737MAX7
United Express Embraer off Runway at BNA
Fri Jan 12, 2018 6:21 pm
Recieved a text from my girlfriend that apparently a United Express Embraer is off the rwy and in the grass at BNA. Apparently happened on takeoff. Not exactly sure the specific Embraer but would guess it’s an E70.
AWACSooner
Re: United Express Embraer off Runway at BNA
Fri Jan 12, 2018 6:32 pm
Slippery when wet...or in this case, icy/sleety/snowy
ilovelamp
Fri Jan 12, 2018 7:17 pm
http://www.wsmv.com/story/37255025/plan ... s-on-board
Local news saying it’s just a nose gear.
Cubsrule
Fri Jan 12, 2018 7:22 pm
More wet still here. Virtually everything that has falllen was liquid when it came down, and while the temperature has dropped most paved surfaces aren’t yet icy. It was nearly 70 yesterday so the ground is pretty warm.
Brick
Fri Jan 12, 2018 7:35 pm
The flight number referenced in the local news story is a Trans States Airlines flight number. This would mean the aircraft type involved was a Embraer 145.
A noble spirit embiggens the smallest man...
asuflyer
Fri Jan 12, 2018 7:38 pm
Flight is reported to be UA 4696 an E145, N18114 to ORD.
737MAX7
Fri Jan 12, 2018 7:56 pm
Thanks for the correction, I assumed E70 since that is the majority of the EJets I see UA bring in here.
asuflyer
Fri Jan 12, 2018 8:12 pm
Looks minor, although the nosegear looks to have turned.
flyguy84
Fri Jan 12, 2018 8:28 pm
Trans States has quite the history for these kind of mishaps.
SFO
Cubsrule
Fri Jan 12, 2018 11:45 pm
Not too bad. As WN knows, BNA is a bad place to have an excursion.
AAvgeek744
Sat Jan 13, 2018 12:03 am
Its a little worse than your description. I only heard about this on the news when they mentioned the Titans were late arriving at PVD because of this. Roads are pretty slick. It's not supposed to get above 20 all weekend, so despite yesterday being warm, there is going to be enough ice to be troublesome.
Cubsrule
Sat Jan 13, 2018 12:19 am
At least in town, the roads are fine. I just saw a Camaro going up the hill on Broadway by Bridgestone with no trouble.
