rootsair
What Are The Long Straight Lines In Canada
Tue Mar 02, 2010 12:25 pm
Hi folks,
While flying over Canada, last month, more particularly the province of Quebec, I couldn't help noticing very long straight lines that have been clearly manmade across the forest. All covered in snow, you could clearly see the trees had been cut at that place.
Here you have a link to Google Maps
http://maps.google.ch/maps?f=q&sourc...072&spn=0.332771,0.885773&t=h&z=11
and you can see they are many meters wide.
Have tried to get information about these but didn't find any!
would anyone be able to tell me what these long straight lines that measure hundreds of kilometers are meant for
Regards BM
A man without the knowledge of his past history,culture and origins is like a tree without roots
czbbflier
RE: What Are The Long Straight Lines In Canada
Tue Mar 02, 2010 12:33 pm
Those are Hydro Québec's high-tension transmission lines. You will find similar lines in the forests of British Columbia.
Google Maps- High Tension Transmission Lines in BC.
They're not quite as straight as they are in Québec as BC is severely mountainous and the transmission lines generally follow the valleys....
FX772LRF
Tue Mar 02, 2010 12:38 pm
Quoting RootsAir (Thread starter):
I think they're power lines. If you zoom in more, you can clearly see smaller lines going across, all parallel. You can also see the lines crossing rivers really well, because of the color contrast.
The only thing that would make me not think that it was power lines is the fact that there are no shadows from the towers.
Just my
-Noah
Cleared to IAH via CLL 076 radial/BAZBL/RIICE3, up to 3k, 7k in 10, departure on 134.3, squawk 4676, Colgan 9581.
AirPacific747
Tue Mar 02, 2010 12:43 pm
Try placing the yellow man on a road that crosses the lines. You can clearly see that powerlines are running along the long lines without trees. So I'd say this is due to powerlines.
http://maps.google.ch/maps?f=q&sourc...ehRTCkD1GzQgw&cbp=12,74.46,,0,8.64
[Edited 2010-03-02 04:44:56]
rootsair
Tue Mar 02, 2010 1:06 pm
Thanks a lot! folks !
Its incredible to see such long wide lines run acroos like that throughout the province. Must have certainly taken lots of time to ave the trees removed from those areas!
Regards BM
Users browsing this forum: ArchGuy1, Dutchy, Ken777, Kno, LJ, lugie and 75 guests
