MrHMSH
What's the biggest airport that is either all-Boeing or all-Airbus?
Thu Jun 23, 2016 1:18 am
Being a regular at GIB, it's fairly noticeable that almost all of the flights operated into the airport are Airbus aircraft, in this case always A319s or A320s. The exceptions are the ATR72s that AT fly across to Morocco, but ignoring them for a second, it got me thinking: what's the biggest/busiest airport you can think of where all the regular flights are only from one manufacturer?
NamGunner
Re: What's the biggest airport that is either all-Boeing or all-Airbus?
Thu Jun 23, 2016 3:07 am
I'm not sure this is a valid question.
Firstly, no airport controls the type or manufacturer of aircraft that use its facilities. Either the aircraft's operating parameters align with the airport or not. i.e. You cannot schedule a 747 or 380 operations onto a dirt strip.
Secondly, even if by some wild stretch of imagination this were true today for a given airport -- tomorrow is a whole new day.
Third, even your own example has to have a caveat.
Sorry, I decline to play.
'Gunner
MaxxFlyer
Thu Jun 23, 2016 3:14 am
I agree. Some very small airports with service by one or two airlines could qualify, but it's a question that leaves any response open to debate.
bmacleod
Thu Jun 23, 2016 12:36 pm
PTY Panama seems at least 90% or so Boeing looking at this shot.
"What good are wings without the courage to fly?" - Atticus
fjhc
Thu Jun 23, 2016 1:37 pm
What's the biggest airport only served by Ryanair? I was thinking of Frankfurt Hahn, on a passenger side anyway, but I think Wizz fly there too.
hufftheweevil
Thu Jun 23, 2016 2:57 pm
I'm pretty sure the OP knows this. But most routes are operated by the same type every day, so it's not very difficult to at least discuss the topic.
But the question is for the biggest airport. So any "very small airports" are probably not the winner.
Second, isn't debate what we do???
Huff
nkops
Thu Jun 23, 2016 3:22 pm
Currently, ACY is all 319,320, and 321's.. excluding charters...
Probably not the biggest though
Turn left heading 080 contact departure
slowrambler
Thu Jun 23, 2016 3:58 pm
Much easier to come up with airports that are all-Bombardier (in the US, anyway).
slcdeltarumd11
Thu Jun 23, 2016 4:37 pm
ACY atlantic city NJ all airbus is probably the largest in number of seats?
Maybe TTN also since frontier is the only carrier
cheeken
Thu Jun 23, 2016 5:07 pm
"biggest" is relative though, and given the nature of the question, it is highly likely that a small airport is the winner....
litz
Thu Jun 23, 2016 5:10 pm
I'd say the two most obvious answers are the ones nobody's mentioned .... TLS and BFI/RNT .... ;-)
Devilfish
Thu Jun 23, 2016 6:10 pm
Technically, the ATRs are still 50% Airbus. ;)
Yflyer
Thu Jun 23, 2016 6:32 pm
DAL has got to be over 90% Boeing, given that over 90% of the flights are on Southwest. The only exceptions would be the VX Airbuses and occasional Delta Connection RJ. It will be interesting to see what happens with the VX flights once the merger with AS is complete. Will they continue to operate the flights with A320s under the Virgin brand as has been rumored? Will they phase out the Airbuses and change the flights to Alaska 737s? Will they leave DAL altogether? The latter two options would make DAL very close to being all Boeing.
Alexdk
Thu Jun 23, 2016 6:39 pm
In TLS at least AH, AT and TB use Boeings. Many more also use non-Airbuses.
steex
Thu Jun 23, 2016 6:57 pm
Neither Boeing nor Airbus, but YTZ (Toronto Billy Bishop) is a fairly busy airport and has all scheduled commercial flights operated not only by one manufacturer (Bombardier), but by one type (Q400). I believe YTZ sees something like 2.5 million pax per year.
Kilopond
Thu Jun 23, 2016 7:13 pm
And don't forget Ryanair's operations at Toulouse-Blagnac (TLS)! The other Airbus base at Hamburg-Finkenwerder (XFW) should not qualify here, since it has no scheduled flights at all. By the way, those Boeing factory airfields shouldn't qualify either.
However, you will always find an Airbus dominance at points where field performance really matters. In particular, the overpowerd A319-115 is the workhorse at highly elevated airports in the Far East. A very spectacular Airbus-only airport is Paro, Bhutan (PBH).
timz
Re: biggest airport all-Boeing or all-Airbus?
Thu Jun 23, 2016 8:00 pm
Guess you mean ACY has no scheduled Boeings, but it does have other non-Airbus scheduled airliners. Nobody can find an actual all-Boeing or all-Airbus airport?
AV8AJET
Thu Jun 23, 2016 8:20 pm
HOU, Houston Hobby is mostly 737's with Southwest
"To fly or not to fly there is no question!"
UPS757Pilot
Thu Jun 23, 2016 8:27 pm
HNL used to be mostly Boeing until Hawaiin started operating A330s.
Yflyer
Thu Jun 23, 2016 8:32 pm
Unless Wikipedia is wrong, it looks like Spirit is the only scheduled airline at ACY, and they are all Airbus. I too thought surely someone else must fly there with RJs or something (I'm 99% sure Delta Connection used to do ACY-ATL), but apparently not anymore.
It's going to be really difficult. Any airport big enough to get mainline flights is most likely going to be served by multiple airlines, which means more than likely some airlines will send Boeings there and some will send Airbuses and some will send both. Even if we consider airports that are just big enough to only have mainline flights on one airline, they'll more likely than not have regional flights on others. ACY seems to be a notable exception. And like someone already mentioned there are probably some airports in Europe that are only served by Ryanair, so that's probably the best bet for all-Boeing airports.
steex
Thu Jun 23, 2016 8:43 pm
I don't know what the largest such airport would be, but WMI (Warsaw-Modlin) comes to mind as a Ryanair-only airport.
richardw
Thu Jun 23, 2016 8:47 pm
If we say airport terminal, it makes things slightly more interesting.
timz
Re: ACY
Thu Jun 23, 2016 8:54 pm
Flightaware shows a Boston-Maine Airways Jetstream from DCA. Is it not scheduled?
Maybe not-- no mention of it on the airport websites.
EIDL
Re: ACY
Thu Jun 23, 2016 8:55 pm
Didn't Boston-Maine close down years and years ago?
timz
Re: Boston-Maine
Thu Jun 23, 2016 9:03 pm
Guess the original Boston-Maine became Northeast, didn't it? Circa 1940? No idea what the one on Flightaware is.
precure787
I seriously doubt that any major airport would be a Boeing exclusive or Airbus exclusive, but I know for sure that many airports within the European Union are Airbus dominant.
Edward Zen/Precure 787
Brokkenpiloot
Thu Jun 23, 2016 9:10 pm
GRO seems to be 737 only, at least tomorrow. It has mainly Ryanair flights, but also some Jet2 and a Transavia flight.
Yflyer
Re: Boston-Maine
Thu Jun 23, 2016 9:14 pm
That's got to be a Flightaware error. Like EIDL said Boston-Maine folded years ago. They were one several airlines to own the Pan Am brand over the years since the real Pan Am went under, and used to fly 727s and Jetstreams under the "Pan Am Clipper Connection" banner. I'm pretty sure they were the last airline in the US to use 727s on scheduled flights when they shut down in 2008. Maybe some charter outfit took their callsign and it's confusing Flightaware or something.
USAirKid
Thu Jun 23, 2016 9:21 pm
The issue with RNT is the 737s leave RNT, but never come back. (or pretty rarely come back.)
BFI has service from 5X, which brings A300s in on a regular basis.
PAE has a bunch of MRO work at the field that is non Boeing, so other manufacturers show up there too.
To make this sane, it'd probably be best to limit this to scheduled ops (121/Foreign Equivalent) for a given month, perhaps May 2016?
timz
Re: ACY
Thu Jun 23, 2016 9:28 pm
So if ACY is all-Airbus (scheduled airlines only) has anyone beat it?
konkret
Thu Jun 23, 2016 9:29 pm
WMI is 100% Boeing
mozart
Thu Jun 23, 2016 9:37 pm
Depends how one looks at the question:
1) Airports that have only Boeing or Airbus and NOTHING ELSE - i.e. not even a single commuter flight - I can't think of any major airports. Smaller airports that have only Boeing do exist: Longyearbyen/Svlabard sees only Boeing and nothing else, so does Adak Island, Tamanrasset in Algeria; LinZhi and a couple of other airports in Tibet only see Airbus, and so does Paro in Bhutan. I am sure there are other airports that only have a few flights but get served by mainline material from that country's airline
2) Airports which see Boeing but no Airbus or vice-versa, alongside some commuter planes: many more. For instance Trondheim in Norway is all 737, no Airbus
EUflyer
Thu Jun 23, 2016 9:46 pm
Is FR the only scheduled airline (passenger) into PIK ?
steex
Thu Jun 23, 2016 10:23 pm
Actually, Wizzair flies into Trondheim, and they have an all-Airbus fleet.
juantorresair08
Thu Jun 23, 2016 10:35 pm
In my opinion, it is not about the manufacturer, it is about the airlines. For example here where i live (Bogota, SKBO) the principal airlines are AVIANCA and LAN and their principal aircraft is the A320 family, therefore El Dorado intl (skbo airport) is almost all-airbus, but theres no limitations or regulations conserning what type of aircarft could operate in the apt.
If you want an all-airbus or all-boeing, you just got to look for the headquarters.
benjjk
Fri Jun 24, 2016 2:26 am
Canberra (YSCB) in Australia has about 3.5 million pax/year, 821 weekly scheduled flights, not one of them on an Airbus.
However quite a few Embraer and ATRs make up that number so it's not all Boeing.
flyingdoc787
Fri Jun 24, 2016 3:23 am
This is actually a good question, as it made me think real hard to find an airport with all commercial service on just one manufacturer's plane. Is it really possible? I suspected I could find one such airport in the Philippines, as the major airlines there operate a lot of Airbus planes and there are some fairly busy domestic airports.
After some research, I came up with Zamboanga Airport in the Southern Philippines. According to the latest figures (2012), it handled 904,000+ pax... Probably by now it handles close to 1M pax. All commercial services (Manila, Cebu, Davao, Tawi-tawI) are on Airbus jets (A320 or A319), either on Cebu Pacific or Philippine Airlines. There are around 10 flights a day in this airport.
So this is the busiest airport with all scheduled passenger services operated by the same manufacturer that I could think of. :ugeek:
qfvhoqa
Fri Jun 24, 2016 7:30 am
WMI seems to be the largest Ryanair-only airport (most others also host Wizzair). PIK is quite a bit smaller.
UKB (Kobe, Japan) has 4 airlines who all fly Boeing, had 2,532,869 pax in 2015.
SZB (Kuala Lumpur) has 2 scheduled airlines, Firefly & Malindo, and both only fly ATR 72 from there. 3,059,144 pax in 2015.
vhqpa
Fri Jun 24, 2016 7:49 am
As far as I know ASP (Alice Springs) is all Boeing
QF Sydney Daily 737-800
QF Melbourne Daily 737-800
QF Adelaide Daily 737-800
QJE Darwin 2x Daily 717-200
QJE Cairns Daily 717-200
QJE Brisbane 2x (soon 3) Weekly 717-200
QJE Yulara Daily 717-200
QJE Perth Daily 717-200
VA Darwin 3x Weekly 737-800
VA Adelaide 3x Weekly 737-800
*EDIT
It appears Airnorth have just restarted their Darwin-Katherine-Tennant Creek-Alice Springs milkrun operated 3x Weekly using an Embraer 120 so ASP no longer qualifies but until recently it did.
"There you go ladies and gentleman we're through Mach 1 the speed of sound no bumps no bangs... CONCORDE"
steex
Fri Jun 24, 2016 9:45 am
SZB (Kuala Lumpur) has 2 scheduled airlines, Firefly & Malindo, and both only fly ATR 72 from there. 3,059,144 pax in 2015.[/color]
Both good catches. I thought of SZB, but wasn't 100% sure of the fleet mix there. I completely overlooked UKB.
nkops
Re: ACY
Fri Jun 24, 2016 2:46 pm
The DCA run is an FAA chartered plane to run folks between DC and the Tech Center at ACY.. it actually leaves from the FAA ramp and does not come to terminal
PatrickZ80
Sat Jun 25, 2016 9:04 am
I was thinking of NRN (Dusseldorf-Weeze), which is also almost a Ryanair-only airport and I think NRN is bigger than WMI. Transavia does have some charter flights out of NRN, but they also use the 737 so it still qualifies.
qfvhoqa
Sun Jun 26, 2016 12:05 am
WMI handled 2,588,175 pax in 2015, NRN 1,909,704 pax (figures from Wikipedia, but linked to their source).
777Jet
Sun Jun 26, 2016 12:16 am
The Singapore Airlines Changi-Canberra-Wellington route was initially going to be operated by an A330 until SQ decided to go with the 777. So, Canberra almost got an Airbus flight!
Beatyair
Sun Jun 26, 2016 12:19 am
Chicago Midday
Houston Hobby
Dallas Love
Basically southwest airline fields
Viscount724
Sun Jun 26, 2016 1:06 am
USAirKid wrote:
Also the Airbus assembly facility at Hamburg Finkenwerder (XFW) which must be virtually 100% Airbus.
Yflyer
Sun Jun 26, 2016 1:52 am
Beatyair wrote:
Chicago Midday
Houston Hobby
Dallas Love
Don't know about the others without looking it up, but Love Field gets Airbuses from Virgin America.
PatrickZ80
Sun Jun 26, 2016 7:04 am
Beatyair wrote:
Chicago Midday
Houston Hobby
Dallas Love
Basically, but not entirely and that's what it's about. MDW has Volaris, DAL has Virgin America and HOU has JetBlue. All of them fly Airbusses into those airports.
PS it's Chicago Midway and not Chicago Midday.
Viscount724 wrote:
If you read back you'd know these don't qualify because they don't see regular airline service. They're just production facilities.
You're absolutely right, WMI has grown harder than I thought. However 2015 is the first year WMI has handled more passengers than NRN, all the years before NRN handled more passengers.
RYG is also an all Boeing airport with Ryanair and Norwegian both flying 737's out of there, but it will close in october. However it's still behind NRN in number of pax, so it's not the biggest.
mandala499
Sun Jun 26, 2016 2:38 pm
In other part of the world, Part 121 Ops, are not limited to scheduled flights, 121 ops is aircraft size...
And given that the question is:
XFW sees 2 daily flights by Germania, which in the regulations of some country counts as "regular flights" in terms of safety regulations (Part 121 or equivalent for some countries, I think US now has more than one FAR part for large aircraft ops?)...
So, if Germania sends in Airbus only to fly the Airbus corporate charter between XFW and TLS, then, XFW counts...
The question is, what is the meaning of "regular flights" in the eyes of the OP...
However, I can name not just 1 airport, but one country where all the public scheduled (ie: not charter) aircraft operations are from 1 (well, 1.5) manufacturer... that is... BHUTAN! Only Paro is operational with public scheduled flights, and the aircraft types are A319s and ATR42s...
metaldirtnskin
Tue Oct 04, 2016 10:53 pm
You'd be looking at an airport served by just one airline or, if you're lucky, two airlines that always use the same (complementary) equipment. Only five airlines at dinky little EUG, and yet we get 737, A319, MD80, DHC8, seemingly all variants of both CRJ and ERJ... and so forth.
This would have been a much easier question back when Boeing owned DHC, but that's been a number of years now. (edit: 24 years, even longer than I thought)
