superbizzy73 wrote:https://www.flightglobal.com/news/articles/korean-air-a220-suffers-significant-engine-damage-454740/
Mods, please do move as you see fit. Just saw this come across the news. Does anyone know any more information about what happen?
strfyr51 wrote:superbizzy73 wrote:https://www.flightglobal.com/news/articles/korean-air-a220-suffers-significant-engine-damage-454740/
from the pictures? It looks like Foreign Object damage. but whatever it was? it ate that engine UP!! That's an overhaul for sure!!
c933103 wrote:Video at https://m.news.naver.com/read.nhn?mode= ... 0000199417 contain higher resolution zoom in/highlight to the sane photo
Revelation wrote:strfyr51 wrote:superbizzy73 wrote:https://www.flightglobal.com/news/articles/korean-air-a220-suffers-significant-engine-damage-454740/
http://newsinflight.com/2019/01/01/engi ... rbus-a220/ gives us:
That will not just buff out.
uta999 wrote:c933103 wrote:Video at https://m.news.naver.com/read.nhn?mode= ... 0000199417 contain higher resolution zoom in/highlight to the sane photo
Love the way the news item includes clips of an A380, a 77W and cabin views of a WB, as well as them maintaining a 77W engine which is bigger than an A220 fuselage.
Spacepope wrote:Revelation wrote:strfyr51 wrote:from the pictures? It looks like Foreign Object damage. but whatever it was? it ate that engine UP!! That's an overhaul for sure!!
No, that will clearly take some bondo to fix. Maybe fiber strand.
Looks like it ate something hard. Question now becomes did said hard crunchy object come from inside or outside the motor....
Nothing to make one think this damage came from outside the engine...but with all the talk of drones these days, I can only imagine this is sort of what might happen should one ever get ingested. Not good on climbout or takeoff.
william wrote:uta999 wrote:c933103 wrote:Video at https://m.news.naver.com/read.nhn?mode= ... 0000199417 contain higher resolution zoom in/highlight to the sane photo
Worse than "Hollywood" movies.![]()
kalvado wrote:A traditional question... Is it a write-off?
More elaborate version of the same question:
apparently rotor and stator blades from the last stage as seen in picture are scrap metal. Probably at least some of stages before that also damaged. What would that do to the engine in general? Shafts, bearings? Blade attachment points? SO is it worth to rebuild such an engine after all, or it is just spare parts donor at this point?
Waterbomber wrote:If we look at the damage on the shroud, to me it looks like the turbine started rotating outside its normal axis and engraved itself into the shroud while turning. This can explain the shear point moving from the tip of the turbine blades towards the root as the turbine rotated clockwise which you can see from right to left. It also explains the shroud being broken and losing its circle shape.
Also it looks like the turbine blades' leading edge scraped the vanes.
So my speculation is a shaft or aft bearing failure.
Revelation wrote:Waterbomber wrote:If we look at the damage on the shroud, to me it looks like the turbine started rotating outside its normal axis and engraved itself into the shroud while turning. This can explain the shear point moving from the tip of the turbine blades towards the root as the turbine rotated clockwise which you can see from right to left. It also explains the shroud being broken and losing its circle shape.
Interesting analysis!
Given Pratt has had issues with the aft bearings, it's quite plausible.
I wonder if any of the low pressure spool parts can be reused after such a deceleration.
stephanwintner wrote:https://www.flightglobal.com/news/articles/damaged-a220-pw1500g-undergoes-examination-in-usa-455104/
Well, that's not adding any clarity to the matter....
WayexTDI wrote:stephanwintner wrote:https://www.flightglobal.com/news/articles/damaged-a220-pw1500g-undergoes-examination-in-usa-455104/
Can you summarize/provide another source? Article is for subscribers only.
Momo1435 wrote:WayexTDI wrote:stephanwintner wrote:https://www.flightglobal.com/news/articles/damaged-a220-pw1500g-undergoes-examination-in-usa-455104/
- The engine has been shipped to the USA for examination, P&W will tear the engine down completely.
- Airbus says they think it's an isolated incident, but they don't know for sure until the examination is completed.
anxo75 wrote:What a wonderful aircraft! Everything that happens to it is an "isolated incident".
ITMercure wrote:FOD? Why 'foreign'? It could also be that a fan blade broke and shattered, damaging other blades. Or that the fan case slightly ovalized, leading to fan tip friction that shattered metal pieces and damaged the fan.
RB211trent wrote:Definitely not FOD. Internal failure resulting in damage downstream.
GlobalAirways wrote:Has anyone done a drone test on a commercial engine? You hear about them more and more entering air space. Maybe when they are cannoning the frozen birds during testing they can throw a couple drones in too?
strfyr51 wrote:ITMercure wrote:FOD? Why 'foreign'? It could also be that a fan blade broke and shattered, damaging other blades. Or that the fan case slightly ovalized, leading to fan tip friction that shattered metal pieces and damaged the fan.
Foreign object Damage is a generic term for anything other than Air that goes down an engine which damages it, It could have been MANY things But anything other than Airflow? Would be considered a foreign Object.
strfyr51 wrote:RB211trent wrote:Definitely not FOD. Internal failure resulting in damage downstream.
and how could you say it's NOT? The leading and trailing edges pf the turbine are torn up so the damage had to come from Forward, Since we can't see the inlet? How would you know unless you did the Borescope inspection? Which you probably DIDN'T..
stephanwintner wrote:@ Joe, no, that's a view from the aft at the back of the LPT. Between the turbine exhaust case struts at the stage 3 blades. Well, where the stage 3 blades should be.
@Wayextdi sorry didn't realize it was for subscribers. I'd agree with the summary Momo posted. (Subscribe mate, it's free! Good content too, I like it better than AvWeek)
JoeCanuck wrote:
Are you sure? I may have it wrong but I didn't think the exhaust behind the LPT was painted. Plus...the blades of the first two rows we see, (I'm not talking about the large support struts), are canted in opposite directions. It seems to me that the first row of blades could be a stator, with the second row being the first stage of the low pressure compressor. Judging by the direction of the second row of blades, they look to be angled in the same direction as the low pressure compressor, not the low pressure turbine.
Also to me, it just doesn't look like these parts have seen any significant heat.
If I am correct, (and I may very well be out to lunch on this), then the damage could very well have been FOD ingestion.
787SIN wrote:That is the exhaust section of the engine quite clearly. Last stage of LPT (3rd), with vane segments in front of it. Very unlikely to be the result of FOD damage if its just at the rear of the engine. Even with most ingestion events the debris is normally all but destroyed by the time it gets through the combustion chamber.
Although if you get a really bad ingestion event or a compressor blade/vane/blade lock etc. fail then you'll get a corn cobbed compressor from where the first failure occured, in that case, there may be metallic residue aft of the combustion chamber in the form of metal splatter. This sometimes blocks the cooling in the first stages (blades/vanes) of the turbine leading to burnback of the material due to localised hot spots potentially the resulting in failure of turbine parts. But as the front is usually toast by this stage it is unusual to get anything more than some blocked cooling holes/channels as the engine is unlikely to run for that long in this state.
For this one the look of the damage here appears to be very similar to what would be experienced if a blade had failed in the turbine, given it is a new engine in all likelihood a material defect that may have got past inspections following manufacture and a premature failure has occured.
stephanwintner wrote:https://aviation-safety.net/wikibase/wiki.php?id=222410
This incident seems to have also had a failure of the 3rd stage LPT blade...
