mikegigs wrote:While I think It's great that they are (finally) rebuilding Concourse B, I fear these gates will be underutilized. If I'm not mistaken, aren't there unused gates in Concourse C currently?
WeatherPilot wrote:Seems like a lot construction/building for 6 extra gates.
JAXDan wrote:mikegigs wrote:While I think It's great that they are (finally) rebuilding Concourse B, I fear these gates will be underutilized. If I'm not mistaken, aren't there unused gates in Concourse C currently?
In the morning hours every gate does get used at least once.
MIflyer12 wrote:JAXDan wrote:mikegigs wrote:While I think It's great that they are (finally) rebuilding Concourse B, I fear these gates will be underutilized. If I'm not mistaken, aren't there unused gates in Concourse C currently?
That's not a very high standard of gate utilization, JAXDan. Do they average ten flights a gate between 6AM and 10PM? If so, then JAX might need more gates.
I was just letting mikegigs know that all the gates do get used, but I would certainly acknowledge there is not a current need for more gates.
The standard of ten flights/day is for high cost areas. Lower standards apply here. However, I'd concur gates are not needed.
727LOVER wrote:...
January was their biggest month ever. Wasn't that NK's first full month? Coincidence?
727LOVER wrote:I hope they put an obs deck on the new concourse....dreaming of course.
UALifer wrote:Even the most gate constrained airports in the US generally don’t run 10 departures per gate. That’s an absurd standard.
jplatts wrote:UALifer wrote:Even the most gate constrained airports in the US generally don’t run 10 departures per gate. That’s an absurd standard.
There are actually a few U.S. airports such as AUS, DAL, LAX, and SJC where WN operates more than 10 departures per gate.
JAXDan wrote:727LOVER wrote:I hope they put an obs deck on the new concourse....dreaming of course.
I haven’t seen it in person but JAX recently tweeted there is a new pre security observation deck.
https://twitter.com/jaxairport/status/1100173352998715393?s=21
FF630 wrote:....
I am puzzled why the plan is relocating security, certainly needs a little expansion, both the TSA precheck and regular lines are a little long at times.
FF630 wrote:JAX probably needs on 2 or 3 more gates. Adding them to the end of the existing concourses would take 4 gates out during construction, therefore not practical. I am puzzled why the plan is relocating security, certainly needs a little expansion, both the TSA precheck and regular lines are a little long at times.
