qf789
Asiana Airlines A333 knocks tail off Turkish Airlines A321 at IST
Sun May 13, 2018 4:16 pm
At IST today an Asiana Airlines A333 (HL7792) got a little close to a Turkish Airlines A321 (TC-JMM), damaging the tail of the aircraft
https://twitter.com/JacdecNew/status/995693283937538050
Forum Moderator
ikramerica
Re: Asiana Airlines A333 knocks tail off Turkish Airlines A321 at IST
Sun May 13, 2018 4:20 pm
Speed Tape!
enilria
Sun May 13, 2018 4:21 pm
Note to self. In tail vs wing, bet on wing.
HarryLi
Screener
Sun May 13, 2018 4:25 pm
I am a Guangzhou Spotter. My photos are here : https://www.airliners.net/search?user=20 ... =viewCount :D
mercure1
Well at least on Airbus frames, the vertical stabilizer and rudder come as singe assembly, so it can be replaced entirely for TK.
mercure f-wtcc
qf789
Sun May 13, 2018 4:32 pm
Close up of the tail
Approximate location of collision
https://twitter.com/JacdecNew/status/995700271794749440
Forum Moderator
ikolkyo
Sun May 13, 2018 4:33 pm
Don't know why but just seeing that tail just flopped over to the side like that makes me laugh for some odd reason. Should be just a new vertical stab assembly for the A321 though.
Antarius
Sun May 13, 2018 4:35 pm
How does something like this happen? Unreal.
19:SIN HKG NRT DFW IAH HOU CLT LGA JFK SFO SJC EWR SNA EYW MIA BOG LAX ORD DTW OAK PVG BOS DCA IAD ATL LAS BIS CUN PHX SYD CVG PHL MAD ORY CDG SLC SJU BQN MHT YYZ STS DOH BLR KTM MFM MEX MSY BWI BNA
Runway28L
Sun May 13, 2018 4:38 pm
That's gonna leave a mark.
And yet no one has dared to ask the million dollar question? ;)
iahcsr
Sun May 13, 2018 4:40 pm
It appears the 333 was on the proper taxi line, 321 holding short or just pushed from gate. Either way TK was there to be clearly seen by OZ crew. Seems another case of taxing pilots not paying proper attention to their wing clearance zone.
readytotaxi
Sun May 13, 2018 4:48 pm
The tail is okay, appears to have just fainted. :D
Growing older, but not up.
iahcsr
It happens because pilots get complacent and just look straight ahead, forgetting to watch side to side for their wing clearance. It happens WAY to often around the world. :banghead:
Spacepope
Sun May 13, 2018 5:23 pm
ikramerica wrote:
Speed Tape!
Slightly more involved of a fix. It'll need some bondo too.
MileHFL400
Sun May 13, 2018 5:25 pm
is that a write off?
Thanks and best Regards
AA
Blerg
Sun May 13, 2018 5:31 pm
Is it a write off? ;)
From the pictures it looks as if Asiana is taxiing on the yellow line. Could it be that the A321 wasn't properly parked?
alfa164
Sun May 13, 2018 5:35 pm
I thought it just needed to be using Viagra... ;)
I'm going to have a smokin' hot body again!
I have decided to be cremated....
Jayafe
Sun May 13, 2018 5:36 pm
Nope
Dutchy
Spacepope wrote:
ikramerica wrote:
Speed Tape!
It'll Buff Out.
jetmatt777
Sun May 13, 2018 5:39 pm
Looks like the A321 was holding short of the gate waiting to be marshaled in. Just because the A330 is on the line doesn’t give them the right of way. They are still responsible for watching their wings, and avoiding in this case an airplane that was encroaching on the taxiway.
Lighten up while you still can, don't even try to understand, just find a place to make your stand and take it easy
ikramerica
Sun May 13, 2018 5:47 pm
Spacepope wrote:
ikramerica wrote:
Speed Tape!
Well yeah. And a can of krylon. But that’s later. I’m just trying to get it into service without having to cancel the next flight...
stylo777
Sun May 13, 2018 5:51 pm
maybe luck in an unlucky situation: TC-JMM is one of those leased and former Kingfisher frames; so not really own metal.
jeffrey0032j
Sun May 13, 2018 5:58 pm
Its more tricky in this case, because you have to inform and communicate with your lessor.
CrimsonNL
Sun May 13, 2018 6:13 pm
Jeez that video is insane! Is that smoke coming from the severed tail or hydraulic fluid that's venting out?
Martijn
GE90man
Should buff out pretty well
Casablanca
Sun May 13, 2018 6:17 pm
It definitely seems quite careless, as they were very close and taxiing very fast
It is a little difficult to judge wing tip clearance sometimes and most wide bodies are so long you can’t see the wing from the Flight deck
JAAlbert
Sun May 13, 2018 6:29 pm
Interesting that the tail didn't break where it meets the fuselage, but a half a meter or so up the tail. It shows me how firmly affixed the tail is to the fuselage.
So what is the smoke spewing from the tail after the accident? Is there a hydraulic hose or mechanism up in that area?
EA CO AS
Sun May 13, 2018 6:45 pm
Will the nose gear on the A321 need to be replaced after the lateral stress placed on it? The nose of the aircraft moved damn near six feet from what I can tell.
barney captain
Sun May 13, 2018 6:49 pm
In many large aircraft, you can't even see the wings from the cockpit - so I fail to "see" your point.
Southeast Of Disorder
hOMSaR
Sun May 13, 2018 6:52 pm
stylo777 wrote:
Reminds me of the scene in the movie Airplane! where their wing knocks over a radio station antenna.
The plural of Airbus is Airbuses. Airbii is not a word.
There is no 787-800, nor 787-900 or 747-800. It's 787-8, 787-9, and 747-8.
A321neoLR is also unnecessary. It's simply A321LR.
Airplanes don't have isles, they have aisles.
NWADTWE16
Sun May 13, 2018 7:00 pm
THis is insanity! Why wasn't there a marshaller out by the tail, since the A321 was clearly sitting in the active thru way? Asiana was cruising too, seems way to fast for that congested zone, at this well known over capacity airport.
I haven't been everywhere, but it's on my list!
FredrikHAD
Sun May 13, 2018 7:01 pm
They sprayed a lot of water on the tail, so they must have suspected the smoke was from something hot, not only hydrualic fluid. The APU was reported damaged, so that may be what’s causing the smoke. It is strange though, since the first impact seems to be with the rudder, then the tail, so the fuselage (where the APU is, right?) should be pretty much undamaged, apart from secondary damage.
As for the nose gear, I find it hard to believe the stress was severe enough to cause damage. They’re designed to handle rough landings, sideways too.
/Fredrik
A388
Sun May 13, 2018 7:18 pm
I actually think the A321 is at fault here seeing that they weren't suposed to be stopping where they stopped. The A330 was taxiing by as it should with or without looking for wing clearance. The A321 definitely shouldn't have stopped where it seems to have done. Like someone already told, a bit difficult to see from the video angle. In any case very unfortunate for both airlines.
A388
tjcab
Sun May 13, 2018 7:26 pm
Doesn't seem that fast to me, then again, I cannot draw conclusive information from a 17 sec video recorded off a screen which seems to be less than 10 frames per second. As always, lets wait and see what the official reports say.
NWADTWE16
Sun May 13, 2018 7:28 pm
yeah good point, just my 2 cents, and that's all it is worth LOL
AirKevin
Sun May 13, 2018 7:43 pm
stylo777 wrote:
At least the A321 didn't rotate 90 degrees like the CRJ did after getting hit by an A380.
Captain Kevin
Basefly
Sun May 13, 2018 7:50 pm
The A321 appears to be waiting either for an marchall or a bridge operator to turn on the guidence system. In that case the A321 has gone to far into the stand, it should be holding on the taxiway before turning into the stand.
757/777-A340/A380, Love them.
gatibosgru
Sun May 13, 2018 8:11 pm
Ouch! I wonder how much damage the A330 wing got.
@DadCelo
OA940
Sun May 13, 2018 8:20 pm
The way that wing cut that makes me think it should consider a career in surgery if this whole plane thing doesn't work out for it.
A350/CSeries = bae
Winterapfel
Sun May 13, 2018 8:27 pm
I was wondering: from the video the "wing vs tail" collision is clear. However, in the cockpit of the A321, how would the flight crew know what happened? The would have felt the unbelievable side swipe, probably followed by bells and wissles... And then what??
AirKevin
Sun May 13, 2018 8:32 pm
I assume you'd get indications of systems like the yaw damper failing. Other than that, I guess either ground crew, if connected, or air traffic control, if they happen to be looking in that direction, would say something.
Captain Kevin
airtrantpa
Sun May 13, 2018 8:36 pm
Would have been ironic if it was a shamu plane of WN, since orca dorsal fins seem to flop like that in captivity
AVL my new Hometown airport! Farewell TPA
longhauler
Sun May 13, 2018 9:58 pm
I would be curious what was going on in the cockpit of the A330 that distracted both pilots to the point they did not notice the A321 had stopped. It does happen!
Maybe a revised taxi clearance. Perhaps a new runway or new load numbers ... either of which requires new performance calculations.
There are a lot of very acceptable reasons for stopping where the A321 did. The most likely would be the Gate Guidance System stopped working. It happens from time to time. Procedure is to stop. Then wait for a marshaller to take over. Or it could be the sterile gate area was compromised. The marshaller then stops the aircraft, (either with the wands or with the GGS) then allows the aircraft to continue when the way is clear.
MON
Sun May 13, 2018 10:30 pm
As a 330 pilot I can state for information that both in the A330-200 and A330-300 the respective wingtips are clearly visible from each pilot’s side of the flightdeck.
EWRandMDW
Sun May 13, 2018 11:23 pm
These days it seems the 321 is getting more attention than the 330. Perhaps this is a case of sibling rivalry where the "older" child acts out badly?
Newbiepilot
Sun May 13, 2018 11:38 pm
Another reason that ISTANBUL needs another airport. Now I get that this could happen anywhere, but IST is just way too congested. Every possible space is now a parking stand or gate. There is little room for error when taxiing. There is also so much congestion that pilots and ground crews need to keep up the pace. It can take 10-20 minutes to get pushback clearance. Do we know if the A321 stopped short or was pushing back?
Newbiepilot
Sun May 13, 2018 11:41 pm
If they didn’t notice the A321 was holding short, would you expect the first officer to be actually watching the wing or would they be busy with other activities?
Mir
Mon May 14, 2018 12:50 am
A388
If the 321 doesn't believe it can safely proceed, it should stop. It is then the responsibility of other aircraft to not hit it. If the 330 crew was unsure of their wingtip clearance, they should have stopped as well and either waited for the 321 to move or requested wingwalkers to make sure (more likely the first option).
hongkongflyer
Mon May 14, 2018 2:08 am
Mir wrote:
A388
time for a sensors at the wingtip. can't believe it is so difficult and expensive to do so if we have numbers of cams installed on the tail; front wheels etc.
AirKevin
Mon May 14, 2018 3:03 am
Think that was more so in response to an earlier post where somebody made the following claim:
hongkongflyer wrote:
Mir wrote:
A388
When parts need to be certified, it's going to be expensive. I think the question then becomes if the cost for doing it is justified.
Captain Kevin
