flyingturtle
How do you determine best glide?
Tue Dec 27, 2016 8:08 am
While binge-watching the "Mayday" series on accident investigations and in the context of certain South American pilots who revolutionized the concept of MZFW, a question cropped up:
In cases like the Gimli Glider or Air Transat 236, pilots need to find the speed with the best lift/drag ratio. How do you arrive at that number? Do manufacturers shut down all engines in test flights (except the APU) and observe the flight characteristics?
And what do pilots actually optimize when they have to glide - the maximum time of flight, or the maximum distance covered?
Thanks in advance for your insights!
David
Reading accident reports is what calms me down
Branzino
Re: How do you determine best glide?
Tue Dec 27, 2016 9:31 am
The best gliding speed is really the best Lift to Drag ratio, so it can be mathematically calculated without the need to shut down engines.
https://www.mathworks.com/help/examples ... ide_01.png
That being said, I'd also be interested in learning how L/D ratios are calculated in flight testing.
David
From my very limited personal experience, most powered pilots only have trained for gliding at maximum distance. It's glider pilots that would trouble themselves with debating distance vs. duration.
thepinkmachine
Tue Dec 27, 2016 9:35 am
Best glide speed is best lift/drag speed. It can be pretty accurately calculated by engineers and wind tunnel tests. No need to shut down engines to find it...
In modern jets it is continuously displayed to the pilots - on the Airbus it is "green dot" speed, same on the Embraer. On Boeings it is the "up" speed, i.e. minimum maneuvering speed with flaps up. Or so I believe, as I have never flown a Boeing
In all engine-out scenario you either go for windmill start speed (generally 280-300kts) if you decide to try restarting the engines. If this is not an option (e.g. out of fuel), you go for "best glide" speed for maximum distance. "Best endurance" speed would be somewhat less than "best lift/drag", but it is not displayed to pilots and not used in procedures.
"Tell my wife I am trawling Atlantis - and I still have my hands on the wheel…"
WIederling
Tue Dec 27, 2016 10:46 am
If you want to "feel for it" you'd go for least sinkrate, right?
Murphy is an optimist
thepinkmachine
Tue Dec 27, 2016 11:24 am
"Minimum sink rate speed" will be a better term than "best endurance".
I suspect flying at this speed would yield a small gain in terms of sink rate, at a cost of range and, more importantly, stall margin - as this speed will put the airplane close to the stall...
benbeny
Tue Dec 27, 2016 3:23 pm
How do you determine sacrificing altitude vs cabin pressure in terms of total engine loss?
WIederling
Tue Dec 27, 2016 3:39 pm
Reaching the required altitude ( 8000') in the required time (??) is hard prioritized.
No way around it. From there you can go for most economic glide.
thepinkmachine
Tue Dec 27, 2016 3:43 pm
You don't, at least not on the Bus. Reaching a suitable airport/landing site is of the highest priority.
In absence of bleed pressure cabin altitude will rise slowly, but it should not be a rapid decompression. The procedure calls for oxygen masks on for pilots.
As for the passengers, if the cabin altitude rises high enough, oxygen masks will drop. 15 minutes or so of pax oxy should be enough for the airplane to descend to an altitude where breathing is possible...
benbeny
Tue Dec 27, 2016 4:18 pm
I see. Nice to know how the philosophy behind any procedure. Thank you :)
OldAeroGuy
Wed Dec 28, 2016 1:55 pm
And since there is only about 20 minutes or less of flight time available wit all engines inoperative, O2 available time is hardly an issue.
flyingturtle
Wed Dec 28, 2016 6:32 pm
Ah yes, there's a mathematical function that describes the lift for a certain speed, and another one describing drag for a certain speed, and then you have the L/D ratio for any specific speed. That's one part...
...thanks for the second and less obvious part of the answer! Could you also gather data from a test flight (e.g. find best "glide" at, say, 20% N1 and 10% N1 and then interpolate from there?
David
Revelation
Wed Dec 28, 2016 9:46 pm
David
Glider pilots are very familiar with 'min sink' and 'best glide' speeds. When you're in a thermal you fly min sink speed so you maximize your time in lift. When you are in between thermals you fly best glide speed so you maximize performance to the next source of lift.
http://www.5c1.net/Glider%20Performance%20Airspeeds.htm shows how you can find them using a 'polar' and/or by in-flight experiments.
Users browsing this forum: Armadillo1, GalaxyFlyer, Google [Bot] and 35 guests
