boefan
Qatar A321 destroyed by fire at DOH
Sat Dec 09, 2017 11:53 am
A Qatar Airways Airbus A321 In-flight Entertainment (IFE) Satellite Antenna caught fire during maintenance, according to Qatari Authorities. "The aircraft was parked at a remote stand at Hamad International Airport. Fire inside cabin was promptly contained and extinguished."
https://www.facebook.com/RunwayNewsline ... 8992682842
The aircraft is a write off
LoganTheBogan
Re: Qatar A321 destroyed by fire at DOH
Sat Dec 09, 2017 12:23 pm
Well they have to make room for the NEOs somehow
Anyone who has never made a mistake has never tried anything new.
Siren
Sat Dec 09, 2017 12:27 pm
Is it possible to repair that sort of damage? In theory, I think it is. I remember the ET 787 that burned due to the ELT wiring fault, which was repaired. Yes, I know, carbon barrel vs aluminum, but I would expect the aluminum to be much easier than what Boeing went through. The entire fuselage barrel doesn't need to be replaced, right? It's very clear that the entire frame wasn't subjected to fire and high heat - just the crown and top surfaces. The cabin is still intact. Depending on the age of the frame, is there any chance it might be economically feasible to rebuild it?
chrisnh
Sat Dec 09, 2017 12:33 pm
Siren wrote:
Is it possible to repair that sort of damage? In theory, I think it is?
In looking at the exterior photos I’d have agreed (“it’ll buff right out!”) but that photo of the interior suggests otherwise.
andymartin
Sat Dec 09, 2017 12:34 pm
Could that have happened in the air, or was it caused by something going wrong during maintainence??
smi0006
God if I was QR management is be livid how those photos got out...
Hopefully as mentioned nothing that could happen in the air. The amount of water they used won’t help repair case either. Is this their first hull loss?
CFM565A1
Sat Dec 09, 2017 12:40 pm
Can’t know for sure yet. Here’s my experience with computers or electronics... when I used a computer it worked fine but when I tired to mod it, I cooked it! :white:
Flown: C172-M/N/P/R/S , P2006T, PA-34-200T, DH8A/C Been on: B1900D, DH8A/C ERJ-145, CRJ-100/200, DH8D, CRJ-700/705/900, E-175/190, A319/320/321, 737-200/300/400/600/700/800/900ER/M8, MD-82/83, 757-200/300, 767-300, A330-300, 787-9, 777-300ER, F28-4000.
amax1977
Sat Dec 09, 2017 12:45 pm
Someone left Samsung Note 7 onboard :duck:
Newbiepilot
Sat Dec 09, 2017 12:51 pm
Maintenance could have been doing something, but I am concerned with how much interior damage there is. The cabin materials used in seats, carpets, insulation, etc is supposed to be treated not to burn. The interior pictures show way more damage that I would have expected from a satcom antenna fire.
9VSMF
Sat Dec 09, 2017 12:52 pm
Is this A7-ADV or A7-AIB?
9VSMF
Sat Dec 09, 2017 12:55 pm
One of their A300s (A7-ABV) was also written off in a fire at AUH in 2007.
RalXWB
Sat Dec 09, 2017 1:07 pm
Destroyed by fire? The title is a bit misleading...
cathay747
With that amount of damage, it's GOT to be a write-off. Damn.
Try a Little VC-10derness
OA940
Sat Dec 09, 2017 1:10 pm
But it was destroyed by fire. What's misleading?
A350/CSeries = bae
dbo861
Sat Dec 09, 2017 1:11 pm
Well...it’s definitely never going to fly again. Sure the engines several parts are probably recoverable, but I don’t think it’s too misleading to say this aircraft was destroyed.
Sat Dec 09, 2017 1:22 pm
True. Interior destroyed by fire is more of what it looks like. The China Airlines 737 that burned out at Naha airport is more like a destroyed by fire.
Aesma
Sat Dec 09, 2017 1:23 pm
I'm sure if you wanted to repair it you could, and it might even make sense economically. However for an airline that whines about minute details, I guess they don't want an oddball aircraft in their fleet, and they'd rather write it off, reduce their tax liability and replace the aircraft by a better one.
MalevTU134
Sat Dec 09, 2017 1:29 pm
Tax liability? You do know that they are based in Qatar, right? No taxes there...
B777LRF
Sat Dec 09, 2017 1:30 pm
Hold on guys. It's a bit crispy around the edges, granted, and there's a fair bit of sheetmetal work to be done before a new IFE antenna can be fitted. But the interior is carpets, side-panels and chairs - hardly the most expensive or difficult parts to replace. Air it out for a while, stuff some Wunderbaum's behind the panels and she's good to go in a few weeks time.
PS
I do love statements along the lines of 'it's definitely never going to fly again', 'it's GOT to be a write-off' or 'the aircraft is a write off'. All made by people who've seen nothing but a couple of pictures and has absolutely zero experience assessing damage to aircraft. Yet, somehow that makes them instant experts.
Signature. You just read one.
Siren
Sat Dec 09, 2017 1:35 pm
Remember the Ethiopian 787-8 that caught fire back in 2013, due to faulty ELT wiring? The general consensus on the board was that it would never fly again. Boeing repaired it. Same thing with the BA 77E at LAS that blew its GE90 in 2015.. I'm just saying, it is a little too early to jump to conclusions regarding the frame's future.
Heavierthanair
Sat Dec 09, 2017 1:45 pm
G'day
With the front including the cockpit, the wings and the tailplane left undamaged there is enough undamaged airplane left to turn this into an A 319 :duck:
Peter
"Two things are infinite: the universe and human stupidity; and I'm not sure about the universe." (Albert Einstein, 1879 - 1955)
Tedd
Sat Dec 09, 2017 1:55 pm
I`d speculate it is repairable, & that Qatar will go ahead & do it.
scbriml
Sat Dec 09, 2017 1:56 pm
ATDB says it's A7-AIB c/n 4382.
The damage looks to be pretty substantial, with the fuselage clearly burned through. While it could likely be repaired, I'd be surprised if it's economical to do so.
The damage to the 787 was quite superficial compared to this A321. Out of interest, I flew on ET-AOP after it was repaired.
Channex757
Sat Dec 09, 2017 2:05 pm
The most helpful factor is going to be it happened at DOH so QR doesn't need to ship people and machinery to a remote location. That cuts repair costs straightaway.
Negatives are going to be procuring an out of sequence interior, although with the QR cancellations at Airbus even that could be less of an issue. The only showstopper I see is going to be electrical damage. If that's not too severe then the fact that the aircraft's tail is not on the ground means it is still intact enough for some qualified Airbus metalworkers to re-skin.
I would not write this off as the wings, engines, all landing gear, fuel tanks and cockpit are intact.
Polot
Sat Dec 09, 2017 2:07 pm
Multiple spots too, both in front and behind the wing.
KarelXWB
Sat Dec 09, 2017 2:14 pm
smi0006
Sat Dec 09, 2017 2:21 pm
If it is repairable, would QR want to? They are incredibly protective of their brand, now the photos are out of the damage they may not want it flying again and people becoming aware of this incident. Brand damage is hard to quantify.
AAEK192
Sat Dec 09, 2017 2:25 pm
I believe QR will decide to write the aircraft off just as Emirates did with A6-EMW involved on EK521 , basically due to de blockade in the Middle East..And also due to the level of destruction of the cabin and the fuselage
vhtje
Sat Dec 09, 2017 2:26 pm
I kinda agree with you - one of the problems with this forum over recent years has been the marked degradation on the quality of comment and conversation, with too many amateur 'experts' asserting 'facts' with little real industry knowledge, and a corresponding decrease in contributions from real aviation industry scions.
On the other hand that is an awfully large hole in fuselage. But is it a write off? Who knows. Certainly not me. Plenty (on this forum!) said G-VIIO/BA 2276 was a "definite write-off" and yet 'VIIO is gracing the skies, and doing sterling service flying for BA - she is currently in Cancun, I believe.
I only turn left when boarding aircraft. Well, mostly. All right, sometimes. OH OKAY - rarely.
Balerit
Sat Dec 09, 2017 2:29 pm
I would hazard a guess that this will be scrapped, it's not only the skin but also all those frames and stringers that will have to be replaced, but obviously it depends on the insurance company.
Licensed Aircraft Maintenance Engineer (retired).
scbriml
Sat Dec 09, 2017 2:37 pm
KarelXWB wrote:
Wow, that looks much worse than the earlier photos. Can't see that flying again.
You say that as though EK had a choice: :crazy:
vhtje wrote:
On the other hand there are several awfully large holes in fuselage. But is it a write off?
Fixed that for you and yes, I believe that's beyond economic repair.
neomax
Sat Dec 09, 2017 2:53 pm
I'm no expert, but I think this is a writeoff. This is not some small cockpit fire, this is the entirety of the airplane's cabin destroyed. G-VIIO was in better shape because the engines can easily be replaced and the cabin was untouched. Besides a replacement of some lower fuselage panels near the engine, G-VIIO had nowhere near enough damage to warrant a writeoff. Here, you're looking at a completely new cabin, avionics, and electronics at a MINIMUM. G-VIIO didn't need any of that, I think it's ridiculous to even compare the two.
prebennorholm
Sat Dec 09, 2017 2:59 pm
Repairable or not, that's impossible for we armchair aviators to guess.
Some people are talking about what we can see. Burned through roof, destroyed interior, panels, carpets and such. But believe me, these are the minor things.
Has the center wing box become weakened by heat exposure? What about the wing main spars where connected to the wing box?
All cabling and controls have of course been destroyed in the affected area. Hydraulic tubing has been weakened by heat.
What about the seemingly undamaged parts of the fuselage? Especially the rest of the pressurized hull. What heat has it been exposed to?
We don't know. Maybe nobody knows? What do we do with structures, which nobody knows if they have been weakened by heat? We test them. We break them to see if they were up to specs or they were too weak.
In any case, if repaired, then this will be a much more substantial job than most of us imagine. What damage we can't see on these pictures could be ten times more serious than what we see.
I am not going to guess about repair or not. Mainly because my guess would be exactly as uninteresting to read as all previous guesses on this thread.
Dutchy
Sat Dec 09, 2017 3:16 pm
Those are some nasty burn marks on her back and a mess inside.
A7-AIB is 7,4y/o. Curious to see it in the sky again, but I can see this as a write-off. Let the bean counters figure that one out.
DL757NYC
Sat Dec 09, 2017 3:20 pm
99% of the time photos come from other airport employees. I remember a plane burning slightly here in the US and the airport pd took the photos
JetBuddy
Sat Dec 09, 2017 3:23 pm
It's probably technically possible to repair it, but the question is if it's worth doing or not. There's a lot of scrap value in that aircraft. The engines, the APU, the avionics, the flight deck, the gear, the wings..
cougar15
Sat Dec 09, 2017 3:25 pm
[quote="Dutchy"]Those are some nasty burn marks on her back and a mess inside.
A7-AIB is 7,4y/o. Curious to see it in the sky again, but I can see this as a write-off. Let the bean counters figure that one out.[/quote]
yup, sadly....
some you lose, others you can´t win!
Francoflier
Sat Dec 09, 2017 3:36 pm
Of course it's a write off... the firemen ruined the carpets.
flee
Sat Dec 09, 2017 3:40 pm
Would this not be a subject for an insurance claim? If so, the insurance company would have some input on whether it is a write off or not, wouldn't it?
PatrickZ80
Sat Dec 09, 2017 3:43 pm
I agree with that. Repair would cost a lot of money, scrapping it could still get some money out of it. And at least then parts of this aircraft would fly again.
PatrickZ80
Sat Dec 09, 2017 3:44 pm
I doubt if the aircraft was insured. As far as I know, most aircraft aren't.
IPFreely
Sat Dec 09, 2017 3:48 pm
I'm not sure about it buffing right out. I was going to go with "My dad is a tv repair man, he's got this ultimate set of tools, I can fix it."
Spacepope
Sat Dec 09, 2017 4:15 pm
It's my understanding that the reality is the exact opposite. Insurance is standard, including with leased aircraft.
Siren
Yeah, this shows much more damage than the initial photos did. I'm pretty confident that the frame will be a write off, upon seeing that photo. If they were to repair (which would be theoretically possible), they would need to essentially replace half the fuselage barrel for the entire length of the fuselage. I've never heard of such a repair before...
RalXWB
Sat Dec 09, 2017 4:16 pm
Ever since they repaired that old BA 777 at LAS...everything is possible.
ikolkyo
Sat Dec 09, 2017 4:20 pm
This is a whole different beast. That’s BA 777’s damage was centered in the middle fuselage barrel section. This damage stretches across the whole frame, it’s doable but will be very expensive.
Siren
Sat Dec 09, 2017 4:26 pm
New avionics and electronics? I'm assuming the flight deck wasn't touched by this event, and the avionics bay sits beneath the flight deck.. Are we talking about new cabin electrics and IFE? That's a given. I would guess the data feeds for the CVR and FDR run through that area, plus the satellite receivers/transmitters if the plane is so equipped... what else would be required in the electronics department, that lives up in the crown of the fuselage?
lightsaber
Sat Dec 09, 2017 4:31 pm
Wow... An analysis will have to be done. Perhaps rebuild and sell... But at this point, I would suspect with today's faster depreciation, it could be a write off. But if insured, QR doesn't make the decision...
Lightsaber
Spacepope
Sat Dec 09, 2017 4:52 pm
You also can't discount water damage from extinguishing the fire, so things at the bottom of the fuselage might be affected too. Just looking at the fuselage penetrations through both skin and structure, I'm not sure we've seen an NB repaired after such substantial damage. Especially a "previous generation" one.
kmz
Sat Dec 09, 2017 5:08 pm
Makes me nervous to see how the fire spread....could that happen in flight? Flam characteristics of some part seems to be not per spec....
