pabloeing
IB A350's with 348 seats
Mon Aug 21, 2017 9:02 am
In A350 production web page put the Iberia A350 map seat of his future 16 A350 fleet......
A350 Production‏ @A350_Production
Seat map of @Iberia A350s:
-31 Business
-24 Premium Economy
-293 Economy
Total: 348 seats
FIRST DELIVERY IN JUNE 2018
jmmadrid
Re: IB A350's with 348 seats
Mon Aug 21, 2017 9:26 am
This means 15 seats less in Business but 17 seats more in Economy/Premium Economy for a final balance of +2 seats.
Not bad as a 1:1 replacement, with a more realistic number of saleable Business seats. And on a much more efficient plane! Looks like a good decision for their finances.
behramjee
Mon Aug 21, 2017 9:51 am
This is the highest density of the A359 so far revealed. What is the seat pitch in economy class please ?
This layout is perfect for the high volume Latin America flights.
KarelXWB
Mon Aug 21, 2017 10:01 am
Nope, Air Caraïbes features 389 seats and FrenchBlue will have 411 seats.
horizon360
Mon Aug 21, 2017 10:21 am
Perhaps the highest density so far for a 'main' carrier. French Blue has 411 seats in their A359 and Air Caraibes has 389.
Oopps. Karel just beat me to it.
pabloeing
Mon Aug 21, 2017 10:24 am
The A359 cant be a A346 replacement.....IB needs another type of plane.....A350-1000 or B777-9X
Polot
Mon Aug 21, 2017 10:28 am
LATAM also has 348 seats on their A359s.
KarelXWB
And yet that's what LH and IB are doing.
pabloeing
Mon Aug 21, 2017 10:39 am
Because IB needs more seats at EZE,MEX,BOG,etc......with 3 daily flights ........a A35K in IB configuration is near 390 seats.
ro1960
Mon Aug 21, 2017 10:43 am
Must be that IB is going 9 abreast in Y and not 10 like Air Caraibes (3-4-3). French Blue has a 3-3-3 layout in Y but only two classes of service hence the higher total count.
mat66
Mon Aug 21, 2017 10:55 am
It is the highest density of any 9 abreast configuration. Assuming those 31C are in front of door 2, there are a lot of seats cramped in between door 2 and 4. The 24 PE are real premium economy of probably 3 rows of 8 taking up space of 4 rows of 9 economy. If you add these theoretical 36 to 293Y you get 329. More than Finnair's new configuration (304), LATAM (309) or Ethiopian (318) or anyone else fit in that space at 9 abreast.
I really wonder how they do it. 29"-30" pitch? Is the new aft lav/galley thing available for the A359 in 2018? Even then...very tight.
julianrv
Mon Aug 21, 2017 11:20 am
LATAM A350 is also 348 in total (30J/18Y+/300Y) but while they lack a real Premium Economy up to row 21 there's extra legroom. IB A330-200 config fits 269 in Y with 8-abreast so I think with same legroom they should be able to fit 300 with 9-abreast plus the 3 rows of Premium Economy.
BENAir01
Mon Aug 21, 2017 11:28 am
I'm sorry but I'm only seeing 2 daily flights to EZE and MEX, and only one to BOG. I don't think they need that much capacity.
jmmadrid
Mon Aug 21, 2017 11:47 am
Does any one know what will be the first route for this aircraft? If they ony get one at the beginning, it should be somewhere with a total rotation time of less than 24 hours, e.g. New York? Caracas (cough)?
mat66
Mon Aug 21, 2017 12:04 pm
The sheer number of Y in the A330-200 explains a lot, thanks. I looked at up on seatguru. Haven't checked but it must be a record on his own aft of door 2 and 8-abreast.
There isn't any economy seat really comfortable after 5-6 hours at any airline, but Iberia is to be avoided here.
Your LATAM configuration is the correct one, I was wrong there. But according to seatguru the 18Y+ are just bulkhead seats with more pitch at knee level.
MoKa777
Mon Aug 21, 2017 1:58 pm
That is a lot of seats. I also wonder how they plan to do it.
For comparison:
CX - 38J / 28W / 214Y
IB - 31J / 24W / 293Y (!) The number of Y seats alone is more than CX (or most carriers) entire seat counts!
r2rho
Mon Aug 21, 2017 2:31 pm
Wow, that is a lot of Y seats. I wonder what this will mean for Y legroom...
I was expecting a more standard config, with the A35K being the actual A346 replacement.
As expected, it looks like Premium Y is cannibalizing J. I still believe that a Y+ would have been more appropriate for IB than PY.
I agree. IB will need the A35K for a) premium-heavy routes b) the "core" LatAm routes at a minimum EZE, MEX
Polot
Mon Aug 21, 2017 2:45 pm
I wonder if the IB A350s will be getting the same (dense) J seats as BA's A350s.
Boeing778X
    IAG may get the 777-9 for BA, but the A350-1000 seems almost like a given for IB.
    A332
    A333
    A359
    A3510
    pabloeing
    Mon Aug 21, 2017 2:53 pm
    ORD would be the first......
    whywhyzee
    Mon Aug 21, 2017 3:12 pm
    Much like AC and KL on their 777's, sounds like a very efficient, high CASM layout. Most Y pax really don't care how tight it is, so may as well make it as tight as is possible. My question is, do they really need another aircraft above this? For a couple of routes, I don't see too much value, especially if messing with configurations. MAD isn't exactly a high premium hub, so having a layout that isn't commencerate with the majority of routes just makes for operational headaches if aircraft need to be swapped. Frequency is an option if 1 flight on this smaller aircraft isn't enough. Also, given average LF's are not always full, lowering the seat count slightly will improve LF's and can potentially boost yields as the supply more closely matches demand.
    Jayafe
    Mon Aug 21, 2017 3:51 pm
    IB flies Airbus-Only, forget about any B7-whatever
    rouelan
    Mon Aug 21, 2017 3:59 pm
    French Blue is also 3-4-3 (quite logic they are as dense as Air Caraïbes since they are supposed to be their low cost arm)
    ro1960
    Mon Aug 21, 2017 6:54 pm
    Thanks for the correction, I was looking at the A330 layout.
    LupineChemist
    Mon Aug 21, 2017 7:54 pm
    I don't know what the pitch is, but I think people put too much into what is just the pitch number rather than legroom.
    Seat thickness and overall form of the seat can make for more reasonable legroom with reduced pitch.
    IAHWorldflyer
    Mon Aug 21, 2017 8:10 pm
    Currently ( August 2017) IB has3 daily MEX flights ( #6400, 6402, 6408 in the direction MEX-MAD).
    cityairline
    Mon Aug 21, 2017 11:07 pm
    Regarding the high number of seats, not only IB (and LATAM as many claimed) will be configured like that. ET also has 348 seats om their A350...
    thgsr08
    Mon Oct 30, 2017 12:31 am
    Latam's A350 features 2 configs. C30Y318 and C30W63Y246.
    aemoreira1981
    Mon Oct 30, 2017 1:40 am
    And Evelop in its A359 (to be leased from Air Lease Corporation) will be Y432. (Their A330-300s are Y388.)
