A3801000
SpiceJet Boeing 737 overshoots runway at Shirdi
Mon Apr 29, 2019 12:45 pm
- Boeing 737
- flight 945
- aircraft VT-SGJ
- Shirdi/India
pic:
A3801000
Re: SpiceJet Boeing 737 overshoots runway at Shirdi
Mon Apr 29, 2019 12:46 pm
SpiceJet statement :
"On 29th April 2019, SpiceJet B737-800 aircraft operated SG 946 from Delhi to Shirdi.
While landing at Shirdi, the aircraft overshot the runway. Passengers and crew are safe and are being deplaned normally."
Deltabravo1123
Mon Apr 29, 2019 4:11 pm
They clearly lucked out with the landing gears not collapsing. How long would an aircraft in such an incident like this be out of service? It's still flyable, but I imagine they must examine the tires and landing gears in some way to ensure they weren't damaged or compromised.
Floridaguy74656
Mon Apr 29, 2019 4:39 pm
Also it depends on how much the engines inhaled. The aircraft looks to have avoided major damage but it could still be a week or more before its back one would guess.
God Bless the United States of America
wetpantsmcgee
Mon Apr 29, 2019 4:58 pm
Cabin door open yet no slide?
WayexTDI
Mon Apr 29, 2019 5:18 pm
There is an airstair approaching the plane. Makes sense that they deactivated the slide before opening the door.
anshabhi
Mon Apr 29, 2019 6:06 pm
The runway looks so parched and dry. If they touched down at the right spot, I wonder what could be any other reason for them to overshoot.
morrisond
Mon Apr 29, 2019 7:00 pm
Landing with a tailwind albeit only 6KN is usually a bad idea especially on a clear day and you don't need too.
If you look at the replay on FR24 they arrived at the Airport at 5,000 ft AGL and had to do a circling approach to 09. Other Flights beforehand landed the opposite way on runway 27. Right after on 09 an ATR landed - but I assume they let them land downwind as they didn't want them crossing over 737 at the far end of the Runway and the ATR would not have needed much of the 8,200' Runway.
Interestingly - they are in the process of extending the runway to 10,500' which was supposed to be it's length by now but they are behind schedule.
8,200' would have been more than enough if they landed in the right direction for the conditions.
Weather at time of Inicident https://aviation-safety.net/wikibase/wiki.php?id=224475
Info on Shirdi Airport https://en.wikipedia.org/wiki/Shirdi_Airport
I think there is some confusion on the Flight number - FR24 has it as SG946
anshabhi
Tue Apr 30, 2019 6:29 am
This is almost sad and gross neglect for safety.
https://mobile.twitter.com/Mohan_Rngnat ... 1634025472
They literally used the stairs used in maintenance for evacuation
juliuswong
Tue Apr 30, 2019 7:33 am
Apparently the aircraft was supposed to go to South Korea's T'Way, but they did not take it up. Hence the weird livery.
- Life is a journey, travel it well -
KFTG
Tue Apr 30, 2019 8:00 am
I mean, it is that time of month again.
anshabhi
Tue Apr 30, 2019 8:10 am
SpiceJet is one Airline which gives no value to liveries and brand image at all
VTCIE
Tue Apr 30, 2019 8:41 am
700% true. Put together all the aircraft with white tails and fuselages as well as those in a partial Travel Service Moravian-Silesian livery or a T’way Air livery as you see here, and you have an airline that tries its level best to slash painting costs.
It is no coincidence that, of the measly 300 pictures of SpiceJet in the A.net database, at least 10% are taken at Prague Václav Havel Airport.
For comparison, not a single IndiGo aircraft is painted in any livery other than the standard livery, which is also tied to the fact that 6E has never had a special livery.
In grieving remembrance of the thousands of people who lost their lives on ET-AVJ, PK-LQP, XA-UHZ, S2-AGU, CP-2933, SU-GCC, EI-ETJ, D-AIPX, PK-AXC, 9M-MRD, VT-AXV and above all 9M-MRO, besides many more. Your deaths are not in vain. Safety first, always.
B737MAX
Tue Apr 30, 2019 8:43 am
Could you develop?
sibibom
Tue Apr 30, 2019 9:35 am
They don't invest in their interiors either, it can be really old and worn out, and even have other airline's branding. But then people get what they pay for...its one of cheapest fares always
Gr8Circle
Tue Apr 30, 2019 11:56 am
In an earlier pic you can see a proper airstair being towed across to the plane and then in the next pic you see the maintenance stairs being actually used....before jumping to conclusions about "gross neglect", I would stop and wonder if there was some problem getting the regular airstairs in place and in order to evacuate the passengers, they quickly used the maintenance stairs.....
juliuswong
Tue Apr 30, 2019 1:22 pm
OMG, this is horrendous. Can't they do a bit better with branding??
anshabhi
Tue Apr 30, 2019 1:34 pm
And this:
