seat64k
GPS Rollover incidents
Mon Apr 08, 2019 12:35 am
You may be aware of the GPS rollover incident on 6 April. Short description: Date is expressed as a week, and day of the week, both represented by a number. The week is a 10-bit number, so every 1024 weeks (just short of 20 years), it flips over to 0. Devices that don't know this will teleport you back to 1999.
https://twitter.com/ChinaAvReview/statu ... 8919411712
Not sure how real this is, but the flight does appear to be 789 on that day:
https://uk.flightaware.com/live/flight/CES567
Any other events?
GalaxyFlyer
Re: GPS Rollover incidents
Mon Apr 08, 2019 12:48 am
Yeah, it happens. There’s been other rollover effects with dates and times. It’s fixed with a NOTAM and a procedure. No one goes back in time. Yawn.
GF
northstardc4m
Mon Apr 08, 2019 12:59 am
GF
Well dang... and here I was hoping to go back and make a fortune in BitCoin! :P
Those who would give up Essential Liberty to purchase a little Temporary Safety, deserve neither Liberty nor Safety.
LH707330
Mon Apr 08, 2019 5:37 pm
Holy crap, that's a gnarly headwind.
XAM2175
Mon Apr 08, 2019 6:43 pm
Amusingly, there are two main approaches to avoiding this in future:
* Modernised GPS uses a 13-bit week counter, allowing for just shy of 158 years between roll-overs. Galileo and Beidou are similar.
* GLONASS rolls-over every four years, in the assumption that something that happens so frequently will be accounted for in the design of even the cheapest receivers :lol:
Francoflier
Mon Apr 08, 2019 11:47 pm
You'd think the GPS receiver on a 787 would be modern (and expensive) enough to have a software workaround for this.
140 kts? Meh. Try flying westward around eastern Asia or continental US in the winter for that "I might die of old age before we get there" feeling...
GalaxyFlyer
Tue Apr 09, 2019 1:46 am
It’s not in the FMS, the rollover is in the NAVSTAR system.
Chemist
Tue Apr 09, 2019 5:08 pm
That's nothing. Try flying westward over the New Mexico Rockies in a Cherokee 140 and seeing 60kts on your GPS, and watching semi-trucks on the interstate below going faster than you.
nws2002
Tue Apr 09, 2019 6:03 pm
FAA released an InFO about this last week.
https://content.govdelivery.com/attachm ... O19005.pdf
Tue Apr 09, 2019 6:12 pm
It is an onboard problem, fact is most aircraft (and other GPS receivers) were able to handle the week cycle change without falling over.
The three common receiver offset methods to overcome this are a battery backed up real-time clock, store the reference year in non volatile RAM, or use a date values stored in the receiver software (the software gets update from time to time). All three methods will allow math receiver to select the correct week cycle.
It is downright embarrassing for the 787 to go back to 1999.
LH707330
Tue Apr 09, 2019 6:13 pm
The worst one I ever dealt with was 74 GS and 125 TAS in a DA40, that turned into a long day.
litz
Tue Apr 09, 2019 6:20 pm
Or seeing a fully laden freight train stall out on flat, level, track - purely from headwinds.
XAM2175
Tue Apr 09, 2019 7:55 pm
It should also be noted that the actual positioning function performed by the receiver isn't affected by the roll-over - only the translation to the calendar day is.
Now, the Year 2038 Problem on the other hand should be a real fun one :P
AirKevin
Tue Apr 09, 2019 10:26 pm
How fast were the trucks going. 60 knots is roughly 70 miles, so they would have had to be going pretty fast. Some of these trucks are governed at 65 or even less.
Before the 787 was even around.
Captain Kevin
Chemist
Wed Apr 10, 2019 12:52 am
The semis were very slowly gaining on us.
It was bumpier in the plane than on the interstate, too.
WIederling
Wed Apr 10, 2019 7:22 am
You can handle such problems in a sane way or just ignore them ( when writing software.)
Most domains have tended to just ignore the issues ...
On the other hand I don't see why a 2010+ GPS receiver installed on a plane that
will be used for a couple or three decades should stumble over a well known
thing like roll over in regular intervals.
I always do wonder what other less benign oversights sit in the same code basket?
GLONAS approach ( rather like some other solution used by Linux:
start with negative timer value to make errors come up on boot )
seems to be "a Good Thing (TM)" here.
Murphy is an optimist
thepinkmachine
Wed Apr 10, 2019 7:05 pm
AFAIK it is a bit of a problem, as there’s an unexpected glitch affecting the planes that were powered down during the rollover.
On some frames the date remains stuck in the year 99 affecting things like Nav DB validity, CPDLC and even WX radar - they are all fed by GPS clock and reportedly there’s no simple way to reset it...
"Tell my wife I am trawling Atlantis - and I still have my hands on the wheel…"
seat64k
Thu Apr 11, 2019 2:45 am
That would explain why this isn't a big news story. If it affected planes that were powered on at the time, it would be the entire fleet (assuming this piece of equipment is common).
WIederling
Thu Apr 11, 2019 8:00 am
Didn't the 787 have another unpleasant software roll over problem coming up in the early years?
https://www.engadget.com/2015/05/01/boe ... ftware-bug
and some others:
https://www.google.com/search?q=787+sof ... +roll+over
Users browsing this forum: Georgehay1960, mxaxai, Slide and 28 guests
