747-600X
UAL2051 doing laps for 3 hours
Thu Mar 15, 2018 2:55 pm
United 2051 took off from TPA bound for SFO and immediately started doing short laps up and down the FL coast. Curious to find out what's going on.
https://flightaware.com/live/flight/UAL2051
pksundevil
Re: UAL2051 doing laps for 3 hours
Thu Mar 15, 2018 3:11 pm
Twitter user says it was a bird strike after takeoff and then has been dumping fuel- not sure the second part would be accurate given how long it's been circling- but what a miserable experience for passengers to just circle at 7,000 feet for so long.
flyguy84
Thu Mar 15, 2018 3:16 pm
Considering an A320 can’t dump fuel... no.
SFO
pksundevil
Thu Mar 15, 2018 3:17 pm
Thanks- so I wonder whether 4 hours of circling at 7,000 feet is getting close to enough fuel burned off? Or do you think there's something else going on that they are trouble-shooting?
Through the engines !
“Don't be a show-off. Never be too proud to turn back. There are old pilots and bold pilots, but no old, bold pilots.” E. Hamilton Lee, 1949
zrs70
Thu Mar 15, 2018 3:24 pm
I was watching it on Flightradar24. Crazy.
But I can’t find the flight now.
21 year airliners.net vet! 2000-2021
pksundevil
Thu Mar 15, 2018 3:25 pm
Flightaware still shows it.
747-600X
Thu Mar 15, 2018 3:32 pm
Must've been one heck of a bird strike. Those don't usually require a return to field, unless it prevented slats from retracting or similar. For how long they've been up there, almost seems like they might as well have just gone to SFO!
pksundevil
Thu Mar 15, 2018 3:34 pm
Looks like it is finally heading in for a landing.
LOWS
Thu Mar 15, 2018 3:40 pm
With a flight number like that, is it an NCAA charter?
pksundevil
Thu Mar 15, 2018 3:41 pm
And... for whatever reason looks like they've temporarily decided against that plan. Has to be uncomfortable for the passengers.
flyguy84
Thu Mar 15, 2018 4:37 pm
No scheduled flight.
SFO
dxBrian
Thu Mar 15, 2018 4:56 pm
Land the airplane and do an overweight landing inspection. Easy and less time consuming.
LOWS
Thu Mar 15, 2018 4:58 pm
Ah, ok, thanks. I thought all UA 2XXX were charter for some reason.
flyguy84
Thu Mar 15, 2018 5:10 pm
Unless the birdstrike damaged parts of the aircraft that impacted other systems. Just saying. It’s not so cut and dry.
SFO
ual763
Thu Mar 15, 2018 5:30 pm
I could be wrong, but if I remember correctly, the 25xx numbers are charters.
From flying to the NOTAM office
jayunited
Thu Mar 15, 2018 5:41 pm
This was a cross country flight TPA-SFO that was a few seats shy of being full there was over 4,500 pounds of cargo and bags in the pits and over 41,000 pounds of jet fuel. The bird strike occurred right after takeoff damaging one of the pitot tubes, I'm not a pilot I don't know if you are one or not, but I believe in this situation the pilot made the right decision to burn the fuel to reduce the weight of the aircraft before attempting to land. Performing an overweight landing is not something to be taken lightly serious damage can be done to an aircraft during overweight landings if not executed properly.
Runway28L
Sounds like there was damage to the pitot tubes.
http://twitter.com/tompodolec/status/97 ... 85154?s=21
StTim
Thu Mar 15, 2018 5:46 pm
Doing a holding pattern you are always close to a landing point should things get worse.
Aesma
Fri Mar 16, 2018 7:54 am
So unreliable airspeed on an least one flight computer.
BENAir01
Fri Mar 16, 2018 11:21 am
Yeah, its much safer to circle the airport burning fuel than to go to your destination. First of all, they probably stayed at 7,000 feet to have enough power in the one engine to keep the plane in their - they wouldn't fly to SFO at 7,000 feet. Second of all, they probably wanted to be right at the airport just in case something bad should happen.
Why is flying so expensive? And why is flying well so much more?
ordbosewr
Fri Mar 16, 2018 1:02 pm
I am happy that everything ended up safe and sound. Yes, the passengers got more than they expected, but the eventually got to SFO, safely, of course.
FriscoHeavy
Fri Mar 16, 2018 2:29 pm
A. Not sure where it says anything about losing an engine. Appears they had full power.
B. Even on one engine, they'd be able to stay much higher than 7,000 ft.
Whatever
United1
Fri Mar 16, 2018 2:45 pm
As stated above it wasn't an engine issue the bird strike took out a pitot tube. The engines burn fuel at a higher rate at 7K vs 30K and 7K allows them to leave the aircraft unpressurised which is prudent if you are unsure of the extent of hull damage.
I know the voices in my head aren't real but sometimes their ideas are just awesome!!!
Seabear
Fri Mar 16, 2018 3:47 pm
Bad week to be a dog or bird on United.
ctrabs0114
Fri Mar 16, 2018 3:57 pm
UA charters start at UA25xx, so you weren't that far off...
2019: DAL, MCI, PHX, LAS, DFW, SAT, ORD, SLC, SEA, DTW, PHL, MIA, LAX; B73G (WN x3), B738 (WN, AA, DL), A20N (NK), MD83 (AA), B788 (AA x2), CS1 (DL), B739 (DL), B712 (DL), B752 (AA), B763 (AA), B77W (AA), B789 (AA)
Next: TBA
