redflyer
C-130: Lockheed To Widen For Army
Mon Sep 08, 2008 2:37 pm
Lockheed Martin confirms studies are under way for a new version of the C-130 featuring a wider fuselage to accommodate a proposed class of US Army ground vehicles entering service after 2015.
http://www.flightglobal.com/articles...kheed-looks-to-widen-hercules.html
Guess this puts to rest any doubts about the C-130 accommodating the Army's FCS...and it also gives competition to the A400M and those that thought it might be a shoe-in for the USAF.
ptrjong
RE: C-130: Lockheed To Widen For Army
Mon Sep 08, 2008 3:42 pm
Quoting RedFlyer (Thread starter):
Widening, rather than lengthening a fuselage is easier studied than done though...
Peter
Thorny
Mon Sep 08, 2008 4:06 pm
Aside from the Super Guppies and the like, has anyone ever widened a fuselage? Wouldn't that be an entirely new aircraft?
redflyer
Mon Sep 08, 2008 4:10 pm
Quoting Ptrjong (Reply 1):
It can be done. What it may all boil down to, though, is at what price? The only other current viable option, the A400M, is by no means a cheap bird. So the value proposition is going to be the cost of fattening the C-130 vs. the cost of acquiring a mid-sized lifter (e.g., A400M), the cost of introducing a completely new model into the USAF inventory, minus any cost-savings benefits/performance advantages it brings to flying the same mission as the C-130XWB. Not to mention the comparative operating costs of the two models over their lifespan, but I don't think that will be as big a factor (this is, after all, the USAF and not a commercial airline operation).
The article was interesting in that it mentions the following:
One is to partner the army to develop an all-new airlifter for delivery after 2021. A notional development programme called Joint Future Theatre Lift, emphasising either vertical or super-short take-off and access to austere airstrips, is in the planning stages.
Obviously, if they move forward with that program, neither the C-130XWB nor A400M would suffice. And that is what I said in the other thread on the C-17B: if/when the USAF decides to address the gap in its lift capabilities then it may just order up a spec-to-build airframe. Let the competition begin!
[Edited 2008-09-08 09:35:05]
redflyer
Mon Sep 08, 2008 4:18 pm
Quoting Thorny (Reply 2):
The KC-135 has a narrower fuselage than the production 707's that were based on it. From what I remember reading in the past, the KC-135 fuselage was going to be put into production for the passenger variant, but too many airlines balked and requested a wider fuselage, so Boeing complied. But you are correct in that the C-130XWB may ultimately be an entirely new model.
Stitch
Mon Sep 08, 2008 9:20 pm
Lockheed-Martin's congressional clout is without peer in the Military-Industrial complex. Unless Airbus planned to build the A400M in Georgia, it would be hard to fight the C-130. Even Boeing would have fun trying to get a C-17B buy over the C-130.  Smile
zanl188
Mon Sep 08, 2008 11:48 pm
Not necessarily. The narrow bit of a 130 fuselage is between the wheel wells - might be as simple as moving the wheel wells outboard of the pressure hull ala C-141 & C-17.
L-188
Tue Sep 09, 2008 2:20 am
Peter
Agreed, Unless you are talking about a Supercub wide cabin, but in that case you simply replace the whole fuselage
Well you had Boeing do it with the 367-80 to the KC-135 to the 707 and I think Donald Douglas widened the fuselage of the DC-2 to the DC-3.
bennett123
Tue Sep 09, 2008 7:03 pm
Mind you, the DC3 was unpressurised.
Tue Sep 09, 2008 9:36 pm
Quoting RedFlyer (Reply 4):
It was actually the original B717, some KC-135 parts still bear the 717 model number.
Quoting ZANL188 (Reply 6):
It is only 5" you are tanking about, forward cabin is 10'5", in the middle it goes back to 10'.
They already are, also no point in making the cabin wider, if the cargo ramp is not made wider, it is useless for airdrops otherwise.
redflyer
Tue Sep 09, 2008 10:06 pm
Quoting Zeke (Reply 9):
Glad to see you're back, Zeke. These threads have been so boring in your absence and the absence of the constant back-and-forth.
Would that not be an assumed modification? It wouldn't make a lot of sense to widen the fuselage to accommodate wider loads, only to bottleneck it at the ramp.
On another topic, I've been told by others that the load on the C-130XWB would have to go up by such a large amount in order to accommodate "Combat Ready" vehicles (not "transport ready") as to render it requiring the A400M's type engines. I don't know if I buy into that, especially since I'm not even sure the A400M is that effective for "combat ready" loads.
zanl188
Tue Sep 09, 2008 10:36 pm
C-130 main gear are well inside the mold line of the hull, moving the main gear outboard would open up considerable space. Widening the fuselage would provide additional room for the vehicles crew - which I understand from reading the thread is one of the issues the army has has with the 130...
It isn't necessarily the width of the ramp that's the problem - it's being able to get the loadmaster thru the narrow bit between the gear wells. 463L pallets loaded between the gear wells require aisleway built into the pallet for this reason. Also AAR makes custom ISUs specifically to address this problem... strangely enough C-130 pax & crew want access to the honey bucket
My own personal experience of this dimensional limitation of the C-130 was with a L-100 that had a busted exterior ramp switch. No troop doors on the L-100 so I had to crawl over the top of a couple of well cubed out pallets to reach the interior ramp switch- there was NO clearance between the pallets and the wheel wells - good thing I was skinny then...
http://www.aarcorp.com/gov/Mobility/...d/PDFs/02-06-ISU-90I-Container.pdf
Not enough info in this thread though to understand the exact dimensional requirement for the armys new vehicle....
[Edited 2008-09-09 15:38:10]
Tue Sep 09, 2008 10:47 pm
Quoting RedFlyer (Reply 10):
The C-130J-30 ( the so called C-130J Super Hercules) in my view is already at the upper limit of performance capability of that airframe, it has a maximum 2.5g payload (i.e. tactical) of 47,812 lb (providing you have the right wing relief fuel setup), but it unable to take that payload anywhere, it can only take about 45,000 lb 1,000 nm, or 40,000 lb at 2450 nm.
The A400M is has a tactical payload of 66,138 lb, and can carry that full tactical payload 2450 nm (the payload is constant to 2450 nm unlike the C-130J-30 which is constantly decreasing), 26,136 lb more than the C-130J-30.
I am comparing tactical weights here (2.5g) as you were talking about "combat ready" loads, if you were to disassemble loads and put them into the C-130, you would be looking at the logistic loads (2.25g) which are higher on both frames.
Devilfish
Wed Sep 10, 2008 2:14 am
The article also talks about the possibility of lengthening the fuselage.....
"We have teams looking at what it would take to make a [longer] fuselage," Grant says, "and then we also have the design teams looking at the emerging technologies should the requirements drive us to the new airframe."
Quoting Zeke (Reply 12):
Except that LockMart is looking at putting those loads onto a virtually new airframe - a widened and lengthened one. Then they may just ask P&W or GE to propose for the engines if RR is tied to an exclusivity contract on the A400M with Europrop..... should the AJACS initiative not materialize.
http://www.flightglobal.com/articles...air-force-hopes-for-heavylift.html
http://www.flightglobal.com/articles...ontest-to-build-cargo-x-plane.html
[Edited 2008-09-09 19:24:23]
L-188
Wed Sep 10, 2008 2:24 am
Quoting ZANL188 (Reply 11):
You know I didn't think about that, but if you did convert it so that you din't have the MLG wells in the cabin that would be good for probably a foot and half of space.
Edit:The other thought I just had was that a wider track MLG for the Herk won't hurt it's off-road capablities in the least. Also might help on the x-wind landings, A couple of Herks have come to grief dragging a wing in a x-wind landing.
[Edited 2008-09-09 19:31:41]
UH60FtRucker
Wed Sep 10, 2008 6:28 am
What about increasing the carrying capacity?
The article even mentions it: the FCS has outgrown the C-130's weight limit, so what is going to be done to solve that issue?
What I found strange, was Jim Grant's argument that Army FCS vehicles may eventually be too heavy for the A400M! ...So if it's too heavy for the A400... then how can the C-130 even compete??? He basically made an argument in favor of his competitor - Boeing's C-17B proposal!
texl1649
Wed Sep 10, 2008 1:55 pm
It's tough to believe the AN-70 is completely ruled out still.
moo
Wed Sep 10, 2008 2:04 pm
Quoting L-188 (Reply 7):
KC-135 to the 707
The KC-135 and 707 mods made sense tho right from the outset - with 803 KC-135s built, and 1,010 707s built, the two aircraft could have been completely different and still have made financial sense.
But there have only been around 200 C-130J orders placed, and a similar number for the A400M - does it make financial sense to spend the money widening it?
gsosbee
Wed Sep 10, 2008 2:26 pm
Quoting TexL1649 (Reply 16):
The Russians are showing their true stripes now, so forget anything Russian. Look at the ruckus on the tanker; can you imagine the uproar of spending US money on a Russian airplane!
ptrjong
Wed Sep 10, 2008 2:34 pm
Quoting Gsosbee (Reply 18):
Antonov is Ukranian.
redflyer
Wed Sep 10, 2008 2:39 pm
Quoting Moo (Reply 17):
There's a lot more C-130 airframes out there that will eventually need replacing. Frankly, I'm a little surprised LM isn't coming up with an all-new offering that can be a viable replacement for the existing fleets of C-130s as well as go head-to-head in all aspects with the A400M. But, then again, perhaps that is what the C-130XWB is intended to be. It may end up being an all-new design and LM may just be marketing it as a variant of the C-130 in order to make sure it continues to appeal to existing C-130 operators by implying it has the same bloodlines.
Wed Sep 10, 2008 2:48 pm
See for yourself, C-130J-30 shown, the wheels are already outside the cargo box.
Quoting DEVILFISH (Reply 13):
Rather useless exercise in my view, may as well add a new wing and engines to that.
Quoting UH60FtRucker (Reply 15):
That is true, todays Stryker has even out grown the C-130.
Depends on the vehicle, I have seen one class of vehicle that would be around 45,000 lb empty, and around 55,000 lb combat ready, also seen vehicles approaching 100,000 lb. It is not one vehicle, it is a family of vehicles that form a system.
gsosbee
Wed Sep 10, 2008 3:26 pm
Quoting Ptrjong (Reply 19):
The general public and, more importantly, the Congress would view it as a Russian since that is how Boeing and LM would portray it.
redflyer
Wed Sep 10, 2008 4:14 pm
Quoting Zeke (Reply 21):
Zeke, from your diagram it would appear that the wheels themselves are outside of the cargo box. But it also appears that the wheel wells themselves impinge on the cargo box, albeit by only a few inches on either side.
moo
Wed Sep 10, 2008 4:20 pm
Quoting RedFlyer (Reply 23):
Wed Sep 10, 2008 4:58 pm
Quoting Moo (Reply 24):
That sums it up in 1000 words, thank you. The dotted line of the sponsons is the shape on the outside of the fuselage, not inside. The solid lines indicate that they drawings indicate plan and elevation sections.
zanl188
Wed Sep 10, 2008 10:34 pm
Maybe you've never been in a C-130 cargo compartment but for those of us who have and especially those of us who have worked the aircraft it's clear the gear wells intrude on the interior fuselage space.. and are in fact the limiting factor for cargo width...
Revelation
Wed Sep 10, 2008 11:04 pm
Quoting Gsosbee (Reply 22):
Yep, just like the "French" tanker, unfortunately.
Wed Sep 10, 2008 11:13 pm
Quoting ZANL188 (Reply 26):
You mean this ...
Just to clarify, you clearly said previously "main gear are well inside the mold line of the hull", the main gear is outside the cargo compartment (the track is 14'3"), as the diagram and photo indicates.
The 10' constriction is due to a fairing around the main gear, not the main gear itself. Maybe that s what you were trying to communicate before, but you didn't.
Moving the sponsons laterally away from the fuselage center line would only gain about 2.5" either side, as the forward cabin is 10'5" wide.
Just in case you have not been in a C130 cargo compartment, this is what the cross sections look like
redflyer
Wed Sep 10, 2008 11:53 pm
Quoting Zeke (Reply 28):
Zeke, I think that is what he and I were referring to. And that is what I said in my post about the wheels themselves being outside of the fuse, but that the well itself intrudes. While you might gain only a few inches in floor width, there would be a significant gain in lateral width. No matter how you look at it, the mid-fuse is very restricted.
The other advantage to moving the wheels and well further out is that a double-bogey wheel scheme could be employed, allowing for less weight being distributed per wheel, and which would certainly benefit any potential MTOW increases with regards to performance from unimproved surfaces.
Beta
Thu Sep 11, 2008 2:33 am
Quoting RedFlyer (Reply 20):
I have a suspicion that if this LM's "proposal" ever comes to fruition, it will be an attempt by LM to backdoor in a C 130 replacement without ever going through a competitive bidding process.
MD11Engineer
Thu Sep 11, 2008 2:58 am
Not if the Ukraine attempts to join NATO and the EU, as they would like to, and Russia makes hostile moves.
Jan
scouseflyer
Fri Sep 12, 2008 9:19 am
I don't know it counts as a true widening but the Nimrod was a "double-bubble" version of the Comet with an extra lower lobe
keesje
Sat Sep 13, 2008 10:21 pm
RR was suggesting use of the engine for other appliences recently.
What about LM striking a deal with EADS. EADS is tight on slots for a long time to go. McDonnell Douglas / Boeing did it with the AV-8B before.
The new A400M seems to far ahead to be competed effectively by a beefed up C130. The TP400 has growth potential build in and the A400M could be stretched.
zanl188
Sat Sep 13, 2008 10:49 pm
If all that's needed is the 5" additional width moving the gear and yes, your "fairing" as well, outboard is the easiest way to go about it. No widening of cargo door and ramp required....
Devilfish
Sun Sep 14, 2008 5:33 pm
Did you miss this?.....
Sorry, but I think most everyone on here would see those as a given. At the least, that's what should be expected of any manufacturer worth their salt.
Quoting Keesje (Reply 33):
Well and good if RR would be able to use that engine on a competing platform. Just the same, engine proposals will likely still be solicited from other manufacturers to get best value for money in case such a program goes ahead.
I could see Northrop Grumman doing it - not a company with the capability and such a huge stake in it like Lockheed Martin - they will go it alone. Boeing may not do it either because it would undermine their C-17B or C-17C project.
It's not like the US's airlift capability would all of a sudden be seriously compromised if they did not order the A400M - they still have the largest, most capable fleet in the world, and could just as soon buy some more C-17s and C-130J-30s if they needed to. They could wait for a new design.
OTOH, EADS have a lot of customers waiting for the A400M for the longest time who now might be reconsidering their decisions, or could no longer be in a position to take delivery. The USAF would not want to be in a similar situation - they have had enough with the KC-X.
Devilfish
Wed Sep 24, 2008 1:46 am
There's a better view here of the conceptual C-130XL.....
http://www.flightglobal.com/articles...wider-larger-c-130xl-to-fight.html
With the feared one-year further delay of the A400M, this proposed Herk on steroids might be able to make progress in time for the next procurement round after the current economic storm blows over.....
http://www.defense-aerospace.com/cgi...lUKG38AAAEAAHA-goYAAAAA&modele=afp
"Airbus military transport delayed by a year: aviation body"
L-188
Wed Sep 24, 2008 4:36 am
Quoting DEVILFISH (Reply 36):
Which is going to be really damming for the Europeans if the Lockheed can get a comparable prototype flying within a couple of years when the A400 actually enters service.
Some of these European weapons/aircraft systems just take forever in development.
LifelinerOne
Wed Sep 24, 2008 9:42 am
Quoting L-188 (Reply 37):
I think you can leave the "European" part out of that sentence. Military projects tend to be late all over the world.
Cheers!  wave
gsosbee
Wed Sep 24, 2008 1:50 pm
Quoting LifelinerOne (Reply 38):
 checkmark
From current experience, you might want to leave the "Military" part out of the sentence.
columba
Wed Sep 24, 2008 2:19 pm
Big "If" as we don´t know what kind of problems LM will face and give the experience over the last few years I doubt we will see any project on time even a redesign of an existing model.
Just look how long it took for the latest versions of the Cobra and the Huey to be in service with the marines.
texl1649
Wed Sep 24, 2008 4:51 pm
The XL will have a new engine, wing, and airframe. Of course it will have new landing gear and floor to go with that.
They're playing with a simpler "double bubble" mod now in the sketches (along with, yes, cutting down on the intrusion from the gear), but that's only a a small step from a new wing, etc., since the double bubble will by necessity require a new attachment to the fuselage for the wing. If you're changing that, and the engines, then you might as well chunk the 60-year old wing also.
Air Force lifters typically have hugely over-built floors (a la C-17, which was practically built around this component), and that will be interesting to see in the new version. It would be highly unusual for this to be an afterthought.
LifelinerOne
Tue Sep 30, 2008 8:26 am
Quoting Gsosbee (Reply 39):
 checkmark
Cheers!  wave
ptrjong
Tue Sep 30, 2008 4:02 pm
Some US projects do run relatively fast, the F-22 for example. The European projects seem to take ages without exception.
keesje
Tue Sep 30, 2008 4:05 pm
Quoting Ptrjong (Reply 43):
The United States Air Force originally planned to order 750 ATFs, with production beginning in 1994; however, the 1990 Major Aircraft Review altered the plan to 648 aircraft beginning in 1996. The goal changed again in 1994, when it became 442 aircraft entering service in 2003 or 2004, but a 1997 Department of Defense report put the purchase at 339. In 2003, the Air Force said that the existing congressional cost cap limited the purchase to 277. By 2006, the Pentagon said it will buy 183 aircraft, which would save $15 billion but raise the cost of each aircraft, and this plan has been de facto approved by Congress in the form of a multi-year procurement plan, which still holds open the possibility for new orders past that point. The total cost of the program by 2006 was $62 billion.[3]
http://en.wikipedia.org/wiki/F-22_Raptor
So EIS was 10 yrs later then originally planned..
ptrjong
Tue Sep 30, 2008 5:31 pm
Quoting Keesje (Reply 44):
Thanks for correcting me on that.
Peter
keesje
Wed Oct 01, 2008 2:34 pm
Lockheed Explores Niche For Widebody C-130
http://www.aviationweek.com/aw/gener...s%20Niche%20For%20Widebody%20C-130
In between the lines you can see LM is positioning it as a niche variant of the C-130J. In the same article it becomes clear it really would be an entirely new aircraft..
Not damaging the C130J prospects, positioning it as a variant (low risk perception) and at the same time promoting new capabilities maybe requiring little modification like new fuselage, wings, engines, etc..  Big grin
