conaly
Boeing 787: different HF-antennas
Mon Feb 11, 2019 3:05 am
While I'm sitting here at HND airport and having a lookout to the tarmac, I've noticed, that on the 787-9 the HF-antenna was missing on the spot, where it is located on the B787-8. After a quick search on google, I found this graphic: https://i.stack.imgur.com/me4UV.jpg
So it seems it was relocated from the leading edge in the middle to the area above the root. Does anyone know the reason for this change? Why did the not use one common design here? And if the -9-design is better, why not use it on newly delivered 787-8?
Some pictures
B787-8:
B787-9:
Airports 2019: ADB, ALG, AMD, ATL, BOS, CTS, DEL, DTW, DUS, EWR, FRA, FUK, HAM, HIJ, HND, IST, JFK, MUC, NGO, NUE, OKA, PHL, SIN, STN, YYZ
Planned 2019: BOG, CDG, FRA, MUC, NUE, ZRH
wildwobby
Re: Boeing 787: different HF-antennas
Mon Feb 11, 2019 3:50 am
I believe the 787-9, unlike the 787-8, has an HLFC system on the leading edge of the v-stab.
A319 A320 A321 A346 A380 B712 B733 B735 B736 B737 B738 B748 B739 B752 B753 B763 B772 B77W B788 CONC CRJ2 CRJ7 CRJ9 DC10 E120 E145 F100 MD80 MD83 MD88 MD90
Faro
Mon Feb 11, 2019 7:45 am
IIRC, the 789 implemented a (limited) laminar flow technology on the vertical stabilizer...if this is the case, the new HF antenna location lower down on the leading edge may be to help with that implementation...to furnish a smooth, seamless leading edge surface to enhance the laminar flow further back on the face of the fin...
Faro
The chalice not my son
akoma
Thu Feb 14, 2019 1:37 pm
Faro
In the 789s we have, the HF antenna is a grounded 5 foot aluminium tube located just below the dorsal panels (the bottom part of the leading edge of the vertical stab). The leading edges are not used as an antenna.
Faro
Sat Feb 16, 2019 9:45 am
akoma wrote:
Faro
Thanx...funny that they are made of aluminium...I would have thought that some manner of copper alloy would give better performance given the higher conductivity...
Faro
Users browsing this forum: fr8mech, Max Q and 31 guests
