zachary165
post screening: zachary165
Tue Aug 30, 2016 2:15 am
a few from my last set of ORD pictures were rejected today and I'd just like a second opinion on some of them
dark and vignetting: personally, I don't see any darkness on this one. There may be vignetting in the right but I'm not experienced enough to tell
dark and noisy: Again, I don't see darkness and the noise is at an acceptable level given what else I've had accepted on here
dark and overexposed:
soft: I can't really tell softness that well
JakTrax
Re: post screening: zachary165
Wed Aug 31, 2016 3:55 pm
Some very questionable rejection reasons there if you ask me. The UA is no darker than the bizjet, so I'm not sure why it wasn't thrown for dark as well; to be honest they could both stand a little more brightness. I see vignetting on the bizjet, mostly to the right, as you say. The two AAs look fine to me - they're about what I'd expect given the angles.
zachary165
Wed Aug 31, 2016 4:05 pm
also this one was rejected for banding, soft, and vignetting, none of which I see
kulverstukas
Sat Sep 03, 2016 2:56 pm
I won't discuss soft as I seems not in sync with A.net screeners here, but I don't see any banding and I do see quite prominent vignetting (top right and left side). Generally, I suggest that you must try to use some lens corrections settings in your editing software.
airkas1
Mon Sep 05, 2016 9:14 pm
C750: Looks fine, although the cheatlines seem a bit jaggy/hazed.
B738: Looks fine.
MD80: Could be a bit brighter (try adding some "fill light" in the RAW converter).
B737: Tad soft.
B755: Looks fine.
zachary165
Tue Sep 06, 2016 8:11 pm
thanks for the feedback. I put the 757 in for an appeal.
fresh off the priority add line for
Blurry
Colour (red cast)
Soft
airkas1
Tue Sep 06, 2016 10:05 pm
I agree on blurry and soft. Color looks passable.
zachary165
Tue Sep 06, 2016 11:39 pm
where is the blur?
airkas1
Wed Sep 07, 2016 6:11 am
"gle" and from the nosegear forward. The "Embraer 175" and "Operated by Envoy air" look blurry.
zachary165
Mon Sep 12, 2016 9:38 pm
How about this? it was rejected for grainy and overexposed. The aircraft is faded as is
jelpee
Fri Sep 16, 2016 2:09 am
I can see how the faded paint on the top of the fuselage may look like overexposed which is what the screener likely responded to. For a close-up, parts of the image ( "ection and the nose gear and "CRJ900") look blurry to me. It could also use some additional contrast. Lower part of the fuselage shows some noise (grain).
