AlexC
Trying to upload photo
Sat Aug 13, 2016 11:44 am
I've been trying to upload a photo of a home build, namely a Skyranger NYNJA 912S (1) manufactured by a Mr. J. Mundy seen recently at Old Warden without success. It seems that the standard entries, manufacturer, generic, etc., do not allow for this type of up-load. Any thoughts?
airkas1
Re: Trying to upload photo
Sat Aug 13, 2016 12:43 pm
Hi Alex,
Try the following steps (in the order I listed them):
- Upload photo
- Choose watermark (optional).
- "Aircraft Manufacturer Filter Enabled?" --> press "No"
- Generic Type: Tick the "new entry" box and put "Skyranger NYNJA 912S"in the field.
- Version: "Skyranger NYNJA 912S"
- Builder: "Tick the "new entry" box and put "J. Mundy" in the field.
- Airline: "Untitled"
- Input c/n and registration
- Add location info
- Add date
- Select appropriate categories
- Write a remark about the photo (optional)
- Press "Submit"
AlexC
Sun Aug 14, 2016 2:28 pm
Many thanks, I'll give it a try!
AlexC
Fri Aug 19, 2016 4:43 pm
I've had to give up, so frustrating! Tried several times. Get as far as 'Airline', but can't input 'Untitled' as the field turns grey, end of story, nightmare!
bombayduck
Fri Aug 19, 2016 5:38 pm
When you get to choose airline wait a few seconds while the list of airlines is being completed. Then scroll down until you find untitled then select untitled.
airkas1
Fri Aug 19, 2016 6:01 pm
You don't have to scroll. Just start typing and the the correct airline (in this case Untitled) will show up. Then select it.
If a field does not appear to take input, double click it. You should get the cursor then.
kulverstukas
Sun Aug 21, 2016 10:21 am
Also sometimes it's just doesn't works in IE, I use Firefox instead.
Users browsing this forum: No registered users and 4 guests
