david b.
Physic Question-can Of Compressed Air
Sat Feb 07, 2004 3:12 am
How does a metal can containing compressed high pressure gas get so cold while it is being released? Can someone explain how that happens?
Teenage-know-it-alls should be shot on sight
N6376M
RE: Physic Question-can Of Compressed Air
Sat Feb 07, 2004 3:16 am
Dusting off the old memory banks, I think the answer is found in Boyle's Law Pv=nRT
There is direct relationship between pressure (p) and temperature (t). As the pressure decreases so do the temperature, all other factors remaining constant.
See -
http://www.grc.nasa.gov/WWW/K-12/airplane/boyle.html
or
http://members.aol.com/profchm/boyle.html
SlamClick
Sat Feb 07, 2004 3:41 am
Correct on Boyle's law and the reciprocal is why compressed gases get hotter.
Aviation-related examples: The adiabatic temperature lapse rate. How an air cycle machine turns hot (from compression) bleed air into cold conditioned air (through expansion) for the cabin.
photopilot
Sat Feb 07, 2004 9:03 am
Well your partly right and partly wrong with Boyle's Law.
Remember, the can of compressed "gas" that you have and use to blow dust off your equipment is actually a chemical gas. It used to be dichlorodifloromethane which was a florocarbon, however I am not sure what the newer non FL gases are.
This gas is held in a liquid state (shake the can, the liquid sloshes) because the vapor pressure of the gas above the liquid in the can is sufficient to stop the liquid from boiling. Note that this gas boils at a very low temperature, unlike water which boils at 100C.
When you spray the can, you release the pressure above the liquified gas and it starts to boil. If you remember your physics, it takes a tremendous amount of heat to change the liquid to a gaseous state.
This heat comes from the walls of the can which is why they cool down very quickly. If you are holding the can, this heat (energy required to change the state of the liquid to a gas) also is taken from your hand.
Therefore it is not only the loss of pressure as per Boyle that reduces the temperature, but it is also the change of state that requires heat energy.
Steve
airways1
Sat Feb 07, 2004 9:11 am
Actually, Boyle's law has nothing to do with it at all.
N6376M
Sun Feb 08, 2004 4:45 am
Um not quite right photopilot. The heat that caused the change in state from liquid to gas occurs outside the can. Here's a simple way to prove it.
Invert the can and spray. What will come out is liquid and remains so for less than a second until the spray absorbs enough heat from the evironment to go into a gaseous state. The can will still cool as the pressure in it drops because of the release of the liquid. The pressure inside the can falls why it's volume stays the same PV = nRT.
Furthermore, water boils at 100C only at sea level (or more correctly at the pressure of sea level). If you go to Denver, water boils at a much lower temperature, and therefore that is why you often see "high altitude" cooking instructions on foods such as cakes.
And upon further review, Airways1 does correctly point out the PV=nRT formula is not Boyle's Law but the Ideal Gas Law- though he does do it in sort of a smug manner that reminds me of the dork in high school who always got his ass kicked.
MD11Engineer
Sun Feb 08, 2004 5:40 am
What you´ve got to deal with if you expand a gas rapidly is the Joule-Thompson effect. Due to the expansion the gas looses energy. If you have a slow expansion, heat from outside will come in and equalize the amount of temperature lost. In case of a rapid expansion the heat flow from the ambient enviroment isn´t fast enough, this is called an adiabatic expansion. The energy can only come out of the gat itself, causing it to cool down. This effect is widely used in cryogenic machines, like a refrigerator, or in liquifying gases.
Jan
777236ER
Sun Feb 08, 2004 7:43 pm
The answers above just go to show why everyone hates thermodynamics.
Users browsing this forum: BaconButty, Baidu [Spider], flipdewaf, JJJ, L410Turbolet, mad99, sabenapilot, ThePointblank and 77 guests
