swafa
737max tail cone redesign = greater rotation angle?
Thu Jan 26, 2017 5:04 am
After an admittedly cursory search, no info found on whether the tail cone redesign would allow for a greater rotation angle for the max-8 or max-9. Has anyone seen any information on this? From photos it looks like the angle from the mlg to the tail cone might be slightly different compared to the ng models.
richcam427
Re: 737max tail cone redesign = greater rotation angle?
Thu Jan 26, 2017 7:12 am
The 737 MAX does have a different tail cone design, but it's purely for aerodynamics and has nothing to do with necessitating a higher rotation angle or anything like that.
ODwyerPW
Mon Jan 30, 2017 4:39 am
I think the OP's question was does it allow for a greater rotation angle? When deciding on the tailcone redesign was any of Section 47 redesigned that would permit a slight increase in rotation angle? My uneducated guess says no...as the tailcone just appears to be an extension, following the same 'line' .... (sorry just don't know the term you'd use).. where as the previous tailcone came to a blunt end.. the new one continues... again following the same 'line'. I don't know... so I'm asking the same question as the OP..
learning never stops.
77west
Mon Jan 30, 2017 7:44 am
No. The point where the fuselage would hit the ground has not changed with the new cone design. So no rotation benefits..
77West - AW109S - BE90 - JS31 - B1900 - Q300 - ATR72 - DC9-30 - MD80 - B733 - A320 - B738 - A300-B4 - B773 - B77W
WIederling
Mon Jan 30, 2017 2:55 pm
Where going aft does the new structure actually start? Any idea?
Murphy is an optimist
77west
Mon Jan 30, 2017 9:32 pm
It seems to only be the bit aft of the APU access door - well above the fuselage ground strike point.
Chemist
Mon Jan 30, 2017 11:50 pm
Looks like they just need to thin out the fuselage a bit where the lower curvature starts upward.
Oh well, there goes the cargo hold!
77west
Tue Jan 31, 2017 12:33 am
Modifying the fuselage to overcome this problem would be more complex and costly than the proposed gear changes. They may even require a whole new certification process. And yes, no more cargo hold..
crimsonchin
Tue Jan 31, 2017 9:20 pm
Aesthetics wise, it certainly is better looking.
ODwyerPW
Sun Feb 05, 2017 5:08 am
77west, thank you very much for those detailed fotos. they illustrated to point perfectly.
77west
Sun Feb 05, 2017 10:26 am
No problem, glad to have helped you visualize it!
Users browsing this forum: Bing [Bot] and 14 guests
