• 1
  • 4
  • 5
  • 6
  • 7
  • 8
Dieuwer
Re: U.S. Politicians propose Green-New-Deal. Air Travel to Become Unnecessary
Mon Feb 11, 2019 5:27 pm
Dutchy wrote:
Dieuwer wrote:
When I was really really young, a big issue was "Acid Rain" in Europe: due to extreme amounts of sulfur oxides spewed into the air, the rain had turned acidic and was ruining medieval buildings like cathedrals and overall creating an unhealthy atmosphere. Something was done about it and nowadays there is no such things as "Acid Rain" anymore.
Similar story with the "Ozone Hole". Remember that crisis? We would all burn to death. Guess what, the problem was addressed, the culprits (freons) were banned and nowadays you don't hear about the "Ozone Hole" anymore.
Not sure why "Climate Change" is any different.
:checkmark: we can do this, if the political will is there.
Dutchy, you also do remember those two issues?
AirFiero
Mon Feb 11, 2019 5:30 pm
seb146 wrote:
AirFiero wrote:
seb146 wrote:
Melting ice caps and mountain glaciers, coastal areas under water, stronger storms, spieceis of animals dying off.... absolutely zero problems there brought on by rising CO2 levels.
Ice caps are NOT melting. Arctic ice is still near normal, even though we were told ten years ago that the arctic would be ice free by now. Antarctic ice is ABOVE normal, contrary to the warmists models.
Sea level rise began in the 1700s, as we came out of the little ice age.
Animal species are not dying off at any rate greater than history.
NO weather events can be connected to alleged warming.
So no, we don't have a problem.
You have any peer reviewed studies to back any of that up?
Sea level history with links to studies and explanations and analysis
http://notrickszone.com/2011/02/16/a-le ... ea-levels/
Arctic ice within standard deviation
https://nsidc.org/data/seaice_index/ima ... series.png
Neither hurricanes nor tornadoes are increasing
Links to data and datasets are either listed with the graphs or embedded in the graph
https://wattsupwiththat.com/extreme-weather-page/
I will leave it up to you to prove animal species are dying at an accelerating rate
Dutchy
Mon Feb 11, 2019 5:34 pm
Yes, I am old enough to remember this and these two indeed were solved.
GalaxyFlyer
Mon Feb 11, 2019 5:36 pm
Dutchy wrote:
GalaxyFlyer wrote:
In 2007, IPCC said we had 8 years left, in 2018 they said 12 years. More scare mongering. If you want to go back to the 70s, we were all supposed to be stricken with starvation by said the population experts of the day. In 1973, fossil fuels were going run out by 1979. Of course, we were supposed to run out of petroleum in the next ten years since they were first discovered for modern uses in the 1800s. I had a friend who was a UAL captain tell me in no uncertain terms jet fuel would run out by July 1979; that fact was “inescapable”. Lord Kelvin, the preeminent scientist of his time said, in 1903, “heavier than air flight was impossible”.
I lived long enough to have healthy skepticism of “experts” especially when they are predicting the future. Don’t believe anything I hear and only half of what I see. Treat sacred objects with deep caution. Climate change has a lot in common with medieval religion; “believe us, the anointed, it’s too much for you deplorables”. The GND is a society wide “indulgence” paid to prevent hell on Earth—rising waters (Obama stopped that); disappearing cities going underwater. It’s warmed before (Roman and Middle Age Warm Periods); cooled before and its changing again. Adapt.
GF
Pfffff so we should distrust experts because of what?
So you are at least 65years old, probably quite a bit older. So you will not see the results if you are wrong, quite an easy position to be in. Adapting, right. Have you looked at the map I supplied you? How do you adapt to that without massive disruptions? So is it worth the risk, perhaps for you yes, because you can continue your way of life, without seeing the consequences? Perhaps you have grandchildren? Perhaps they may inherit a habitable planet, just like you did?
These children believe we should do more because they want to have a habitable planet. https://www.bbc.com/news/world-europe-47070853
Because they’ve proved to be seriously in error so many times.
Dutchy
Mon Feb 11, 2019 5:43 pm
GalaxyFlyer wrote:
GF
So is it worth the risk for you, even if the experts happened to be right and the consequences are that half the planet is uninhabitable?
seb146
Mon Feb 11, 2019 7:54 pm
Your first and third links are laughable at best. The second link shows there is less ice in the Arctic 1980-2018, which backs up what many of us say.
Like NASA and NOAA, the two agencies who study this kind of thing
https://climate.nasa.gov/news/2680/new- ... elerating/
https://climate.nasa.gov/vital-signs/arctic-sea-ice/
https://www.thoughtspot.com/thoughtspot ... d-7-charts
yeah, I know but it does provide links to NOAA information
https://www.biologicaldiversity.org/pro ... on_crisis/
https://www.earthday.org/2018/05/18/fac ... s-decline/
Colony collapse in bees is being examined as being caused by pesticides. No bees means no fruits or vegetables.
We need to stop polluting. It will take time to set up factories to produce green alternatives but we need to start this today and not wait until this place is on it's last legs and you righties are saying "gee... I wish we would have know, I wish there were something we could do!"
You bet I'm pumped!!! I just had a green tea!!!
GalaxyFlyer
Mon Feb 11, 2019 8:02 pm
Yes, as I believe the risks of some the actions contemplated is as bad as some of the worst outcomes none of which makes the planet uninhabitable. We’re talking rises in temp on the order of a few degrees which has occurred in history a number of times.
Again, when the scientists and politicians pushing this agenda ACTUALLY change their behaviors, I’ll believe it. They need to walk the talk better. They have conferences all over the world, Jet go Davos and Aspen, build large homes and ride in big, long limousines. Stop that, they might be more convincing. Skin in the game, I believe.
GF
Dutchy
Mon Feb 11, 2019 8:31 pm
GF
Ok, the world was a few degrees colder then it is today when there were kilometers of ice sheets in Europe and America. So yes, the temperature is shifting over the centuries, but now it is human-induced and with the shifting in temperature there was a shifting in overall nature as well.
A few degrees matter. But hey that is what experts say, so why would you believe them? We have established that you are over 65, so the consequences are not yours and that is quite shameful.
But hey, you are rather waiting for a few politicians to change their behavior. Really? Sorry, I do not believe one bit of it.
2122M
Mon Feb 11, 2019 8:51 pm
GF
Incorrect. There have been temperature swings of a few degrees, but never this quickly. The pace of recent global temperature change is what is truly alarming and is also what points to this being a man-made phenomenon.
https://www.climate.gov/sites/default/f ... ph-610.gif
GalaxyFlyer
Mon Feb 11, 2019 10:59 pm
Well, then, we’re screwed because nobody, and I mean nobody, is actually changing behaviors. If time is that short, it’s already way too late. I’ll have another Scotch.
I’ve listened to too many experts who proved to be wrong to panic over this one and since no one else, except you lot, are panicking, I’m not either.
If you th8nk this program has a chance of enactment, listen to Chait, a Democrat
http://nymag.com/intelligencer/2019/02/democrats-need-a-climate-plan-the-green-new-deal-isnt-it.html
GF
SheikhDjibouti
Re: New Green Deal - Air travel obsolete
Mon Feb 11, 2019 11:19 pm
Spark94541 wrote:
As far as I can tell, trains are competitive in the best circumstances with distances inside of 200km, or just over the 120 mile mark. High speed trains are good to maybe 500km. After that, it's a bit of novelty SF to LA, it works, but SF to Seattle? That flight is an easy 2 hours, and I doubt we can get a train to do it in 6. Chicago to New York is another. It's 2 1/2 hours on a plane, but can a train do it in 7 hours?
This is a discussion that's been had in many forums over many years.
Up until 20 years ago, the distance where trains were competitive in terms of time was quite low.
Then we had 9/11
Now (when flying) you need to add a whole bunch of time for security, checking in your (very limited) quantity of luggage, and squeezing all the passengers on board in single file through one (or at best, two) small aircraft doorways.
The flight that you describe as "an easy 2 hours" is in total a much more prolonged slog.
As for cost; the average train seat, with a decent corridor and space to walk around, plus access to sensibly sized toilets, and possibly even a buffet & bar, makes the entire experience much more "first class" than economy.
SheikhDjibouti
Mon Feb 11, 2019 11:54 pm
KFLLCFII wrote:
But nowhere near safer over up to thousands of miles including countless thousands of grade crossings...Or do you also want to spend the money to bridge every last paved and unpaved country road crossing in the middle of nowhere?
It is a pity you haven't provided any numbers to justify that allegation. It would certainly strengthen your case... if it could be proved true. :scratchchin:
Meanwhile it is unfortunate that some countries are starting this whole process from such a poor position.
Grade crossings are almost unknown these days in Europe. Certainly in terms of high speed lines, of which there are many.
Likewise, you will not find European locomotives fitted with cow-catchers.
In fact, not two miles away from me are two over-bridges that were constructed not for vehicles or people, but rather so that cattle could safely wander from one side to the other without meeting an InterCity Express.
Here is a similar construction over a major road
Thx wikipedia
Also, people in Europe who live "in the middle of nowhere" are quite used to the idea that maybe they have to drive 5 or even 10km out of their way, in order to find somewhere with enough traffic to justify a bridge. They have to do exactly the same if there is a river across their path. Accommodating every single unpaved road would be foolish idea.
MSPNWA
Tue Feb 12, 2019 12:56 am
Logically, what is the bigger "risk" - the guaranteed harm and potential destruction of the world economy and way of life as we know it, or the possible disruption to the economy and way of life as we know it for some (only if the alarmists that have had it wrong all along are right this time).
SheikhDjibouti
Tue Feb 12, 2019 1:20 am
AirFiero wrote:
I am curious why you and others are here on any aviation forum and are willing to eliminate some portion of aviation activity?
I am curious as to why you would even think that is curious.
Perhaps your comment says more about you than it does about anybody else?
I am a great fan of good aviation (however you might interpret that)
I am not a fan of aviation at any cost. That would just be selfish.
Besides, I have already lived long enough to witness numerous "portions of aviation activity" eliminated, or in slightly less dramatic terms, altered &/or reduced.
Sometimes it was in the name of progress (the introduction of fuel-efficient, quieter, high-bypass twin-jets)
Sometimes it was a backwards step (the withdrawal of Concorde, 9/11 and locked cockpit doors)
And sometimes there are more important things in life than pushing ever more aircraft into the sky.
GalaxyFlyer
Tue Feb 12, 2019 1:26 am
I would with all that, SD, aviation has become incredibly efficient over the last 40 years. Fuel consumption and noise especially reduced, but also engineering design for safety, operational safety, reduction in content and waste in manufacturing. My car is an immeasurable advance over my Ford Pinto of 1975, but gets better fuel mileage, is more recyclable and light-years better in emissions. These improvements can be attained without upending individual rights, collectivization, ever larger government as planned by the GND.
GF
seb146
Tue Feb 12, 2019 2:03 am
GF
Believe it or not, some of those things came about because of the government. Safety systems, emissions, mileage. I know you hate government but government is good for some things.
AirFiero
Tue Feb 12, 2019 2:35 am
Both of you my links contain links to the SCIENCE that you like to talk about, but I obviously know nothing about. You're lazy dismissals prove that.
Are for bee colony collapse, that has nothing to do with warming.
ALL factories involve pollution.
seb146
Tue Feb 12, 2019 2:41 am
The greatest data suggests oceans are warming and the Arctic ice is shrinking. Your links suggest nothing is wrong.
There are some people who claim science proves vaccines cause autism because this or that shady link.
I suppose you are one of those people who say climate change is not real because it is snowing during winter and hot during the summer.......
DIRECTFLT
Tue Feb 12, 2019 3:57 am
It's worth the chance to me, to not give up my right to freedom to carbon taxers.
Smoothest Ride so far ~ AA A300B4-600R ~~ Favorite Aviation Author ~ Robert J. Serling
Jouhou
Tue Feb 12, 2019 4:35 am
Yeah, because you support the party with beneficial tax policies (LOL!)
bgm
Tue Feb 12, 2019 6:38 am
Thankfully, your generation is slowly but surely dying off along with the selfish attitude shown above. It's the younger generation that will have to clean up your generation's mess. Not that you would care of course, as you'll be pushing daisies long before that happens.
████ ███ █ ███████ ██ █ █████ ██ ████ [redacted]
Dutchy
Tue Feb 12, 2019 7:07 am
Easy to take that chance if someone else pays the price.
Dutchy
Tue Feb 12, 2019 7:13 am
GF
yes, there has been great steps in reducing noise and increasing efficiency, but the increase in planes and cars vastly outways the efficiency steps, so overall more pollution instead of less.
tommy1808
Tue Feb 12, 2019 7:24 am
So, your link shows that there is a lot less ice today than 40 years ago, but somehow that proofs that there is no global warming? It shows water covered by at least 15% ice, obviously there can be a large difference between fully covered with ice, which is more than 15% or covered with just 15% ice uniformly. Of course you do know that the "data" is worthless in isolation, and post it with deception in mind.
Lets look at the total ice instead:
gosh, geez, that doesn´t look as harmless as the handpicked graph you presented, does it?
Lets put that in perspective:
White is 1938, fairly close to the local minimal ice cover, blue is 2012.....
Now i could go on and on and on with hundreds of data-sets, while you may be able to dig out a dozen or so handpicked representations to feed your narrative.
"But, warming is normal because we are coming out of a little ice age and totally natural".
No, it ain´t. Temperatures are climbing at about 100 times the speed it has ever before without an extinction level event causing it. Lucky for us, we have xkcd, who is splendid in his way to put data into perspective. Climate change deniers seem to struggle especially with that. Based on the climate record:
best regards
Thomas
This Singature is a safe space......
anrec80
Tue Feb 12, 2019 7:35 am
aviationaware wrote:
I love how Ocasio Cortez ran on making housing a human right and now she wants to rebuild or renovate every single building in the country, which would make housing utterly unaffordable for many people.
Totally nuts.
Yeah. Every Parliament has some lower IQ, but loud and visible individuals. Normally they don’t last there long, if they don’t grow up. This is normal, I wouldn’t be concerned just yet. But I would be if the number of such characters starts growing.
seahawk
Tue Feb 12, 2019 7:48 am
There is not even a conflict between aviation and green power. You do not need to replace planes with trains, you just need to replace the fuel and turbines have very little problems running synthetic fuel made from biomass or converted from carbon in air. And the last solution will become standard in the future, as this is the only sensible way to store renewable energy and answers the problem of energy density for mobile uses.
tommy1808
Tue Feb 12, 2019 7:56 am
Totally nuts.
elsewhere in the world housing is a human right, and has been for decades....... she is already way, way behind the curve. Its cute how that can been seen as progressive in the US....
best regards
Thomas
DL717
Tue Feb 12, 2019 1:46 pm
Totally nuts.
best regards
Thomas
Just for my own edification, which countries provide housing as a human right vs. state it is a human right?
Welcome to Nothingburgers. May I take your order?
tommy1808
Tue Feb 12, 2019 3:01 pm
DL717 wrote:
best regards
Thomas
Germany for example. The states of Bavaria, Bremen, Berlin and Brandenburg directly in their constitution, Bremen puts it
Bremen Constitution wrote:
Every resident of the Free Hanseatic City of Bremen is entitled to
to an adequate apartment. It is the task of the state
and the municipalities, the realization of this claim to the
to promote.
For Germany as a whole it stems right from Art. 1 of the constitution, since we dn´t think you can live a dignified life in the streets....
Also Article 25 of the Universal Declaration of Human Rights, Article 11 of the International Covenant on Economic, Social and Cultural Rights, Article 16 of the European Social Charter or the Article 34 of the Charter of Fundamental Rights of the European Union.
Paragraph 3 wrote:
3. In order to combat social exclusion and poverty, the Union recognises and respects the right to social and housing assistance so as to ensure a decent existence for all those who lack sufficient resources, in accordance with the rules laid down by Community law and national laws and practices.
In one form or another you find it in all EU countries, sometimes per simple law, sometimes in the constitution (Netherlands, Art 22; Spain Article 47,...), sometimes as legal tradition (Denmark comes to mind).
best regards
Thomas
SheikhDjibouti
Tue Feb 12, 2019 3:31 pm
best regards
Thomas
<cough>
Roosevelt's proposed Second Bill of Rights, January 11th, 1944
https://en.wikipedia.org/wiki/Second_Bill_of_Rights
timh4000
Tue Feb 12, 2019 5:43 pm
A lucrative multi billion dollar industry that a majority of people need or enjoy isn't about to be dismantled due to a young political uber extremist senator.
DL717
Tue Feb 12, 2019 5:46 pm
tommy1808 wrote:
DL717 wrote:
best regards
Thomas
to promote.
best regards
Thomas
That’s not what I asked. If it was truly a human right in the places you mention there would be no homeless in those areas. They would have a home, which they don’t. Talk is cheap. We have shelters too.
tommy1808
Tue Feb 12, 2019 5:57 pm
to promote.
best regards
Thomas
Say what? A human right doesn't mean that someone actively seeking you out to give it to you. You have to go to a government building and fill out forms, just as with anything else. You truly do get a home here if you cant afford one.
Best regards
Thomas
slider
Tue Feb 12, 2019 6:04 pm
lebda wrote:
This is blown way out of proportion. This all appears speculative, and there's no chance in hell it's gonna stop air travel, or that it's even going to get up off the ground for that matter.
It's not about the realism of it. This is obviously going nowhere. This is about the fact that this actually resonates with a large portion of Democratic lawmakers. Really frightening.
Precisely right. I think AOC is an utterly hilarious useful idiot and I find her about as harmful as an ant. But her ideas clearly have resonated with some other elected officials and some of the braindead citizenry and THAT is the terrifying thing--that such absolutely stupid, wrong, and foolish full-blown Marxist ideas would get traction in the minds of people.
winginit
Tue Feb 12, 2019 6:27 pm
I think you could argue that's almost identically how the left and many moderates view Donald Trump - with the difference of course being that as President, Trump can be much more harmful than an ant. I'll even rewrite it as such:
Precisely right. I think Donald Trump is an utterly hilarious useful idiot and I find him about as harmful as an ant. But his ideas clearly have resonated with almost the entirety of the Republican Party and some of the braindead citizenry and THAT is the terrifying thing--that such absolutely stupid, wrong, and foolish full-blown Fascist ideas would get traction in the minds of people.
No real point here, just an observation.
aviationaware
Tue Feb 12, 2019 6:37 pm
Best regards
Thomas
So all homeless people are homeless because they are stupid or lazy or what are you trying to say? About 1% of the German population do not have a permanent home. Know what? In America, that number is "only" 0.5%. So somehow your precious human right for housing doesn't work as well as you'd make us believe.
Also, this was not about criticizing a right for housing but rather the utter stupidity of demanding that right while at the same time ignoring economic realities of housing modernization, which is one of the main drivers of housing prices. One of the reasons housing is unaffordable for many in Germany is that the building laws there are so ridiculous. I read somewhere recently that the majority of all real estate price increases in Germany over the past 20 years were due to building regulation, most of which isn't even conserving energy but just pushed by the building materials lobby.
Germans are really in no position to feel morally superior on housing.
SheikhDjibouti
Tue Feb 12, 2019 6:51 pm
True.
It won't be dismantled because of AOC and her personal agenda.
However it will be dismantled when enough people are willing to accept that too much of it is a bad thing.
Meanwhile let's have some fun with all your red herrings.
1) "A lucrative multi billion dollar industry"
If that is sufficient reason to maintain a way of business, there are a number of Mexican drug cartels who will gladly employ you as a lobbyist.
2) "that a majority of people need or enjoy"
Oh really? If you add up all the passengers around the world, the airline employees (& sub contractors), airport employees (& sub contractors) and every employee at Airbus & Boeing (& etc etc), are you going to come up with 3½ billion people? :shakehead:
For a start, it will not even come close. Secondly, very few of them actually "need" aviation.
An exception might be a casualty at the side of a road, or half way up a mountain, waiting for an air ambulance.
Aside from those rare cases, who else really needs aviation?
if the money invested in aviation were to go elsewhere, guess what? The jobs would follow the money.
And suddenly you will find people "need" the Green Deal, because it provides employment for many of them.
As for "enjoy" aviation; here's a strange thing. I used to "enjoy" football. Then I broke my leg. Now I enjoy something else.
Life on this planet will not suddenly cease because aircraft stop flying. The human species is remarkably capable of adapting - in most cases.
Obviously Trump supporters are a special sub-set that are unable to manage this, but I guess I can live with that problem. :lol:
3).."due to a.."
young (is that a good thing or a bad thing?)
political (er, yes)
uber (did someone buy you a dictionary for Xmas?)
extremist (pot, say hello to kettle)
senator.
Let's see what we've actually got left, after editing out the surplus.
An industry that some people think they need as a comfort blanket is hopefully about to be overhauled due to a US senator starting the ball rolling.
There, I fixed it for you. :lol:
Dutchy
Tue Feb 12, 2019 10:35 pm
1%? Seems like a lot for Germany. It made me curious for the Dutch numbers and that is 0,18% and with those numbers can be psychiatric cases, so difficult to get off the streets.
So could you provide us with the source for your numbers for Germany?
Dutchy
Tue Feb 12, 2019 10:39 pm
Let's not tell him about ecoducts 8-)
aviationaware
Wed Feb 13, 2019 12:33 am
Source:
https://www.dw.com/en/germany-150-perce ... a-41376766
Even if you adjust for the increase brought about by Angela Merkel's massive refugee failure (probably the worst policy decision of the 21st century in Europe by far up to this point), the share of the total population is still 0.5% and thus not lower than in the US - using the high estimate for the US. If we use the low estimate, the US are better off than Germany.
By the way - all of the numbers used, both for Germany and the US, refer to people who were homeless for at least one night in the year studied - this includes people who crash on friends' couches, not just people who are literally without shelter. The actual number of people who are homeless on any given night is approx. 20% of those numbers in both cases.
mham001
Wed Feb 13, 2019 1:21 am
Best regards
Thomas
And so? You can do that here too.
DIRECTFLT
Wed Feb 13, 2019 3:50 am
The US spends a great amount of our GDP on the Military, and rightfully so, to keep America safe and strong. There are other superpowers, and the best policy is to be strong. If these little EU darlings had to spend what we do on Defense, there'd be precious little funds left to keep their utopias afloat.
anrec80
Wed Feb 13, 2019 4:58 am
Spending this great amount of GDP on military would have been great if you actually could afford it, to begin with.
tommy1808
Wed Feb 13, 2019 6:37 am
Because, like every "fact" he presents, it is nonsense. You get to one percent not having their own place if you add the 440.000 Refugees/refugee seekers that don´t have permanent resident of their own. Even denied, but tolerated, refugees have a permanent roof over their head. The "of their own" bit is important, because by definition you are "homeless" if you are
local definition homeless wrote:
A person is homeless if he or she does not have a residential space secured by a rental agreement or is the owner of one and uses it himself or herself.
So, technically i was "homeless" when i lived with my girlfriend, because back then only she was on the lease......
The US definition of "homeless" is a LOT tighter, and pretty much means living in the streets
https://www.nhchc.org/faq/official-defi ... elessness/
And that number for Germany is 52.000, or 0.063% ...
That is a lot like unemployment rates, they are done by different definitions.
mham001 wrote:
Best regards
Thomas
Difference being here you get a place to live, in the US you have just filled out a form. Don´t try to tell me otherwise, my oldest US friend became homeless after an accident ruined her back, and her Job went with it, and last time i visited her i had to drop of at a charity shelter every evening..... about a year after she had lost her house.
Best regards
Thomas
aviationaware
Wed Feb 13, 2019 7:08 am
I already conceded that above. I also mentioned the definition thing. You can go back to sleep, German genius.
Kiwirob
Wed Feb 13, 2019 7:13 am
TheFlyingDisk wrote:
I don't get why the development of high-speed rail is so detested. China's been developing high speed rail lines by the thousands of miles.
I guess it's down to 'not invented here' syndrome, I bet if high speed rail was a US idea there would be high speed rail lines all over the country by now. If you look at it logically only coast to coast travel would require a plane, all other travel a high speed rail line would likely be just a quick or quicker once you take all the waiting around done in airports into consideration.
tommy1808
Wed Feb 13, 2019 8:07 am
Sleeping at 9 am in Germany? You don´t know many Germans do you?
best regards
Thomas
bgm
Wed Feb 13, 2019 8:21 am
The irony is not lost on the fact that the US spending on the military is the largest social program in the US. :rotfl:
SheikhDjibouti
Wed Feb 13, 2019 11:13 am
"The US spends a great amount of our GDP on the Military, and rightfully so,"
:rotfl:
That there my friend is called "an apology".
Even as you were typing those words, you knew things didn't add up so you added "and rightly so" to help convince yourself you have a case.
"to keep America safe and strong"
Safe from whom?
Are you worried that Mexico is going to invade you? Too late, they already have..... :biggrin:
As for the other superpowers, what exactly are they going to do?
How are they going to gain a foothold in the US?
Slide a few thousand landing craft into the Everglades and hope nobody notices?
Launch a mass attack on Alaska using kayaks and dog sleds?
Or follow the Japanese approach and sneak up on Hawaii?
Based on geography alone, your biggest threat is from Canada. Bonne chance!
In reality the US itself is as safe as … a very safe thing, wrapped up in cotton wool, and stored in a bank fault.
Countries under the protection of the US might be in a different situation; some of them rely on something defined as "power projection".
As for keeping America strong; this is just typical partriotic BS.
What you mean to say is "keeping America strong, so that we can poke our nose into other people's business."
I will admit there was a time when much of the world was grateful for a strong USA. Two world wars and Korea attest to that.
These days I subscribe to the philosophy of having an army based on the Luxembourg model, with a Navy like that of Switzerland, all backed up by the Irish Air Corps.
:bigthumbsup:
And with all the money left over from not spending on defense, America could become a really powerful nation.
ORDfan101
Wed Feb 13, 2019 12:57 pm
We can afford it even with tax cuts
  • 1
  • 4
  • 5
  • 6
  • 7
  • 8
Users browsing this forum: Airstud, B747forever, Fiend, JJJ, Kiwirob, speedygonzales, TTailedTiger, wirkey and 41 guests
