FlexJetOKC
Mysterious Military Jet Over OKC
Wed Apr 10, 2019 1:33 pm
I need some help identifying a military aircraft that I have seen flying in to Tinker AFB (KTIK) twice in the past week. It was at night both times, so I could not physically see the airplane. What had me confused is that it looked exactly like the red beacons that the T38 aircraft have, but they were LED. I will also say that it did not sound like a T38. It was also very quiet. Way quieter than a T38. The first time I saw the plane, it was heading east over OKC at about 3000 feet going approximately 300 mph into TIK then about 20 minutes later, it quickly departed back WNW.
Last night, I saw the same LED pattern. Low level jet around 3000 feet going around 300 mph right towards Tinker. Is it possible that its the XQ-58A? Like I said, I have never seen a consistent pattern of this type of activity up until about a week ago. Any help would be great!
Above the planet on a wing and a prayer, my grubby halo, a vapour trail in the empty air...
WKTaylor
Re: Mysterious Military Jet Over OKC
Thu Apr 18, 2019 5:34 pm
Your description has a couple of faults/omissions.
300-MPH is way-to fast for low-altitude operations in [what amounts to] commercial airspace.
Also, 'how big' do you estimate the aircraft was?
HaveBlue
Thu Apr 18, 2019 10:24 pm
Speed limit below 10,000' is 250 knots which is 288mph, so close enough to 300mph to be doable, and plenty of aircraft aren't obeying the speed limit. That being said a night time sighting with details as ambiguous as those given leaves a lot to be desired. A T-38 is very quiet at idle speed and lights are a good one to identify most aircraft.
kc135topboom
Fri Apr 19, 2019 11:50 pm
Aircraft whos performance requires higher airspeeds than 250 knots can fly faster the 250 KIAS below 10,000'. You just have to let ATC know it.
I really doubt this aircraft was the XQ-58, seeing it just had its first flight last month in Arizona.
Moose135
Sat Apr 20, 2019 1:35 am
It's based on the operational needs of the aircraft. A hundred years ago, when I was flying the T-38, 300 knots was our "everyday" airspeed for normal flight - which included under 10K.
HaveBlue
Sun Apr 21, 2019 11:09 pm
Meant to say 'lights are not a good way to identify most aircraft at night.' Silly inebriated post!
kc135topboom
Mon Apr 22, 2019 12:42 am
When I started flying the KC-135, our normal climb speed was 275 KIAS. Around 1976 or 1977 the FAA came up with the requirement of 250 knots below 10,000', unless aircraft performance required a higher airspeed. At the same time the USAF required all aircraft external lighting to be on below 10,000' for bird aviodance (birds avoiding the airplane, not the other way around). The FB-111s at Pease and Plattsburgh were climbing out at 300 knots.
rlwynn
Mon Apr 22, 2019 6:06 am
I have planes fly over all day long faster than 250 knots and way lower than fl100. I Just right now looked and Info DUS there is a 321 at 4000 280kts. And there is a Condor 767 7000 354kts.
I can drive faster than you
FlyHossD
Tue Apr 23, 2019 12:29 am
Are you reading groundspeed? I suspect so.
The speed limits earlier in the thread refer to indicated airspeed. Also, in Europe, it's more common for ATC to authorize speeds above 250 KIAS.
WKTaylor
Wed Apr 24, 2019 6:48 pm
Tinker AFB is located within S.E. OKC city limits... and there is LOT of local commercial, GA and helo traffic crossing everywhere.
A fast-mover jet [NOT climbing to altitude] that is very low visibility, scooting around airspace like OKC would be a pretty sketchy proposition.
Users browsing this forum: bikerthai and 9 guests
