Matatan1293
Cl215 canadair
Mon Feb 04, 2019 1:13 am
Hey guys I'm wondering what would be a repair for a damage on a spar where the wing meets the fuse . I drill out a hi lok but miss and my number 20 bit came beside the hole and of the hi lok and damage one of the main spars by the fuel cell 2 l/h and I'm wondering how can it be fixed . I'm looking for experienced that can be learn or similar situations so I don't fell bad at all.. thanks
GalaxyFlyer
Re: Cl215 canadair
Mon Feb 04, 2019 1:40 am
Get the AMM or the Structual Repair Manual. You come here asking technical information on a damage repair?
GF
747Whale
Re: Cl215 canadair
Mon Feb 04, 2019 5:10 am
Why are you drilling out a hi-lock instead of removing the collar, or holding the collar and driving the hi-lock out with an allen key?
If you've missed the hole, you're facing either enlarging the hole (with a reamer: this is a tight tolerance), or building a repair over the area and redoing all the other hi-locks, too. Edge distance between holes and tolerance per the structural repair manual may preclude both. If you don't have a repair noted in the SRM, then you'll need engineering involved.
Nobody online can see the damage, and won't be able to provide specifics.
It sounds like you may be doing work that you're not qualified to do, given your choice of tools, your method of removal, and your question. Regardless, if you've drilled into the spar, you've created a very dangerous condition and need to get someone at your location, who is qualified, involved immediately.
Francoflier
Re: Cl215 canadair
Mon Feb 04, 2019 8:42 am
Whatever you do, please, do the right thing and get the work checked and re-checked. Get advice from your peers. Do not try to cover it up.
People's lives are at stake.
Matatan1293
Re: Cl215 canadair
Mon Feb 04, 2019 9:15 am
Hi lock was stock and I was told by my supervisor to drill from the tail due to lack of room on the other side . I enlarge the hole and It looks like a 8 perfectly..
stratclub
Re: Cl215 canadair
Tue Feb 05, 2019 1:03 am
In the trade, what you did is drilled a sno-man :banghead: .
Go to the SRM for the aircraft you are working on. Nothing we tell you here is valid if it can not be verified in the SRM for the aircraft you are working on. Your super may have meant to drill the head off and then punch the Hi-Lok's shank out.
747Whale
Re: Cl215 canadair
Tue Feb 05, 2019 6:32 pm
Have you ever removed a hi-lock? Have you ever removed a rivet?
If you have access to the "tail," then you can easily either remove the collar by backout the Hilock body, or you can break the tail off.
You understand that drilling a rivet doesn't mean you run the drill into the material, right?
Drilling a rivet involves using a bit the same size and the rivet shank diameter of smaller, ensuring it stays center, and drilling the factory head (usually). You drill to the depth of the factory head, inside the rivet only, and then use a punch to break off the head, and then use the punch to drive the body out the other side. You should never attempt to actually drill into a rivet beyond the head.
stratclub
Re: Cl215 canadair
Tue Feb 05, 2019 6:41 pm
Well depends. A lot depends on that thing called experience. Don't make sno-men holes and don't pooch the metal when you drive the rivet out and you are golden.
acmx
Re: Cl215 canadair
Sat Feb 09, 2019 3:11 am
You need a binocular bolt shown on the left side of this pic!
If you’re lucky you might oversize the hole and get away with a larger fastener, but with a snowmanned hole you could have edge distance issues. You need to find a repair in the srm or get an engineer involved. Keep it legal and safe no matter what you do. Seems like if you had access to the tail to drill it, that you should’ve just took the collar off and knocked it out. But I wasn’t there to see how you ended up resorting to that. They say you learn the most from your screw ups, I believe that is true.
Users browsing this forum: No registered users and 20 guests
