climbing230
Making a 180 degree turn to lineup on the runway
Wed Dec 21, 2016 4:53 pm
Hello everyone. :)
Question : When an aircraft/jet backtracks on the runway it makes a 180 degree turn to line up on the center line , so my question is in order to make this turn the aircraft steers (nose wheel )either to the "left" or the 'right' side before entering into the turn sequence.What factors determine this turn either from the RIGHT HAND SIDE or the LEFT HAND SIDE? (is it the winds?)
[Hope i was able to convey my query properly in terms of the technicality]
- Thanking You
Wings take you higher
StereoTechque
Re: Making a 180 degree turn to lineup on the runway
Wed Dec 21, 2016 5:39 pm
The aircraft just follows the Centre line and the turn inside the Runway dumbell which is also marked by yellow Centre line. So there is no choice but only a single line to follow. Hope it clears your doubt..
Looking California.. Feeling Minnesota.... R. I.P. Chris Cornell...
FlyHossD
Wed Dec 21, 2016 6:13 pm
Some of the decision and technique is left to whoever is taxiing the airplane (generally, the captain). As a captain, I generally preferred to stay on the outside of the turn, so that I could better judge how close to the edge we were; others prefer to be inside the turn. The size and location of the dumbbell (which side the turn-around pavement is on) must be considered, too.
Further, some airports have restrictions - or at least recommendations - about how turns are to be made; this might include a prohibition against locked wheel turns, for example.
scbriml
Wed Dec 21, 2016 7:36 pm
Here's the threshold for runway 28 at everyone's favourite airport, SXM. As you can see, the yellow line has arrows to clearly indicate that the plane should move to the right, then turn left back onto the runway. Interestingly, you can see the old turning area before the runway was lengthened.
climbing230
Thu Dec 22, 2016 3:35 pm
Sir that was a nice picture of SXM runway., my doubdt is clear now.I did not know about the "Dumbell" marking.Now i know.
-Thanking You
Pramod
climbing230
Thu Dec 22, 2016 3:38 pm
Great.More over i just saw a video and i am a bit astonished to see the B-777 making that turn along the dumbell with the nose gear slowly steering.Sheer power.
-Thanking You :)
Pramod.
richcam427
Thu Dec 22, 2016 7:41 pm
Some smaller airports that serve only bushplanes don't have turning dumbbels, so the direction is up to the captain. Of course, you're got going to see a 747 try and make a sharp turn without one, but a Twin Otter can do it just fine.
RetiredWeasel
Thu Dec 22, 2016 8:23 pm
Actually most airports don't have turning dumbbels. If something is blocking the normal runway access taxiway at the beginning of the RW, and the aircraft has to backtaxi because it needs the entire length for takeoff, then it's up the CPT's desecration on how he makes a U-turn.
Fri Dec 23, 2016 1:29 am
In our FCOM it says if the Captain is taxiing, you should taxi on the right side of the runway, turn 20 degrees towards the left edge and then turn sharp right for the reversal. Vice-versa for FO. This assumes no dumbbell.
Say you have a dumbbell, though, and it is on the left side as you approach, meaning you'll have to enter the dumbbell and turn right for the reversal. However the FO is PF, putting him on the "wrong" side of the aircraft for this turn. the practical thing to do is turn over control to the Captain for the turn.
Florianopolis
Fri Dec 23, 2016 3:43 am
How often do FOs taxi in a typical airline operation? Many airliners don't even have tillers for the right seat...
RetiredWeasel
Fri Dec 23, 2016 4:32 am
On the 747s, even with no tiller on the FO's side, a captain occasionally would ask you to taxi it while he fiddled with something...but only when going straight. Rudder pedals provided around 7 degrees of nosewheel deflection. On the DC-10 which did have a tiller on the right, I don't recall ever taxiing it very much, if at all, during my 2 year stint as an FO on the aircraft. This was all red-tails before the merger. I don't know what if any policy they have now.
Fri Dec 23, 2016 4:50 am
At my airline all the planes have tillers on the right and the PF taxis whether it is the Captain or FO.
dfwjim1
Sun Dec 25, 2016 7:14 pm
A couple of years ago a KLM 747 went the wrong way around the dumbbell at SXM and the exhaust from the engines caused damage to buildings next to the runway.
Users browsing this forum: ltbewr, YQGflyer and 24 guests
