chuchoteur
2x Rafale And C135FR Deploy To Indian Ocean
Wed Apr 23, 2014 1:23 pm
http://www.fagers.fr/rafale-en-action-avec-le-2erpima/
2x Rafale from 01.091 Gascoigne squadron and a C135 FR have deployed to La Reunion island in the southern Indian Ocean. The mission maintains the operational projection capabilities of the French Air Force, the non-stop flight lasting over 10h with 5 in-flight refuelling operations.
The fighter aircraft have also conducted Forward Air Controller training with the local parachute regiment (2e RPIMA), as well as practice "show of force" passes. They will return to their airbase non-stop, departing friday.
bthebest
RE: 2x Rafale And C135FR Deploy To Indian Ocean
Wed Apr 23, 2014 2:24 pm
Impressive staminar from the Rafale pilots. Whats the advice regarding DVT etc for pilots in this situation?
Pyrex
Thu Apr 24, 2014 4:55 am
Quoting chuchoteur (Thread starter):
Wow, that is not a lot of flight autonomy. I would have imagined a modern fighter jet, particularly in ferry configuration, would have a longer autonomy than roughly 2 hours, I guess not.
Read this very carefully, I shall write this only once!
bthebest
Thu Apr 24, 2014 11:11 am
Quoting Bthebest (Reply 1):
It's actually less than that. 5 refuelling ops gives six sectors across 10h of about 1h40m each.
You're right though that the numbers don't appear to add up.
Reunion is roughly 9370km from Paris. 10h gives an average speed of 937 km/h.
Range is listed at 3700km+ on Wikipedia. That gives nearly 4h endurance. 937km/h probably isn't best cruise speed so extra fuel consumption could bring it down to 3h endurance.
However, there may be rules for diversion fuel, in case the refuelling can't be done. Another possibility is they load them light with fuel to reduce weight, and therefore improve fuel burn, topping them up frequently instead.
seahawk
Thu Apr 24, 2014 11:14 am
You must always be able to reach the next suitable diversion airfield with your current fuel state. It is not the best idea to ditch a Rafale (or any other expensive fighter) because you could not take fuel from the tanker.
[Edited 2014-04-24 04:15:38]
kc135topboom
Fri Apr 25, 2014 12:27 am
USAF fighter pilots have been doing 10-12 hour deployments for decades.
Quoting Pyrex (Reply 2):
Quoting Bthebest (Reply 3):
Quoting seahawk (Reply 4):
Correct. The tanker keeps the chicks fueled to above their divert fuel requirements, which will be different for each sector of the mission. The tanker begins refueling the chicks when they hit their divert fuel and fills them back to full tanks. Sometimes this is as little as 500 lbs. of fuel.
Pyrex
Fri Apr 25, 2014 12:24 pm
Quoting KC135TopBoom (Reply 5):
That makes perfect sense, thanks. That's the great thing about A.Net, you learn something new every day!
A bit off-topic, but do they specifically pick for these missions the pilots with the... hmmm... largest bladders? I for one would not be able to sit down in a cramped environment for 10-12 hours, probably hydrating to replenish the fluids you lost through sweating and not have to go to the bath-room. Or do they just dry-clean the flight suits afterwards?
chuchoteur
Fri Apr 25, 2014 12:50 pm
Quoting Pyrex (Reply 6):
...back in the old days, you took some pills to cater for number two cases, and for number one you either went with a nappy (as routinely used by NASA astronauts, btw) or a soft bladder... the second option involving some fairly complex manoeuvering in a tight space... *kind of takes the shine out of the whole fighter pilot thing lol!
Pyrex
Sat Apr 26, 2014 5:39 am
Quoting chuchoteur (Reply 7):
Wow... didn't even know those things existed. Did the pilots need to take some TurboLax immediately upon landing to prevent some concrete build-up on their digestive tract?
Wow, I guess it isn't as glamorous as I thought.
GDB
Sun Apr 27, 2014 7:34 pm
By any standards, that was a feat of planning, logistics, airmanship.
The Rafale is not in the same size or fuel capacity as say, a F-15E with the Fastpacs and other external fuel stores, let alone the internal fuel, so for an aircraft in the Rafale's class, a challenging deployment.
Somewhat related, here is a doc about last year's intervention in Mali, not brilliant quality but with English subtitles, it contains much previously unseen footage.
Not a wholly aviation related film, however there is much footage of French Amy chopper operations, including in combat, as well as fast air and transports, the latter featuring some pretty hairy assault landings;
https://www.youtube.com/watch?v=lAFnuVGYNcY
kc135topboom
Sun Apr 27, 2014 7:49 pm
Quoting GDB (Reply 9):
Fastpacs, etc. make like a little easier. But the Rafale should have no problem deploying anywhere, with tankers. Back in the early and mid 1960s the F-100, F-101, F-102 and F-105 all deployed to Vietnam from the 'States using KC-135s. None of those century series were designed for comfort, yet had sector legs as long as 10 hours.
knoxibus
Mon Apr 28, 2014 7:57 am
Just as an info, one of the bird happened to go tech on Friday morning when both were supposed to fly back. The other did fly back on Saturday with the KC-135.
The one tech is still there and is waiting for another KC-135 to arrive with some replacement parts so that it can be fixed and fly back. I guess the pilots are enjoying some nice beach time forced vacations.
No matter what anybody tells you, words and ideas can change the world.
Cross757
Tue Apr 29, 2014 3:34 am
Frequent inflight refueling by fighters when crossing the ocean are not usually because the plane lacks range, but to keep the tanks topped off such that if there were a problem with the tanker or the aircrafts' own in-flight refueling system (or an emergency), the aircraft has enough fuel onboard to make it to a divert base. With full internal and external tanks, I'm sure the Rafale is capable of more than 2 hours, but topping off the tanks frequently is just a precaution.
The pilots carry "piddle packs". They are essentially a heavy-duty plastic "bag" that nowadays contains a powder that when it comes into contact with liquid, it turns to a gel to prevent spills. They have a twist-tie type top that seals them after use. I carried about 4-5 of them in my G-suit pockets when crossing the ocean. Pity the guy who forgot to pack them, as could happen when wearing the "poopy-suit" anti-exposure suit when flying over cold water. Most pilots didn't wear the G-suit over top of it (it wasn't needed anyway), and stuffed their G-suit in the travel pod. Only after takeoff would they realize their mistake...oops! That was rare though. For the "other" (i.e. #2), most would either be very careful about what they ate before the flight and/or would take a few Imodium AD caplets...they do the trick nicely.
kc135topboom
Thu May 01, 2014 11:18 pm
Quoting Cross757 (Reply 12):
I never had that problem during long fighter deployments. I'd just get up and walk to the latrine, then wash my hands, go to the galley and grab a cup of coffee, and maybe heat up a meal for myself.
Cross757
Fri May 02, 2014 12:08 am
Quoting KC135TopBoom (Reply 13):
Yep, certainly a lot more comfortable!
The boomer on one of our crossings had a stack of trivial pursuit cards and the board...played on VHF
Users browsing this forum: No registered users and 17 guests
