TWA772LR wrote:do thermoclines exist in the air? If so, what factors come into play at what altitude it's at?
Thermoclines are the whole reason we have weather in the first place.
Air (the atmosphere) is a fluid so it can also experience a thermocline. The major thermoclines you should know are the ones for the different atmospheric layers:
Notice how temperature fluctuates with altitude increase.
Now, let's focus on the troposphere, which is where all of the weather happens. Notice how as you go up, temperature goes down. Air temperature behaves differently: cold air sinks while warm air rises. If your top layer is warm air and the bottom layer is cold air, no mixing should happen (that's why at night there's usually not a lot of weather going on...cold air remains on the ground with no rising motion while warm air remains aloft or will cool and sink). However, if you invert the scenario (warmer air near the ground and cooler air with altitude), warm air will want to rise. If you add daytime heating, you have the ingredients set for a weather event. How strong the event will be will depend on the lapse rate: the rate at which air is cooled as you go up. That also behaves as a thermocline.
So yeah...the factors that will affect it are the density of the air, the temperature, and its content (is it humid or is it dry?).
