mjoelnir wrote:I know about winglets and tankage, but are there further changes, like structural?
mjoelnir wrote:I have just seen that Air Cap had around 2006/2007 modified some A321-100 to A321-200. That were frames returned from ANA. Is that common? Are there limitations like production year? Is it a big deal or a rather simple change? I know about winglets and tankage, but are there further changes, like structural? The A321-200 seems to have a higher MTOW than the -100.
RacheyFlies wrote:mjoelnir wrote:I have just seen that Air Cap had around 2006/2007 modified some A321-100 to A321-200. That were frames returned from ANA. Is that common? Are there limitations like production year? Is it a big deal or a rather simple change? I know about winglets and tankage, but are there further changes, like structural? The A321-200 seems to have a higher MTOW than the -100.
Is it AerCap not Air Cap? I think it should be AerCap because Air Cap never been listed since then. But the engine has also changed since it was modified to -200.
mjoelnir wrote:RacheyFlies wrote:mjoelnir wrote:I have just seen that Air Cap had around 2006/2007 modified some A321-100 to A321-200. That were frames returned from ANA. Is that common? Are there limitations like production year? Is it a big deal or a rather simple change? I know about winglets and tankage, but are there further changes, like structural? The A321-200 seems to have a higher MTOW than the -100.
It is AerCap, my mistake. The engine changes from IAE V2530-A5 to IAE V2533-A5 with the conversion, but that could be a plug or a different program for the FADEC.
What was new for me, was that this is possible. I never heard about converting the A321-100 to -200.
RacheyFlies wrote:Btw, what is FADEC?
trijetsonly wrote:A321-100 and -200 have slightly different nose gears, but I don't know what exactly is different.
HAWK21M wrote:trijetsonly wrote:A321-100 and -200 have slightly different nose gears, but I don't know what exactly is different.
Only the earlier IC requested for bogie gears.
Most of the difference is internal apart from the wing fences on the -200.
Narrowbodymech wrote:An A321-200 has heavier gears to begin with. Also engines designation change could be IDG mod too.
HAWK21M wrote:Narrowbodymech wrote:An A321-200 has heavier gears to begin with. Also engines designation change could be IDG mod too.
Why the need for heavier gears....is there a load variation.
