Charlie757
A320 Series Doors
Thu Oct 18, 2018 10:47 pm
So this is probably a really obvious question but I’ve been flying on the A320 family a lot recently and noticed a hissing noise during the initial climb. I’ve been told it’s just the pressurisation, but was wondering if anyone could shed some more light on what it actually is and why it makes that noise?
TIA
Re: A320 Series Doors
Fri Oct 19, 2018 1:29 am
Often it is just a small stone between the rubber seal and the fuselage.
fr8mech
Fri Oct 19, 2018 1:37 am
As seals get older, they become a little stiffer, less pliable. The seal takes a little bit more pressure to seat against the seal depressor or frame. The hiss you're hearing is the air escaping between the seal and the frame. It should go away rather quickly as the pressure differential goes up.
For a little aside, back in the day of "smoking on aircraft" we used to hunt for pressurization leaks along seals by looking for the nicotine buildup that formed around the flaw in the seal.
When seconds count, the police are minutes away, or may not come at all.
It’s hard to win an argument with a smart person, but it’s damn near impossible to win an argument with a stupid person. ~B. Murray
Georgetown
Fri Oct 19, 2018 5:27 am
Those A320 family doors often “bang” or “knock” as you climb and pressure changes.
Let's go Hoyas!
Woodreau
Fri Oct 19, 2018 9:50 am
Cockpit windows too. It’s quite annoying when the seal just doesn’t quite seal. right before it does the squeal changes to a very high pitch/squeak and then it seals and the relative silence is bliss.
greg85
Fri Oct 19, 2018 4:19 pm
Are you sitting near the front when you hear it?
nws2002
Fri Oct 19, 2018 7:16 pm
It makes mx mad because I don't think its good for the seals, but we used to dump a cup of water on the whiny or squealing door seals. The water would freeze and seal it, stopping the noise.
Charlie757
Fri Oct 19, 2018 11:44 pm
That’s actually very helpful thank you!
Charlie757
Fri Oct 19, 2018 11:45 pm
I’ve been sat at the front and also right at the back
teachpdx
Tue Nov 06, 2018 5:09 am
I’ve heard it a couple times at the overwing exits on a 320. It tends to go away around 7000 feet or so.
Up Next: THIS YEAR IS CANCELLED!!!
Users browsing this forum: GalaxyFlyer, Woodreau and 6 guests
