NameOmitted wrote:FM and AM use different parts of the frequency spectrum with very different radiation properties. FM is line of site. AM shoots through obstacles. You can get a LOT further with AM than you can with FM.
timz wrote:Is that true? FM is line-of-sight and AM at the same frequency isn't?
oOfredOo wrote:Because a stronger FM signal completely supresses a weaker signal. It's called the capture effect. With AM you just receive both.
strfyr51 wrote:NameOmitted wrote:FM and AM use different parts of the frequency spectrum with very different radiation properties. FM is line of site. AM shoots through obstacles. You can get a LOT further with AM than you can with FM.
Actually? All the Navigation VORs are on the FM band and all the Non-directional Beacons are AM
