seabosdca wrote:The gimmicky shtick of "every airliner before the A320 is an unsafe piece of junk at all times, but the A320 and every airliner after it are Modern and Good" is tiresome at the best of times and quite inappropriate in a thread where we are discussing an event that killed three flight crew members.
spudsmac wrote:I'm sure it will come out soon but it seems mechanical.
If I had to place bets I would play it on runaway pitch trim with the autopilot staying engaged until it couldn't manage it anymore then just said "peace out, your problem now" then at that point the pilots could not recover in time.
yoshua16 wrote:If it was caused but auto pilot disengaging then they should have maintained control. Unless one of the flight control cables broke.
Sent from my SM-G950U using Tapatalk
Jouhou wrote:I talked to a guy at work and said it could have been both mechanical and weather.yoshua16 wrote:If it was caused but auto pilot disengaging then they should have maintained control. Unless one of the flight control cables broke.
I'm not a pilot, but looking up runaway trim procedures in Google : https://steemit.com/b737/@jeonbyeongcha ... stabilizer
(I guess that's for a 737 but I'm assuming this is similar to 767) it seems that an "aerodynamic runaway" could create this situation easily. Pilots, please provide input, I'm just an amateur doing a Google search!
glideslope900 wrote:Really surprising that no one here has mentioned that the NTSB statement today basically rules out foul play/suicide...
TTailedTiger wrote:glideslope900 wrote:Really surprising that no one here has mentioned that the NTSB statement today basically rules out foul play/suicide...
No one has mentioned it because it has not been ruled out.
wjcandee wrote:RyanVHS wrote:Ignore - somebody beat me to posting a link to the NTSB press release.
So it's a loss of control. Accordingly apparently not an intentional act. The reason for the loss of control is going to be the thorny subject of the investigation. The press release really doesn't tell us whether it was a human factors issue or a mechanical issue or a little of both.
ikramerica wrote:Is there any situation where a lightening strike could cause this downward trajectory ? Could also explain audio quality issues.
glideslope900 wrote:TTailedTiger wrote:glideslope900 wrote:Really surprising that no one here has mentioned that the NTSB statement today basically rules out foul play/suicide...
So what does “conversations consistent with loss of control” mean to you? To me, it means they literally lost control of the airplane for some reason.
If there was a criminal action, the NTSB would have worded that very differently and not come out with such a statement. It would have been something along the lines of “we believe there may have been foul play involved in the loss of Atlas 3591.”
You would do well to read all of the posts in the thread. Someone already mentioned that that is the standard statement issued after preliminary CVR reviews. The FDR data has not been analyzed yet and they can't even hear much of what is recorded on the CVR. We will know the cause in due time. Until then, everything is still on the table.
cougar15 wrote:TTailedTiger wrote:glideslope900 wrote:Really surprising that no one here has mentioned that the NTSB statement today basically rules out foul play/suicide...
Your starting to push a few buttons my friend, too bad if you can´t read, but even on an enthusiasts site it is about time for a little respect for 3 fine aviators and their families!
SCFirefighter wrote:ikramerica wrote:Is there any situation where a lightening strike could cause this downward trajectory ? Could also explain audio quality issues.
There was no lightning in the area at the time.
This may be true but I certainly would not expect that statement if they had heard some nefarious action on the CVR.
CO953 wrote:One girl on my team would know better since she works in the 767 cable rigging. I've seen a little bit of it under the cockpit but that's all I've seen.yoshua16 wrote:If it was caused but auto pilot disengaging then they should have maintained control. Unless one of the flight control cables broke.
Knowing nothing about how the flight cables are set up, I wonder if it's possible that a broken cable could result in a wings-level dive. Granted that the released video so far is poor, but from what I gather of witnesses, it seemed like more of a straight nose-dive, instead of a spin. Wings level seems to indicate some degree of control. What I have not yet done is to try to overlay the weather front, minute by minute, with the flight path. Some have posited that the crew was disoriented in clouds; however, the radar shows a defined front line, with seemingly relatively clear air around. If the crew was not actually in the front when the upset began, the visibility doesn't look bad. I live 200 miles east of the site. I was out of state when the accident happened, however, I recognize that front pattern because it has come over my house many times, and if you're not in the front, usually you're not socked in.
If they were in the front, then yes disorientation becomes a possibility. But then, also does the possibility of a hard spot of turbulence jamming or breaking something,
The video from the school (I think it was a school) is weird because the plane seemed to disappear. Some thought that was because the plane disappeared into low cloud cover. But to me, it looked more like an artifact of the camera setting. like it was set to record in bursts or something. The plane was already in the dive.
A question I have not yet seen well answered is: was the plane hitting the front at the moment of the loss of control? The radar seems to show that yes, it was close, but it's going to take closer examination that just trying to compare Flightaware and available Doppler maps.
glideslope900 wrote:So what does “conversations consistent with loss of control” mean to you? To me, it means they literally lost control of the airplane for some reason.
konrad wrote:glideslope900 wrote:So what does “conversations consistent with loss of control” mean to you? To me, it means they literally lost control of the airplane for some reaason.
Could a catastrophic shift of cargo cause such loss of control?
Follow-up questions: do we know what was the cargo? Are we sure this was a more or less standard assortment of Amazon parcels?
TTailedTiger wrote:The 767 will right itself if you simply just let go of the controls.
N126DL wrote:https://twitter.com/NTSB_Newsroom/status/1100183258539663360
I've stared at this piece of the wreckage for a good 10 clock minutes trying to figure out what part of the airplane it is from. Which 767 driver here can shed some light?
ltbewr wrote:Note that the plane apparently lost 1500' from 7500 AGL to 6100 AGL in one second (18:38:39 - 18:38:40).
TTailedTiger wrote:I stated a fact. I said nothing has been ruled out. I said nothing about any of the crew members.
konrad wrote:Follow-up questions: do we know what was the cargo? Are we sure this was a more or less standard assortment of Amazon parcels?
IAHWorldflyer wrote:NTSB says they plan to release a transcript of the CVR in the next week. Will be interesting to see that.
I have a question for those who work in aviation here. The NTSB says the audio quality of the CVR is poor and needs some enhancement. On this thread people have said by looking at the pictures that this is likely an original Siemens product which would date it over 20 years old. Do these old ones work like the cassette tapes of my youth in that they just erase and tape over old conversations? If that's the case, wouldn't the sound quality be expected to deteriorate over decades? Or do they not use magnetic tape to record?
