McG1967
Post Screening - McG1967
Wed Jun 12, 2019 7:01 pm
Had this photo rejected for motive, along with a personal message saying avoidable pole.
There is a small fence that runs along the length of the taxiway over the canal that partially covers the wheels.
It is not possible to take this particular shot without part of the wheels being blocked by that fence.
What are the current motive rules regarding parts of the aircraft being blocked?
https://imgproc.airliners.net/photos/ai ... cff6ec843b
Is it worth submitting an appeal?
airkas1
Head Screener
Re: Post Screening - McG1967
Wed Jun 12, 2019 7:19 pm
Hey Mark,
It's a bit too bright and it would be nicer if the nose gear was not blocked by the pole (I realize the man gear is unavoidable). We have similar photos from this spot, so it's not impossible. If this is your only good shot, I'd add it after the exposure is better.
McG1967
Wed Jun 12, 2019 7:44 pm
Kas,
Many thanks. I'll have a look through the sequence to see if there is one without the nose gear blocked.
Noted the comment about the brightness needing adjusted lower.
wiggy
Fri Jun 14, 2019 3:35 am
a little soft for me
Runway28L
Fri Jun 14, 2019 4:33 am
Definitely not soft. I'll second Kas' opinion that it is too bright... toning down the exposure should do the trick.
McG1967
Sun Jul 07, 2019 9:09 pm
The image 1 frame later was added to the database today, thanks to all for the editing tips for this photo.
Users browsing this forum: Deepgreen and 31 guests
