WPvsMW wrote:It's a work-around at Airbus, in view of multiple Boeing patents on bark-suppression. Sometimes the dogs has emotional swings the 1st gen. CECS (Canine Emotional Control System) can't handle, and feeding doesn't work. The second generation CECS was introduced on the A321.
greg85 wrote:You’ll also find that the barking dog is much faster and louder after a single engine taxi in. This is because of the pressure difference between the green and yellow hydraulic systems. After a single engine taxi in the green system slowly loses pressure as the engine winds down, while the yellow goes quickly to zero after the yellow electric pump is switched off.
Caryjack wrote:greg85 wrote:You’ll also find that the barking dog is much faster and louder after a single engine taxi in. This is because of the pressure difference between the green and yellow hydraulic systems. After a single engine taxi in the green system slowly loses pressure as the engine winds down, while the yellow goes quickly to zero after the yellow electric pump is switched off.
I heard this dog on a Delta A-330 (SEA-AMS). It barked from the start of the outbound taxi until the takeoff roll. I'd guess that the delayed barking occurred because the larger airliner required extra time for the pump to equalize pressure. It was funny to me and I quietly laughed most of the way out.
http://www.askthepilot.com/questionansw ... us-noises/
From the link: "This pertains to twin-engine Airbus models: the A320 series (includes the subvariants A319 and A321) and the larger A330."
Cary
Cary
CLTRampRat wrote:One of the funnier moments from my Ramp Agent Days was a Frontier F/O who had never heard the barking dog before.
They were doing a crew swap so he was on the ramp with us when the plane arrived so he could immediately do the walk around. We are opening the cargo doors and as always the Airbus is barking. The pilot goes “Hey, what the ____ is that?!”
“What?”
“That!” *flails at plane*
“Sir?”
“That sound!”
“Sir that’s the hydraulics.”
“Does it always do that?”
“Yessir, every Airbus with any airline.”
“Huh, never heard that before!”
Sigh...
Apprentice wrote:Hi: A320 need hydraulic pressure, before engine start, for: Brakes, Steering, Flight Control Check (High demanding), flaps/Slats positioning, (also high consumption) and... So, if not Engine 2 is not on, You need to use electrical pump for that, there You have your barking noise.
Even, with engines on, while taxing, during checks, if You have High Consumption demand, electric pump will start pumping automatically, when Hyd Pressure will be below certain level.
Starlionblue wrote:Caryjack wrote:greg85 wrote:You’ll also find that the barking dog is much faster and louder after a single engine taxi in. This is because of the pressure difference between the green and yellow hydraulic systems. After a single engine taxi in the green system slowly loses pressure as the engine winds down, while the yellow goes quickly to zero after the yellow electric pump is switched off.
Cary
I don't know what you heard but it wasn't a PTU since the A330 does not have one. There are 3 hydraulic systems and no way to transfer power from one to another.
(Yes, Mr. Smith is wrong on that one.)greg85 wrote:You’ll also find that the barking dog is much faster and louder after a single engine taxi in. This is because of the pressure difference between the green and yellow hydraulic systems. After a single engine taxi in the green system slowly loses pressure as the engine winds down, while the yellow goes quickly to zero after the yellow electric pump is switched off.
I think you mean the Yellow system Engine Driven Pump.
Starlionblue wrote:Apprentice wrote:Hi: A320 need hydraulic pressure, before engine start, for: Brakes, Steering, Flight Control Check (High demanding), flaps/Slats positioning, (also high consumption) and... So, if not Engine 2 is not on, You need to use electrical pump for that, there You have your barking noise.
Maybe I'm misunderstanding you but you don't need brakes, steering, flight controls or flaps/slats movement before engine start.
Starlionblue wrote:I don't know what you heard but it wasn't a PTU since the A330 does not have one. There are 3 hydraulic systems and no way to transfer power from one to another.
CALTECH wrote:Starlionblue wrote:I don't know what you heard but it wasn't a PTU since the A330 does not have one. There are 3 hydraulic systems and no way to transfer power from one to another.
Are you sure ?
http://www.smartcockpit.com/docs/A330_F ... Pilots.pdf
Page 39 of 210
A330 hydraulic system
4.3
General
• Three fully independent systems : Green, Blue, Yellow
(nominal pressure at 3000 psi).
• Normal operation :
They are managed by the HSMU (Hydraulic System
Monitoring Unit) which ensures all autofunctions (electrical
pumps, RAT, monitoring, etc) ; manual override is
available on the overhead panel.
- one handpump on the Yellow system for cargo doors
operation when no electrical power is available.
• Abnormal operation :
ELEC
OVHT
GREEN
3000
LO AIR
PRESS
OVHT
1
ELEC
BLUE
3000
1
ELEC
YELLOW
3000
2
PTU
GREEN
2
Apprentice wrote://. Starlionblue wrote:
I don't know what you heard but it wasn't a PTU since the A330 does not have one. There are 3 hydraulic systems and no way to transfer power from one to another. [Unquotted]//
Hi.
You may not transfer Hydraulic Fluid from two systems, but You have a push button to pressurize System 2 is there is Pressure in System 3 and System 1 If on nbr 2.
When ready to push back, Electric Pumps for System #3 are selected on (System 3 pressurize Brakes and Steering, and, if needed, “Pressure Transfer Pumps”will pressurize, in order, System 2 and System 1
greg85 wrote:Starlionblue wrote:Caryjack wrote:I heard this dog on a Delta A-330 (SEA-AMS). It barked from the start of the outbound taxi until the takeoff roll. I'd guess that the delayed barking occurred because the larger airliner required extra time for the pump to equalize pressure. It was funny to me and I quietly laughed most of the way out.
Cary
No, I mean yellow electric pump. I’m talking about taxi with engine number 1 only.
Are you sure ?
Page 39 of 210
4.3
General
ELEC
OVHT
GREEN
3000
LO AIR
PRESS
OVHT
1
ELEC
BLUE
3000
1
ELEC
YELLOW
3000
2
PTU
GREEN
2
WPvsMW wrote:Perhaps an option that operators could select, FCOMs and marketing brochures being apples and oranges.
Starlionblue wrote:WPvsMW wrote:Perhaps an option that operators could select, FCOMs and marketing brochures being apples and oranges.
True.
However, I can't understand why you would need a PTU given the architecture of the hydraulics.
True.
Apprentice wrote:Starlionblue wrote:WPvsMW wrote:Perhaps an option that operators could select, FCOMs and marketing brochures being apples and oranges.
True.
Mostly for Push Back and for Maintenance:(A330/340) and of course, for emergency.
-2 ea electric pump pressurize System 3 only
- 1 Hydraulic Pump, use system 3 pressure as energy source and move a Pump that raise pressure on system nbr 1
- same that above, raise pressure in system # 1
Apprentice wrote:Hi: They called it: “Redundancy” and it is considered necessary, specially for ETOP flights. Should one engine fails, You loose one or 2 systems, provide no PTU.
Same on ground, if for any Mx check You need to start eng, big lost of time. (Note that Hyd Carts, for A330, whith 3 ea independent high pressure high flow pumps do not abund.
Starlionblue wrote:It isn't considered necessary for ETOPS. We do ETOPS every day on the A330 without a PTU.
Apprentice wrote:Hello: Long time I did not touch a A-330, but I was not sure that an emergency Item will be allowed to be inop as per MEL. So I look in an a FAA’s MMEL and did not find nothing related to Pressure Transfer Unit (PTU). As per This MMEL You may have inop an Engine Driven Pumps, & Electric Pumps, but I found nothing about PTU. (By the way: PTU are our “barking Dogs”since, as explained, they use Hydraulic Pressure in “Motor” side and produce Hyd power in Hyd ).
Some one correct me with last MMEL?
Many Thanks
Quotte//: get that a PTU would increase redundancy, but I still don't see a compelling case for it.
At pushback, with either engine running the green system is pressurised, so you have brakes. Once the left engine is running you also have alternate braking powered by the blue system. So you're fine taxiing on the left engine only.
In an emergency, the plane can be controlled with any two hydraulic systems failed.
For reference, engine one has pumps for the blue and green system, while engine two has pumps for the yellow and green system. The RAT powers the green system.// Unquotted
If Green System is inop. You have not NWS. So it will be difficult to control on ground.
Also, You do not have pressure for Move down LG, so Yo will need to lower it manually. And main doors will remain open. No Spoiler 1
If You lost eng #2, two system out of three are lost. Making difficult to have full Authority over FC, and...
Apprentice wrote:A-320, a PTU push button located between yellow and blue system.: http://www.smartcockpit.com/docs/A320-O ... _Panel.pdf
4 ea posts above there is a link to a photo in Main LG wheel well.
So, You have a real PTU image and a Pushbutton that control it, (A-320, as Post’s title But, is Station
Blue said that “there is not PTU” up to him. I do not go into fighting
By the way, MEL is a list of items that may be deferred for flight. No -Go ítems do not use to be there as per obvious reasons.
So, for instance, You will not find listed a “Lower Rudder Surface” since it is no-go
jetwet1 wrote:I've spent the last week flying in and out of LHR on (sadly) BA's 320.
The first one was (judging from the cabin) an older 320 and the dog was barking like a pitbull on crack, the next couple were on newer aircraft (new style cabin, mood lighting etc) and no dog.
I did do a search, but couldn't find a clear answer (using my phone so searches are brutal), did Airbus change something to reduce the "barking" on later ceo's ?
