audidudi
Re: Airbus A350 Production/Delivery Thread - 2019
Wed May 08, 2019 7:20 pm
Thank you Mario! That's an amazing posting that you put together there!
JamesAlice
Thu May 09, 2019 2:20 pm
Jesus i'm sweating after that post! Excellent Mario.
hkcanadaexpat
Thu May 09, 2019 5:13 pm
MSN 297 (VN#14-last on order) active at the delivery centre
MSN 305 (SQ#34-Regional) sporting final reg (9V-SHF) - delivery imminent
MSN 307 (MU#6) active on the flightline
hkcanadaexpat
Fri May 10, 2019 9:04 am
MSN 260 (HX#9) maintenance engine run and taxi test (delivered 12/31/18)
MSN 310 (ET#12) out on another test flight #AIB03FA
hkcanadaexpat
Fri May 10, 2019 8:03 pm
MSN 241 (QR#41-35J) out on another test flight #AIB03GC
MSN 297 (VN#14-last on order) first CAF #AIB09FZ
MSN 311 (CA#10-last on order) RTO - first flight scheduled for Monday
hkcanadaexpat
Fri May 10, 2019 11:49 pm
MSN 305 (SQ#34-Regional) about to depart on its delivery flight as SQ8895. #269. #34 in 2019. #4 in May
audidudi
Sat May 11, 2019 12:46 am
Are there incorrect TOTAL and YTD deliveries being shown here, as #267 TOTAL and #32 YTD in 2019 seem to have been skipped? Shouldn't MSN 229 be #267 and #32 in 2019, and MSN #305 be #268 and #33 in 2019?
MSN 237 (QR#39-359) on its delivery flight as QR3350. #266. #31 in 2019. #2 in May
MSN 229 (QR#40-35J) on its delivery flight as QR3350. #268. #33 in 2019. #3 in May
hkcanadaexpat
Sat May 11, 2019 1:26 am
Post #550
hkcanadaexpat
Sat May 11, 2019 9:37 am
MSN 315 (EY#2) initial engine run this morning (unpainted)
hkcanadaexpat
Mon May 13, 2019 9:35 am
MSN 301 (OZ#9) active on the flightline
MSN 307 (MU#6) initial engine run
MSN 309 (SQ#35-Regional) active at the delivery centre
mfranjic
Mon May 13, 2019 7:14 pm
You are very welcome, audidudi! I have noticed with how much attention, dedication and personal contribution You are involved in this thread and that's why I was even more pleased to hear Your praise.
Thank You!
I hope You did recover quickly after reading my post, finding it at the same time interesting and obviously very exciting. Until now, I've been reported on the different side effects caused by reading my posts, but You are the first one who complains of sweating…
Thank You, JamesAlice, for paying attention to my post!
Image.Image.A350-941, MSN 305, reg. 9V-SHF, delivered on 11. May 2019 is Singapore Airlines#.34 Airbus A350-941 aircraft; #.6 Airbus A350-900 Regional.
On the Image.(please click on the image below)
….Image
….Singapore Airlines34th Image.A350-941 aircraft of the A350-900 Regional configuration (MTOW: 250.000 kg / 551.156 lb); MSN 305, reg. 9V-SHF, test reg. F-WZFP, with the cabin configuration C40 Y263 and powered by two Image.Trent XWB-84, three-shaft, high-bypass, turbofan engines (fan diameter: 2.997,2mm / 118,0 in; BPR: 9,6:1; engine architecture: 1F–8IPC=6HPC〨1HPT=2IPT–6LPT), OPR: 50,0:1, each rated at 374,54 kN / 38.192 kgf / 84.200 lbf, was delivered to SQ on 11. May 2019, flying on the route TLS - SIN (FLT SQ8895). The aircraft first flew on 19. Mar 2019.
…..Singapore AirlinesAirbus A350-941; MSN 305, reg. 9V-SHF - delivery flight SQ8895 (click on the image)
….Image
Singapore AirlinesAirbus A350-941, reg. 9V-SHF, is the 35th Image.A350 aircraft that left the factory in 2019 and 265th altogether for the 24 different airlines. Of that number, 246 aircraft are of the type A350-941 and 19 of the type A350-1041.
Singapore Airlines has three different cabin configurations on their fleet of, for the time being 34, Image.A350-941aircraft:
Image.Image.A350-900 (Standard) configuration (MTOW: 275.000 kg / 606.272 lb), cabin configuration: C42 W24 Y187, which operates predominantly the long-haul flights from Singapore to destinations in Europe, the USA and South Africa. The aircraft is also used on selected flights to Australia, Japan and some shorter flights to Kuala Lumpur, Jakarta and Hong Kong.
Image.Image.A350-900 Regional configuration (MTOW: 250.000 kg / 551.156 lb), cabin configuration: C40 Y263, which operates short- and medium-haul flights from Singapore across the Asia-Pacific region. The first aircraft was delivered in November 2018, and entered service on 17. Dec 2018.
Image.Image.A350-900 ULR configuration (MTOW: 280.000 kg / 617.295 lb), cabin configuration: C67 W94, which operates ultra long-haul non-stop flights from Singapore to the USA in a 2-class configuration.
……Image
……IMG.1 – Singapore AirlinesAirbus A350 aircraft by the cabin configurations (12. May 2019)
In the Singapore Airlines’ fleet the Image.A350-900 Regional aircraft come as the complement to their medium-haul fleet, with a somewhat smaller seating capacity (C40 Y263), but capable, according to SQ’s CEO, for a little longer distances in the comparison with their Image.787-10 aircraft with the cabin configuration C36 Y301 and powered by two Image.Trent 1000-J3, three-shaft, high-bypass, turbofan engines (fan diameter: 2.844,8 mm / 112,0 in; BPR: 10,0:1; eng. architecture: 1F–8IPC=6HPC1HPT=1IPT–6LPT), OPR: 50,0:1, rated at 347,54 kN / 35.439 kgf / 78.129 lbf.
In the recent issue of the type-certificate data sheet (TCDS) of the Image.A350 aircraft: Image.TCDS.EASA.A.151 Issue 17, dated on 03. Apr 2019, it is visible.(IMG.2) that the Image.A350-941 model, besides with the R-R Trent XWB-84, three-shaft, high-bypass turbofans, rated at 374,54 kN / 38.192 kgf / 84.200 lbf, has been also certified with the Image.Trent XWB-75, three-shaft, high-bypass, turbofan engines (fan diameter: 2.997,2mm / 118,0 in; BPR: 9,6:1; engine architecture: 1F–8IPC=6HPC1HPT=2IPT–6LPT), OPR: 50,0:1, rated at 330,06 kN / 33.657 kgf / 74.200 lbf, but Mod number 113768 has not been connected yet with any of the Weight Variant (WV) in this document -.IMG.3.
…...Image
…...IMG.2 - Airbus A350-900 TCDS - Engines
…...Image
…...IMG.3 - Airbus A350-900 TCDS - Maximum Certified Weights
In the last Image.A350 aircraft’s factory document - A350. ACAaMP Issue: Nov 01/16 Rev: Jun 01/18, the Weight Variant WV016 (MTOW: 278.000 kg / 612.885 lb) for the Airbus A350-900 aircraft has not been mentioned yet, but the Weight Variant WV017 (MTOW: 210.000 kg / 462.971 lb) is visible -.IMG.4
IMG.4 - Airbus A350-900 ACaMP - Maximum Certified Weights
... and quite possible it is the Weight VARIANT WV017 (Mod number 113768) missing in the above mentioned document.(IMG.3).
..…Image
..…IMG.5 - Possible Mod number code (113768) related to Airbus A350-900 Maximum Certified Weight variant WV017
As I have mentioned it in my previous post; some sources have cited incorrectly the Singapore AirlinesImage.A350-900 Regional aircraft (MTOW: 250.000 kg / 551.156 lb) are powered by two Rolls-Royce Trent XWB-75, three-shaft, high-bypass turbofans, rated at 330,06 kN / 33.657 kgf / 74.200 lbf. From the recent issue of the CAAS Singapore Aircraft Register, as well as from the airline’s website, it is visible that all the versions of SQ’s Image.A350-900 aircraft are powered by two Image.Trent XWB-84, three-shaft, high-bypass turbofans (fan diameter: 2.997,2mm / 118,0 in; BPR: 9,6:1; engine architecture: 1F–8IPC=6HPC1HPT=2IPT–6LPT), OPR: 50,0:1, rated at 374,54 kN / 38.192 kgf / 84.200 lbf. Besides, it is visible the recent (above linked) issue of the type-certificate data sheet (TCDS) of the Image.A350 aircraft does not connect Trent XWB-75 engine / mod 113768.(IMG.2) nor with one of the two Weight Variants (WV005 and WV012) which include MTOW of 250.00 kg / 551.156 lb.(IMG.3). Two e-mails I have received from the airline confirm that all the variants of the Singapore AirlinesAirbus A350-900 aircraft are fitted with the same type of engine, Image.Trent XWB-84...
According to those relevant sources, Japan Airlines is the first airline to operate derated Airbus A350-900 frames; WV017 (MTOW: 210.000 kg / 462.971 lb), aimed for those domestic routes (cabin configuration F12 C94 Y263). It seems quite possible, and there are clear indications about it, the aircraft, since it will be powered by Image.Trent XWB-75, three-shaft, high-bypass turbofans (fan diameter: 2.997,2mm / 118,0 in; BPR: 9,6:1; engine architecture: 1F–8IPC=6HPC1HPT=2IPT–6LPT), OPR: 50,0:1, rated at 330,06 kN / 33.657 kgf / 74.200 lbf, will be certified as the model Airbus A350-942, rather than as the existing Airbus A350-941 powered by two Rolls-Royce Trent XWB-84, three-shaft, high-bypass turbofans, rated at 374,54 kN / 38.192 kgf / 84.200 lbf.
It means soon we might see a new model label in the Image.A350 aircraft’s TCDS, related to different type of the engines fitted to the Airbus A350-900 aircraft of the Weight VARIANT WV017 / Mod number 113768 (MTOW: 210.000 kg / 462.971 lb). Something like this…
IMG.6 - Possible Airbus A350-900 Type Label changes related to the engine model
...and if those SQ’s Airbus A350-900 Regional aircraft were indeed powered by the R-R Trent XWB-75 engines, maybe we might have already seen them being labeled as the Image.A350-942. Possible reason why we haven't maybe lies in the fact that, while the JL’s A350s for domestic routes will have MTOW of 210.000 kg / 462.971 lb, those SQ’s A350-900 Regionals have noticeably higher MTOW of 250.000 kg / 551.156 lb...
The first of the four new SQ’s Image.A380-844plus (MTOW: 578.000 kg / 1.274.272 lb) aircraft, with the single-class cabin configuration Y747 and powered by four Image.Trent XWB-84, three-shaft, high-bypass, turbofan engines (fan diameter: 2.997,2mm / 118,0 in; BPR: 9,6:1; engine architecture: 1F–8IPC=6HPC1HPT=2IPT–6LPT), OPR: 50,0:1, each rated at 374,54 kN / 38.192 kgf / 84.200, is expected to join the fleet in the August 2019. The aircraft will be cerftified by EASA’s regional office in Singapore (opened on 11. Oct 2017) by the end of June, so far geting the principle approval of the African Civil Aviation Commission (AFCAC), Civil Aviation Administration of China (CAAC), the Russian Federal Agency for Air Transport (Rosaviatsiya) and The Civil Aviation Safety Authority (CASA) in Australia.
IMG.7 - Airbus A380-800 TCDS - Models and Engines
The model Image.A380-844plus, jointly developed by Singapore Airlines, one of the Airbus A380’s launch customer and the first operator, the Airbus SE and Rolls-Royce Singapore Pte. Ltd. comes as the part of the project named The Angels’ Wings for the Youth of the World. The project was created in cooperation of International Youth Foundation, The Government of Singapore and Singapore Airlines, with the idea of connecting young people living in the different parts of the Earth, with the idea of instilling into them, at the time of their growing up and maturing, the feeling of appreciation, respect and familiarity with the different nations, their culture, tradition, history and lifestyle. To create a numerous friendships and connections between them for a lifetime. To help them become esteemed, influential and respected members of the society, capable of inception some other, different and better place to live ... the better world ... The Whole New World.
… and wouldn’t it be an exceptional and quite unusual project?
Mario
"Only a life lived for others is a life worthwhile" - Albert Einstein
hkcanadaexpat
Mon May 13, 2019 7:53 pm
MSN 241 (QR#41-35J) new engine run (replacement engines?)
MSN 311 (CA#10-Star Alliance) maiden test flight #AIB01NJ
MSN 315 (EY#2) RTO - first flight scheduled for Tuesday (unpainted)
MSN 321 (JL#1) initial engine run
rufusmi
Mon May 13, 2019 8:31 pm
Mario
I thought SQ already received all of their A380s... and I didn’t think they were actually certifying a new engine on it?
hkcanadaexpat
Tue May 14, 2019 9:30 am
MSN 281 (3U#4) active at the delivery centre
MSN 285 (HU#5) maintenance engine run & taxi test (delivered 04/03/19)
MSN 306 (CX#34-35J) second test flight #AIB02HK
MSN 309 (SQ#35-Regional) first CAF #AIB03NR
MSN 325 (BF#3) active on the flightline
pabloeing
Tue May 14, 2019 9:40 am
¿Some news about VS A350's?
audidudi
Tue May 14, 2019 5:52 pm
MSN 295 (CA #9), B-308C, was delivered today from TLS>TSN, flying as CA080/CCA080. #5 in May...#35 in 2019...#270 total.
hkcanadaexpat
Tue May 14, 2019 7:15 pm
MSN 241 (QR#41-35J) out on another test flight #AIB04GC
MSN 249 (QR#42-359) initial engine run
MSN 295 (CA#9) on its delivery flight as CA080. #270. #35 in 2019. #5 in May
MSN 307 (MU#6) RTO - first flight scheduled for Wednesday
MSN 312 (IB#5) out on second test flight #AIB02NK
MSN 315 (EY#2) maiden test flight #AIB01FD (unpainted)
Kindanew
Tue May 14, 2019 8:11 pm
First unit delivered in September I believe. Possibly a hold up with the interior. Launch event for the 'Upper Class' cabin was a few weeks ago.
hkcanadaexpat
Wed May 15, 2019 9:39 am
MSN 270 (HX?) maintenance engine run and taxi test (unpainted)
MSN 281 (3U#4) first CAF #AIB03GT
audidudi
Wed May 15, 2019 5:23 pm
MSN 307 (MU #6) first test flight today as #AIB01GQ.
hkcanadaexpat
Wed May 15, 2019 7:13 pm
MSN 297 (VN#14-last on order) sporting final reg (VN-A899) - delivery this week
MSN 307 (MU#6) maiden test flight #AIB01GQ
MSN 321 (JL#1-359) RTO - first flight scheduled for Thursday
qf789
Thu May 16, 2019 4:48 pm
First flight for Japan Airlines A359 #1 MSN321 JA01XJ
https://twitter.com/CAlloing/status/112 ... 27937?s=20
Forum Moderator
hkcanadaexpat
Thu May 16, 2019 7:23 pm
MSN 249 (QR#42-359) RTO - first flight scheduled for Friday
MSN 274 (VS#1) spotted on the flightline with engines (unpainted)
MSN 309 (SQ#35-Regional) sporting final reg (9V-SHG) - delivery imminent
MSN 315 (EY#2) flew to XFW for paint #AIB02FD
MSN 321 (JL#1-359) maiden test flight #AIB01HF
mfranjic
Thu May 16, 2019 8:18 pm
I am kindly asking You to read this part of my previous post once again …
The model of the aircraft Image.A380-844plus does not exist, neither the project named 'The Angels’ Wings for the Youth of the World'.
It was not even a joke, as You thought N14AZ. For a moment it was a real, existing and alive project, but only in my head and that's the reason I finished the post with the words:
… and this document below… it does not exist. I made it …
Not at the one moment I have even laughed to those reactions to my post. I just thought: 'Oh, no, no ... no! It's not real, it doesn't exist! Don't You see?' … Anyhow, I apologize to those I have led to conlusion this aircraft and this project are real. I wish they were, but, unfortunately, they are not. The truth is that, with my 50 years, two armies, one war, 218 voluntary blood donations ... everything I left behind me, sometimes I can still be a really big and silly child living in the world of my own, far from everything and everyone ... I am sorry …
……...…Image
Image above:.(Please click for a larger view) On the left side is All Nippon Airways Co., Ltd.'s 2nd Image.A380-841 aircraft, MSN.263, reg. JA382A, test reg. F-WWAF, with the cabin configuration F8 C56 W73 Y383 and powered by four Image.Trent 970B-84, three-shaft, high-bypass, turbofan engines (fan diameter: 2.946,4 mm / 116,0 in; BPR: (7,7-8,5):1; engine architecture: .1F–8IPC=6HPC〨1HPT=1IPT–5LPT), OPR: 39,0:1, rated at 348,31 kN / 35.518 kgf / 78.304 lbf and on the other side is visible Sichuan Airlines4th Image.A350-941 aircraft; MSN 281, reg. B-306N, test reg. F-WZGT, with the cabin configuration C28 Y303 and powered by two Image.Trent XWB-84, three-shaft, high-bypass, turbofan engines (fan diameter: 2.997,2mm / 118,0 in; BPR: 9,6:1; engine architecture: 1F–8IPC=6HPC〨1HPT=2IPT–6LPT), OPR: 50,0:1, each rated at 374,54 kN / 38.192 kgf / 84.200 lbf.
Image.Image.A350-941, MSN 295, reg. B-308C, delivered on 14. May 2019 is Air China’s #.9 Airbus A350-941 aircraft;
….Image
….Air China’s 9th Image.A350-941 aircraft; MSN 295, reg. B-308C, test reg. F-WZHH, with the cabin configuration C32 W24 Y256 and powered by two Image.Trent XWB-84, three-shaft, high-bypass, turbofan engines (fan diameter: 2.997,2mm / 118,0 in; BPR: 9,6:1; engine architecture: 1F–8IPC=6HPC〨1HPT=2IPT–6LPT), OPR: 50,0:1, each rated at 374,54 kN / 38.192 kgf / 84.200 lbf, was delivered to CA on 14/15. May 2019, flying on the route TLS - TSN (FLT CA80) - PEK (FLT CA88). The aircraft first flew on 16. Apr 2019.
…..Air ChinaAirbus A350-941; MSN 295, reg. B-308C - delivery flight CA80 (click on the image)
….Image
…..Air ChinaAirbus A350-941; MSN 295, reg. B-308C - delivery flight CA88 (click on the image)
….Image
Air China’s Airbus A350-941, reg. B-308C, is the 36th Image.A350 aircraft that left the factory in 2019 and 266th altogether for the 24 different airlines. Of that number, 247 aircraft are of the type A350-941 and 19 of the type A350-1041.
A few of the Airbus A350 aircraft, although contractually delivered (31. Dec 2018), have never really left the factory:
…….MSN 246, HX.#.7, reg. B-LGF, test reg. F-WZGR
…….MSN 251, HX.#.8, reg. B-LGG, test reg. F-WWAW
…….MSN 260, HX.#.9, reg. B-LGI, test reg. F-WZNC
Image.A350 aircraft deliveries - by the airlines
….Image
….In the recent issue of the type-certificate data sheet (TCDS) of the Image.A350 aircraft: Image.TCDS.EASA.A.151 Issue 18, dated on 15. May 2019, it is visible.(IMG.1) that the Image.A350-941 model, besides with the R-R Trent XWB-84, three-shaft, high-bypass turbofans, rated at 374,54 kN / 38.192 kgf / 84.200 lbf, has been also certified with the Image.Trent XWB-75, three-shaft, high-bypass, turbofan engines (fan diameter: 2.997,2mm / 118,0 in; BPR: 9,6:1; engine architecture: 1F–8IPC=6HPC1HPT=2IPT–6LPT), OPR: 50,0:1, rated at 330,06 kN / 33.657 kgf / 74.200 lbf, but Mod number 113768 has not been connected yet with any of the Weight Variant (WV) in this document -.IMG.2.
…...Image
…...IMG.1 - Airbus A350-900 TCDS - Engines
…...Image
…...IMG.2 - Airbus A350-900 TCDS - Maximum Certified Weights
…...In this issue of the Image.A350 aircraft’s TCDS it is also visible that the new Weight Variant – WV 018 / Mod number 112498 (MTOW: 217.000 kg / 478.403 lb) was associated with the Airbus A350-900 aircraft, but unlike the Mod number 113768 (MTOW of 210.000 kg / 462.971 lb) that has been connected with the Image.Trent XWB-75 engine, rated at 330,06 kN / 33.657 kgf / 74.200 lbf, for the new Mod number 112498 (MTOW: 217.000 kg / 478.403 lb) it has not been done yet.
…...For now, we can only speculate whether will both of the mentioned Mod numbers: 112498 (MTOW: 217.000 kg / 478.403 lb) and 113768 (MTOW: 210.000 kg / 462.971 lb) and the Weight Variants associated with them, supposedly linked to the Image.Trent XWB-75 engine, will be certified as the model Airbus A350-942, rather than as the existing Airbus A350-941, powered by two Rolls-Royce Trent XWB-84, three-shaft, high-bypass turbofans, rated at 374,54 kN / 38.192 kgf / 84.200 lbf. Something like this …
IMG.3 - Possible Airbus A350-900 Type Label changes related to the engine model
…...That what You do here, in this thread, is just amazing job! When I joined this thread, this type of the posts You write was very valuable and useful to me. Thank You so much, hkcanadaexpat ...
Mario
hkcanadaexpat
Fri May 17, 2019 9:40 am
MSN 251 (HX#8) maintenance engine run & taxi test (delivered 12/31/18)
MSN 281 (3U#4) sporting final reg B-306N, delivery imminent
audidudi
Fri May 17, 2019 6:55 pm
MSN 297, VN-A899, the 14th and last A359 for VN, just took off from TLS>HAN. #6 in May...#36 in 2019...#271 total.
zakuivcustom
Fri May 17, 2019 7:12 pm
And The Wind Plane Rises.
That Airbus A350 text in the back make a beautiful plane looks even greater.
Free Hong Kong! Free China!
hkcanadaexpat
Fri May 17, 2019 8:17 pm
MSN 282 (JJ#11) new engine run after two weeks of repairs in hangar
MSN 297 (VN#14-last on order) on its delivery flight as VN096. #271. #36 in 2019. #6 in May
MSN 312 (IB#5) out on another test flight #AIB03NK
MSN 318 (CZ#1) exited the paint hangar yesterday with engines
hkcanadaexpat
Fri May 17, 2019 10:31 pm
MSN 309 (SQ#35-Regional) departing on its delivery flight as SQ8895. #272. #37 in 2019. #7 in May.
To put things in perspective, on 18/May/2018, Airbus was delivering its 29th A350 of 2018.
hkcanadaexpat
Sat May 18, 2019 9:54 am
MSN 310 (ET#12) out on another test flight #AIB04FA
MSN 338 (HU#8) rolled out of FAL last week
MSN 339 (CZ#3) rolled out of FAL last week
MSN 340 (BA#2) rolled out of FAL last week
hkcanadaexpat
Sat May 18, 2019 7:42 pm
MSN 311 (CA#10-last on order, special livery) out on a second test flight #AIB02NJ
hkcanadaexpat
Mon May 20, 2019 9:45 am
MSN 241 (QR#41-35J) active at the delivery centre
MSN 318 (CZ#1) active on the flightline
Some frames may have moved over the weekend but late last week there were 5 "first" A350s on the flightline (EY/JL/CZ/VS/BA)!
Ravi1925
Mon May 20, 2019 1:32 pm
MSN 330 (EY#3) active on the flightline
afriwing
Mon May 20, 2019 2:27 pm
What happened to MSN310 (ET#12)? last test flight a week ago
Afriwings
Ravi1925
Mon May 20, 2019 3:56 pm
Now online at DC
evanb
Mon May 20, 2019 4:36 pm
Any idea of the weight variants these three are?
hkcanadaexpat
Mon May 20, 2019 7:24 pm
MSN 249 (QR#42-359) maiden test flight #AIB01TW
MSN 310 (ET#12) active at the delivery centre
MSN 330 (EY#3) active on the flightline (unpainted)
hkcanadaexpat
Tue May 21, 2019 7:30 pm
MSN 306 (CX#34-35J) active at the delivery centre
MSN 310 (ET#12) first CAF #AIB05FA
MSN 325 (BF#3) initial engine run
hkcanadaexpat
Wed May 22, 2019 9:43 am
MSN 290 (EY#1) active at the delivery centre
MSN 301 (OZ#9) initial engine run
MSN 306 (CX#34-35J) first CAF #AIB03HK
AECM
Wed May 22, 2019 2:51 pm
Does anyone know which Singapore A359 will be the first to get the Trent XWB-84 EP?
audidudi
Wed May 22, 2019 4:47 pm
MSN 281 (3U #4), B-306N, was delivered today from TLS>TSN and has the "Panda Route" special c/s. #8 in May...#38 in 2019...#273 total.
hkcanadaexpat
Wed May 22, 2019 7:53 pm
MSN 281 (3U#4) on its delivery flight as 3U303. #273. #38 in 2019. #8 in May
MSN 307 (MU#6) second test flight #AIB02GQ
MSN 311 (CA#19-last on order, special livery) active at the delivery centre
MSN 312 (IB#5) first CAF #AIB04NK
MSN 325 (BF#3) RTO - first flight scheduled for Thursday
chonetsao
Wed May 22, 2019 8:09 pm
CA should be #10, not number 19. Must be a typo.
hkcanadaexpat
Thu May 23, 2019 8:38 am
MSN 241 (QR#41-35J) first CAF #AIB05GC
MSN 290 (EY#1) first CAF #AIB04NI
MSN 311 (CA#10-last on order) first CAF #AIB03NJ
Hansea7
Thu May 23, 2019 4:17 pm
https://twitter.com/A350_Production/sta ... 4031031301
Is this the new production standard? Where are the sensors now?
hkcanadaexpat
Thu May 23, 2019 7:02 pm
MSN 298 (VS#1) initial engine run (unpainted)
MSN 301 (OZ#9) RTO - first flight scheduled for Friday
MSN 321 (JL#1-359) second test flight #AIB02HF
MSN 325 (BF#3) maiden test flight #AIB01IW
MSN 341 (SQ#40-LH) rolled out of FAL
Kindanew
Thu May 23, 2019 10:26 pm
Hansea7 wrote:
https://twitter.com/A350_Production/status/1130158544031031301
I believe the information those sensors provided can be gleaned from other sensors.
audidudi
Fri May 24, 2019 3:40 pm
MSN 301 (OZ #9) F-WZHE/HL8361, maiden test flight, #AIB01HE.
hkcanadaexpat
Fri May 24, 2019 8:36 pm
MSN 282 (JJ#11) RTO - first flight scheduled for next week
MSN 298 (VS#1) RTO - first flight scheduled for Monday
MSN 301 (OZ#9) first flight #AIB01HE
MSN 310 (ET#12) departing on its delivery flight as ET9201. #274. #39 in 2019. #9 in May
817Dreamliiner
Sat May 25, 2019 7:56 am
photo:
ImageRTO msn298 F-WZNU 24/5/2019 by A380_TLS_A350, on Flickr
And the BA A35K MSN326 has its engines:
ImageMsn326 F-WZFH 24/5/2019 by A380_TLS_A350, on Flickr
I'll wake from the dream, To keep and relive, Now life it is a dream, And dream's on a... BREAK!
