Quick question. I’m scheduled on SWA 1748 from Slc -Den today and upon checking my boarding pass it doesn’t have the WiFi logo like my connecting flight does. I thought all the Southwest planes had WiFi since the -300/ 500 we’re retired. Anyone know which aircraft this is, or why?
Also I have a very tight connection in DEN tonight and notice that the aircraft seems to be delayed past week quite often on arriving into SLC and departing ? Any insight ?
All of WN's planes are equipped with wifi. As for your connection, there are a number of variables as to why its delayed.. Hope you have a good flight.
I've had a couple flights where the wifi was out recently. That said, they should all have the symbol I would think. You usually don't get any warning ahead of time if it is out or not.
As to the delay, you can use a plane tracker and go back in time on your planes route to see where the delay started. It might have been going through a city with bad weather or a busy station like SFO that just has delays because it gets backed up.
