Saturation isn't an issue to me.
However, the sky is almost completely blown out, and it looks soft or a little blurry, especially toward the nose. Those are bigger issues to me.
Also may want to check the leveling - looks like it could use a bit of CW to me.
vishaljo
Sat May 14, 2016 3:06 pm
Thank You for all your help gentlemen
Photo © Vishal Jolapara
Cheers - VJ
vishaljo
Tue May 24, 2016 5:00 pm
Quoting airkas1 (Reply 24):
I only lowered the a/c in LR & desaturated it a little, result: https://www.airliners.net/addphotos/r...35.170321-feb-2015_1038-edit-3.jpg
Reject reason: grainy, oversharpened, overexposed
vikkyvik
Tue May 24, 2016 5:39 pm
Quoting vishaljo (Reply 27):
Sharpening blurry areas can look like oversharpening.
Can't say I didn't warn you:
Quoting vikkyvik (Reply 25):
angad84
Wed May 25, 2016 12:57 pm
Quoting vikkyvik (Reply 28):
I'm struggling to see the blur/softness up front.
OTOH, it still looks HIF to my eye.
A
vikkyvik
Wed May 25, 2016 5:34 pm
Quoting angad84 (Reply 29):
Fair enough. I'm not on my editing computer at the moment, but I do recall thinking it looked a bit blurry.
Yeah, same here, but there are plenty of images added that are centered about the same....
airkas1
Wed May 25, 2016 7:10 pm
The nose gear looks a bit blurry and maybe it's a case of 'OS to compensate'. But only you can know that, as you can see the original. The sky is too overexposed/blown out, but the grass also looks much brighter than usual ( I think). Perhaps you can reduce the brightness a little and see what that looks like. As for grain, maybe a slight amount, but passable for me. But maybe tweak that a little as well if you're going to attempt another edit.
Quoting vikkyvik (Reply 30):
Me three. Maybe drop it down a notch more.
