Elite
IPod Nano Frozen
Fri Feb 22, 2008 8:29 am
I was charging my iPod nano by connecting it to the computer, but I went out in a rush so I unplugged it with the "DO NOT DISCONNECT" still flashing (bad idea, I know). Now my iPod is completely frozen, with the screen still illuminated and no button works. I can't turn it off or anything and plugging it in the computer does nothing. What can I do? Wait till the battery runs out?
NWA742
RE: IPod Nano Frozen
Fri Feb 22, 2008 8:34 am
Can you manually disconnect the battery and just plug it right back in?
And don't worry - Klaus has alarms next to his bed and at his place of work that will alert him anytime someone mentions "Apple" or "ixx* on this board. He should be here soon.
-NWA742
[Edited 2008-02-22 00:35:52]
Some people are like slinkies - not good for anything, but they bring a smile to your face when pushed down the stairs
Elite
Fri Feb 22, 2008 8:38 am
No, the iPod batteries are built in and you can't open the aluminum case  Sad
JeffSFO
Fri Feb 22, 2008 8:39 am
Quoting Elite (Thread starter):
Try holding down the center button and the MENU part of the scroll wheel at the same time for 10 or so seconds. It should reboot back to normal.
MYT332
Fri Feb 22, 2008 8:40 am
Try putting it next to the fire. That'll unfreeze it.
One Life, Live it.
ManuCH
Never trust a statistic you didn't fake yourself
Jetsgo
Fri Feb 22, 2008 8:41 am
Quoting Elite (Reply 2):
Actually you can, you just have to know what you're doing.  Wink
Not to be a smart ass, but next time, listen to it when it says do not disconnect.
Let the battery completely drain out, then re charge, and you'll be fine.
Marine Corps Aviation, The Last To Let You Down!
Elite
Fri Feb 22, 2008 8:48 am
Quoting JeffSFO (Reply 3):
Quoting ManuCH (Reply 5):
It worked!! Thank you both so much Big grin
bwest
Fri Feb 22, 2008 9:16 am
Ow you can...  Smile Google it  Wink
My pod freezes from time to time, I always forget the reset procedure, so I just wriggle it open, unplug and replug the battery, and let the pod reboot...
gkirk
Fri Feb 22, 2008 9:27 am
Quoting NWA742 (Reply 1):
 rotfl  rotfl
Klaus
Fri Feb 22, 2008 9:29 am
Well, obviously not!
I would just have explained the reset combination as well.
Quoting JetsGo (Reply 6):
I usually let the auto-sync of contacts and calendars go through, swap in some fresh music for the already played titles (my nano can't hold my entire library) and then I immediately eject it again. So apart from the short while after connection, it is simply charging without being locked. I can thus disconnect it at any time thereafter, even when I'm not logged in to the computer.
Klaus
Fri Feb 22, 2008 9:35 am
Quoting Bwest (Reply 8):
Wouldn't it be slightly easier to just keep a note in your wallet with the key combination if you can't remember it?
bwest
Fri Feb 22, 2008 9:41 am
Quoting Klaus (Reply 11):
Probably... but this way is more fun. I always get confused looks from people when I'm like queuing at a sandwich bar and start breaking open my pod...  Smile
Klaus
Fri Feb 22, 2008 9:55 am
Quoting Bwest (Reply 12):
Can't argue with that, of course! Big grin
Users browsing this forum: Aesma, atcsundevil, flyguy89, Newark727 and 72 guests
