enilria
OAG Changes 2/3/2019: AA;B6;UA;WN;XE Adds TRM;Swoop Routes;
Sun Feb 03, 2019 2:34 pm
FAQ
AS OF JULY 2018 THERE ARE CHANGES TO THE FORMAT OF THIS REPORT...SEE BELOW
WHAT IS THIS REPORT?
This compares departures for sale THIS WEEK for the stated period versus what was for sale LAST WEEK...prior year departures are now shown in brackets e.g. [0].
THE SCHEDULES SHOWN HERE CHANGE AFTER YOU POST???
-To improve is to change; to be perfect is to change often---Winston Churchill. This is data the carriers filed at the point in time it was captured. It's changed since then. You are just going to have to live with it.
HOW DO I READ IT?
XXX-YYY DEC 4>5[4] JAN 4>5[4]
XXX Departure IATA code, YYY Arrival IATA code, Month, Average Departures/Day over the month for sale as of last week, Average Departures/Day over the month for sale as of this week, in brackets is the number of Average Departures/Day over the month that were scheduled one year earlier. So, it means that the listed airline changed the frequency between the two airports to add from 4 to 5 roundtrips in December and January. It also means that there were 4 roundtrips the prior year in each month. No other months were changed. I average two directions.
WHAT ABOUT CARRIERS THAT DON'T PUBLISH A SCHEDULE 9 MONTHS IN ADVANCE?
NEW CHANGE-Sometimes airlines do not load their schedules for the entire 330 day standard sales window. Southwest and many LCCs load their schedules for as little as 5 months into the future. When these flight are extended into a new sales month, it becomes a "schedule change". Previously, I have manually deleted these in many cases and replaced them with a Year-Over-Year compare. Effective immediately, this will now change. When a flight is loaded from 0 departures X departures, where X was the same the prior year, the record will not be shown. For example, if Delta loaded ATL-EGE MAR 0>1(1), it would not be shown because this additional flight does not represent a real year-over-year addition. Similarly, if B6 extended their schedule a record like this ATL-BOS JUL 0>4(4) would not be shown. It will be shown if the flight frequency changed from the prior year. So B6 ATL-BOS JUL 0>3(4) would be shown. If a partial month was loaded in a core schedule that became a full schedule month, those changes may be shown under this logic. For example, WN BNA-SEA 0.3>2(2). Because only a fraction of the month was previously loaded for sale, these changes will not be filtered out. I may, however, manually remove them to declutter.
HOW ARE THE DAILY DEPARTURES CALCULATED?
This report uses total operations for the month listed, divided over the days in the month. The following criteria are used to show a change: 1) The change must be at least 6 roundtrips per month with no exceptions, 2) changes of at least 6/week are always shown, 3) routes that are added or dropped are shown subject to the change minimum, and 4) in all other cases routes must change by 20% to be shown. For example, if a route changed from 21/week to 18/week it would not be shown because the change is -14.3%. This is done to filter minor changes that occur in large numbers.
WHAT ARE THE FRACTIONAL FLIGHTS?
Flights that do not operate every day of the month create fractional service. If the route has more than 2 daily flights, departures are rounded, but in cases of less than 2 departures per day a fraction is shown. For example, if a flight operates 4 times in April it will show 4/30=0.133=0.1. Also , a flight that only operates once per week may vary between 0.1 and 0.2 because a weekday may repeat either 4 or 5 times depending on the month.
THOSE FLIGHTS AREN'T DELTA, THEY ARE SKYWEST
This report only shows the marketing code. It is too complicated to show all the operators.
THE FREQUENCIES MAY HAVE CHANGED AS YOU SHOW, BUT THE SEATS DIDNT CHANGE BECAUSE OF EQUIPMENT SWAPS
Seats are not shown. That is a natural weakness of a frequency based report, but it provides something to discuss below.
THIS LOOKS LIKE AN ERROR?
The carriers file the schedules. They do make mistakes. Most of the mistakes I have seen are either related to code shares not being marked as "duplicates" or carriers filing flights with invalid data such as equipment codes that are not standard or overlapping schedule periods that see the same flight number in two places at once. These cause flights to not appear.
CHARTERS?
Lately charters have been showing up in the database. I have no idea if that will continue.
I marked some of the ones I thought were interesting with an "*".
9K ACK-JFK MAY 0.9>0.5[0]
9X BWI-DUJ MAY 1.3>2[2] JUN 1.3>2[2] JUL 1.3>2[2] AUG 1.3>2[2] SEP 1.3>2[2] OCT 1.3>2[2] NOV 1.3>2[2]
9X DFW-HRO MAY 0.9>1.6[1.6] JUN 0.9>1.5[1.6] JUL 0.9>1.6[1.6] AUG 0.9>1.6[1.7] SEP 0.9>1.6[1.7] OCT 0.9>1.6[1.7] NOV 0.9>1.6[1.7]
9X DUJ-PIT MAY 2>3[3] JUN 2>3[3] JUL 2>3[3] AUG 2>3[3] SEP 2>3[3] OCT 2>3[3] NOV 2>3[3]
9X EYW-PBI MAR 1.3>1.0[0] APR 1.3>0.8[0] MAY 1.3>0.8[0] JUN 1.3>0.9[0] JUL 1.3>0.8[0] AUG 1.3>0.9[0] SEP 1.3>0.9[0] OCT 1.3>0.8[0] NOV 1.3>0.9[1.1]
*9X MDT-PIT MAR 0.7>0[1.7] APR 0.7>0[1.7] MAY 0.7>0[1.7] JUN 0.7>0[1.7] JUL 0.7>0[1.7] AUG 0.7>0[1.7] SEP 0.7>0[1.5] OCT 0.7>0[0.9] NOV 0.7>0[0.9]
AA ABE-PHL MAY 4>3[3]
AA ABQ-PHX MAY 4>5[5]
AA ACT-DFW MAY 5>6[5]
AA ANU-JFK MAY 0.7>1.0[0.7]
AA ANU-MIA AUG 1.6>2[1.0] SEP 0.1>1.1[1.0] NOV 1.5>1.0[1.0]
AA ATL-ORD MAY 6>4[5]
AA AVP-CLT MAY 3>4[4] JUN 3>4[4] JUL 3>4[4] AUG 3>4[3]
AA AVP-PHL MAY 4>3[3]
AA BAQ-MIA MAY 1.0>0.7[1.0]
AA BDL-ORD MAY 4>5[4]
AA BDL-PHL MAY 6>4[6]
Earlier start
*AA BGR-CLT MAY 0>0.9[0]
AA BNA-ORD MAY 8>9[7]
AA BOI-DFW MAY 1.0>1.9[1.0]
AA BOS-JFK MAY 5>3[4]
AA BTV-PHL MAY 5>4[5]
AA BUF-DCA MAY 4>3[4]
AA BUF-PHL MAY 6>5[6]
AA BWI-ORD MAY 5>4[5]
AA CAE-DCA MAY 3>4[3]
AA CAE-DFW MAY 1.9>2[1.9]
AA CAE-PHL MAY 3>1.9[2]
AA CAK-ORD MAY 3>1.7[2]
AA CAP-MIA MAY 1.0>0.6[1.0]
AA CHO-ORD MAY 2>3[2]
AA CHS-DFW MAY 3>4[3]
AA CHS-LGA MAY 0.3>0.9[0]
AA CLE-CLT JUN 6>7[7] JUL 6>7[6]
AA CLT-DEN MAY 5>6[6]
AA CLT-DTW MAY 7>6[7]
AA CLT-EWN JUN 6>5[6] JUL 6>5[6]
AA CLT-FAY MAY 6>7[7]
AA CLT-FLL MAY 7>6[7]
AA CLT-FLO MAY 3>4[5]
AA CLT-GRR MAY 2>3[2] JUN 2>3[2] JUL 2>3[1.9] AUG 2>3[2]
AA CLT-GSO MAY 8>9[8]
AA CLT-GSP MAY 8>9[8]
AA CLT-IAD MAY 8>7[7]
AA CLT-JAN MAY 4>3[3]
AA CLT-LAX MAY 6>7[6]
AA CLT-LEX MAY 5>4[6]
AA CLT-MDT MAY 5>6[5] JUN 5>6[5] JUL 5>6[5]
AA CLT-MHT MAY 3>4[3]
AA CLT-MYR MAY 9>8[7]
AA CLT-OAJ MAY 7>5[5]
AA CLT-OKC MAY 2>3[2]
AA CLT-PBI MAY 4>6[6]
AA CLT-PDX MAY 1.9>1.0[1.0]
AA CLT-RSW MAY 4>6[5]
AA CLT-SAN MAY 3>4[3]
AA CLT-SDF MAY 8>7[8]
AA CLT-SFO MAY 6>5[6]
AA CLT-SYR MAY 3>4[3]
AA CLT-TUL MAY 2>3[2]
AA CLT-TYS MAY 7>6[8]
AA CLT-YYZ MAY 4>5[4]
AA CMH-DFW MAY 5>4[4]
AA CMH-ORD MAY 8>9[8]
AA CMH-PHL MAY 7>6[6]
AA COS-DFW MAY 4>5[4]
AA COS-ORD MAY 2.0>1.0[1.8]
AA CUN-MIA MAY 6>5[6]
AA CUN-ORD MAY 1.0>0.7[1.9]
AA CUR-MIA NOV 0.1>2[2]
AA CUU-DFW MAY 2>3[2]
AA CVG-PHL MAY 6>5[6]
AA CYS-DFW MAY 1.0>1.9[0]
AA DAY-DCA MAY 4>3[5]
AA DAY-PHL MAY 5>4[5]
AA DCA-DFW MAY 9>10[9]
AA DCA-DSM MAY 1.0>1.8[1.0]
AA DCA-GSP MAY 2>3[2]
AA DCA-MYR MAY 1.0>1.3[1.0]
AA DCA-ROC MAY 3>4[3]
AA DCA-TPA MAY 3>4[4]
AA DCA-YYZ MAY 3>1.9[3]
AA DEN-PHL MAY 2.0>3[1.8]
Earlier start
*AA DFW-EYW MAY 0>1.1[0] JUN 1.0>1.2[0.1]
AA DFW-GCM MAY 0.3>0.5[0.3]
AA DFW-GDL MAY 2>3[2]
AA DFW-GRI MAY 2>3[2] JUN 2>3[2] JUL 2>3[3] AUG 2>3[2]
AA DFW-GSO MAY 1.9>3[1.9]
AA DFW-GSP MAY 2>3[1.9]
AA DFW-IAD JUN 4>5[4] JUL 4>5[4]
AA DFW-JLN MAY 2>3[2.0]
AA DFW-LBB MAY 7>8[6]
AA DFW-MAF MAY 8>7[5]
AA DFW-MCI JUN 7>8[7] JUL 7>8[7] AUG 7>8[7] SEP 7>8[7] OCT 7>8[7] NOV 7>8[7]
AA DFW-MEI MAY 0.5>1.0[0.5]
AA DFW-MEM MAY 7>9[6] JUN 7>8[7] JUL 7>8[7]
AA DFW-MOB MAY 3>4[3]
AA DFW-PIB MAY 0.5>1.0[0.5]
AA DFW-PIT MAY 5>4[4]
AA DFW-RAP MAY 2>3[2]
AA DFW-SBA MAY 1.0>1.9[1.0]
AA DFW-SDF MAY 5>6[6] JUN 5>6[5] JUL 5>6[6] AUG 5>6[6] SEP 5>6[6] OCT 5>6[5] NOV 5>6[5]
AA DFW-SFO JUN 9>10[9] JUL 9>10[9] AUG 9>10[9]
AA DFW-SGF MAY 7>8[7]
AA DFW-SHV MAY 5>6[5] JUN 6>7[5] JUL 6>7[5] AUG 6>7[5] SEP 5>6[6] OCT 5>6[6] NOV 5>6[6]
AA DFW-STL JUN 7>8[7] JUL 7>8[7] AUG 7>8[7] SEP 7>8[6] OCT 7>8[7] NOV 7>8[7]
AA DFW-SWO MAY 2>3[2] JUN 2>3[2] JUL 2>3[2] AUG 2>3[2] SEP 2>3[2] OCT 2>3[2] NOV 2>3[2]
AA DFW-TLH MAY 2>3[1.9]
AA DFW-TVC SEP 0.1>1.0[0]
AA DFW-YVR MAY 2>3[2]
AA DSM-ORD MAY 6>7[6]
AA DTW-LGA MAY 4>5[4]
AA DTW-PHL MAY 6>5[6]
AA ELP-LAX MAY 2>3[2]
AA FAT-LAX MAY 4>3[5]
AA GJT-PHX MAY 2>3[2]
AA GRR-ORD MAY 7>5[6]
AA GSO-LGA MAY 3>4[3]
AA HPN-ORD MAY 2>3[3]
AA IAH-PHL MAY 4>3[3]
AA IND-LAX MAY 1.9>1.0[1.9]
AA JFK-LAS MAY 3>1.9[2]
AA JFK-LAX MAY 12>11[12]
AA JFK-MCO MAY 2>0.1[2]
AA JFK-ORD MAY 1.1>3[1.0] JUN 1.0>1.3[1.0]
AA JFK-ORF MAY 1.9>1.0[2]
AA JFK-SEA MAY 3>1.9[1.0]
AA JFK-YUL MAY 2>1.1[2]
AA LAX-MSY MAY 2>1.1[1.0]
AA LAX-RDM MAY 1.0>1.6[1.0]
AA LAX-RDU MAY 1.7>1.1[2]
AA LAX-SAN MAY 6>5[6]
AA LAX-SFO MAY 11>8[11]
AA LAX-SJC MAY 6>5[6]
AA LAX-SLC MAY 4>3[4]
AA LGA-MSP MAY 3>1.8[2]
AA LGA-PHL MAY 2.0>4[5]
AA LGA-RIC MAY 4>5[3]
AA LGA-YUL MAY 4>3[4]
AA LGA-YYZ MAY 5>4[5]
AA LSE-ORD MAY 3>4[3]
AA MAO-MIA MAY 1.0>0.7[1.0]
AA MDT-PHL MAY 6>5[5]
AA MEI-PIB MAY 1.5>1.0[1.5]
AA MEM-ORD MAY 4>5[4]
AA MHK-ORD MAY 2>3[2]
AA MIA-PTY MAY 3>2[3]
AA MIA-SAN MAY 1.0>0.7[1.1]
AA MIA-SAT MAY 1.0>1.6[0.8]
AA MIA-SFO MAY 4>2[4]
AA MIA-STL MAY 3>1.9[3]
AA MIA-TLH MAY 3>4[4]
AA MKE-ORD MAY 4>3[4]
AA MLI-ORD MAY 3>4[3]
AA MRY-PHX MAY 3>4[4]
AA MSN-ORD MAY 7>5[4]
AA MSP-ORD MAY 7>6[6]
AA MSP-PHL MAY 4>3[3]
AA MSP-PHX MAY 4>3[4]
AA MSY-PHL MAY 2>3[3]
AA MYR-PHL MAY 3>2[1.3]
AA OKC-PHX MAY 1.1>2[1.0]
AA OMA-ORD MAY 5>6[5]
AA OMA-PHX MAY 2.0>1.1[1.8]
AA ORD-ORF MAY 1.8>2[1.8]
AA ORD-PHX MAY 9>8[9]
AA ORD-PVD MAY 2>3[2]
AA ORD-RAP MAY 1.3>1.0[1.3]
AA ORD-RSW MAY 3>2[2]
AA ORD-TUL MAY 2>3[2]
AA ORD-TYS MAY 3>4[3]
AA ORD-XNA MAY 5>6[4]
AA PHL-RIC MAY 7>6[6]
AA PHL-ROC APR 6>5[5]
AA PHL-SAN MAY 2>3[1.9]
AA PHL-SBY MAY 4>3[3]
AA PHL-SCE MAY 5>4[4]
AA PHL-SDF MAY 4>3[3]
AA PHL-SWF MAY 3>4[3]
AA PHL-YOW MAY 3>2[3]
AA PHX-PIT MAY 2>1.1[1.9]
AA PHX-SAF MAY 1.0>1.9[1.0]
AA PHX-SAT MAY 4>3[4]
AA PHX-SEA MAY 4>3[4]
AA PHX-SGU MAY 1.9>3[2]
AA PHX-TUS MAY 6>7[7]
AA PHX-YUM MAY 4>5[4]
AA PHX-YVR MAY 1.9>1.0[1.6]
Doubling of frequency for AC in AUS
*AC AUS-YYZ MAY 1.0>1.9[1.0] JUN 1.0>1.8[1.0] JUL 1.0>1.9[1.0] AUG 1.0>1.8[1.0] SEP 1.0>1.9[1.0] OCT 1.0>1.7[1.0]
AM IAH-MEX APR 2>3[2] MAY 2>3[2] JUN 2>3[3] JUL 2>3[3] AUG 2>3[3] SEP 2>3[2] OCT 2>3[2] NOV 2>3[2]
AS ANC-SEA SEP 16>17[16] OCT 13>14[13] NOV 13>14[12]
AS BOI-PDX AUG 6>8[7] SEP 0>8[7] OCT 0>8[7] NOV 0>8[7]
AS EWR-LAX SEP 4>3[4] OCT 4>3[4] NOV 4>3[4]
AS LAX-PDX SEP 7>8[7] OCT 7>8[7] NOV 7>8[7]
AS PHX-SEA SEP 5>6[5] OCT 5>6[5]
AS SAT-SEA NOV 1.1>1.4[1.0]
AS SEA-SFO SEP 12>13[11] OCT 12>13[11] NOV 14>13[14]
AS SEA-SJC NOV 10>8[10]
AS SEA-YEG NOV 1.5>2[1.6]
B6 Extends their Schedule. Note that October is not fully filed, so best ignored.
B6 ABQ-JFK SEP 0.1>0.8[0.8] OCT 0>0.8[0.9]
B6 ACK-BOS SEP 0.2>0.8[0.6] OCT 0>0.4[0.2]
B6 ACK-DCA SEP 0.0>0.2[0.3]
B6 ACK-JFK SEP 0.5>3[3] OCT 0>1.1[0.9]
B6 ALB-FLL SEP 0.1>1.0[1.0] OCT 0>0.8[1.0]
B6 ALB-MCO SEP 0.1>1.0[1.0] OCT 0>0.8[1.0]
B6 ANC-SEA SEP 0.1>0.5[0.5]
B6 ATL-FLL SEP 0.2>2[2] OCT 0>1.7[2]
B6 ATL-JFK SEP 0.2>2[2] OCT 0>1.7[2]
B6 ATL-MCO SEP 0.1>1.0[1.0] OCT 0>0.8[1.0]
B6 AUA-BOS SEP 0.1>1.4[1.5] OCT 0>1.4[1.7]
B6 AUA-FLL SEP 0.1>1.0[1.0] OCT 0>0.8[1.0]
B6 AUA-JFK SEP 0.2>2[2] OCT 0>1.7[1.9]
B6 AUS-BOS SEP 0.1>1.8[1.0] OCT 0>1.5[1.0]
B6 AUS-FLL SEP 0.1>1.0[1.0] OCT 0>0.8[1.0]
B6 AUS-JFK SEP 0.2>1.9[1.9] OCT 0>1.5[1.9]
B6 AUS-LGB SEP 0.1>1.0[1.1] OCT 0>0.8[1.0]
B6 AUS-MCO SEP 0.1>1.0[1.0] OCT 0>0.8[1.0]
B6 BDA-BOS SEP 0.1>1.0[1.0] OCT 0>0.8[1.0]
B6 BDA-JFK SEP 0.2>2[2] OCT 0>1.1[1.3]
B6 BDL-DCA SEP 0.2>1.7[1.9] OCT 0>1.6[2]
B6 BDL-FLL SEP 0.2>1.6[2] OCT 0>1.3[2]
B6 BDL-MCO SEP 0.2>2[2] OCT 0>1.7[2]
B6 BDL-PBI SEP 0.1>1.0[1.0] OCT 0>0.8[1.0]
B6 BDL-RSW OCT 0>0.8[1.0]
B6 BDL-SJU SEP 0.1>0.6[0.6] OCT 0>0.4[0.5]
B6 BDL-TPA SEP 0.1>1.0[1.9] OCT 0>0.8[1.5]
B6 BGI-FLL SEP 0.1>1.0[1.0] OCT 0>0.8[1.0]
B6 BGI-JFK SEP 0.2>2[2.0] OCT 0>1.8[1.7]
B6 BNA-FLL SEP 0.1>1.5[1.0] OCT 0>1.3[1.0]
B6 BOG-FLL SEP 0.1>1.0[1.0] OCT 0>0.8[1.0]
B6 BOS-BUF SEP 0.5>5[5] OCT 0>4[5]
B6 BOS-BUR SEP 0.1>1.0[0.9] OCT 0>0.8[0.9]
B6 BOS-CHS SEP 0.2>3[2] OCT 0>2[1.9]
B6 BOS-CLT SEP 0.3>2[2.0] OCT 0>2[3]
B6 BOS-CUN OCT 0>0.3[0.4]
B6 BOS-DCA SEP 1.1>10[9] OCT 0>9[10]
B6 BOS-DEN SEP 0.2>1.9[1.9] OCT 0>1.5[1.8]
B6 BOS-DFW SEP 0.2>1.9[1.8] OCT 0>1.5[1.8]
B6 BOS-EWR SEP 0.6>5[5] OCT 0>4[5]
B6 BOS-FLL SEP 0.4>5[4] OCT 0>4[5]
B6 BOS-HOU SEP 0.1>1.0[1.0] OCT 0>0.8[1.0]
B6 BOS-JFK SEP 0.5>5[6] OCT 0>4[6]
B6 BOS-LAS SEP 0.4>4[4] OCT 0>3[4]
B6 BOS-LAX SEP 0.4>4[4] OCT 0>3[4]
B6 BOS-LGA SEP 0.5>5[5] OCT 0>4[5]
B6 BOS-LGB SEP 0.1>1.0[1.7] OCT 0>0.8[1.6]
B6 BOS-MCO SEP 0.5>6[6] OCT 0>5[6]
B6 BOS-MEX SEP 0.1>1.0[0] OCT 0>0.8[0.2]
B6 BOS-MSP SEP 0.3>3[3] OCT 0>2[3]
B6 BOS-MSY SEP 0.1>1.9[1.6] OCT 0>1.7[1.9]
B6 BOS-MVY SEP 0.1>0.6[0.1]
B6 BOS-PBI SEP 0.3>4[4] OCT 0>3[4]
B6 BOS-PHX SEP 0.1>1.0[1.0] OCT 0>0.8[1.0]
B6 BOS-PIT SEP 0.6>6[6] OCT 0>5[6]
B6 BOS-RDU SEP 0.6>6[6] OCT 0>5[6]
B6 BOS-RIC SEP 0.4>4[4] OCT 0>3[4]
B6 BOS-ROC SEP 0.1>1.0[0] OCT 0>0.8[0]
B6 BOS-RSW SEP 0.2>4[3] OCT 0>3[4]
B6 BOS-SAN SEP 0.2>2[2] OCT 0>1.7[2]
B6 BOS-SAV SEP 0.1>1.7[1.0] OCT 0>1.7[1.0]
B6 BOS-SDQ SEP 0.2>2.0[1.3] OCT 0>1.1[1.3]
B6 BOS-SEA SEP 0.2>1.9[2] OCT 0>1.5[1.9]
B6 BOS-SJU SEP 0.2>1.1[1.1] OCT 0>0.8[1.0]
B6 BOS-SLC SEP 0.1>0.6[0.6] OCT 0>0.6[0.7]
B6 BOS-SRQ OCT 0>0.8[1.0]
B6 BOS-STI SEP 0.2>1.2[1.2] OCT 0>0.9[0.7]
B6 BOS-SYR SEP 0.1>1.0[1.0] OCT 0>0.8[1.0]
B6 BOS-TPA SEP 0.4>4[4] OCT 0>3[5]
B6 BQN-FLL OCT 0>0.2[0.3]
B6 BQN-JFK SEP 0.1>0.5[0.6] OCT 0>0.4[0.3]
B6 BQN-MCO SEP 0.1>0.5[0.5] OCT 0>0.4[0.5]
B6 BTV-JFK SEP 0.3>3[4] OCT 0>3[4]
B6 BUF-FLL SEP 0.1>0.8[1.0] OCT 0>0.6[1.0]
B6 BUF-JFK SEP 0.5>7[7] OCT 0>6[7]
B6 BUF-MCO SEP 0.1>1.0[1.0] OCT 0>0.8[1.0]
B6 BUR-JFK SEP 0.2>1.9[1.7] OCT 0>1.5[1.6]
B6 CHS-DCA SEP 0.2>1.9[3] OCT 0>1.5[3]
B6 CHS-FLL SEP 0.1>1.0[1.0] OCT 0>0.8[1.0]
B6 CHS-JFK SEP 0.3>2[2] OCT 0>1.9[3]
B6 CLE-FLL SEP 0.1>0.9[1.0] OCT 0>0.8[1.0]
B6 CLT-JFK SEP 0.2>2[2] OCT 0>1.7[2]
B6 CMW-FLL SEP 0.1>1.0[1.0] OCT 0>0.8[1.0]
B6 CTG-FLL SEP 0.1>0.8[1.0] OCT 0>0.6[1.0]
B6 CUN-FLL SEP 0.2>1.1[1.1] OCT 0>0.8[1.0]
B6 CUN-JFK SEP 0.3>1.8[2] OCT 0>1.4[1.7]
B6 CUN-MCO SEP 0.1>1.0[1.2] OCT 0>0.8[1.1]
B6 CUR-JFK SEP 0.0>0.3[0.4] OCT 0>0.2[0.5]
B6 DCA-FLL SEP 0.5>5[5] OCT 0>3[5]
B6 DCA-JAX SEP 0.2>2[2] OCT 0>1.7[2]
B6 DCA-MCO SEP 0.4>4[4] OCT 0>3[4]
B6 DCA-PBI SEP 0.1>1.0[1.0] OCT 0>0.8[1.0]
B6 DCA-RSW SEP 0.1>1.0[1.0] OCT 0>1.4[1.1]
B6 DCA-SJU SEP 0.1>0.5[0.5] OCT 0>0.4[0.5]
B6 DCA-TPA SEP 0.1>1.0[1.0] OCT 0>0.8[1.0]
B6 DEN-JFK SEP 0.2>1.9[2.0] OCT 0>1.4[1.7]
B6 EWR-FLL SEP 0.3>4[4] OCT 0>3[4]
B6 EWR-MCO SEP 0.6>6[6] OCT 0>5[6]
B6 EWR-PBI SEP 0.2>2[2] OCT 0>1.7[2]
B6 EWR-RSW SEP 0.1>1.9[2] OCT 0>1.7[2]
B6 EWR-SDQ SEP 0.2>1.1[1.0] OCT 0>0.8[1.0]
B6 EWR-SJU SEP 0.1>0.6[0.6] OCT 0>0.4[0.5]
B6 EWR-STI SEP 0.2>1.1[1.0] OCT 0>0.8[1.0]
B6 EWR-TPA SEP 0.2>2[2] OCT 0>1.7[2]
B6 FLL-GCM SEP 0.1>1.0[0] OCT 0>0.8[0.2]
B6 FLL-GYE SEP 0.1>1.0[0] OCT 0>0.8[0]
B6 FLL-HAV SEP 0.3>3[1.8] OCT 0>2[1.9]
B6 FLL-HOG SEP 0.1>1.0[1.0] OCT 0>0.8[1.0]
B6 FLL-HPN SEP 0.2>2[2] OCT 0>1.7[2]
B6 FLL-JFK SEP 0.6>6[6] OCT 0>5[6]
B6 FLL-KIN SEP 0.3>2[2] OCT 0>1.7[2]
B6 FLL-LAS SEP 0.1>1.0[1.0] OCT 0>0.8[1.0]
B6 FLL-LAX SEP 0.3>3[2] OCT 0>3[2]
B6 FLL-LGA SEP 0.5>5[5] OCT 0>4[5]
B6 FLL-LIM SEP 0.1>1.0[1.0] OCT 0>0.8[1.0]
B6 FLL-MBJ SEP 0.2>1.2[2] OCT 0>1.0[1.5]
B6 FLL-MDE SEP 0.1>1.0[1.0] OCT 0>0.8[1.0]
B6 FLL-MEX SEP 0.2>2[2] OCT 0>1.7[2]
B6 FLL-MSY SEP 0.1>1.0[1.0] OCT 0>0.8[1.0]
B6 FLL-NAS SEP 0.5>4[4] OCT 0>3[4]
B6 FLL-ORD SEP 0.1>0.9[1.0] OCT 0>0.7[1.0]
B6 FLL-ORH SEP 0.1>1.0[1.0] OCT 0>0.8[1.0]
B6 FLL-PAP SEP 0.3>3[3] OCT 0>3[2]
B6 FLL-PHL SEP 0.1>1.9[1.9] OCT 0>1.7[2]
B6 FLL-PHX SEP 0.1>1.0[0] OCT 0>0.8[0]
B6 FLL-PLS SEP 0.1>1.0[1.0] OCT 0>0.8[1.0]
B6 FLL-POS SEP 0.1>0.6[0.6] OCT 0>0.5[0.6]
B6 FLL-PUJ SEP 0.1>1.0[1.0] OCT 0>0.8[1.0]
B6 FLL-PVD SEP 0.1>1.0[1.0] OCT 0>0.8[1.0]
B6 FLL-RDU SEP 0.2>2[2] OCT 0>1.7[2]
B6 FLL-RIC SEP 0.2>1.8[2] OCT 0>1.4[2]
B6 FLL-SDQ SEP 0.2>1.1[2.0] OCT 0>0.8[1.0]
B6 FLL-SFO SEP 0.2>2[2] OCT 0>1.7[2]
B6 FLL-SJO SEP 0.1>1.0[1.0] OCT 0>0.8[1.0]
B6 FLL-SJU SEP 0.3>2[2] OCT 0>1.7[2]
B6 FLL-SLC SEP 0.1>1.0[1.0] OCT 0>0.8[1.0]
B6 FLL-SNU SEP 0.1>1.0[1.0] OCT 0>0.8[1.0]
B6 FLL-STI SEP 0.1>1.0[1.0] OCT 0>0.8[1.0]
B6 FLL-SWF SEP 0.1>1.0[1.0] OCT 0>0.8[1.0]
B6 FLL-SXM SEP 0.1>1.0[0] OCT 0>0.8[0]
B6 FLL-UIO SEP 0.2>1.1[1.0] OCT 0>0.8[1.0]
B6 GND-JFK SEP 0.2>0.9[0.7] OCT 0>0.6[0.7]
B6 HAV-JFK SEP 0.1>1.0[1.0] OCT 0>0.8[1.0]
B6 HAV-MCO SEP 0.1>1.0[1.0] OCT 0>0.8[1.0]
B6 HOU-JFK SEP 0.1>1.0[1.0] OCT 0>0.8[1.0]
B6 HPN-RSW SEP 0.1>1.0[1.0] OCT 0>0.8[1.0]
B6 HPN-TPA SEP 0.1>1.0[1.0] OCT 0>0.8[1.0]
B6 JFK-LAS SEP 0.3>4[4] OCT 0>2[4]
B6 JFK-LAX SEP 1.1>11[9] OCT 0>8[9]
B6 JFK-LGB SEP 0.2>1.9[1.9] OCT 0>1.5[1.9]
B6 JFK-MBJ SEP 0.3>2[2] OCT 0>1.7[2]
B6 JFK-MCO SEP 0.8>7[7] OCT 0>6[7]
B6 JFK-MEX SEP 0.1>1.0[0] OCT 0>0.8[0.2]
B6 JFK-MSY SEP 0.2>3[3] OCT 0>3[2]
B6 JFK-MVY SEP 0.2>1.1[1.0] OCT 0>0.5[0.4]
B6 JFK-NAS SEP 0.3>1.2[1.3] OCT 0>0.8[1.0]
B6 JFK-OAK SEP 0.1>0.8[1.0] OCT 0>0.5[0.6]
B6 JFK-ONT SEP 0.1>1.0[0.9] OCT 0>0.8[1.0]
B6 JFK-ORD SEP 0.2>3[3] OCT 0>3[2]
B6 JFK-ORH SEP 0.1>1.0[1.0] OCT 0>0.8[1.0]
B6 JFK-PAP SEP 0.2>2[1.1] OCT 0>1.7[1.0]
B6 JFK-PBI SEP 0.3>4[4] OCT 0>3[4]
B6 JFK-PDX SEP 0.1>0.9[1.0] OCT 0>0.5[0.6]
B6 JFK-PHX SEP 0.1>1.0[1.0] OCT 0>0.8[1.0]
B6 JFK-PLS SEP 0.1>0.8[1.0] OCT 0>0.8[1.0]
B6 JFK-POP SEP 0.1>1.0[1.0] OCT 0>0.8[1.0]
B6 JFK-POS SEP 0.2>1.1[1.0] OCT 0>0.8[1.0]
B6 JFK-PSP OCT 0>0.3[0.4]
B6 JFK-PUJ SEP 0.3>2[2] OCT 0>1.7[2]
B6 JFK-PWM SEP 0.3>2[4] OCT 0>0.9[4]
B6 JFK-RDU SEP 0.2>3[3] OCT 0>2[3]
B6 JFK-ROC SEP 0.3>3[4] OCT 0>3[4]
B6 JFK-RSW SEP 0.2>2[2] OCT 0>1.7[2]
B6 JFK-SAN SEP 0.2>2[2] OCT 0>1.7[2]
B6 JFK-SAV SEP 0.2>2[2] OCT 0>1.7[2]
B6 JFK-SEA SEP 0.2>1.9[2.0] OCT 0>1.5[1.7]
B6 JFK-SFO SEP 0.6>6[6] OCT 0>5[6]
B6 JFK-SJC SEP 0.1>0.9[1.0] OCT 0>0.7[0.6]
B6 JFK-SJU SEP 0.3>2[1.7] OCT 0>1.7[1.8]
B6 JFK-SLC SEP 0.2>2[1.0] OCT 0>1.7[1.0]
B6 JFK-SMF SEP 0.1>1.0[1.0] OCT 0>0.8[1.0]
B6 JFK-SRQ SEP 0.1>1.0[1.0] OCT 0>0.8[1.0]
B6 JFK-STI SEP 0.8>6[6] OCT 0>4[5]
B6 JFK-SXM SEP 0.1>1.0[1.0] OCT 0>0.8[1.0]
B6 JFK-SYR SEP 0.2>2[2] OCT 0>1.7[2]
B6 JFK-UVF SEP 0.1>1.0[1.0] OCT 0>0.8[1.0]
B6 LAS-LGB SEP 0.3>3[3] OCT 0>2[3]
B6 LAX-MCO SEP 0.1>0.6[1.0] OCT 0>0.5[0.6]
B6 LGA-MCO SEP 0.4>4[4] OCT 0>3[4]
B6 LGA-PBI SEP 0.3>3[3] OCT 0>2[3]
B6 LGB-OAK SEP 0.2>2[2] OCT 0>1.7[2]
B6 LGB-PDX SEP 0.1>1.0[1.1] OCT 0>0.8[1.0]
B6 LGB-RNO SEP 0.1>1.0[1.0] OCT 0>0.8[1.0]
B6 LGB-SEA SEP 0.2>2[1.1] OCT 0>1.7[1.0]
B6 LGB-SFO SEP 0.2>2[2] OCT 0>1.7[2]
B6 LGB-SJC SEP 0.2>2[2] OCT 0>1.7[2]
B6 LGB-SMF SEP 0.2>2[2] OCT 0>1.7[2]
B6 MBJ-MCO SEP 0.2>1.1[1.0] OCT 0>0.8[1.0]
B6 MCO-MEX SEP 0.2>2[2] OCT 0>1.7[2]
B6 MCO-NAS SEP 0.1>0.8[0.8] OCT 0>0.7[0.9]
B6 MCO-ORH SEP 0.1>1.0[1.0] OCT 0>0.8[1.0]
B6 MCO-PAP SEP 0.1>0.8[1.0] OCT 0>0.6[0.7]
B6 MCO-PSE SEP 0.1>0.5[0.5] OCT 0>0.4[0.5]
B6 MCO-RIC SEP 0.1>1.0[1.9] OCT 0>0.8[2]
B6 MCO-SDQ SEP 0.1>1.0[1.0] OCT 0>0.8[1.0]
B6 MCO-SJO SEP 0.1>1.0[1.0] OCT 0>0.8[1.0]
B6 MCO-SJU SEP 0.3>3[2] OCT 0>2[3]
B6 MCO-SLC SEP 0.1>1.0[1.0] OCT 0>0.8[1.0]
B6 MCO-SWF SEP 0.1>1.0[1.0] OCT 0>0.8[1.0]
B6 MCO-SYR SEP 0.1>1.0[1.0] OCT 0>0.8[1.0]
B6 PBI-PVD SEP 0.1>1.0[0] OCT 0>0.8[0]
B6 SJU-TPA SEP 0.1>0.5[0.6] OCT 0>0.4[0.6]
D7 HNL-KIX APR 1.0>0.6[0.6] JUL 1.0>0.6[0.5]
DL BOS-PHL JUL 5>4[0] AUG 5>4[0]
DL LGA-ORD JUL 13>11[11]
DL MSP-PVR NOV 0.7>0.1[0.1]
ES CCS-JFK MAR 0.4>0.1[0] APR 0.4>0.2[0]
*ET LAX-LFW MAR 0.4>0[0] APR 0.4>0[0] MAY 0.4>0[0] JUN 0.4>0[0] JUL 0.5>0[0] AUG 0.4>0[0] SEP 0.4>0[0] OCT 0.4>0[0] NOV 0.4>0[0]
G3 BSB-MCO JUL 1.0>1.5[0]
HA HNL-ITO APR 16>15[16] MAY 16>15[15]
HA HNL-KOA APR 20>19[19]
J5 AGN-JNU SEP 0.5>1.1[1.1] OCT 0.5>1.0[1.0] NOV 0.0>0.9[1.0]
J5 AGN-TKE AUG 0.1>0.4[0] SEP 0.5>1.1[0] OCT 0.5>1.0[1.0] NOV 0.0>0.9[1.0]
J5 JNU-SIT MAR 3>2[0]
J5 JNU-TKE SEP 0.5>1.1[1.1] OCT 0.5>1.0[1.0] NOV 0.0>0.9[1.0]
KG DEN-RIW MAR 2>1.3[0]
KG DEN-SHR MAR 1.5>0.5[0]
LF CEC-OAK MAY 1.0>1.6[1.0] JUN 1.0>1.6[1.0] JUL 0>1.5[1.0] AUG 0>1.6[1.0] SEP 0>0.8[1.0]
LF LAS-PGA MAR 0.4>0.7[0] JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>1.0[0] OCT 0>0.5[0]
LF LAS-SBA APR 0.4>0.9[0] MAY 0>1.9[0] JUN 0>1.8[0] JUL 0>1.9[0] AUG 0>1.8[0] SEP 0>1.4[0] OCT 0>0.5[0.3]
LF OAK-SBA MAY 1.0>1.9[0] JUN 1.0>1.8[0] JUL 0>1.9[0] AUG 0>1.8[0] SEP 0>0.9[0]
LF PGA-PHX MAR 1.3>1.6[0] APR 1.2>1.4[0] MAY 1.0>1.3[0] JUN 1.0>1.3[0] JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>1.0[1.7] OCT 0>0.5[1.7]
*LF SBA-SMF APR 0>0.5[0] MAY 0>1.0[0] JUN 0>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>1.0[0] OCT 0>0.5[0]
LH FRA-TPA NOV 0.6>0.9[0.6]
July is not fully loaded, so ignore
MW HNL-JHM JUN 0>8[9] JUL 0>1.5[9]
*MW HNL-LUP MAY 0>0.9[0] JUN 0>0.9[0] JUL 0>0.2[0]
MW HNL-MKK MAY 0>11[14] JUN 0>11[14] JUL 0>2[14]
MW HNL-OGG JUN 0>3[4] JUL 0>0.6[4]
MW HNM-OGG JUL 0>0.4[2]
MW IPL-LAX JUL 0>0.7[3]
MW JHM-KOA JUL 0>0.4[3]
MW KOA-OGG MAY 0>12[13] JUN 0>12[14] JUL 0>2[15]
*MW LUP-MKK MAY 0>0.9[0] JUN 0>0.9[0] JUL 0>0.2[0]
MW MKK-OGG MAY 0>10[9] JUL 0>1.9[10]
MW MUE-OGG JUL 0>0.4[2]
NK DFW-MSY APR 0>0.3[0.5]
RJ AMM-DTW JUN 0.2>0.4[0.2]
SY JFK-MSP MAR 1.0>0[0.7]
TJ ACK-HPN JUL 4>3[5] AUG 5>3[5] SEP 1.9>3[2] OCT 0.8>3[0.9] NOV 0>3[1.0]
TJ ACK-TEB JUL 4>3[5] AUG 5>3[5] SEP 1.8>3[1.9] OCT 0.8>3[0.8] NOV 0>3[0.9]
TJ HPN-MVY SEP 0.8>1.7[0.8] OCT 0.5>1.6[0.3] NOV 0>1.7[0.2]
TJ MVY-TEB SEP 0.5>1.4[0.7] OCT 0.3>1.4[0.3] NOV 0>1.5[0.2]
UA ABQ-IAH JUL 5>4[3]
UA ABQ-SFO SEP 1.9>3[2]
UA ACV-LAX JUN 1.2>2[0.8] JUL 1.0>2[1.0] AUG 1.0>1.6[1.0]
UA AVL-IAD AUG 2>3[0] SEP 2>3[0]
UA BNA-IAH JUN 6>5[5] JUL 6>5[5]
UA BOI-DEN SEP 4>5[4]
UA BRO-IAH JUN 4>5[4] JUL 4>5[4] AUG 4>5[4] SEP 4>5[5] OCT 4>5[4] NOV 4>5[4]
UA CHA-ORD JUN 3>2[2] JUL 3>2[2] AUG 3>2[2]
UA COS-DEN JUN 9>10[9] JUL 9>10[9]
UA COU-ORD JUN 2>3[2] JUL 2>3[1.9] AUG 2>3[2] SEP 2>4[1.9] OCT 2>4[2] NOV 2>4[2]
UA CPR-DEN SEP 4>5[3]
UA CRP-IAH JUN 7>6[5] JUL 7>6[5]
UA DEN-DFW SEP 5>6[5]
UA DEN-DRO SEP 6>7[6]
UA DEN-FAI AUG 0.3>0.5[0]
UA DEN-FAT SEP 3>4[4]
UA DEN-FSD JUN 4>5[4] JUL 4>5[4]
UA DEN-OKC JUN 5>6[5] JUL 5>6[5]
UA DEN-PDX SEP 4>5[4]
UA EDI-ORD OCT 0.8>0.1[0.8]
UA ELP-IAH JUL 6>5[5]
UA EWR-IAH SEP 9>10[9]
UA EWR-MYR JUN 1.1>1.9[1.1] JUL 1.0>2[1.1] AUG 1.0>1.6[1.1]
UA EWR-PIT JUN 9>8[7] JUL 9>8[7]
UA EWR-ROC JUL 5>4[5]
UA EWR-SJO SEP 2>1.0[1.0]
Nice extension into Fall
*UA FAI-ORD AUG 0.6>1.0[0.6] SEP 0>1.0[0] OCT 0>0.3[0]
UA FAR-ORD JUN 3>4[4] JUL 3>4[4] AUG 3>4[3] SEP 3>4[3] OCT 3>4[4] NOV 3>4[3]
UA FLL-ORD AUG 3>2[3] SEP 4>2[3]
UA FSD-ORD JUN 4>5[4] JUL 4>5[4] AUG 4>5[4] SEP 4>5[4] OCT 4>5[5] NOV 3>5[6]
UA GRR-IAH JUN 1.1>1.8[1.0] JUL 1.0>1.9[1.9] AUG 1.0>1.5[1.9]
UA GRR-ORD JUN 6>7[7] JUL 6>7[7] AUG 6>7[7] SEP 6>7[8]
UA GSO-ORD JUL 4>3[3]
UA HRL-IAH JUL 4>5[4] AUG 4>5[4] SEP 4>5[4] OCT 4>5[4] NOV 4>5[4]
UA HSV-IAH SEP 3>4[3]
UA IAD-MSP JUN 3>2[2] JUL 3>2[2] AUG 3>2[2]
UA IAD-SEA SEP 3>4[3]
UA IAH-JAN JUN 5>6[5] JUL 5>6[5] AUG 5>6[5] SEP 5>6[5] OCT 5>6[5] NOV 5>6[5]
UA IAH-LBB SEP 3>4[4] OCT 3>4[4] NOV 3>4[4]
UA IAH-LFT SEP 5>6[5] OCT 5>6[5] NOV 5>6[5]
UA IAH-LIT SEP 5>6[5]
UA IAH-MCO SEP 6>7[6]
UA IAH-MFE JUL 6>7[6] AUG 6>7[6] SEP 6>7[6] OCT 6>7[5] NOV 6>7[5]
UA IAH-MKE SEP 1.9>3[1.8]
UA IAH-PHL SEP 4>5[3]
UA IAH-PIT SEP 5>6[5]
UA IAH-PNS JUN 4>5[5] JUL 4>5[5] AUG 4>5[5] SEP 4>6[5] OCT 4>6[5] NOV 4>6[4]
UA IAH-RDU SEP 4>5[4]
UA IAH-TYS JUN 3>4[3] JUL 3>4[3] AUG 3>4[3] SEP 3>4[3] OCT 3>4[3] NOV 3>4[3]
UA IAH-VPS JUN 2>3[3] JUL 2>3[3] AUG 2>3[3] SEP 2>3[3] OCT 2>3[3] NOV 2>3[2]
*UA LAX-RAP JUL 0>0.3[0] AUG 0>0.3[0]
UA LIH-SFO AUG 1.7>2[1.7]
UA MDT-ORD JUN 3>4[3] JUL 3>4[3] AUG 3>4[3] SEP 3>4[3] OCT 3>4[3] NOV 3>4[3]
UA MSN-ORD JUN 7>8[8] JUL 7>8[8] AUG 7>8[8] SEP 7>8[9] OCT 7>8[8] NOV 7>8[7]
UA ORD-PNS JUN 1.2>2[2] JUL 1.0>2[2] AUG 1.0>2[1.8] SEP 1.0>2[1.3] OCT 1.0>2[1.0] NOV 1.0>2[1.0]
UA ORD-PVD JUN 2>3[2] JUL 2>3[2] AUG 2>3[2] SEP 2>3[2] OCT 2>3[2] NOV 2>3[1.9]
UA ORD-RAP SEP 3>4[3] OCT 1.1>2.0[1.7]
UA ORD-RDU SEP 5>6[5]
UA ORD-SAT SEP 3>4[3]
UA ORD-SGF JUN 3>4[3] JUL 3>4[3] AUG 3>4[3] SEP 3>4[4] OCT 3>4[4] NOV 3>4[3]
UA ORD-SLC SEP 3>4[4]
UA ORD-SMF AUG 2>3[2] SEP 1.9>3[2.0]
UA ORD-SYR SEP 4>5[5]
UA ORD-TVC JUN 4>5[5] JUL 4>5[5] AUG 4>5[5] SEP 3>5[5] OCT 3>4[5]
UA ORD-YWG JUN 2>3[3] JUL 2>3[3] AUG 2>3[3] SEP 2>3[3] OCT 2>3[3] NOV 2>3[3]
*UA RAP-SFO JUL 0>0.3[0] AUG 0>0.3[0]
*VC SFB-TLH MAR 0.3>0[0] APR 0.3>0[0]
Schedule roll. October is not fully filed, so ignore October.
WN ABQ-AUS AUG 0.1>1.2[0.5] SEP 0>1.3[0.6]
WN ABQ-LAX AUG 0.4>2[2] SEP 0>2.0[2]
WN ABQ-MCI AUG 0.2>0.9[1.0] SEP 0>0.9[1.0]
WN ABQ-MDW AUG 0.4>2[2] SEP 0>1.3[1.9]
WN ABQ-PHX AUG 0.8>6[6] OCT 0>0.2[6]
WN ABQ-SAN AUG 0.4>1.9[2] SEP 0>1.8[2.0]
WN ABQ-SJC AUG 0.0>0.9[0.1] SEP 0>1.0[0.2]
WN ALB-BWI AUG 0.9>6[6] OCT 0>0.2[6]
WN ALB-TPA AUG 0.2>1.0[1.0] SEP 0>0.3[0.4]
WN ATL-BOS AUG 0.2>1.0[3] SEP 0>1.0[2]
WN ATL-BWI AUG 0.9>7[6] OCT 0>0.2[6]
WN ATL-CLE AUG 0.3>1.8[1.8] SEP 0>1.8[1.7]
WN ATL-CUN AUG 0.2>0.7[1.0] SEP 0>0.3[1.0]
WN ATL-DEN AUG 0.8>5[4] SEP 0>5[4]
WN ATL-IAD AUG 0.4>3[1.9] SEP 0>3[1.8]
WN ATL-MCO AUG 0.9>5[6] SEP 0>5[6]
WN ATL-MDW AUG 0.9>6[6] OCT 0>0.2[6]
WN ATL-MKE AUG 0.3>2[1.9] SEP 0>1.9[1.8]
WN ATL-PHL AUG 0.3>2[2] SEP 0>2[2.0]
WN ATL-PHX AUG 0.4>3[1.9] SEP 0>3[1.8]
WN ATL-PIT AUG 0.4>3[1.8] SEP 0>3[1.7]
WN ATL-PUJ AUG 0.2>0.8[0.8] SEP 0>0.2[0.7]
WN ATL-RSW AUG 0.3>1.8[1.7] SEP 0>1.8[1.0]
WN AUA-BWI AUG 0.2>0.5[0.4]
WN AUS-BNA AUG 0.5>3[2] SEP 0>3[2]
WN AUS-BWI AUG 0.5>3[2] SEP 0>3[2]
WN AUS-DAL AUG 1.5>9[10] OCT 0>0.3[10]
WN AUS-DEN AUG 0.9>6[5] SEP 0>6[5] OCT 0>0.2[5]
WN AUS-ELP AUG 0.4>3[3] SEP 0>3[2]
WN AUS-EWR AUG 0.3>1.8[1.9] SEP 0>1.9[1.8]
WN AUS-HRL AUG 0.2>0.9[0.9] SEP 0>0.9[0.8]
WN AUS-LAS AUG 0.6>4[3] SEP 0>4[3]
WN AUS-LAX AUG 0.4>3[3] SEP 0>3[2]
WN AUS-LBB AUG 0.2>0.9[0.9] SEP 0>0.9[0.8]
WN AUS-MCI AUG 0.2>0.9[0.9] SEP 0>0.9[0.8]
WN AUS-MCO AUG 0.5>2[1.3] SEP 0>1.3[1.4]
WN AUS-MDW AUG 0.6>4[3] SEP 0>4[3]
WN AUS-MSY AUG 0.4>3[2.0] SEP 0>3[2]
WN AUS-OAK AUG 0.2>0.9[1.0] SEP 0>0.9[1.0]
WN AUS-RDU AUG 0.2>1.0[0] SEP 0>1.0[0]
WN AUS-SFO AUG 0.2>0.9[1.0] SEP 0>0.9[1.0]
WN AUS-SJC AUG 0.4>3[2] SEP 0>3[1.8]
WN AUS-STL AUG 0.3>1.8[1.8] SEP 0>1.9[1.8]
WN AUS-TPA AUG 0.3>1.2[1.0] SEP 0>1.1[0.9]
WN BDL-BWI AUG 0.8>5[6] SEP 0>5[6]
WN BDL-DEN AUG 0.2>1.1[1.1] SEP 0>1.1[1.2]
WN BDL-MCO AUG 0.3>2[3] SEP 0>2.0[1.2]
WN BHM-BWI AUG 0.2>1.1[1.0] SEP 0>1.1[1.0]
WN BHM-DAL AUG 0.3>1.9[1.9] SEP 0>2[1.8]
WN BHM-HOU AUG 0.3>1.8[1.9] SEP 0>1.9[1.8]
WN BHM-MCO AUG 0.3>1.4[1.3] SEP 0>2.0[1.8]
WN BHM-MDW AUG 0.3>2[1.9] SEP 0>2.0[1.8]
WN BHM-TPA AUG 0.2>1.1[1.9] SEP 0>1.1[1.7]
WN BNA-BUR AUG 0.2>1.0[0] SEP 0>1.0[0]
WN BNA-BWI AUG 1.0>6[6] OCT 0>0.2[6]
WN BNA-CMH AUG 0.3>2[2] SEP 0>2[2.0]
WN BNA-DAL AUG 0.8>5[4] SEP 0>5[4]
WN BNA-DCA AUG 0.6>4[3] SEP 0>4[3]
WN BNA-DEN AUG 0.9>6[5] SEP 0>6[5] OCT 0>0.2[5]
WN BNA-DTW AUG 0.5>3[1.9] SEP 0>3[1.8]
WN BNA-ECP AUG 0.4>2[2] SEP 0>3[2]
WN BNA-EWR AUG 0.4>3[0] SEP 0>3[0]
WN BNA-LGA AUG 0.5>3[3] SEP 0>4[3]
WN BNA-MCO AUG 0.9>4[4] SEP 0>4[3]
WN BNA-MDW AUG 1.1>7[7] OCT 0>0.2[7]
WN BNA-MKE AUG 0.3>2[1.9] SEP 0>2.0[1.8]
WN BNA-MSP AUG 0.3>1.9[1.0] SEP 0>1.8[1.0]
WN BNA-MSY AUG 0.6>4[3] SEP 0>4[3]
WN BNA-ORF AUG 0.1>0.3[0] SEP 0>0.3[0]
WN BNA-PHX AUG 0.6>3[2] SEP 0>3[2]
WN BNA-PIT AUG 0.4>2[1.1] SEP 0>2[1.5]
WN BNA-PNS AUG 0.4>2[2] SEP 0>2[2.0]
WN BNA-SAT AUG 0.3>2[2] SEP 0>2.0[1.9]
WN BNA-SJC AUG 0.2>1.0[0] SEP 0>1.0[0]
WN BNA-STL AUG 0.5>4[3] SEP 0>4[3]
WN BOI-DEN AUG 0.3>2[2] SEP 0>2.0[1.9]
WN BOI-GEG AUG 0.3>1.7[1.8] SEP 0>1.7[1.6]
WN BOI-OAK AUG 0.3>2[2] SEP 0>2.0[1.9]
WN BOI-SJC AUG 0.3>1.7[1.0] SEP 0>1.7[1.0]
WN BOS-BWI AUG 1.5>9[9] OCT 0>0.3[9]
WN BOS-CMH AUG 0.3>1.7[1.9] SEP 0>1.0[1.2]
WN BOS-DAL AUG 0.2>1.1[1.0] SEP 0>1.1[1.0]
WN BOS-DEN AUG 0.5>3[3] SEP 0>3[2]
WN BOS-MCI AUG 0.2>1.0[1.8] SEP 0>1.0[1.6]
WN BOS-MKE AUG 0.2>1.1[1.8] SEP 0>1.1[1.8]
WN BOS-STL AUG 0.7>4[3] SEP 0>4[3]
WN BUF-BWI AUG 0.8>6[6] SEP 0>6[5] OCT 0>0.2[6]
WN BUF-DEN AUG 0.2>1.0[0] SEP 0>1.0[0]
WN BUF-LAS AUG 0.2>1.1[2.0] SEP 0>1.1[1.3]
WN BUF-TPA AUG 0.2>1.1[1.1] SEP 0>1.1[1.2]
WN BUR-DEN AUG 0.5>3[2] SEP 0>3[1.8]
WN BUR-HOU AUG 0.2>1.0[0] SEP 0>1.0[0]
WN BUR-LAS AUG 1.6>10[10] SEP 0>10[9] OCT 0>0.4[9]
WN BUR-MDW AUG 0.3>1.7[0] SEP 0>1.7[0]
WN BUR-OAK AUG 2.0>13[12] SEP 0>13[11] OCT 0>0.5[12]
WN BUR-PHX AUG 1.0>6[5] SEP 0>6[5] OCT 0>0.2[6]
WN BUR-SFO AUG 0.8>5[4] SEP 0>5[4] OCT 0>0.2[4]
WN BUR-SJC AUG 1.6>11[8] SEP 0>11[8] OCT 0>0.4[8]
WN BUR-SLC AUG 0.2>0.9[0.9] SEP 0>0.9[0.8]
WN BUR-SMF AUG 1.5>10[8] SEP 0>11[8] OCT 0>0.4[8]
WN BWI-CUN AUG 0.4>1.3[1.3] SEP 0>1.1[1.2]
WN BWI-DEN AUG 1.0>6[5] SEP 0>6[5] OCT 0>0.2[5]
WN BWI-FLL AUG 1.6>8[8] OCT 0>0.2[8]
WN BWI-HOU AUG 0.7>4[3] SEP 0>4[3]
WN BWI-LAX AUG 0.6>4[4] SEP 0>4[3]
WN BWI-MCO AUG 1.7>9[8] SEP 0>8[7] OCT 0>0.2[7]
WN BWI-MDW AUG 1.1>7[7] OCT 0>0.2[7]
WN BWI-MEM AUG 0.2>1.1[1.2] SEP 0>1.1[1.0]
WN BWI-MHT AUG 0.9>6[6] OCT 0>0.2[6]
WN BWI-MSP AUG 0.3>2[1.9] SEP 0>2.0[1.8]
WN BWI-PVD AUG 1.1>6[8] SEP 0>6[8] OCT 0>0.2[8]
WN BWI-RDU AUG 1.0>6[6] OCT 0>0.2[6]
WN BWI-SAT AUG 0.5>2[2] SEP 0>2[2.0]
WN BWI-TPA AUG 1.2>7[7] SEP 0>7[6] OCT 0>0.2[7]
WN CHS-DAL AUG 0.2>1.0[0.3] SEP 0>1.0[0.3]
WN CHS-MDW AUG 0.4>2[2] SEP 0>1.3[2.0]
WN CLE-DEN AUG 0.3>1.7[1.0] SEP 0>1.7[1.0]
WN CLE-LAS AUG 0.0>0.3[1.0] SEP 0>0.3[1.0]
WN CLE-MKE AUG 0.2>1.5[1.8] SEP 0>1.6[1.7]
WN CLE-STL AUG 0.5>3[1.9] SEP 0>3[1.8]
WN CLT-HOU AUG 0.2>1.0[1.2] SEP 0>1.0[1.1]
WN CMH-DAL AUG 0.2>1.1[1.0] SEP 0>1.2[1.0]
WN CMH-DCA AUG 0.3>1.8[1.9] SEP 0>1.9[1.8]
WN CMH-FLL AUG 0.2>1.0[0.3] SEP 0>1.0[0.2]
WN CMH-HOU AUG 0.2>1.0[0] SEP 0>1.0[0]
WN CMH-LAS AUG 0.3>2[1.4] SEP 0>2.0[1.9]
WN CMH-MDW AUG 0.8>6[6] OCT 0>0.2[6]
WN CMH-OAK AUG 0.1>0.8[1.0] SEP 0>0.9[1.0]
WN CMH-TPA AUG 0.5>2[1.3] SEP 0>2.0[1.0]
WN CUN-FLL AUG 0.3>1.2[3] SEP 0>1.0[3]
WN CUN-MDW AUG 0.2>1.2[1.3] SEP 0>1.1[1.2]
WN CVG-MCO AUG 0.0>0.3[0] SEP 0>0.3[0]
WN DAL-DCA AUG 0.8>5[4] SEP 0>5[4]
WN DAL-DEN AUG 1.1>7[7] OCT 0>0.2[7]
WN DAL-ECP AUG 0.4>2[1.3] SEP 0>2[1.2]
WN DAL-FLL AUG 0.5>3[2] SEP 0>3[2]
WN DAL-HOU AUG 3>18[19] OCT 0>0.6[19]
WN DAL-IND AUG 0.2>1.1[1.3] SEP 0>1.0[1.3]
WN DAL-JAX AUG 0.2>1.0[0.3] SEP 0>1.0[0.3]
WN DAL-LAX AUG 0.8>5[4] SEP 0>5[4]
WN DAL-LGA AUG 0.7>5[4] SEP 0>5[4]
WN DAL-MAF AUG 0.7>5[5] SEP 0>5[4]
WN DAL-MCI AUG 0.9>6[6] OCT 0>0.2[6]
WN DAL-MCO AUG 0.7>4[3] SEP 0>4[3]
WN DAL-MDW AUG 1.1>7[7] OCT 0>0.2[7]
WN DAL-MEM AUG 0.5>3[1.2] SEP 0>3[1.2]
WN DAL-MKE AUG 0.2>1.0[0] SEP 0>1.0[0]
WN DAL-MSP AUG 0.2>1.0[0.0] SEP 0>1.0[0]
WN DAL-MSY AUG 1.1>7[7] SEP 0>7[6] OCT 0>0.2[7]
WN DAL-OAK AUG 0.3>1.7[1.9] SEP 0>1.7[1.8]
WN DAL-OMA AUG 0.2>1.1[1.0] SEP 0>1.1[1.0]
WN DAL-PHX AUG 0.9>6[6] OCT 0>0.2[6]
WN DAL-PNS AUG 0.2>1.1[0.3] SEP 0>1.0[0.2]
WN DAL-SAT AUG 1.5>9[9] OCT 0>0.3[9]
WN DAL-SDF AUG 0.2>1.0[0] SEP 0>1.0[0]
WN DAL-SFO AUG 0.3>1.1[2] SEP 0>1.0[1.9]
WN DAL-SJC AUG 0.3>2[1.9] SEP 0>2[1.8]
WN DAL-SNA AUG 0.1>0.8[0.9] SEP 0>0.9[0.8]
WN DAL-STL AUG 0.9>6[6] OCT 0>0.2[6]
WN DAL-TPA AUG 0.5>3[2] SEP 0>3[2]
WN DAL-TUL AUG 0.6>4[4] SEP 0>4[3]
WN DCA-FLL AUG 0.4>2[2] SEP 0>1.5[2]
WN DCA-HOU AUG 0.5>3[3] SEP 0>4[3]
WN DCA-MCI AUG 0.3>1.8[1.9] SEP 0>1.9[1.8]
WN DCA-MCO AUG 0.4>2[2] SEP 0>1.3[2]
WN DCA-MDW AUG 1.0>6[6] SEP 0>7[6] OCT 0>0.2[6]
WN DCA-MKE AUG 0.3>1.8[1.9] SEP 0>1.9[1.8]
WN DCA-OKC AUG 0.2>1.0[0] SEP 0>1.0[0]
WN DEN-DTW AUG 0.3>2.0[2.0] SEP 0>2.0[2]
WN DEN-ELP AUG 0.2>1.0[0] SEP 0>1.0[0]
WN DEN-EWR AUG 0.3>1.8[1.9] SEP 0>1.9[1.8]
WN DEN-FLL AUG 0.3>1.2[1.2] SEP 0>1.1[1.2]
WN DEN-HOU AUG 1.1>7[6] SEP 0>7[6] OCT 0>0.2[6]
WN DEN-LAS AUG 1.5>9[9] OCT 0>0.3[8]
WN DEN-LAX AUG 1.1>7[7] OCT 0>0.2[7]
WN DEN-LBB AUG 0.2>1.0[0] SEP 0>1.0[0]
WN DEN-LGA AUG 0.5>3[2] SEP 0>3[2]
WN DEN-MCI AUG 1.1>7[7] SEP 0>6[7] OCT 0>0.2[7]
WN DEN-MDW AUG 1.5>9[9] OCT 0>0.3[9]
WN DEN-MEM AUG 0.2>1.0[0] SEP 0>1.0[0]
WN DEN-MSY AUG 0.5>2[2] SEP 0>1.9[1.8]
WN DEN-ONT AUG 0.4>3[1.9] SEP 0>3[1.8]
WN DEN-PDX AUG 0.8>5[4] SEP 0>5[4]
WN DEN-PHL AUG 0.5>3[3] SEP 0>3[2]
WN DEN-PHX AUG 1.7>11[10] SEP 0>11[10] OCT 0>0.4[11]
WN DEN-PIT MAR 1.1>1.4[1.1] AUG 0.4>1.8[1.1] SEP 0>1.7[1.0]
WN DEN-RDU AUG 0.4>1.9[2] SEP 0>1.8[1.9]
WN DEN-RNO AUG 0.4>2[2] SEP 0>2[2.0]
WN DEN-SAN AUG 1.0>6[6] OCT 0>0.2[6]
WN DEN-SAT MAY 3>2[3] AUG 0.5>3[2] SEP 0>3[2.0]
WN DEN-SJC MAR 3>4[3] AUG 0.8>5[4] SEP 0>5[4]
WN DEN-SLC AUG 0.9>6[6] SEP 0>6[5] OCT 0>0.2[6]
WN DEN-SMF AUG 0.8>5[4] SEP 0>5[4]
WN DEN-SNA AUG 0.6>3[5] SEP 0>3[4]
WN DEN-STL AUG 1.0>6[5] SEP 0>6[5] OCT 0>0.2[5]
WN DEN-TUL AUG 0.3>2[2] SEP 0>2.0[2]
WN DEN-TUS AUG 0.3>2[2] SEP 0>2[2.0]
WN DSM-PHX AUG 0>0.2[0] SEP 0>0.3[0]
WN DTW-LAS AUG 0.0>0.3[1.0] SEP 0>0.3[1.0]
WN DTW-MDW AUG 0.7>5[4] SEP 0>5[4]
WN DTW-STL AUG 0.4>3[1.9] SEP 0>3[1.8]
WN ECP-HOU AUG 0.2>1.1[1.2] SEP 0>1.1[1.2]
WN ECP-STL AUG 0.2>0.5[0.3] SEP 0>0.3[0.2]
WN ELP-LAX AUG 0.3>1.7[1.9] SEP 0>1.7[1.8]
WN ELP-SAN AUG 0.2>1.0[0.1] SEP 0>1.0[0.2]
WN ELP-SAT AUG 0.4>2[3] SEP 0>2.0[2]
WN EWR-MDW AUG 0.8>5[6] OCT 0>0.2[5]
WN EWR-OAK AUG 0.1>0.8[1.0] SEP 0>0.9[1.0]
WN EWR-SAN AUG 0.1>0.8[1.0] SEP 0>0.2[1.0]
WN EWR-STL AUG 0.3>1.9[1.9] SEP 0>1.9[1.8]
WN FLL-GCM AUG 0.2>1.0[1.0] SEP 0>0.3[0.7]
WN FLL-HOU AUG 0.5>3[2] SEP 0>3[2]
WN FLL-JAX AUG 0.5>2[3] SEP 0>2[3]
WN FLL-MBJ AUG 0.3>2[2] SEP 0>2[1.9]
WN FLL-MSY AUG 0.5>2[1.2] SEP 0>1.8[1.0]
WN FLL-PHX AUG 0.2>1.1[0.9] SEP 0>1.2[0.8]
WN FLL-PIT AUG 0.2>1.0[1.1] SEP 0>1.0[0.8]
WN FLL-PLS AUG 0.2>1.0[1.0] SEP 0>0.3[0.2]
WN FLL-PVD AUG 0.1>0.3[1.0] SEP 0>0.3[1.0]
WN FLL-STL AUG 0.4>1.9[1.9] SEP 0>1.9[1.8]
WN FLL-TPA AUG 0.6>4[5] SEP 0>4[5]
WN GEG-LAS AUG 0.3>2[2] SEP 0>2[2.0]
WN GEG-OAK AUG 0.3>2[2] SEP 0>2.0[1.9]
WN GEG-SAN AUG 0.2>1.0[0] SEP 0>1.0[0.1]
WN HAV-TPA AUG 0.2>1.2[1.0] SEP 0>1.1[1.0]
WN HOU-IND AUG 0.3>1.9[1.3] SEP 0>1.8[1.2]
WN HOU-LAS AUG 0.9>5[4] SEP 0>5[4]
WN HOU-LAX AUG 0.8>5[4] SEP 0>5[4]
WN HOU-LIR AUG 0.2>1.1[1.0] SEP 0>0.3[0.2]
WN HOU-MAF AUG 0.5>4[3] SEP 0>4[3]
WN HOU-MBJ AUG 0.2>0.5[0.6] SEP 0>0.3[0.6]
WN HOU-MDW AUG 1.0>6[6] OCT 0>0.2[6]
WN HOU-MEM AUG 0.3>1.8[1.9] SEP 0>1.9[1.8]
WN HOU-MEX APR 2>0[4] MAY 2>0[4] JUN 2>0[4] JUL 2>0[4] AUG 0.3>0[4]
WN HOU-MSY AUG 1.5>9[9] OCT 0>0.3[9]
WN HOU-OAK AUG 0.4>3[2] SEP 0>3[2.0]
WN HOU-OKC AUG 0.6>4[4] SEP 0>4[3]
WN HOU-PHL APR 0.2>1.0[0] MAY 0>1.0[0] JUN 0.1>0.4[0]
WN HOU-SAN AUG 0.5>3[2] SEP 0>3[2]
WN HOU-SAT AUG 0.9>6[5] SEP 0>6[5] OCT 0>0.2[5]
WN HOU-SDF AUG 0.2>1.0[0] SEP 0>1.0[0]
WN HOU-SLC AUG 0.1>0.3[0.1] SEP 0>0.3[0.2]
WN HOU-SNA AUG 0.2>1.0[1.7] SEP 0>1.0[1.1]
WN HOU-STL AUG 0.6>4[4] SEP 0>4[3]
WN IND-LAX AUG 0.2>0.9[1.0] SEP 0>0.9[1.0]
WN IND-MCI AUG 0.3>1.8[1.7] SEP 0>1.8[1.7]
WN IND-MDW AUG 0.2>1.2[1.7] SEP 0>1.3[1.7]
WN IND-OAK AUG 0.1>0.7[1.0] SEP 0>0.7[1.0]
WN IND-PHX AUG 0.3>1.8[1.2] SEP 0>1.7[1.0]
WN IND-RSW AUG 0.3>1.1[1.1] SEP 0>0.3[1.0]
WN IND-TPA AUG 0.5>1.4[1.5] SEP 0>1.0[1.2]
WN LAS-LAX AUG 1.6>10[11] SEP 0>10[11] OCT 0>0.4[11]
WN LAS-LBB AUG 0.2>1.0[1.1] SEP 0>1.0[1.1]
WN LAS-LGB JUN 0.3>3[0.6]
WN LAS-MCO AUG 0.4>1.9[2] SEP 0>1.8[2.0]
WN LAS-MDW AUG 1.4>9[9] OCT 0>0.3[9]
WN LAS-MKE AUG 0.5>2[2] SEP 0>2[1.5]
WN LAS-MSY AUG 0.3>1.9[2] SEP 0>1.8[1.9]
WN LAS-OAK AUG 1.3>9[9] OCT 0>0.3[9]
WN LAS-PHX AUG 1.6>10[10] OCT 0>0.4[10]
WN LAS-PIT AUG 0.3>2[2] SEP 0>2.0[2]
WN LAS-RNO AUG 1.5>9[9] OCT 0>0.3[9]
WN LAS-SAN AUG 1.7>11[11] OCT 0>0.4[10]
WN LAS-SFO AUG 1.0>6[7] OCT 0>0.2[7]
WN LAS-SJC AUG 1.6>10[9] SEP 0>10[9] OCT 0>0.4[9]
WN LAS-SMF AUG 1.3>8[7] OCT 0>0.3[8]
WN LAS-SNA AUG 0.7>5[6] SEP 0>5[6]
WN LAS-TPA AUG 0.2>1.0[1.9] SEP 0>1.0[1.8]
WN LAS-TUL AUG 0.2>1.1[1.0] SEP 0>1.1[1.0]
WN LAS-TUS AUG 0.5>4[3] SEP 0>4[3]
WN LAX-MDW AUG 0.9>6[6] OCT 0>0.2[6]
WN LAX-MSY AUG 0.4>1.9[3] SEP 0>1.9[2]
WN LAX-OAK AUG 1.9>13[13] SEP 0>13[12] OCT 0>0.5[12]
WN LAX-OMA AUG 0.1>0.8[1.0] SEP 0>0.9[1.0]
WN LAX-PDX AUG 0.4>2[3] SEP 0>2[3]
WN LAX-PHX AUG 1.3>8[8] OCT 0>0.3[8]
WN LAX-PVR AUG 0.2>0.6[1.0] SEP 0>0.6[1.0]
WN LAX-SFO AUG 1.3>8[9] SEP 0>8[9] OCT 0>0.3[9]
WN LAX-SJC AUG 1.7>11[10] SEP 0>11[10] OCT 0>0.4[10]
WN LAX-SJD AUG 0.2>0.7[1.0] SEP 0>0.7[1.0]
WN LAX-SMF AUG 1.3>8[8] OCT 0>0.3[8]
WN LAX-TPA AUG 0.1>0.7[0.8] SEP 0>0.7[1.0]
WN LAX-TUS AUG 0.4>2[2] SEP 0>2[2.0]
WN LGA-MCI AUG 0.3>1.8[1.0] SEP 0>1.9[1.0]
WN LGA-MDW AUG 1.0>6[6] OCT 0>0.2[6]
WN LGA-MKE AUG 0.3>1.8[1.9] SEP 0>1.9[1.8]
WN LGA-MSY AUG 0.2>1.0[0] SEP 0>1.0[0]
WN LGA-TPA AUG 0.3>1.7[2] SEP 0>1.0[2]
WN LGB-SJC JUN 0>4[0]
WN LGB-SMF JUN 2>4[2] AUG 0.3>2[2] SEP 0>2[3]
WN LIT-PHX AUG 0.2>1.0[0.9] SEP 0>1.0[0.8]
WN LIT-STL AUG 0.3>1.8[1.9] SEP 0>1.9[1.8]
WN MBJ-MCO AUG 0.2>0.7[0.7] SEP 0>0.3[0.7]
WN MCI-MCO AUG 0.6>2[2] SEP 0>2[2.0]
WN MCI-MDW AUG 1.2>8[8] SEP 0>8[7] OCT 0>0.3[8]
WN MCI-MKE AUG 0.3>1.8[1.7] SEP 0>1.8[1.6]
WN MCI-MSP AUG 0.3>1.7[1.7] SEP 0>1.7[1.6]
WN MCI-MSY AUG 0.2>1.1[1.1] SEP 0>1.1[1.0]
WN MCI-OAK AUG 0.2>0.9[1.2] SEP 0>0.8[1.0]
WN MCI-RDU AUG 0.2>0.9[1.0] SEP 0>0.9[1.0]
WN MCI-SAN AUG 0.3>1.8[1.9] SEP 0>1.7[1.8]
WN MCI-STL AUG 0.5>4[4] SEP 0>4[3]
WN MCI-TPA AUG 0.3>1.0[1.1] SEP 0>0.9[0.8]
WN MCO-MHT AUG 0.2>1.2[1.9] SEP 0>1.1[1.3]
WN MCO-ORF AUG 0.2>1.2[1.1] SEP 0>1.1[1.0]
WN MCO-RIC AUG 0>0.2[0] SEP 0>0.3[0]
WN MCO-SAN AUG 0.2>0.9[1.0] SEP 0>0.8[1.0]
WN MCO-SAT AUG 0.4>1.4[1.3] SEP 0>1.3[1.0]
WN MCO-SDF AUG 0.3>1.2[1.1] SEP 0>1.2[1.0]
WN MCO-SJU AUG 0.6>1.8[1.9] SEP 0>1.5[1.1]
WN MDW-MEM AUG 0.3>1.8[1.9] SEP 0>1.9[1.8]
WN MDW-MSP AUG 1.1>7[7] OCT 0>0.2[7]
WN MDW-MSY AUG 0.6>4[3] SEP 0>4[3]
WN MDW-OMA AUG 0.8>4[5] SEP 0>4[5]
WN MDW-ORF AUG 0.3>1.3[2] SEP 0>1.3[2]
WN MDW-PHL AUG 0.9>6[6] SEP 0>5[6]
WN MDW-PHX AUG 1.2>7[7] OCT 0>0.2[7]
WN MDW-SDF AUG 0.5>4[4] SEP 0>4[3]
WN MDW-SFO AUG 0.3>1.9[3] SEP 0>1.8[3]
WN MDW-SJC AUG 0.3>1.8[1.1] SEP 0>1.7[1.0]
WN MDW-SMF AUG 0.3>1.1[1.3] SEP 0>1.0[1.2]
WN MDW-STL AUG 1.1>7[7] SEP 0>7[6] OCT 0>0.2[7]
WN MEM-TPA AUG 0.2>0.9[0.9] SEP 0>0.9[0.8]
WN MKE-PHX AUG 0.3>1.8[1.9] SEP 0>1.9[1.8]
WN MKE-STL AUG 0.3>1.8[1.9] SEP 0>1.9[1.8]
WN MKE-TPA AUG 0.2>0.9[0.2] SEP 0>0.9[0.6]
WN MSP-OAK AUG 0.1>0.7[1.0] SEP 0>0.7[1.0]
WN MSP-STL AUG 0.4>3[3] SEP 0>3[2]
WN MSY-OAK AUG 0.2>0.9[0.9] SEP 0>0.9[0.8]
WN MSY-SAN AUG 0.2>0.9[0.9] SEP 0>0.9[0.8]
WN MSY-SAT AUG 0.3>1.7[1.0] SEP 0>1.7[1.0]
WN MSY-STL AUG 0.3>2[1.9] SEP 0>2[1.8]
WN OAK-ONT AUG 1.1>6[7] SEP 0>6[7] OCT 0>0.2[6]
WN OAK-PDX AUG 0.9>6[6] SEP 0>6[5] OCT 0>0.2[6]
WN OAK-PHX AUG 0.9>6[6] SEP 0>6[5] OCT 0>0.2[6]
WN OAK-RNO AUG 0.3>1.9[1.9] SEP 0>1.9[1.8]
WN OAK-SAN AUG 1.8>11[10] SEP 0>11[10] OCT 0>0.4[10]
WN OAK-SAT AUG 0.2>0.9[1.0] SEP 0>0.9[1.0]
WN OAK-SEA AUG 1.1>7[7] OCT 0>0.2[6]
WN OAK-SJD AUG 0.1>0.4[1.0] SEP 0>0.3[1.0]
WN OAK-SNA AUG 1.0>7[7] OCT 0>0.2[7]
WN OKC-STL AUG 0.3>1.9[1.9] SEP 0>1.9[1.8]
WN OMA-PHX AUG 0.2>1.2[1.8] SEP 0>1.2[1.8]
WN OMA-SAN AUG 0.2>0.8[0] SEP 0>0.7[0]
WN ONT-PHX AUG 1.0>6[6] OCT 0>0.2[6]
WN ONT-SFO AUG 0.6>4[0] SEP 0>4[0]
WN ONT-SJC AUG 0.6>5[4] SEP 0>5[4]
WN ONT-SMF AUG 1.0>7[7] OCT 0>0.3[7]
WN PDX-SAN AUG 0.4>3[3] SEP 0>3[2]
WN PDX-SJC AUG 0.9>6[5] SEP 0>6[5] OCT 0>0.2[5]
WN PDX-SMF AUG 0.7>5[5] SEP 0>5[4]
WN PHX-RNO AUG 0.3>2[2] SEP 0>2[2.0]
WN PHX-SAN AUG 1.6>10[10] OCT 0>0.4[10]
WN PHX-SJC AUG 1.0>6[5] SEP 0>6[5] OCT 0>0.2[6]
WN PHX-SLC AUG 0.9>6[6] SEP 0>6[5] OCT 0>0.2[5]
WN PHX-SMF AUG 0.9>6[5] OCT 0>0.2[6]
WN PHX-SNA AUG 1.0>7[7] OCT 0>0.2[7]
WN PHX-TPA AUG 0.2>0.9[1.1] SEP 0>0.9[0.8]
WN PIT-RSW AUG 0.2>0.4[0.3] SEP 0>0.3[0.2]
WN PIT-STL AUG 0.2>1.1[1.0] SEP 0>1.2[1.0]
WN PIT-TPA AUG 0.4>2[2] SEP 0>2[1.4]
WN RDU-STL AUG 0.3>2[2] SEP 0>2[2.0]
WN RDU-TPA AUG 0.3>1.9[1.8] SEP 0>1.8[1.7]
WN RIC-TPA AUG 0>0.2[0] SEP 0>0.3[0]
WN RNO-SAN AUG 0.5>3[2] SEP 0>3[2]
WN RNO-SJC AUG 0.3>1.9[1.6] SEP 0>3[1.7]
WN SAN-SAT AUG 0.3>2[2] SEP 0>2.0[1.7]
WN SAN-SEA AUG 0.3>1.3[1.2] SEP 0>1.2[1.0]
WN SAN-SFO AUG 1.2>7[8] SEP 0>8[7] OCT 0>0.3[7]
WN SAN-SJC AUG 2>15[11] SEP 0>15[11] OCT 0>0.5[11]
WN SAN-SLC AUG 0.3>1.9[1.0] SEP 0>1.8[1.0]
WN SAN-SMF AUG 2>14[11] SEP 0>14[11] OCT 0>0.5[11]
WN SAT-STL AUG 0.3>1.9[1.9] SEP 0>1.9[1.8]
WN SEA-SMF AUG 0.9>6[6] SEP 0>6[5] OCT 0>0.2[5]
WN SFO-STL AUG 0.2>1.0[1.1] SEP 0>1.0[1.1]
WN SJC-SLC AUG 0.3>1.8[1.6] SEP 0>1.8[1.7]
WN SJC-SNA AUG 1.5>9[8] OCT 0>0.3[9]
WN SJC-TUS AUG 0.1>0.8[0] SEP 0>0.9[0]
WN SLC-SMF AUG 0.2>1.1[1.0] SEP 0>1.1[1.0]
WN SMF-SNA AUG 0.9>6[6] OCT 0>0.2[6]
WN STL-TPA AUG 0.4>2[2] SEP 0>2[2.0]
WN STL-TUL AUG 0.3>1.8[1.9] SEP 0>1.9[1.8]
Swoop
*WO AZA-YEG MAY 0>0.3[0]
*WO FLL-YHM MAY 0>0.3[0] JUN 0>0.3[0] JUL 0>0.3[0] AUG 0>0.3[0] SEP 0>0.3[0] OCT 0>0.2[0.0]
*WO LAS-YHM MAY 0>0.6[0] JUN 0>0.6[0] JUL 0>0.5[0] AUG 0>0.6[0] SEP 0>0.6[0] OCT 0>0.5[0.1]
*WO MCO-YHM MAY 0>0.5[0] JUN 0>0.4[0] JUL 0>0.5[0] AUG 0>0.4[0] SEP 0>0.4[0] OCT 0>0.4[0.2]
*WO OAK-YEG JUN 0>0.4[0] JUL 0>0.4[0] AUG 0>0.4[0] SEP 0>0.4[0] OCT 0>0.4[0]
*WO TPA-YHM MAY 0>0.3[0]
Nothing we didn't know, but now official.
*WW KEF-LAX MAR 0.5>0[0.5] APR 0.4>0[0.5] MAY 0.9>0[0.8] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 0.5>0[1.0]
*WW KEF-ORD MAR 1.0>0.0[0.9] APR 1.0>0.6[1.0]
*WW KEF-PIT MAR 0.5>0[0.5]
*WW KEF-SFO APR 0.4>0[0.5] MAY 0.7>0[0.8] JUN 0.7>0[1.0] JUL 0.7>0[1.0] AUG 0.7>0[1.0] SEP 0.3>0[1.0]
XE BUR-CCR MAR 0>3[0.8] APR 0>3[0.9]
XE BUR-LAS MAR 0>6[0.9] APR 0>6[1.0]
XE BUR-MMH MAR 0>0.6[0.3]
XE BUR-OAK MAR 0>5[1.1] APR 0>5[1.1]
TRM is Riverside, CA
*XE BUR-TRM APR 0>0.5[0]
*XE LAS-OAK MAR 0>3[0] APR 0>3[0]
*XE LAS-SNA MAR 0>4[0] APR 0>4[0]
*XE MMH-SNA MAR 0>0.6[0]
*XE OAK-SNA MAR 0>3[0] APR 0>3[0]
*XE OAK-TRM APR 0>0.2[0]
*XE SNA-TRM APR 0>0.4[0]
jetbluefan1
Re: OAG Changes 2/3/2019: AA;B6;UA;WN;XE Adds TRM;Swoop Routes;
Sun Feb 03, 2019 2:59 pm
Thanks enilria!
Interesting to see AA bring MIA-SFO down to 2x from 4x. Perhaps an opportunity for B6 to add a third Mint frequency from FLL to backfill some of the capacity.
B6 is finally adding a second frequency on BOS-AUS. This is way overdue. Also nice to see a third BOS-CHS frequency added. Notably both markets are served by DL.
WN chopping BOS-ATL to 1x -why even bother any more? This market is a blood bath.
RJNUT
Riverside is RAL..TRM is Thermal California 30 miles southeast of Palm Springs
jfklganyc
Sun Feb 03, 2019 3:17 pm
Is AA really pulling JFK MCO or is that an error?
My god if they are! They are in serious trouble in NYC. Totally irrelevant
Brickell305
Sun Feb 03, 2019 3:28 pm
I figured last week’s numbers on ANU-MIA had to be an error. Good to see it fixed this week.
adamh8297
Sun Feb 03, 2019 3:33 pm
The "0.1" on these routes come up as extra Sunday flights. Its pretty much a late pm depature in both directions. I guess they just to squeeze a bit more out of these 4 737's that day.
Airlines flown: A3, AA, AC, AF, AM, BA, B6, CA, CO, CX, DL, EA, EL, IB, LH, MI, MQ, NH, NW, NZ, OU, PE, QF, S4, SQ, TP, UA, US, VS, WE, WN
2019: CX BOS-HKG, WE HKG-HKT, CA HKT-PEK-EWR, B6 EWR-BOS
klm617
Sun Feb 03, 2019 3:35 pm
WOW Royal Jordanian doubling it's service to Detroit.
the truth does matter, guys. too bad it's often quite subjective. the truth is beyond the mere facts and figures. it's beyond good and bad, right and wrong...
HVNandrew
Sun Feb 03, 2019 3:46 pm
Has there been a concerted effort to attract commercial service to TRM? I would think that PSP could handle all of the demand in the Coachella Valley. TRM would be convenient for certain spots, like Coachella, La Quinta and maybe Indian Wells, but any further west and PSP is a closer option with quite a bit of service. And there's really nothing to the east and south.
Chuska
Sun Feb 03, 2019 4:03 pm
Great to see WN bringing up ABQ-AUS and SJC to a daily flight each. They've been operating on only one or two days per week for some time.
ericm2031
Sun Feb 03, 2019 4:27 pm
Looks like mainline will only operate for about a month this Spring and then they will go to 2x CR9 afterwards and both will be morning departures, which offer more connecting opportunities over the current afternoon departure. If only they'd put an E75 on the route similar to SBP-DFW.
SBA will be very busy in the mornings with LF and AA both adding an additional overnight aircraft to the 4 UA, 1 AA that already overnight and DL adding one in August.
enilria
Sun Feb 03, 2019 4:28 pm
jetbluefan1 wrote:
Thanks enilria!
Agreed on BOSATL
Google says:
Jacqueline Cochran Regional Airport (IATA: TRM, ICAO: KTRM, FAA LID: TRM) is a county-owned, public-use airport in Riverside County, California, United States.
Is it not in Riverside?
Spot checking AA.com. Seems like that is the case for May. I don't see a nonstop on most days.
RJNUT
Sun Feb 03, 2019 4:43 pm
I believe this service is just operational in April for the Coachella Music Festival. You know, flying all the "stars" out from LA Area and also the Bay area. Thermal does have Advanced Air regular service to Hawthorne, I believe.
To enilria, Riverside ,(the city) is at the far western end of Riverside County which is quite long in geographical area. They have their own municipal airport .
PVD757
Sun Feb 03, 2019 4:50 pm
Glad to see both UA and AA going up to 3x on PVD-ORD.
FATFlyer
Sun Feb 03, 2019 5:02 pm
enilria wrote:
Google says:
Riverside County is over 7,000 sq miles, larger than Rhode Island and Connecticut combined.
The city of Riverside is on the northwestern corner of the county. TRM is over 80 miles east of the city of Riverside.
"Travel is fatal to prejudice, bigotry, and narrow-mindedness." - Mark Twain
Vctony
Sun Feb 03, 2019 5:03 pm
Looks like as far as PHX is concerned, there are a handful of mainline AA cuts, a handful of regional AA adds, and a handful of WN adds.
sargester
Sun Feb 03, 2019 5:06 pm
BA is shifting more capacity to MIA and PHL to connect people to MCO, JFK MCO is a route that's dominated by B6 and DL... I believe aa wants to make this seasonal
FATFlyer
Sun Feb 03, 2019 5:13 pm
Those will only operate in April for the Coachella Music Festival.
DALLAS, Jan. 23, 2019 /PRNewswire/ -- JetSuiteX, the acclaimed air carrier that offers scheduled flights from private terminals for the cost of a commercial ticket, has announced that tickets are now on sale for seasonal flights to Coachella Valley in April. Following the success of last year's service from Burbank (BUR) to Thermal, only 15 minutes from the Valley, JetSuiteX has added flight capacity from Burbank and introduced flights from two new markets – Oakland (OAK) and Orange County (SNA). Ticket prices start at $69 each way.
https://www.prnewswire.com/news-releases/jetsuitex-announces-the-return-of-hassle-free-seasonal-flights-to-coachella-valley-in-april-300783166.html
FlyHossD
Sun Feb 03, 2019 5:35 pm
Each Sunday morning, my first and favorite thing to check on line is for your routes post, Enilria. Thanks again for your work and dedication to spreading the word, it's much appreciated.
jfklganyc
Sun Feb 03, 2019 5:38 pm
JFK MCO is not a seasonal route.
It is one of the busiest routes in the nation.
AA is really toast to the NYC traveller of their own doing. Bizzare
Bigant0408
Agreed I always look forward to his Sunday post. Best part of my Sundays
The man who sleeps on the floor doesn’t fall out of bed
Bigant0408
Sun Feb 03, 2019 5:41 pm
I’m just curious how BA is shifting capacity to those hubs?
OA412
Sun Feb 03, 2019 5:46 pm
I believe they still fly LGA-MCO.
Hughes Airwest - Top Banana In The West
AVLAirlineFreq
Sun Feb 03, 2019 5:53 pm
Will flight attendants wear sundresses and cowboy boots? And will each passenger be provided with their own flower crowns? ;)
sargester
Sun Feb 03, 2019 6:07 pm
Not saying it is, I have a feeling AA will fly it seasonal, cmon go look at the fares yourself, let B6 and DL slaughter themselves over getting the families to Disney, and that's only for the month of May which is not a very busy month for air travel... do you know how many people every day end up booking connections on DL and AA through ATL/CLT to do the same route
sargester
Upgaged from 737-800 to A321
jfklganyc
Sun Feb 03, 2019 6:10 pm
Once daily to LGA
FATFlyer
Sun Feb 03, 2019 6:47 pm
I don't know about this year. But last year, JetSuiteX partnered with Boots on Stage. Passengers received free passes to a private pre-party plus swag gifts on the flight.
http://www.facebook.com/jetsuitex/photos/introducing-our-latest-pop-up-flight-presented-by-boots-on-stage-a-leader-in-cou/2048085915414086/
TWA1985
Sun Feb 03, 2019 7:19 pm
I’ve noticed a lot of AA reductions at ORD. Is this possibly to due to upgauging or what do y’all think?
Be Young. Be Wild. Be Free.
Midwestindy
Cutting JFK-MCO won't cause them to lose any NYC based flyers. Once they start cutting things like JFK-SEA/SAN/YYZ/e.t.c, they will be in trouble
The majority of families fly to MCO once or twice, and it isn't a high yielding destination like some of the Caribbean destinations are, so it isn't that important that AA serve that route.
I'd be willing to wager JFK-MCO had a large portion of the passengers on mileage tickets, which is not profitable.
Status for 2019/2020: AAdvantage Platinum, Delta Gold, Southwest A-List
B757capt
Sun Feb 03, 2019 7:40 pm
What’s LGA-MCO at? I bet 2x or 3x a day in peak.
No way JFK can compete. Connect traffic will have their lunch eaten with all of the new non stop service from Europe.
I would bet JFK becomes an INTL only operation with feed to high value and or perimeter void routes. I.e. LAX SFO SEA.
The views written by this user are in no manner the views of my employer and should not be thought as such.
axiom
Sun Feb 03, 2019 8:51 pm
This is a surprise. Up to six weekly in the low season, with DL also joining the AMS fray year-round. The six-way battle on TPA-Europe continues... surely someone blinks. DY would be my bet, but UK-Florida is something of a bottomless pit.
grbauc
Sun Feb 03, 2019 9:25 pm
Agree not sure you can sugar coat that at all. NYC for AA is plain and simple like UA at LAX a mess of there own doing.
EvanWSFO
Sun Feb 03, 2019 10:09 pm
FATFlyer wrote:
enilria wrote:
Google says:
https://www.world-airport-codes.com/uni ... -9253.html This says it's in Palm Springs, but Google maps places it in Thermal.
I have been on this site 15 years. A unrecoverable email account led me to starting over. Those of you who call me a rookie, you may stop ok?
BTVB6Flyer
Sun Feb 03, 2019 10:19 pm
DY's pax numbers looked pretty good for TPA' December numbers.
I think after AMS it will stabilize for a bit and TPA has already said it's not looking to add to Europe. WK has gone to 1x sometimes 2x weekly and Icelandair is back down to I think 2x now?
HeeseokKoo
Sun Feb 03, 2019 10:21 pm
Sadly both flights are somewhat BOS oriented - 7am and 11am departure from BOS; 3pm and 7pm departure from AUS. Both A320.
Big news indeed but WN was quite about it. News media in ABQ area were quite, too.
FSDan
Sun Feb 03, 2019 10:51 pm
It's still showing as 2x daily in June and on, so not sure if it's just a shoulder season cut or what...
There are a few routes that show up differently in this thread than what's actually loaded. Examples:
MIA-SFO - shows 2x daily here, looks like 3x daily on aa.com
ORD-ATL - shows 4x daily here, looks like 5x daily on aa.com
And regarding the AA frequency cuts at places like ORD, it does appear that some are related to upgauging. For example, ORD-ATL is now up to 1x daily E75 and 4x daily 738. Until relatively recently it had at most 1-2 daily mainline.
This is my signature until I think of a better one.
intotheair
Sun Feb 03, 2019 11:36 pm
EvanWSFO wrote:
FATFlyer wrote:
enilria wrote:
Google says:
The Thermal airport is not in Palm Springs. It's in the same region, which is often collectively called the Coachella Valley. Palm Springs and Thermal are about 35 minutes from each other on I-10.
For reference, let's zoom out to show all of Riverside County. As you can see, it stretched from the LA region all the way to the Arizona border. Riverside to Thermal is about a 90 minute drive (in no traffic).
300 319 320 321 332 333 345 346 380 717 733 734 735 73G 738 739 744 752 753 762 763 772 77W 788 789 CR2 CR7 CR9 CRK Q400 E175 DC10 MD82 MD90
AA AF AS AY AZ B6 BA BR DL F9 FI GA HA KF LH MI QX SK SN SQ UA US VY WN
EvanWSFO
Sun Feb 03, 2019 11:44 pm
I was merely pointing out what World Airport Codes lists it as. I also noted it is in Thermal per Google maps.
intotheair
Mon Feb 04, 2019 12:02 am
Oh yes, I didn’t want to sound argumentative — I just thought some visuals would help everyone who didn’t open up Google Maps.
pbodyphoto
Mon Feb 04, 2019 1:19 am
Well spotted, I flew this route for the first time this week, was a full flight but I booked it only hours before departure for only $220. There is over 40 daily flights from NYC to MCO, way too much competition to make money.
FLYKTPA
Mon Feb 04, 2019 1:27 am
[quote="axiom"]LH FRA-TPA NOV 0.6>0.9[0.6]
This is a surprise. Up to six weekly in the low season, with DL also joining the AMS fray year-round. The six-way battle on TPA-Europe continues... surely someone blinks. DY would be my bet, but UK-Florida is something of a bottomless pit.[/quote]
October and November are actually two busy months for the Lufthansa flight at TPA and European traffic overall. Filling 6x weekly at TPA shouldn’t be an issue for them except during January and February.
Huge fan of Tampa International Airport
FLYKTPA
Mon Feb 04, 2019 1:29 am
The Lufthansa flight was 89% full in November 2017. They must see the potential for it to support more capacity.
sargester
Mon Feb 04, 2019 1:34 am
I can attest to what your saying, have gotten at least 5 trips just on miles on that route, and dirt cheap J tickets too... actually memorized the J ticket price if it was the lowest fare class lol
tphuang
Mon Feb 04, 2019 2:00 am
jetbluefan1 wrote:
Thanks enilria!
Yep, good time for B6 to up their frequency on FLL-SFO. But they might not have the airframe for this until next year. I don't know if you noticed, but they added to a few markets out of BOS in May to mid june, too away extra frequency in peak summer period and then added them back for September. I think they are just really short on planes.
Also WN is down to once daily on CUN-FLL and twice daily on JAX-FLL. Here is my prediction, those those won't be around next summer.
I guarantee you JFK-SEA/SAN/YYZ are not profitable either.
Thanks enilria. I believe TRM stuff is for Coachella.
OAK-SNA is up to 3 daily for twice daily in Feb. Jetsuitex is building up some nice frequency at OAK and SNA against WN.
Timaay419
Mon Feb 04, 2019 2:11 am
More mainline, less eagles nest = good. Latest departure from SFO @ 6pm = bad.
sargester
Mon Feb 04, 2019 3:55 am
tphuang wrote:
jetbluefan1 wrote:
Thanks enilria!
SEA/SAN do well, and not sure about YYZ they have had the same amount of frequencies there for a few years
MIAFLLPBIFlyer
Mon Feb 04, 2019 1:00 pm
tphuang wrote:
jetbluefan1 wrote:
Thanks enilria!
It's pretty remarkable from where I sit how much trouble WN is having at FLL because NK and B6 networks rely on local O/D AND POS abroad. WN seems to hope connections can offset the POS abroad but it hasn't happened. In general WN's international strategy seems to be coming apart as the recent axing of MEX shows us. Hopefully they turn it around. WN is basically a hybrid LCC/network carrier these days and it is good for overall competition if they can offer more than just domestic flights.
jetbluefan1
Mon Feb 04, 2019 3:22 pm
Re AA dropping JFK-MCO - I think this is just emblematic of AA’s continuing decline in NYC. UA and DL are stronger than they have ever been, and B6 is holding its own. AA has decided that it’s just not worth it with the limited resources that they have.
That said JFK-MCO is actually a decently yielding market with limitless demand, so this drop is somewhat surprising.
On a personal note...I remember flying this on a TWA 717 right before 9/11, in the last days of the old T5 and right around the time AA put TWA out of its misery. Surreal to think how the market has evolved.
They noted on the conference call that all new 321 deliveries this year will be in the Core configuration, which is disappointing. I feel like a third FLL-SFO and fourth FLL-LAX Mint frequency are low hanging fruit with a direct benefit to the bottom line. (I think there’s an argument for even more Mint flights from BOS and JFK too.)
The delay in the 321neos is really an inconvenience they don’t need right now in an already-strained operation. I’d like to see them completely eliminate LGB and redeploy those planes to build in additional spare capacity time and to add (permanent) frequency to markets like BOS-BNA/HOU/DFW/PHX. Seeing the additional CHS and especially AUS flights is encouraging though. (And the retiming of the BUR flight I think helps their overall BOS-LA position.)
[quote=“sargester”]SEA/SAN do well, and not sure about YYZ they have had the same amount of frequencies there for a few years[/quote]
I doubt AA makes any money from JFK to SEA/SAN. I believe their RASM is lower than B6/DL (and far lower than UA from EWR). Fuel prices have moderated though, so that makes these markets somewhat more viable.
MIAFLLPBIFlyer wrote:
It’s pretty remarkable from where I sit how much trouble WN is having at FLL because NK and B6 networks rely on local O/D AND POS abroad. WN seems to hope connections can offset the POS abroad but it hasn't happened. In general WN's international strategy seems to be coming apart as the recent axing of MEX shows us. Hopefully they turn it around. WN is basically a hybrid LCC/network carrier these days and it is good for overall competition if they can offer more than just domestic flights.
Based on what I have read in numerous articles and discussion sites, WN hasn’t invested in the ground resources necessary to make certain international markets work (primarily those that rely on VFR or foreign POS demand, such as MEX). But I think this goes beyond that. WN can’t even make FLL-NYC work.
That said, B6 has its own weakness at FLL - primarily those markets where it competes with both NK/WN and doesn’t have strong POS on the other end (I.e. DTW, BWI, which have been dropped). I also wouldn’t be surprised to see B6 drop a market like FLL-MSY, which I believe competes with both, is full of low yielding leisure demand, and offers little relevance to its primary FLL-based target market.
enilria
Mon Feb 04, 2019 5:21 pm
That's interesting.
Wow. I guess there's always more to learn.
Interesting!
True, but it's super-odd to drop a big route like that for a month. I wonder what will absorb the slots for a month? Or maybe they will extend this?
VERY helpful. I love maps!
Agreed
Yeah, that's pretty cool. Don't they need TSA for a scheduled flight on an aircraft over 10 seats? I didn't look, but I assume this is an RJ.
I've predicted this before, but I predict a transaction where NK/WN/B6 becomes a two carrier situation in FLL. One of those guys will sell their gates to another. Hard to say which. I would assume B6 is the least likely to sell, with NK and WN most likely. It should be WN selling to B6, but they are stubborn in the face of what is probably poor performance. NK probably does really well, but I think pretty much anything there is for sale at the right price. I don't think B6 can afford to reduce their network footprint any further by exiting. I could imagine NK pocketing eighty or a hundred million and moving everything to MCO.
I find Floridians are the least snobbish about NK and from what I have seen, NK actually has the most "loyalty" in the FLL point of sale which is surprising because NK and loyalty do not usually go together. Of course the market is mostly inbound, so being king of FLL residents is not enough to have a lock on the market.
On another note, how smart would NK have been to lock down FLL 10 years ago before everybody else started making inroads? That was probably Indigo's only big mistake with NK.
FA9295
Mon Feb 04, 2019 5:24 pm
AA's SEA/SAN-JFK do well do to strong business markets on both sides of each route.
An interesting plot twist would be for AA to add SEA-SAN (and SAN-SEA) so they could run some triangle routes with the 737-800 like JFK-SEA-SAN-JFK or JFK-SAN-SEA-JFK... With that being said though, they already do use AS for routes up and down the west-coast... ;)
