Planeflyer
Re: F-35 news thread
Mon Nov 04, 2019 1:29 am
As always very informative. Much appreciated.
Ozair
Tue Nov 05, 2019 8:29 pm
The six F-35s that were with the 31st T&E squadron have moved back to the 422nd at Nellis. All the IOT&E work has been completed minus the Joint training environment work for which test aircraft are not required.
Six F-35s reassigned to 422nd Test and Evaluation Squadron
The 31st Test and Evaluation Squadron recently completed its initial operational test and evaluation mission and six F-35 Lightning IIs were reassigned to the 422nd Test and Evaluation Squadron at Nellis Air Force Base, Nevada.
“The F-35 will continue through its operational test program,” said Lt. Col. Ryan Thulin, 31st TES Commander. “We consolidated the fleets at Nellis, so they can launch operationally relevant numbers of instrumented airplanes.”
Completing IOT&E allows for the Full Rate Production (FRP) decision to be made and leads into the production and fielding of more F-35s. The six F-35s is now assigned to the 422nd TES at Nellis. Following the F-35 movement, the 31st TES will continue to work on, or provide support for other test programs, Thulin said.
https://defence-blog.com/news/six-f-35s ... adron.html
Ozair
Tue Nov 05, 2019 9:58 pm
For those interested in the air show demonstration by the F-35 team you can find the F-35A demo manoeuvres package here,
https://www.faa.gov/about/initiatives/a ... ackage.pdf
Some things I found interesting are the limits and the fuel load. The minimum fuel load the aircraft will fly with is 12,000 lbs and the standard show is flown with full fuel. Impressive flying those manoeuvres based on that fuel state.
Ozair
Tue Nov 05, 2019 10:36 pm
Well this is an interesting report. Not that I doubt that most companies are engaging in this type of operation but interesting none the less to have this clear an account of it going on with fighter jet selections.
Undercover reporter tells all after working for a Polish troll farm
The Guardian details one such campaign, which sought to influence what kind of fighter jet the Polish government spent its zloty on:
The accounts were used to undermine public support for the Polish government’s decision to place a major order with the American contractor Lockheed Martin for the F-35 fighter jet, promoting instead the Eurofighter Typhoon. […] [email protected] employees were reminded by their managers that “the F-35 is our enemy number one” but “don’t be too pushy with the Eurofighter, otherwise they will know they are being trolled”.
https://nakedsecurity.sophos.com/2019/1 ... roll-farm/
Ozair
Wed Nov 06, 2019 5:03 am
Apparently the Commander of JG74 is claiming the Eurofigher bested the F-35 in a series of WVR engagements.
#Luftwaffe Eurofighters recently went up against USAF F-35s in a visual dogfight. "They flew loads of funky manoeuvres, but I gunned them anyway." - chief JG74 at Neuberg AB. #AirbusTMB
https://twitter.com/GarethJennings3/sta ... 3324718086
As usual with these claims there is plenty of detail missing so it is hard to know what type of WVR sets they were conducting, whether starting neutral or offensive or defensive, and how the aircraft were configured. It is certainly plausible though that seasoned Eurofighter pilots will have had success against comparatively new F-35 aircrew.
JetBuddy
Wed Nov 06, 2019 12:42 pm
Royal Norwegian Air Force declares Initial Operation Capability with the first F-35 squadron.
The squadron has been deployed to Rygge Air Station and have completed 51 out of 53 planned sorties for IOC testing
In 2020, RNoAF will deploy to Iceland for the NATO Air Policing role with F-35.
From 2022 the F-35 at Evenes will completely replace the Quick Reaction Force missions currently operated by F-16 at Bodø.
Full Operational Capability will happen in 2025. At that time the Joint Strike Missile will be ready and integrated into the bomb bays.
Link in Norwegian:
https://www.tu.no/artikler/historisk-me ... are/478198
checksixx
Thu Nov 07, 2019 12:55 am
Good read. The fuel loads have been available for several years from Air Combat Command. Give this a read...it was updated recently as well.
https://www.acc.af.mil/Portals/92/Change%205%20to%202019%20Demo%20Team%20and%20HF%20Support%20Manual%20%28002%29.pdf
DigitalSea
Thu Nov 07, 2019 5:48 am
The Demo F-35 is a perfect test aircraft.
Oroka
Fri Nov 08, 2019 4:27 am
Not to mention that most people reading that headline will not know that the EF-2000 is an air superiority fighter and the F-35 is a light fighter, and that is easily a mismatched fight. Sure an experienced F-35 pilot could give a EF-2000 a run for its money, but the Typhoon was designed to be a purebred fighter and has the immediate advantage in a WVR turning fight. By that point the F-35 pilot had already screwed up by allowing a close in fight.
DigitalSea
Fri Nov 08, 2019 5:15 pm
F-35 To F-22: Can We Talk? Finally, The Answer Is Yes
WASHINGTON: Starting in December, the Air Force will try new network technology in real-world experiments every four months, the service’s new chief architect said today. The initial experiment next month will take three small but crucial steps towards the military’s goal of a comprehensive Multi-Domain Command & Control network linking all four services across all five domains, land, sea, air, space, and cyberspace:
New ways to share data between aircraft and ground forces (this one is tentative);
A cloud-based common operational picture that tracks where friendly forces are and displays a map of their constantly updated positions;
The highest-profile piece, a communications link that finally allows F-35 and F-22 stealth fighters to share data without giving away their position.
“I Iike the F-22/F-35 [experiment], because it’s a problem that everybody recognizes and everybody says, ‘oh, it’s really hard to do,” Preston Dunlap told me after discussing the effort at the Defense One conference here. ”I want to prove we actually can do hard things.”
Why is this so difficult? As stealth aircraft whose whole raison d’être is to evade detection, the F-22 and F-35 would rather not use conventional radios to communicate in combat because the transmissions are too easy for an enemy to pick up. So both jets use so-called Low Probability of Detection/Low Probability of Interception (LPD/LPI) communications – but they each use different ones that operate on different frequencies with incompatible software. F-22s use a unique Intra-Flight Data Link (IFDL) that works only with other F-22s, while the newer F-35s use the Multifunction Advanced Data Link (MADL), which can only talk to other F-35s.
Dunlap wouldn’t detail the approach his team is using to connect the two aircraft, but it involves a gadget called a “gateway” that effectively translates between IFDL and MADL. It’s also very, very nascent, he cautioned.
“It’s not 100 percent done. This is going to be like the 10 percent solution,” Dunlap told me. While he’s taking inspiration from the rapid-fire cycles known in the IT sector as DevOps (Development/Operations), the December experiment will not necessarily even be what the Silicon Valley would call “a minimum viable product.”
“Nothing will be solved in December,” he said. The goal is to get something that works well enough to test in real-world conditions and get feedback from real pilots. Then you take that data and improve your 10 percent solution to 12 percent, or 15 percent, or higher, and run the improved version through another test four months later – then rinse and repeat every four months until you get something good enough to field to actual combat forces.
“Really, December’s going to baseline the state of play and what’s available,” Dunlap told me. “Then we’ll come again in March/April with the lessons that we’ve learned out of that.”
“There’s nothing magical about four months, but the point is that we want to make sure we’re not losing the momentum going forward,” he said.
Over time, Dunlap aims to add more and more pieces to the project. His ultimate goal is to have something happening every four months in each of a half-dozen areas.
“I’ve got six product categories that we care a lot about,” he told me. “We want to be able to integrate sensors. We want to get data off of them. We want to secure the process. We want to be able to put applications [on the system] and connect capability and people together. And we want to output an effect.” (“Effect” is military jargon for anything from publishing a press release, to jamming a radar, to hacking a network, to blowing everything up).
“Across all those lines of effort, every four months we want those to be able to pull into an integrated set of exercises and operational scenarios,” he said. “Ideally, there’d be something from each of those” in each experiment.
“Some folks could say….it seems like that takes a lot of faith,” said Dunlap, a self-described “evangelist” for the new approach. “But it’s actually less faith [than a traditional 10-year procurement program], because you’re going to see faith become sight every four months.”
“You’ll to get to see the capability grow,” he told me, “and you can easily off-ramp things that aren’t working and on-ramp things that are starting to work.”
https://breakingdefense.com/2019/11/f-35-to-f-22-can-we-talk-finally-the-answer-is-yes/?_ga=2.64300527.1562643600.1572903399-652221560.1558640378
Ozair
Mon Nov 11, 2019 12:29 am
500 radars is a significant number!!! I haven’t heard of any issues with the APG-81 and we know if it capable of some very significant EA functions.
Northrop Grumman delivers 500th AN/APG-81 AESA radar for F-35
Northrop Grumman has delivered its 500th AN/APG-81 fire control radar for the F-35 Lightning II. The Northrop Grumman AN/APG-81 active electronically scanned array is the cornerstone of the F-35s advanced sensor suite, providing unparalleled battlespace situational awareness that translates into platform lethality, effectiveness and survivability.
“As a principal member of the Lockheed Martin-led F-35 industry team, our continued investment in facilities and equipment, production enhancements in process and design, and expanded supply chain capability through second sourcing helped reach this milestone,” said Chris Fitzpatrick, director, F-35 programs, Northrop Grumman. “The 500th delivery of this top-of-the-line fighter radar was made possible by our continuous focus on quality and excellence across our company.”
The AN/APG-81 radar has long-range active and passive air-to-air and air-to-ground modes that support a wide range of demanding missions. These modes are complemented by an array of stealth features as well as electronic warfare and intelligence, surveillance and reconnaissance functions.
https://www.aerotechnews.com/blog/2019/ ... -for-f-35/
Planeflyer
Mon Nov 11, 2019 6:45 am
A great product that has huge room for growth
Ozair
Wed Nov 13, 2019 8:32 pm
No surprise that the F-35 still isn’t hitting its availability targets, we have had numerous articles on this over the last few months. The key will be how it does over the next year given the investment by Lm and USDoD.
Lockheed’s stealthy F-35 breaks down too often, Pentagon says
The Pentagon’s chief weapons tester said the next-generation F-35 jet continues to fall short of full combat readiness targets and, despite some progress on reliability issues, all three versions of the fighter are breaking down “more often than planned.”
None of the Air Force, Marines and Navy variants of the Lockheed Martin fighter is meeting its five key “reliability or maintainability metrics,” Robert Behler, the Pentagon’s director of operational testing, said in prepared remarks Wednesday before two House Armed Services Committee panels.
The House subcommittees are reviewing the $428 billion program’s status and progress recovering from years of cost overruns and production delays.
“The operational suitability of the F-35 fleet remains at a level below service expectations,” Behler said in the prepared remarks. “In short, for all variants, aircraft are breaking down more often than planned and taking longer to fix.”
https://www.stripes.com/news/air-force/ ... s-1.607138
Ozair
Wed Nov 13, 2019 9:29 pm
The JPO haven’t completely removed Turkey from the supply chain yet but have gone a decent way and expect to move off Turkey for the last few components in the next year. They won’t hit the march 2020 deadline for a complete move from Turkish suppliers given the few remaining sole source or high volume parts coming from Turkey.
F-35 program on track to replace Turkey, Pentagon officials say
Since removing Turkey from the F-35 program over its purchase of a Russian air defense system, the U.S. has found alternate suppliers for all but a dozen components Turkey is producing for the stealthy fighter jet.
As U.S. President Donald Trump met with Turkish President Recep Tayyip Erdogan at the White House on Wednesday, the Pentagon’s F-35 program executive testified in Congress that he expects Turkey will be phased out on schedule, by March 2020. Lockheed and Pratt & Whitney, he said, have “spectacular progress” finding alternate suppliers.
“We began just over a year ago, very quietly but deliberately, taking actions to find alternate sources for all of those parts,” said the program executive, said Lt. Gen. Eric Fick, adding, “We are not quite there yet, so we have, on the air frame side, 11 components we have to mitigate to be at full-rate production ... and on the engines, there’s one: integrated bladed rotors, IBR’s.”
https://www.defensenews.com/congress/20 ... cials-say/
Ozair
Thu Nov 14, 2019 2:52 am
Urghhh….Things like this are really frustrating. Why can’t LM pull their finger out and realise this type of attitude doesn’t help the program nor allow it to reach the goals it needs to.
The Pentagon plan to save the F-35’s logistics system hinges on whether Lockheed will relinquish data control
The Pentagon and Lockheed Martin are at odds over how much data the military can have access to for its own jet, the F-35, and that’s creating renewed friction in the fight to fix longstanding issues with the automated logistics system vital to keeping it flying.
Both the Pentagon and Lockheed say a relaunched version of the Autonomic Logistics Information System, or ALIS, should be ready to start sending to squadrons by September 2020, both the military’s top acquisition official and the F-35 program manager expressed frustration to lawmakers at a House Armed Services subcommittee hearing Tuesday with how much control Lockheed asserts over crucial data for the system.
ALIS is an off-board system that runs the maintenance and logistics system for the F-35.
“One of the key elements of coming up with a new ALIS architecture, data standards, and all the other parts that would make a very good system is understanding the data set as it exists today — what all the algorithms are — and we are still in the process of going through that with Lockheed Martin,” said Ellen Lord, the under secretary of defense for acquisition and sustainment. “But understanding where all the intellectual property is and making sure the government has access to what it has paid for is a key part of rearchitecting ALIS.”
https://www.defensenews.com/naval/2019/ ... ta-rights/
This must be especially frustrating. I have dealt with this from vendors and it just slows down the process immensely.
“We still have concerns, there still are roadblocks as we go to execute,” Fick said. "Everything from something as simple as U.S. government documents that get uploaded into a system and come back with Lockheed Martin proprietary markings on it. That is a frustrating occurrence, but not one that prevents us from doing work.
Ozair
Thu Nov 14, 2019 9:42 pm
petertenthije wrote:
Ozair wrote:
I believe the aircraft has landed and been welcomed not with water but with foam...
Yeah, someone messed up badly.
Just prior to the F-35 landed at Leeuwarden a Volkel-based F-16 made an emergency landing at Leeuwarden due to fumes in the cockpit. I believe the runway was “foamed” for that landing. Clearly, someone forgot to switch back to water, or forgot to drain remaining foam from the hoses.
Whatever the cause might be, the poor F-35 will require a deep inspection. It will also be interesting to find out how the stealth paint holds up to highly corrosive foam.
Looks like F-009 has had no adverse effects from the foam bath on arrival.
Via Google Translate
Defense: F-35 does not seem to have had anything to do with a fire-fighting foam mistake
"The new F-35 fighter plane that was accidentally received at the end of last month with fire-fighting foam instead of water, seems to have suffered no damage. That is what the Royal Netherlands Air Force says after an inspection of the aircraft.
On October 31, the first F-35 in the Netherlands was sprayed by human error with fire-fighting foam at Leeuwarden air base. "In the fire extinguishers the buttons for foam and water are next to each other, and the fire brigade accidentally pressed the foam button," says an air force spokesperson.
It was feared that the engines of the F-35, also known as the Joint Strike Fighter, had been damaged. That is why photos were sent to the builders of the aircraft. "You can compare it to a viewing operation on the inside," says the spokesperson.
The images were then sent to engine builder Pratt & Whitney. "We have the doctors in-house, but the professors are with Pratt & Whitney," said the Air Force spokesperson. "They indicated that the foam did not cause any malfunctions."
For safety's sake, however, the engines are thoroughly rinsed again. The F-35 will remain on the ground for the time being, but that is according to plan. It is intended that the aircraft will be operational again soon.
https://amp.nos.nl/artikel/2310447-defe ... chuim.html
Ozair
Mon Nov 18, 2019 12:20 am
The RN are stepping up the testing with a four ship launched in rapid succession and recovered the same way.
Royal Navy launch four F-35 fighter jets from aircraft carrier HMS Queen Elizabeth off coast of United States
Four jets have been launched in quick succession from HMS Queen Elizabeth for the first time ever.
The four F-35 Lightning jets took off from the giant aircraft carrier off the coast of the USA.
The operation took place as part of Westlant 19 - a three-month exercise where aircraft carrier HMS Queen Elizabeth, F-35s and supporting units are being rigorously tested under realistic warfighting scenarios, while visiting Canada and the USA.
The exercise was described as "absolutely awe inspiring to watch, hear and feel."
HMS Queen Elizabeth's official Twitter account said: "We have flown our first UKF35 multi-ship, launching 4 jets in quick succession and recovering on completion of their ‘mission’.
https://www.plymouthherald.co.uk/news/p ... -f-3541254
Ozair
Mon Nov 18, 2019 2:35 am
Hill Unveils New Runway for F-35 Operations
The Air Force’s biggest F-35 operating base recently unveiled its new $45 million runway, bringing to a close a nine-month project that sent the base’s F-35s to other locations across the world.
The new 13,500-foot runway included new concrete pavement repairs, wider shoulders, a 55-foot widening to the taxiway, new overruns, improved signage, and upgraded lighting, according to a Hill release.
When the second phase of the construction project began in June, Hill sent its F-35s away to allow for the work. Twenty-four F-35s and about 250 airmen went to Mountain Home AFB, Idaho, to operate during this phase. F-35s and airmen also deployed to the Middle East to conduct combat operations out of Al Dhafra AB, United Arab Emirates.
Additionally, other F-35s and airmen deployed to Europe, with construction being a “catalyst” for this move, 421st Fighter Squadron pilot Capt. Joseph Walz told Air Force Magazine during the deployment. It was the first time since F-35s began arriving at Hill in 2015 that the base’s three squadrons had left the Utah location at the same time.
The construction project will help F-35 operations through an expected reduction in foreign object debris, Hill officials said.
http://www.airforcemag.com/Features/Pag ... tions.aspx
DigitalSea
Mon Nov 18, 2019 9:39 pm
Ozair, you're pretty knowledgeable on the F-35 program, does the US have a system in place to keep track of foreign F-35s or atleast access to their ALIS system? Thinking of terms of safeguarding it from espionage. Some of the countries we are selling the F-35 to, makes me feel as if the US may have rolled the dice in exchange for helping drive down the costs.
Ozair
Mon Nov 18, 2019 10:57 pm
DigitalSea wrote:
Ozair, you're pretty knowledgeable on the F-35 program, does the US have a system in place to keep track of foreign F-35s or at least access to their ALIS system? Thinking of terms of safeguarding it from espionage. Some of the countries we are selling the F-35 to, makes me feel as if the US may have rolled the dice in exchange for helping drive down the costs.
So ALIS in its original form transferred info that included geolocation data but the program issued a contract that modified that.
But some partners on the F-35 program worried that data flowing through ALIS to the United States — and to Lockheed Martin — could give both the U.S. military and the American defense contractor a window into that country’s flight operations, including when and where its F-35s are flying.
Although several foreign F-35 customers have publicly discussed concerns about sovereign data moving through ALIS, this report marks the first time it has been disclosed that those concerns were so severe that multiple countries threatened to withdraw from the program.
“[Two-plus] countries have threatened that, if sovereign data is not addressed, they will either (a) pull out of the F-35 program of (b) stop sending any data to the U.S.,” one document states.
https://www.defensenews.com/smr/hidden- ... hey-didnt/
From the same article further down, the solution was contracted and delivered earlier this year.
On Aug. 17, 2018, the Defense Department awarded a $26 million contract to Lockheed Martin to develop and test an “ALIS Sovereign Data Management” system that will allow foreign partners to more tightly control and protect their own data.
That effort has borne fruit, and certain partner nations have begun using the new data guard, which rolled out earlier this year, Winter said.
“Sovereign data management has been fielded to those that have aircraft. Norway has it. Israel has it. U.K. has it. Italy has it. We’re rolling it out to the Asia-Pacific here, now,” Winter said.
So now the partner nations have a better ability to control or restrict the data that is sent regarding F-35 operations though ALIS. As an aside I believe the US Government may have some say in the movement of aircraft, or at least that nations are required to inform the US when they move aircraft around their country, on a permanent basis.
From a cyber perspective ALIS has been tested and certified for use. It apparently runs on a separate VPN which, I assume, has sufficient safeguards. The aircraft can operate for an extended period of time without ALIS input/output or can operate to a deployed ALIS node which several nations and the USMC/USN have begun deploying.
Ozair
Thu Nov 21, 2019 8:39 pm
Quite the thermometer malfunction when you plan to test to -40 and actually end up at -65… Good that the kit still worked at that much lower temperature.
Airmen in Subzero Temps Discover F-35 Survival Kit Works Better Than Advertised
A survival kit designed to keep F-35 pilots alive in freezing conditions has proven its worth all the way down to -65 degree Fahrenheit. The new kit, designed by the airmen that will fly with it under their seats, is designed to be smaller than previous kits while protecting pilots from the elements until rescue.
The F-35 Joint Strike Fighter differs from older jets in one peculiar way: the space under the ejection seat is a third smaller than the same space in the F-16 Fighting Falcon. Unfortunately, that’s where the pilot survival kit goes. The pilots of the 356th Fighter Squadron will receive their F-35s in 2020, operating them out of Eielson Air Force Base in Alaska, so squadron personnel created a new kit using new materials designed to keep pilots alive in the Arctic cold.
The test to ensure the kit’s contents worked as planned took place at the International Artic Research Center at the University of Alaska Fairbanks. There, according to the website Stars and Stripes, airmen were placed in two different rooms, one dropping to -20 degrees and the other to -40 degrees. An undetected thermometer malfunction inadvertently exposed the airman in the latter room to -65 degrees, but those inside reported the system still worked as planned.
https://www.popularmechanics.com/milita ... vival-kit/
Ozair
Thu Nov 21, 2019 9:05 pm
Good news for Raytheon with respect to export potential for the JSOW but also interesting to see how quick and easy the integration work is to bring the weapon over from the F-35C to the F-35A.
Raytheon Joint Standoff Weapon to be certificated for F-35A
The AGM-154 JSOW precision-strike glide bomb is to be certificated for the internal weapons bay of the US Air Force's F-35A Lighting II stealth fighter by the end of November 2019.
The weapon's manufacturer, Raytheon, says the approval would allow it to sell the standoff weapon to international operators of the F-35A. The conventional take-off and landing F-35A is the most popular variant of the type with international customers.
The US Navy has already qualified the JSOW on its F-35C variant and now the USAF is to use that testing data to integrate the weapon onto its aircraft, says Mark Borup, senior manager of business development for Raytheon Missile Systems’ air warfare systems.
“It is going to be fully integrated on the F-35-A and the importance of that is that the USA has a number of friends and allies who have the F-35A,” he says. “It's very significant. It's a capability that many of our friends and allies really, really advocate for.”
The JSOW can be carried externally on the Boeing F-15, Boeing F/A-18E/F and Lockheed Martin F-16. However, because of its 70nm (130km) glide range and its low radar-cross section, it could also be used by the F-35 stealth fighter on penetrating air strikes.
The glide bomb is GPS guided and can follow a waypoint path to its target. The latest variant of the weapon, the JSOW-C Block III, can be guided in its terminal phase by an infrared seeker and has a tandem warhead, among other improvements.
https://www.flightglobal.com/news/artic ... ic-462320/
For anyone interested these are some of the JSOW variants (I think the sub-munition version is missing) with a powered version reportedly in development. The current operators of the JSOW match well with existing and expected F-35 operators.
GDB
Mon Nov 25, 2019 4:26 pm
To mark the end of the initial test/deployment of UK F-35B's on Queen Elizabeth, the RN have made this excellently produced video, with recruitment in mind too;
https://www.youtube.com/watch?v=wXmnnFcGVSE
Ozair
Thu Nov 28, 2019 8:14 pm
No surprise that Italy continues to invest in the F-35 program. Despite the rhetoric of a couple of years ago they have been consistent in their funding.
Italy Approves Second Phase of F-35 Investment Program: Minister
Italy will press ahead with an investment program for F-35 fighter jets, Defence Minister Lorenzo Guerini said, after uncertainty over further orders from the Rome government had raised questions on production plans.
"As the government aims to build on the investments made so far and seize the opportunities offered by the program, I've decide to give a green light to the phase two," Guerini said during a parliamentary hearing on Thursday.
Luigi Di Maio, leader of the co-ruling 5-Star Movement, said last year that F-35 fighter jets were not a priority for the country and that the program had to be reviewed in 2019.
https://www.nytimes.com/reuters/2019/11 ... e-f35.html
Ozair
Thu Nov 28, 2019 8:16 pm
This looks like it would have bene quite the amusing exercise. They certainly haven’t gone overboard on the size of the inflatable that the aircrew will use post an ejection over water.
Royal Navy and RAF train Norwegian Air Force F-35 pilots
The Royal Navy and RAF have answered a call from Norway to help train F-35 Lightning jet pilots.
The team of survival specialists from the Royal Navy, alongside AF personnel from RAF Marham in Norfolk, travelled to Orland Air Base in Norway to join their NATO partner for a training package.
A Royal Navy spokesperson said: "The Norwegian Air Force called on the UK after visiting the Lightning Force at Marham for training aircrew on how to survive if their aircraft was downed.
"Marham’s Survival, Evasion, Resistance and Escape team, which comprised PO Matthew Williams, Cpl Richard Fuller, AB Brendan Baldwin, SAC Allan Wighton and SAC Susan Whyte, trained 24 pilots during their time at the base north of Trondheim.
"The training consisted of a simulated brief on parachuting from the F-35, moving on to a dry training brief. This included elements of the equipment used to save their lives if they were to eject from the aircraft."
https://www.plymouthherald.co.uk/news/u ... an-3587450
Ozair
Thu Nov 28, 2019 10:00 pm
This article is a few weeks old now but some interesting comments at the end on the prevention of corrosion from operating in a heavy salt environment at RAAF Base Williamtown. In general you get a feel for what it takes to induct a new aircraft, especially in the context that the last aircraft inducted by 3SQN was the Legacy Hornet over 30 years ago.
Royal Australian Air Force personnel discuss working with the F-35A aircraft at Williamtown
Royal Australian Air Force staff gave a rare insight into the Williamtown-based F-35A aircraft at a Hunter Defence Support Network event at Merewether on Friday.
Three members of the RAAF's No. 3 Squadron - Wing Commander Darren Clare, Squadron Leader Leigh Tinker and Flight Sergeant Damian Gardiner - answered questions from the luncheon's audience about working with the F-35A.
The first of Australia's F-35A joint strike fighters arrived at RAAF Base Williamtown in December. Australia has committed to 72 of the long-awaited and controversial fighters for three operational squadrons at Williamtown and Tindal.
No.3 Squadron has been testing the aircraft in the US for several years and now has six F-35As at Williamtown.
Wing Commander Darren Clare said flying the jet was like "riding on a roller-coaster but you're in control".
"The speed, the Gs; if you think about the G-forces thrown around, we pull up to nine Gs in the aeroplane.
"Race car drivers pull four to five when they're driving.
"Physically, when we pull a lot of Gs, it is quite demanding on our body."
Commander Clare discussed the technological advances, describing the F-35A as "like a computer pretending to be an aeroplane".
"I physically log into the aeroplane with a username and a password," he said.
Flight Sergeant Damian Gardiner said the F-35A was more software-driven than past electro-mechanical jets.
"From an avionics background, I've adapted OK to it, we're still educating our workforce," he said. "We're bringing people up to speed with application-based stuff."
Squadron Leader Leigh Tinker said the introduction of the aircraft had led to a more diverse workforce.
"We're trying to be different," he said.
"We're trying to encourage the workforce to be more diverse. If you're an avionics person, let's not just do avionics, let's do everything."
Asked about the jet's corrosion issues, Tinker said learning how to manage the aircraft at Williamtown had been a challenge this year.
"The Williamtown environment has been the biggest learning curve we've got at the moment," he said. "Not that we're the only country that operates near the beach.
"We've got a wash cycle. So at two weeks we will do a wash with chemicals, like a detergent, and then we'll rinse it off the other second week just to get the salt off it."
Officials of F-35A manufacturer Lockheed Martin also spoke at the event, along with Newcastle Business School's Julia Connell.
Hunter Defence Support Network supports Defence families in the region. The organisation raises funds for PTSD-related initiatives.
https://www.newcastleherald.com.au/stor ... -aircraft/
Ozair
Mon Dec 02, 2019 8:34 pm
France complaining about the penetration of the F-35 into Air Forces across Europe. I don’t see how France can claim European Air Forces should invest in something different given the capability difference between the F-35 and its primary competitors.
France Blasts US for Trying to Force Its NATO Allies Into Purchasing American Arms
France’s defense chief has blasted the US for trying to force its NATO allies into purchasing American arms and equipment above anything else, days after President Emmanuel Macron held Washington to blame for the Western military bloc’s “brain death.”
In remarks to French weekly newspaper Le Journal du Dimanche published on Sunday, Florence Parly renewed her criticism of US attempts to force the Lockheed-Martin F-35 fighter jet — the most advanced and expensive aircraft in America’s arsenal — on its NATO partners.
The defense minister said the NATO charter includes Article 5 — which obliges member states to defend each other — rather than “Article F-35,” under which members would be required to buy US military products.
https://www.albawaba.com/news/france-bl ... ms-1324681
Ozair
Mon Dec 02, 2019 8:57 pm
An acknowledged puff piece as the writer went on a paid by LM visit to the Fort Worth factory. I did find the below interesting and demonstrates how ease of maintenance has been factored into the F-35 design.
F-35 Lightning II: A 21st century concept
The lessons learned went beyond simply enhancing aircraft performance; the F-35 ameliorates fundamental life cycle cost issues through leveraging emerging technologies and leading-edge concepts to maximize readiness, logistic and maintenance efficiencies. In effect, the F-35 is built for sustainment.
The fighter aircraft makes use of a modular avionics architecture with fusion technology, rather than a federated architecture where Line Replaceable Units (LRU or “black boxes”) are placed in a sequence. In this manner, maintainers no longer need to remove the first and second boxes to replace the third; they simply replace an easily accessible modular LRU.
Roughly 95 per cent of the LRUs are first line removeable and virtually all first line maintenance functions are accessible through the weapons bay doors, nose wheel well, and behind panels that can be opened and closed without causing any low observable skin repairs. Ease of maintenance is further achieved from simple redesigns such as a front-hinged canopy that facilitates ejection seat removal without the need to remove the canopy.
At a reported six hours of maintenance per flight hour, the F-35A is at the forefront of fighter operations. Conscious design features such as internal weapons carriage and the use of pneumatic (air pressure) weapons ejection rather than explosive cartridges has significantly reduced maintenance personnel hours required to clean and service fourth generation weapons delivery systems.
Another example of manpower savings occurs in routine checks on the fuel tanks and valves, where only one F-35 technician with a Portable Maintenance Aide (a laptop computer the technician connects to the F-35) is now required to conduct the same task that requires six maintainers to perform on the F-16. In manpower savings alone, anecdotal evidence suggests a 60 per cent reduction in personnel to perform routine maintenance functions.
https://www.skiesmag.com/news/f-35-ligh ... y-concept/
Ozair
Wed Dec 04, 2019 8:59 pm
This will certainly improve training opportunities. It has been stated numerous times now that to really test F-35 aircraft they need very high threat simulations (thing that cannot be replicated in real world exercises) and being able to connect multiple together and therefore fly and fight advanced threats should improve overall capability.
Coming in 2020: A new technology to link F-35 simulators across the globe
Next year, U.S. Air Force F-35 pilots will be able to hop into a simulator and practice large-scale coordinated attacks with other F-35A users in simulators around the globe, Lockheed Martin’s head of F-35 training said Tuesday.
The capability, called Distributed Mission Training, will allow an unlimited number of F-35 simulators to be networked, enabling high-end training, said Chauncey McIntosh, Lockheed’s vice president for F-35 training and logistics.
“We’ve been testing to ensure that it’s ready to go with our first customer at Nellis Air Force Base [in Nevada]. We’ve got hardware that’s going up there this month and we’re starting our test connections, and everything is looking very well [regarding] this product,” he said during a briefing at the Interservice/Industry, Training, Simulation and Education Conference.
https://www.defensenews.com/digital-sho ... the-globe/
Ozair
Wed Dec 04, 2019 10:02 pm
Leaked photo: General Atomics offers possible Japenese helicopter destroyer conversion into aircraft carrier
Pictures of a possible Japanese helicopter destroyer JS Izumo conversion into a full-fledged aircraft carrier have appeared on social media.
Japan has grand ambitions to upgrade one of its largest warship, the so-called helicopter destroyer JS Izumo, into a full-fledged aircraft carrier capable of launching the F-35C fighter jets and E-2 all-weather airborne early warning aircraft.
According to a leaked powerpoint slide, U.S defense and diversified technologies company General Atomics offering the concept of conversion the Japan Maritime Self-Defense Force (JMSDF) helicopter destroyer JS Izumo into an aircraft carrier with the capability to launch and recover the full spectrum of carrier-capable aircraft.
https://defence-blog.com/news/leaked-ph ... rrier.html
There are some obvious issues with the proposal like the presence of F-35C aircraft parked along the bow that would prevent both CATS being used. Clearly Izumo is a small vessel and it would require a careful balancing act to be able to conduct continuous flight ops with the CAT positions along the middle of the landing deck. The other issues are the greater training burden, both for aircrew and deck crew for CATOBAR instead of STOVL, the much greater conversion costs to go from the current vessel to a CATOBAR carrier and some political considerations with the increased capability a CATOBAR carrier may provide.
EMALS does provide other benefits though, including the use of E-2Ds for long range radar warning and potential new UCAVs such as the MQ-25 for long range A2A refuelling and the likely strike version that will come from it.
The other interesting possibility is how this may impact US future carrier designs. While we will get at least a few Ford class CVNs how would a modified USS America class with EMALs impact future operations. It could conceivably carry a similar load of F-35Cs to current Bs but expand the capability with E-2Ds and MQ-25s as well while being a lot cheaper to build and sustain. Perhaps even a nuclear powered America sized vessel…
Interesting times ahead for small carrier design.
Ozair
Wed Dec 04, 2019 11:21 pm
The LM head of the F-35 appeared before Congress on the 13th of November and had a fair bit to say. The most interesting part though I think is contained below and covers the modernization efforts.
The big points that stuck out to me are the reference to unmanned testing, the missile defence work and technology roadmap to equip the F-35 will a new or modified interceptor that can conduct missile defence work, direct statement regarding the work with Elbit on a 600 gallon external drop tank with associated jettison-able pylon and finally the increased lethality work that involves increasing internal carriage, the use of hypersonics weapons on the inboard stations, increased payload weight and total missile number.
STATEMENT OF GREGORY ULMER VICE PRESIDENT AND GENERAL MANAGER F-35 PROGRAM LOCKHEED MARTIN CORPORATION
BEFORE THE READINESS AND TACTICAL AIR & LAND FORCES SUBCOMMITTEES HOUSE ARMED SERVICES COMMITTEE ON F-35 PROGRAM UPDATE: SUSTAINMENT, PRODUCTION AND AFFORDABILITY CHALLENGES
IV. Modernization Update
The F-35 is designed to incorporate both software and hardware upgrades throughout its 50+ year life cycle and efforts to modernize the aircraft are already underway. We’ll deliver F-35 modernization through the Department’s Continuous Capability, Development and Delivery (C2D2) framework for timely, affordable, incremental warfighting capability improvements. This approach will deliver more agile, continuous modernization on shorter timelines while aligning and synchronizing capability delivery across the entire F-35 Air System.
In order to maximize the investment in the F-35 fleet, it’s imperative that Congress continues to fund the F-35 modernization plan to leverage the full potential of the weapon system. Additionally, it’s important to note that many of the partner countries have made investments in modernization activities as part of their national defense policies and have established the industrial base to support these activities.
From Electronic Warfare, increased computing power, sensor capability, weapons capacity and more, we are actively enhancing all aspects of the F-35 to ensure it exceeds warfighter demands and outpaces evolving threats. Some key upgrades planned include:
• Automatic Ground Collision Avoidance System (AutoGCAS): AutoGCAS uses terrain mapping, geolocation and automation to detect and avoid potential ground collisions. When the program recognizes imminent impact, it will prompt the pilot to take action. If the pilot is unresponsive, AutoGCAS assumes temporary control to divert the aircraft out of harm’s way, and then returns control of the aircraft to the pilot once on a safe trajectory. Leveraging a rapid, agile development, test and contracting approach, the joint government and industry team successfully fielded the life-saving technology seven years earlier than previously planned.
• Technology Refresh 3 Upgrades: Technology Refresh 3 takes advantage of fast evolving computing power and adds an Open Systems Architecture that will enable the flexibility for Lockheed Martin and our customers to add, upgrade and update future capabilities rapidly. In addition to the Next Generation Distributed Aperture System discussed previously, the F-35’s Integrated Core Processor, Panoramic Cockpit Display and the Aircraft Memory System will all be upgraded beginning in Lot 15.
• Multi-Domain Operations (MDO): To increase the F-35’s role in MDO, we’re upgrading sensor fusion capability in Lot 13 and beyond, integrating enhanced voice and data interoperability in Lot 14 and continuing to conduct exercises to demonstrate MDO teaming. To date, the F-35 has successfully integrated with the Aegis Missile Defense system, a High Mobility Artillery Rocket System, or HIMARS, the Integrated Air and Missile Defense Battle Command System (IBCS), and most recently in partnership with the Missile Defense Agency and U.S. Air Force, we successfully connected an F-35, U2, and a multi-domain ground station. The advantages of the F-35 integrated and fused sensor suite now can be made available to other airborne, air, and even subsurface warfighters. We are active now in sharing the key benefits of our 5th Generation air system with other multi-domain parts of operations.
• Unmanned Teaming: The F-35 is ideally suited for manned / unmanned teaming operations, and we are working closely with our customers to realize a future where the F-35 can command and control unmanned aerial vehicles as wingmen as well as attritable assets in a joint fighting force. Through these and related efforts, this F-35 5th Generation weapon system serves as a force multiplier for our country and allies.
• Missile Defense: The F-35 offers inherent capabilities that can significantly enhance U.S. missile defense. The F-35’s stealth and advanced sensor suite can help detect potential missile threats and provide ‘Left of Launch’ identification and engagement through entering contested airspace undetected. The F-35 can also serve as a sensor node to detect and track missile threats at a much closer distance – and connect sensor information to queue existing missile defense systems to engage an incoming threat. According to the Missile Defense Review, the Department of Defense is also building a technology roadmap to equip the F-35 with a new or modified interceptor capable of shooting down adversary ballistic missiles in their boost phase for direct engagement.
• Extended Range: While the F-35 as configured today, exceeds the specified range performance, we’re engaged in an industry-funded study with Elbit Systems-Cyclone focused on a 600-gallon external tank and an associated jettison-able pylon for the F35A to significantly increase range and loiter time.
• Increased Lethality: In addition to increasing the F-35A and F-35C’s internal weapons capacity from four to six internal weapons, we’re also working to integrate a series of new weapons to increase lethality. Additionally, the F-35 has the structural capacity on our inner wing stations to carry hypersonic weapons externally allowing the F-35 to execute deep strike missions while providing unmatched ISR capabilities. We also see a growth path in the future to add payload weight capacity and increase the total number of missiles the F-35 can carry.
As we integrate upgraded capabilities, our goal is to maintain or reduce both the unit cost to procure and the sustainment costs for F-35s across the enterprise.
https://docs.house.gov/meetings/AS/AS03 ... 191113.pdf
Ozair
Thu Dec 05, 2019 11:29 pm
The Vermont National Guard now have five F-35s and expect to have twenty by summer next year.
Vermont Air Guard takes delivery of 3 more F-35 fighter jets
https://www.wcax.com/content/news/Vermo ... 49901.html
Ozair
Mon Dec 09, 2019 8:11 pm
It will certainly be an unusual site to see this F-35B take off from the QE while it is in Portsmouth. Will they take off while the carrier is stationary, do a run around the harbour or perhaps even have the aircraft take off vertically?
Why Is An F-35 Sitting On The Deck Of HMS Queen Elizabeth?
One of the UK's F-35 aircraft has travelled back home on HMS Queen Elizabeth after developing a fault in the US.
A Royal Navy spokesperson said that after flight trials in the United States, one of the Lightning jets will need to undergo repair and maintenance work.
"Following completion of successful flying trials in the US, one F-35 Lightning remained embarked on HMS Queen Elizabeth in order for repair and maintenance work to be completed," the spokesperson said.
The F-35 was unable to fly home from the US because of the technical problem.
The aircraft is expected to take off from the aircraft carrier in Portsmouth and fly back to RAF Marham once the fault has been addressed.
https://www.forces.net/news/why-f-35-si ... -elizabeth
Ozair
Mon Dec 09, 2019 8:14 pm
Apparently a Norwegian audit report has found some issues with the F-35 but the report is classified and won’t be released to the public.
Secret criticism flies around new F35s
Something seems to be wrong with the operating capabilities of Norway’s growing fleet of new F35 fighter jets, but no one will specify what the problem is. Norway’s State Auditor General is criticizing the government in a report to Parliament on the new jets, but the report is classified and therefore being handled as top secret.
“The audit of the fighter jets’ operating capabilities covers possible vulnerabilities in maintenance, logistics and refueling functions, the fighter jet bases and protection of our air space,” Defense Minister Frank Bakke-Jensen told newspaper Klasse-kampen on Monday. He explained that such information is of “high value” for foreign intelligence-gathering operations, and that’s why the Auditor General’s report is classified and won’t be publicly shared.
Bakke-Jensen claimed that both Defense Chief Haakon Bruun-Hanssen and the auditor general’s office agreed with him on the need to keep the report’s results secret. No one will even release the degree of confidentiality, or how serious the criticism is.
https://www.newsinenglish.no/2019/12/09 ... -new-f35s/
Ozair
Tue Dec 10, 2019 10:00 pm
Some additional congressional oversight related to the Blk 4 upgrade path. Probably a good thing and will hopefully keep the dev costs for Blk 4 to schedule.
Defense Authorizers Direct Increased Oversight of F-35 Upgrades
Defense authorizers in the House and Senate are directing increased oversight of the F-35 Block 4 and Continuous Capability Development and Delivery (C2D2) program.
The oversight requires the secretary of defense “to submit annually to the congressional defense committees an integrated master schedule and past performance assessment for each planned phase of Block 4 and C2D2 upgrades,” according to the House-Senate conference report on the Fiscal 2020 National Defense Authorization Act (NDAA), S. 1790.
In fiscal 2020, the bill authorizes the Pentagon budget request of nearly $695 million for C2D2 for the U.S. Air Force F-35A, $423 million for C2D2 for the U.S. Marine Corps’ F-35B, and $384 million for the U.S. Navy’s F-35C carrier variants.
“The conferees expect the secretary of defense to keep the congressional defense committees fully and promptly informed on the planning, cost, schedule, execution, fielding, and programmatic risk associated with the Block 4 and C2D2 program,” according to the report.
In the Pentagon’s fiscal 2020 budget proposal, DoD said that it plans to spend about $6.6 billion on C2D2 between 2019 and 2024, while the Government Accountability Office said last April that it used figures from the F-35 program to estimate that C2D2 will cost about $10.5 billion through 2024.
https://www.defensedaily.com/defense-au ... /congress/
Ozair
Tue Dec 10, 2019 10:02 pm
Good news for the domestic Japanese production line for F-35 with the decision to continue local manufacture. Appears that MHI has reduced the cost of production to be comparable with US manufactured jets.
Japan reverses course on F-35, will continue assembly at home
Japan intends to continue assembling F-35 stealth fighters domestically, reversing plans to import the finished aircraft from the U.S., Nikkei has learned.
Since Tokyo adopted the F-35A fighter jet in fiscal 2011 under the U.S. Foreign Military Sales program, Japan's Mitsubishi Heavy Industries has assembled and conducted final checks on aircraft sold to the country by Lockheed Martin.
But the costly process prompted a decision by Tokyo to import finished F-35s starting with new contracts made in fiscal 2019, which began in April. Japan's cabinet approved plans at the end of 2018 to buy another 105 F-35s, including 42 F-35Bs, which are capable of short takeoffs and vertical landings.
However, Tokyo looks to reverse that decision after Mitsubishi Heavy revamped its assembly process to reduce costs.
Finishing one F-35 in Japan is now expected to cost 9.37 billion yen ($86.3 million), compared with 9.42 billion yen to ship the plane from the U.S., according to Japan's Defense Ministry. The cabinet is expected to approve the domestic production plan soon.
https://asia.nikkei.com/Business/Aerosp ... ly-at-home
Ozair
Tue Dec 10, 2019 10:09 pm
As expected the US is going to take on the current Turkish jets and has set aside money to do so. Not sure if this will be impacted by the CR that was signed and therefore this acquisition will wait until the next defence budget but either way I am sure the USAF is happy to get their hands on the additional airframes.
U.S. sets aside $440 million to purchase F-35s ordered by Turkey
The United States will set aside $440 million to buy back all F-35 stealth fighter jets ordered by NATO ally Turkey, Dünya newspaper reported, citing the U.S. draft budget for 2020.
U.S. legislators will create a special fund in the budget to purchase the aircraft, which will be transferred to the U.S. military, Dünya said on Tuesday.
Turkey has been suspended from a programme for the production and purchase of the F-35s after it took delivery of S-400 air defence missiles from Russia earlier this year. Turkey still hopes to buy the aircraft, Turkish Defence Minister Hulusi Akar said in an interview with state-run Anadolu news agency on Monday.
Production of lots 12, 13 and 14 – designated for Turkey’s military – will be given priority in the manufacturing schedule and the aircraft will be delivered to the U.S. military instead, Dünya said.
https://ahvalnews.com/us-turkey/us-sets ... red-turkey
Ozair
Tue Dec 10, 2019 10:13 pm
Given how long Kennedy still has it should be doable to get these F-35 mods into the vessel. Not sure the Navy will have the carrier air wing of F-35Cs available to sail on its first deployment but seems fitting to try and get the latest USN aircraft onto the latest USN aircraft carrier as soon as possible.
Get USS Kennedy Ready For F-35Cs, Congress Orders Navy
Congress is continuing to push the Navy hard on its Ford-class aircraft carrier effort, demanding major changes to an $11 billion ship christened just last weekend. The 2020 NDAA calls for the Navy to make changes to allow the USS John F. Kennedy (CVN 79) to carry F-35 fighter planes before her first deployment — something the Navy has neither the money or time to do under current building schedules and budget lines.
The Navy never planned for its first two Ford carriers to carry F-35s because of delays in the aircraft’s planning and construction. The service couldn’t wait for all of the F-35s requirements to shake out before bending steel on its first two Ford carriers, so it went ahead with plans to add the capability later. But Congress thinks that’s not good enough. The new NDAA released Monday night “requires the Navy to insert the Joint Strike Fighter ship alterations on the USS John F. Kennedy (CVN 79) before her first deployment,” in the mid-2020s, a requirement that either requires tens of millions in extra funding, or some other program to lose out.
https://breakingdefense.com/2019/12/get ... ders-navy/
Ozair
Wed Dec 11, 2019 9:10 pm
Poor production line management by LM. While it looks like it will not impact safety of flight I hope LM remains on the hook to fix/pay for this issue when aircraft move into deep maintenance.
Fasteners Cause Brief Break in F-35 Deliveries
Deliveries of the F-35 fighter were halted for two weeks in November after Lockheed Martin discovered a mix up with fasteners used on the aircraft, but the Pentagon has resumed accepting aircraft after an analysis of flight safety issues, Pentagon acquisition chief Ellen Lord said Dec. 10.
Lord, at a press conference discussing her office’s 2019 accomplishments, said the Defense Contract Management Agency was notified on Nov. 12 that there had been “co-mingling” of Titanium and Inconel fasteners on the F-35 production line, and deliveries were halted. However, after a quick analysis, the Pentagon and Lockheed Martin determined the jets with potentially incorrect fasteners were “safe to fly, so on 27 November, we resumed accepting aircraft,” Lord said.
She did not discuss how many aircraft were affected, or whether further corrective action would be taken. The F-35 Joint Program Office could not be reached for comment.
https://www.airforcemag.com/fasteners-c ... eliveries/
Ozair
Wed Dec 11, 2019 10:18 pm
Significant increase to RAAF F-35 numbers at Williamtown with the arrival yesterday of seven additional F-35s.
https://scontent.fsyd8-1.fna.fbcdn.net/ ... e=5E855661
Ozair
Thu Dec 12, 2019 8:19 pm
An interview with Commodore Mike Utley who is the Commander UK Carrier Strike Group. In the interview he stated the below in reference to the numbers of UK and USMC F-35B aircraft that wil occupy the QE and PW during carrier operations over the next few years.
Royal Navy carrier strike development – the next 18 months
Utley also put to bed much of the speculation and guesswork about aircraft numbers. CSG21 will involve “8 plus 8” Lightning jets. The fixed-wing element of the CV wing will comprise 16 aircraft – 8 UK jets from 617 Squadron and 8 US Marine Corps jets of VMFA-211. The Commodore also stated that ultimately the intention is to have “24 in 24”, ie. 24 jets will routinely embark on the deployed carrier from 2024.
A Statement of Intent document was signed 10 years at government level to have USMC assets integrated in UK carrier strike operations. This is breaking new ground and will be a first for both nations. The USMC jets will be under UK tactical command, although a senior US national representative will be on board, presumably able to veto their involvement if not in line with national objectives. Rotary wing assets are expected to include 5 ASW Merlin Mk2s and 3 Crowsnest-equipped Merlins. Surprisingly the intention is that the Merlin Mk4s that provide search & rescue, personnel recovery and troop insertion capability will be based on board other ships, presumably the RFAs. Whether USMC rotary-wing assets including the V-22 Osprey, could be involved in CSG21 are still under discussion and “nothing is off the table”.
https://www.savetheroyalnavy.org/royal- ... 18-months/
Ozair
Thu Dec 12, 2019 9:41 pm
Australia has now committed to the 72 planned F-35As for the replacement of the Classic Hornet fleet. The RAAF has thirteen aircraft in Australia with a further five that are likely to stay at Luke AFB in the US to assist with the international pilot training program.
The conversion rate will see 3SQN fully convert and then 77SQN and 2OCU and finally 75SQN based at Tindal.
Australia approves more F-35s, ends classic Hornet pilot conversion
Australia has approved the procurement of 24 more Lockheed Martin F-35A Lightning II Joint Strike Fighter (JSF) aircraft, the Department of Defence (DoD) announced on 12 December.
The approval from Defence Minister Linda Reynolds came on the same day that a further seven F-35s arrived at RAAF Base Williamtown in New South Wales, and a day after the Royal Australian Air Force's (RAAF's) 2 Operational Conversion Unit (OCU) flew its final flight on the Boeing F/A-18A/B 'classic' Hornet.
With the additional F-35s now approved, Australia is committed to its total programme-of-record of 72 aircraft (though it has a stated requirement of 100 aircraft). Including the most recent arrivals to Williamtown, the RAAF has now received 18 aircraft (five of these remain at Luke Air Force Base [AFB] in the United States for international pilot training).
https://www.janes.com/article/93161/aus ... conversion
DigitalSea
Thu Dec 12, 2019 11:07 pm
Good to hear, we need to push as many of these to the Aussies as possible.
Ozair
Sat Dec 14, 2019 9:09 pm
Continuing integration between USAF F-35s and US Army units. An obvious operating concept for the future where stealthed assets can cue emerging longer ranged artillery and missiles. The concept also allows stealth aircraft to preserve their weapons for targets that may be beyond the range or too fleeting for joint fires.
F-35 Cueing Artillery To Take Out Air Defense Site During Test Is A Glimpse Of The Future
SHARE
U.S. Army ground artillery units recently conducted a test in which they destroyed a mock air defense system based on targeting information from a U.S. Air Force F-35A Joint Strike Fighter. The tactic allowed the joint force to destroy a mock threat while allowing the F-35 to remain in its most stealthy mode and not reveal itself by engaging it directly. This is a concept of operations that could be extremely valuable for U.S. forces in a future large-scale conflict against an opponent with dense integrated air defense network and one that could easily expand to include other assets, including unmanned aircraft and new, longer-range artillery and tactical missile systems.
This particular scenario was part of a larger Joint Strike Fighter Integration experiment that took place at one of the Doña Ana Ranges in New Mexico, which are part of the Fort Bliss Training Center that is headquartered in neighboring Texas. M109A6 Paladin self-propelled 155mm howitzers from the Army's 1st Armored Division Artillery and an F-35A from the Air Force's 59th Test and Evaluation Squadron took part in the test, along with a host of supporting units.
https://www.thedrive.com/the-war-zone/3 ... the-future
Ozair
Re: F-35 news thread
Mon Dec 16, 2019 7:35 pm
The UK F-35B that had been stuck on the QE after the last work up period has taken off while the ship was docked at Portsmouth. You can see a video of the take-off at the below link.
F35 takes off from HMS Queen Elizabeth for first time in UK
https://www.bbc.com/news/av/uk-england- ... time-in-uk
Ozair
Tue Dec 17, 2019 9:30 pm
Congratulations to South Korea on IOC with the F-35. They have a reasonably aggressive delivery schedule for the next two years, with 13 and 14 aircraft coming respectively before a, yet to be signed, follow up order for 20 more from 2021.
South Korean air force declares IOC for its F-35 Joint Strike Fighters
The Republic of Korea Air Force (RoKAF) has declared initial operating capability (IOC) for its conventional take-off and landing (CTOL) F-35A Lightning II Joint Strike Fighters in a ceremony held on 17 December at the 17th Fighter Wing airbase in the South Korean city of Cheongju.
The Yonhap News Agency reported that same day that the ceremony, which was closed to the press in an apparent effort to keep it a low-profile event to avoid angering Pyongyang, was held to officially mark the operational deployment of the fifth-generation aircraft, adding that they are now ready for limited combat operations.
South Korea has so far received 13 of the 40 F-35As its plans to acquire by 2021 as part of a KRW7.3 trillion (USD6.3 billion) deal approved in September 2014.
The RoKAF is expected to receive 13 more platforms in 2020, with another 14 set to be handed over the following year. Seoul is also set to exercise an option to buy 20 more units from 2021.
The RoKAF's F-35 made its official public debut on 1 October when four of the fighters were displayed during an event to mark the 71th anniversary of the country's Armed Forces Day, which was held on 1 October at the Daegu Air Base in North Gyeongsang Province and was presided over by South Korean President Moon Jae-in.
The aircraft was also showcased at this year's Seoul International Aerospace & Defense Exhibition (ADEX) held in October.
Cheongju Air Base is the designated main operational airbase for the type.
https://www.janes.com/article/93233/sou ... e-fighters
Ozair
Wed Dec 18, 2019 8:53 pm
LM and Boeing appear to be in a serious contest for the next Israeli Air Force order. It looks like the Israelis want both aircraft but they can likely only afford to get one at a time. Interestingly as well the article talks about Israel receiving a special F-35 test aircraft that will be delivered next year with the intent to allow Israel to test integration of their domestic equipment and systems onto the F-35.
Lockheed Presses For Sale Of 75 F-35s To Israel; Boeing Touts F-15s
The final push is on between Boeing and Lockheed Martin as Israel closes in on a final decision– which to buy first, more F-35s or an advanced version of the F-15 similar to the F-15X the US Air Force will buy.
A senior military source told Breaking Defense that both competitors are needed and the question is — is who will get bought first: “The IAF needs 75 F-35s and the advanced version of the F-15, and the question is, who will be the first to be purchased.”
Lockheed Martin sent Gary North, the company’s VP for customer requirements, the former head of Pacific Air Forces to press the company’s case. Aside from the expected claim that the F-35 is the best solution for the Israeli Air force’s challenges in the region, North said the unit price of LRIP Lot 14 will be $77.9 million, which means that the last six F-35s in the 50 aircraft contract will carry this price tag. They will be delivered in 2024. According to the best public estimate from the Pentagon, the F-15X will cost $90 million a copy, according to its Cost Assessment and Program (CAPE) analysts.
North said that the price of the F-35 flight hour is going down, and is, as Lockheed keeps promising and the government keeps doubting, going to to be $25,000 by 2025.
The Lockheed Martin senior official said that the radar of the F-35 is capable of detecting low flying threats like Iranian cruise missiles. North revealed that the F-35 test aircraft will be delivered to the IAF in the summer of 2020.
https://breakingdefense.com/2019/12/loc ... uts-f-15s/
Ozair
Thu Jan 02, 2020 11:13 pm
Continued work between the US and Japan Militaries on the F-35. Given Japan is likely to be the second largest operator of the aircraft it makes sense to work together in this way.
US, Japanese F-35 Airmen Collaborate for Maintenance Symposium
Maintainers from Hill AFB, Utah, recently traveled to Japan for an F-35 maintenance symposium designed to increase interoperability at every level.
Eight airmen from the 388th Maintenance Group worked with a Japan Air Self-Defense Force F-35 maintenance squadron, first discussing lessons learned and then working hands-on in the Japanese facilities on specific maintenance tasks.
The JASDF requested the subject matter expert exchange, and since the F-35 program is still in its early stages, it seemed like the “perfect opportunity to come in on the ground level and grow our interoperability together,” explained CMSgt. Brian Kruzelnick, command chief master sergeant for Fifth Air Force.
However, Fifth Air Force doesn’t have any Joint Strike Fighters. So they reached out to the 388th Fighter Wing—the only USAF combat unit with F-35s.
Col. Michael Miles, commander of the 388th Maintenance Group, said the JSF “really enables a different level of cooperation than any other platform” in the USAF arsenal.
“By cooperating and sharing lessons learned, we actually can raise everybody’s performance within the program,” he said. “The idea would be to continue this engagement as we both learn more about the F-35 and the way they capitalize on its capabilities.”
https://www.airforcemag.com/us-japanese ... symposium/
Ozair
Thu Jan 02, 2020 11:16 pm
I expect the McLaren may win the first half a mile but be overtaken after that.
New 'Top Gear' trailer features McLaren Speedtail racing F-35 fighter
While the old Top Gear hosts are piloting boats up the Mekong River over on Amazon Prime’s The Grand Tour, the new Top Gear hosts are pitting fighter jets against McLarens, bungee-jumping in British cabriolets and ragging on classic French cars in Nepal.
Yup, there should be plenty of motoring shenanigans to watch this year.
In a trailer for the 28th season of Top Gear, hosts Chris Harris, Paddy McGuinness and Freddie Flintoff can be seen performing and/or preparing for all sorts of wild stunts, including lining up a Rover for a bungee jump down the face of a massive dam and racing a McLaren Speedtail against an F-35 fighter jet on an airstrip.
https://driving.ca/auto-news/news/new-t ... 35-fighter
Nomadd
Fri Jan 03, 2020 1:14 pm
https://youtu.be/6AlfUKKP81o
Users browsing this forum: Nick614 and 29 guests
