Heights wrote:cvgComair wrote:CVG has posted bids for 12 food concessions and another sit-down restaurant. Looks like 6 and 6 in both concourses. Not sure if the concessions are new or replacements of current vendors. Chapel room is also being relocated to Concourse B to free up space in the main terminal.
Also an interesting tidbit, it appears the new airline lease agreement will take effect in January 2020 with negations ongoing. It shall be interesting to see what DL does with its space usage.
Two things I wonder are
1. Are they negotiating the framework/funding for replacing the terminal at CVG
2. DL's future role at CVG
DL is squatting on a lot of gates in B that could be better used elsewhere, if they aren't going to use them all to a decent extent, they should become common use. Given DL is down to 80 or so flights, they only need about 10-12 gates now. Long term, the terminal layout at CVG needs to become more O&D friendly. I'd like to see the entire terminal complex replaced with a similar design to IND.
jtwall wrote:Heights wrote:cvgComair wrote:CVG has posted bids for 12 food concessions and another sit-down restaurant. Looks like 6 and 6 in both concourses. Not sure if the concessions are new or replacements of current vendors. Chapel room is also being relocated to Concourse B to free up space in the main terminal.
I wouldn't necessarily say that DL is squatting on a lot of gates. When I came in from Seattle on the red-eye on Monday morning, we actually had to wait a few minutes for a gate to open up. They still have a fairly busy morning rush out of CVG.
I also might be in the minority here, but I personally don't mind the current terminal layout. It's pretty easy to still get to any gate in 5-10 minutes from security (as long as the moving sidewalks are operational!).
Yep, DL isn’t squatting on gates, they use all of them at peak times.
Agreed, I don’t get the obsession with a new terminal. CVG is nicely laid out as is. Really the only issue is the customs area.
ncflyer wrote:Hopping on this topic a bit late and I suppose I could be guilty of a digression, but gate utilization at CVG isn't measured by flights per gate per day. I think we've been conditioned to read too much about WN and how they can pump planes in and out of gates (which in my observation they really don't excel at nearly as much now that their network is much more complicated and more like a traditional hub and spoke). The driver is gates needed at peak hours, which is likely RON flights up until they leave. To assess Delta's utilization of gates, I'd count how many flights depart between let's say 5:30AM and 8AM-- or even more broadly, scheduled departures across the hours of a day.
Yep. The customs area is the only real problem with the airport. Once the new CONRAC is finished, the customs area is the biggest problem. When I came back on WW this summer, most people were griping about reclearing security (most of which have never come in on the CDG flight previously, I am assuming). Some people said they would rather just connect sometimes than deal with the reclearing. While that's a bit extreme, it could suppress demand just enough which might hurt CVG in landing more TATL flights that will inevitably be driven somewhat significantly by leisure travelers.
flyguy89 wrote:jtwall wrote:cvgComair wrote:Yep, DL isn’t squatting on gates, they use all of them at peak times.
They'd have to reclear security if they connected as well though. Doesn't make a lot of sense. Anywho... seems like an easy enough problem to address if it truly becomes an issue: add a sterile bypass to a bus to take destinating pax directly to main terminal baggage claim.
ILNFlyer wrote:
topguncnod wrote:Noticed quite a few 737-700’s on the CVG-ATL routes right now. Can’t really remember seeing them here before. @CVGcomair? Maybe you already mentioned this?
Definitely a good way to utilize the 73N pilot base at CVG without adding too much capacity from all the 88–> 73 upguages
cvgComair wrote:topguncnod wrote:Noticed quite a few 737-700’s on the CVG-ATL routes right now. Can’t really remember seeing them here before. @CVGcomair? Maybe you already mentioned this?
Yeah, they loaded the March schedule a while back and recently loaded them in April/May as well. Kind of surprising given how limited they are in the fleet, but I am happy they are reducing the MD fleet at CVG. Although I like the 88/90 as planes, they don't compare to the A320/B737 interiors with PTV/outlets.
cvgComair wrote:AA has extended the 3x mainline on CVG-DFW through June.
Cvgspotter15 wrote:cvgComair wrote:AA has extended the 3x mainline on CVG-DFW through June.
I saw on twitter you said they were also flying 6x daily. Isn't that a daily upgauge? I believe its 4x daily right now with 2 mainline flights and then 2 AE on Embraers.
Cvgspotter15 wrote:Also, sorry for the triple post, I know UA has been really up-gauging flights to mainline which I love, but I can't help to notice the daily flights keep going down in the OAG reports YOY. Don't know if this is just for the month, but ive noticed this multiple times. i.e. IAD and EWR.
miaami wrote:AA at CMH has some changes starting in May.
CMH-DFW down to 4 mainline flights
CMH-ORD downgauges 2 738s to Eagle
CMH-MIA back to 3 flights after being reduced for the month of APR to 2
CMH-LGA upgauge 1 of 6 flights from Eagle to mainline E-190
CMH-JFK upgauge to E-175
I'm curious if there will be additional changes to the summer schedule starting in June.
DeltaRules wrote:VX lands at CMH, if only in spirit and for one day: https://twitter.com/michealw31/status/1 ... 0016186368
flyCMH wrote:DeltaRules wrote:VX lands at CMH, if only in spirit and for one day: https://twitter.com/michealw31/status/1 ... 0016186368
A day after (today), AS is sending an ex-VX A321-neo to CMH:
https://www.flightradar24.com/ASA1692/1fc7961d
DeltaRules wrote:Joe Nardone talks AS and the need to support the service going forward: https://www.bizjournals.com/columbus/ne ... s-off.html
ChasChandler wrote:DeltaRules wrote:Joe Nardone talks AS and the need to support the service going forward: https://www.bizjournals.com/columbus/ne ... s-off.html
Can you bullet point some of the key items?
DeltaRules wrote:ChasChandler wrote:DeltaRules wrote:Joe Nardone talks AS and the need to support the service going forward: https://www.bizjournals.com/columbus/ne ... s-off.html
-Nardone is excited to see CMH-SEA but is fully aware the community has to support the flights (including SFO and SLC) to keep them and is encouraging travelers to do so.
-The first few days' worth of flights are sold out.
-Alex Fischer from the Columbus Partnership acknowledges the value of SEA to Columbus-area companies with ties to Asia (with Honda the biggest) as it's a gateway.
-Columbus is drawing attention for its status as a rising hub for startup companies/venture capital.
I'm only one person, but the first point isn't lost on me- I'm going to SFO in September and intend on connecting through SLC at least one direction (DL loyalist here).
DeltaRules wrote:(DL loyalist here).
CMH2578 wrote:DeltaRules wrote:ChasChandler wrote:Can you bullet point some of the key items?
You're a Delta loyalist?? The handle seemed to suggest otherwise
JK, also a Delta flyer and live in Columbus.
Seems reading between the lines of Fisher's comment is that Delta is at least interested in the SEA route as well. Both from the perspective of protecting their (DL) SEA hub and onward connections to points west (since AS isn't going past SEA).
CMHtraveler wrote:DeltaRules wrote:(DL loyalist here).
How does a one-off airline with one long and thin route to one city make it at CMH post-incentives? What FF wants to earn zero points when they could make one quick stop on their airline of choice with service to multiple hubs, especially with DL starting SLC which is “on the way” to SEA?
flyCMH wrote:I think the route is more geared towards people in Seattle and the PNW that need access to Central Ohio. People in that area of the US are fiercely loyal to AS. My guess is that they anticipate similar results as SEA-IND, which has since grown to include a Delta competing flight. With big data establishing a decent presence in Central Ohio, growth in the PNW as well as in the Columbus Region, and the need for AS to continue to venture into new markets, the anticipation is that a route to CMH is finally commercially viable.
fsafsx wrote:When will Cbus get an expansion from Spirit? I hope they add 5 new routes soon and build a good size operation.
Delta28L wrote:fsafsx wrote:When will Cbus get an expansion from Spirit? I hope they add 5 new routes soon and build a good size operation.
Probably after Spirit analyzes the data of the station performance and also to see if they are making any money. My guess would be probably in a couple of years. Pittsburgh hasn’t gotten any new routes. We actually lost the KDFW route (which wasn’t surprising since AA and SWA ran them off) and Latrobe hasn’t gotten any new routes. They’ve lost the KLAS and KDFW routes but the KDFW route was moved to KPIT before being dropped.
jplatts wrote:Here are the PDEW's for CMH-DFW/DAL and CVG-DFW/DAL in Q3 2018:
CMHtraveler wrote:jplatts wrote:Here are the PDEW's for CMH-DFW/DAL and CVG-DFW/DAL in Q3 2018:
jplatts, do you know the PDEW for CMH-MSY? Hoping for more than sporadic service from NK or WN at some point.
ChasChandler wrote:CMHtraveler wrote:jplatts wrote:Here are the PDEW's for CMH-DFW/DAL and CVG-DFW/DAL in Q3 2018:
It would be interesting to see the historic data for a PDEW from CVG and CMH to various cities. It took forever for CMH to get a flight to LAX and many thought it was because there wasn't the traffic to support it. Now there are three flights. Somehow passengers came from somewhere at a rate high enough to support three flights when there was a question if they could support one.
Midwestindy wrote:2018
Q1 104 PDEW
Q2 ? PDEW
Q3 84 PDEW
AA CVG-ORD MAY 7>8[6] JUN 7>8[7]
DL CVG-SEA MAY 0.5>0.9[0.7] SEP 0.7>0.9[0.7]
WN BNA-CMH OCT 0.1>3[1.9]
WN CMH-TPA OCT 0.1>3[1.9]
cvgComair wrote:Two nice increases in the OAG for CVG:AA CVG-ORD MAY 7>8[6] JUN 7>8[7]
jtwall wrote:cvgComair wrote:Two nice increases in the OAG for CVG:AA CVG-ORD MAY 7>8[6] JUN 7>8[7]
Unfortunately it looks like WN is dropping a CVG-MDW frequency, dropping down to 4. Unless that's been going on for a while.
jplatts wrote:There is an article titled "Editorial: Want more direct flights from CMH? Use the ones we have" that was published on the Columbus Dispatch website today, which can be found at https://www.dispatch.com/opinion/20190225/editorial-want-more-direct-flights-from-cmh-use-ones-we-have.
